path: root/arch/arm/mach-ixp4xx/Kconfig
2010-05-27ixp4xx: base support for Arcom VulcanMarc Zyngier
This patch adds some basic support for the Arcom Vulcan (ixp425 based). Supported devices include: - XR16L551 serial ports - External watchdog - Flash - SRAM - 1-wire id Signed-off-by: Marc Zyngier <maz@misterjones.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-12-05IXP4xx: Extend PCI MMIO indirect address space to 1 GB.Krzysztof Hałasa
IXP4xx CPUs can indirectly access the whole 4 GB PCI MMIO address space (using the non-prefetch registers). Previously the available space depended on the CPU variant, since one of the IXP43x platforms needed more than the usual 128 MB. 1 GB should be enough for everyone, and if not, we can trivially increase it. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-05-23IXP4xx: support for Goramo MultiLink router platform.Krzysztof Hałasa
2008-10-17[ARM] dmabounce requires ZONE_DMARussell King
Rather than having everything that needs DMABOUNCE also select ZONE_DMA, arrange for DMABOUNCE to select it instead. This is far more sensible. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-04[ARM] 4874/2: ixp4xx: Add support for the Freecom FSG-3 boardRod Whitby
The Freecom-FSG3 is a small network-attached-storage device with the following feature set: * Intel IXP422 * 4MB Flash (ixp4xx flash driver) * 64MB RAM * 4 USB 2.0 host ports (ehci and ohci drivers) * 1 WAN (eth1) and 3 LAN (eth0) ethernet ports * Supported by the open source ixp4xx ethernet driver * Via VT6421 disk controller (libata and sata-via drivers) * Internal hard disk (PATA supported, SATA not yet supported) * External SATA port (not yet supported) * ISL1208 RTC chip * Winbond 83782 temp sensor and fan controller * MiniPCI slot The ixp4xx_defconfig is also updated to support this device (the leds-fsg driver is to be submitted separately via the leds tree after this initial support is merged, as it depends on header gpio defines). Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4713/3: Adds drivers for IXP4xx QMgr and NPE featuresKrzysztof Halasa
This patch adds drivers for IXP4xx hardware Queue Manager and for Network Processor Engines. Requires patch #4712 (reading/writing CPU feature (aka fuse) bits). Posted to linux-arm-kernel on 2 Dec 2007 and revised. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4426/2: Netgear WG302 v2 and WAG302 v2 supportImre Kaloz
This patch provides support for the Netgear WG302 v2 and WAG302 v2 AccessPoint series. This patch relies on the patch "Gateway 7001 series support" minimally, as they only have UART2 connected. Updated to stay below the 80 char limit in uncompress.h Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Deepak Saxena <dsaxena@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4425/2: Gