path: root/arch/arm/mach-iop32x
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-22Merge branch 'cleanup/__iomem' into next/cleanupOlof Johansson
__iomem annotation cleanup branch from Arnd. * cleanup/__iomem: (21 commits) net: seeq: use __iomem pointers for MMIO video: da8xx-fb: use __iomem pointers for MMIO scsi: eesox: use __iomem pointers for MMIO serial: ks8695: use __iomem pointers for MMIO input: rpcmouse: use __iomem pointers for MMIO ARM: samsung: use __iomem pointers for MMIO ARM: spear13xx: use __iomem pointers for MMIO ARM: sa1100: use __iomem pointers for MMIO ARM: prima2: use __iomem pointers for MMIO ARM: nomadik: use __iomem pointers for MMIO ARM: msm: use __iomem pointers for MMIO ARM: lpc32xx: use __iomem pointers for MMIO ARM: ks8695: use __iomem pointers for MMIO ARM: ixp4xx: use __iomem pointers for MMIO ARM: iop32x: use __iomem pointers for MMIO ARM: iop13xx: use __iomem pointers for MMIO ARM: integrator: use __iomem pointers for MMIO ARM: imx: use __iomem pointers for MMIO ARM: ebsa110: use __iomem pointers for MMIO ARM: at91: use __iomem pointers for MMIO ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-19ARM: iop32x: use __iomem pointers for MMIOArnd Bergmann
ARM is moving to stricter checks on readl/write functions, so we need to use the correct types everywhere. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-26ARM: iop3xx: use fixed PCI i/o mappingRob Herring
Move iop33x and iop32x PCI to fixed i/o mapping and remove io.h. This changes the PCI bus addresses from the cpu address to 0 based. It appears that there is translation h/w for this, but its untested. Not sure what to do with io_offset. I think it should always be 0. AFAICT, PCI setup is skipped if the ATU is already setup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-05-13ARM: PCI: provide a default bus scan implementationRussell King
Most PCI implementations perform simple root bus scanning. Rather than having each group of platforms provide a duplicated bus scan function, provide the PCI configuration ops structure via the hw_pci structure, and call the root bus scanning function from core ARM PCI code. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-13ARM: PCI: get rid of pci_std_swizzle()Russell King
Most PCI implementations use the standard PCI swizzle function, which handles the well defined behaviour of PCI-to-PCI bridges which can be found on cards (eg, four port ethernet cards.) Rather than having almost every platform specify the standard swizzle function, make this the default when no swizzle function is supplied. Therefore, a swizzle function only needs to be provided when there is something exceptional which needs to be handled. This gets rid of the swizzle initializer from 47 files, and leaves us with just two platforms specifying a swizzle function: ARM Integrator and Chalice CATS. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-06ARM: kill off __mem_pciRob Herring
__mem_pci is only used to enable readl/writel and friends. Just condition this on readl being defined and remove all the __mem_pci defines. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Nicolas Pitre <nico@fluxnic.net> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Stephen Warren <swarren@nvidia.com>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-01-20ARM: big removal of now unused arch_idle()Nicolas Pitre
When this is the only content remaining in mach/system.h then the whole file is removed. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: remove the now empty arch_reset()Russell King
Remove the now empty arch_reset() from all the mach/system.h includes, and remove its callsite. Remove arm_machine_restart() as this function no longer does anything useful. For samsung platforms, remove the include of mach/system-reset.h and plat/system-reset.h from their respective mach/system.h headers as these just define their arch_reset functions. As a result, the s3c2410 and plat-samsung system-reset.h files are no longer referenced, so remove these files entirely. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-05ARM: restart: iop3xx: use new restart hookRussell King
Hook these platforms restart code into the arm_pm_restart hook rather than using arch_reset(). In doing so, we split out the n2100 platform specific restart handler into the n2100 platform file. Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-05Merge branch 'vmalloc' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-11-26ARM: big removal of now unused vmalloc.h filesNicolas Pitre
2011-11-21Merge branch 'restart-cleanup' into restartRussell King
2011-11-21ARM: restart: only perform setup for restart when soft-restartingRussell King
We only need to set the system up for a soft-restart if we're going to be doing a soft-restart. Provide a new function (soft_restart()) which does the setup and final call for this, and make platforms use it. Eliminate the call to setup_restart() from the default handler. This means that platforms arch_reset() function is no longer called with the page tables prepared for a soft-restart, and caches will still be enabled. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Krzysztof Ha■asa <khc@pm.waw.pl> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-18ARM: plat-iop: remove arch specific special handling for ioremapNicolas Pitre
A generic version should replace this later. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-11-17ARM: restart: remove local_irq_disable() from within arch_reset()Russell King
IRQs are already disabled by the time arch_reset() is called, so these calls to local_irq_disable() instead arch_reset() are redundant. Remove them. Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-13ARM: mach-iop32x: remove mach/memory.hNicolas Pitre
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-08-21ARM: mach-iop32x: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-12ARM: convert PCI defines to variablesRob Herring
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow multi-platform builds. This also removes the requirement for a platform to have a mach/hardware.h. The default values for i/o and mem are 0x1000 and 0x01000000, respectively. Per Arnd Bergmann, other values are likely to be incorrect, but this commit does not try to address that issue. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: pci: make pcibios_assign_all_busses use pci_has_flagRob Herring
Convert pcibios_assign_all_busses from a define to inline so platforms can control this setting. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-05-07ARM: zImage: remove the static qualifier from global data variablesNicolas Pitre
To be able to relocate the .bss section at run time independently from the rest of the code, we must make sure that no GOTOFF relocations are used with .bss symbols. This usually means that no global variables can be marked static unless they're also const. Let's remove the static qualifier from current offenders, or turn them into const variables when possible. Next commit will ensure the build fails if one of those is reintroduced due to otherwise enforced coding standards for the kernel. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: iop32x: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Dan Williams <dan.j.williams@intel.com>
2010-12-08ARM: io: make iounmap() a simple macroRussell King
Defining iounmap() with arguments prevents it from being used as a function pointer, causing platforms to work around this. Instead, define it to be a simple macro. Do the same for __arch_io(re|un)map too. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-04-29ARM: 5943/1: iop: n2100: enable serial interruptAaro Koskinen
Thecus N2100 has a jumper (J3/J4) to select whether the XINT1 interrupt line is connected to the second UHCI controller (position J3) or to the serial port UART (position J4). Currently, the kernel is hardcoded to assume the J3 position, and the serial port is always being used in polling mode. The patch adds the IRQ autodetection flag for the serial port interrupt, and also marks it as shared (as the driver for the second UHCI controller will request the interrupt in any case). Now, when the jumper is set to the J4 position, the serial port will have an interrupt line, resulting in less CPU overhead and faster throughput. Tested-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-29iop: enable generic timeMikael Pettersson
This updates the IOP platform to use the kernel's generic time framework. With clockevent support in place, this reduces to selecting GENERIC_TIME and removing the platform's private timer ->offset() operation (iop_gettimeoffset). Tested on n2100, compile-tested for all plat-iop machines. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-08-18iop3xx: ATU and PCI memory configuration correctedAaro Koskinen
There are two 64 MB outbound memory windows at bus addresses 0x80000000..0x83ffffff and 0x84000000..0x87ffffff for PCI memory. Currently, on iop32x, only the lower window is available for allocations, limiting the available space to 64 MB. On iop33x the full 128 MB can be allocated, but the translation value is wrong for the upper window. The patch enables the full 128 MB space on iop32x and corrects the initialization of OMWTVR1. Redundant definitions are deleted. Tested using a Thecus N2100 board with a graphics adapter in the expansion slot. Both windows are in use: 00:05.0 VGA compatible controller: XGI Technology Inc. (eXtreme Graphics Innovation) Volari Z7 (prog-if 00 [VGA controller]) [...] Region 0: Memory at 80000000 (32-bit, prefetchable) [size=64M] Region 1: Memory at 84080000 (32-bit, non-prefetchable) [size=256K] Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] iop3xx: avoid polluting the kernel's namespaceRussell King
Avoid unnecessarily pollution of the kernel's namespace by avoiding mach/hardware.h in mach/io.h, mach/memory.h and mach/timex.h. Include this header file where necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
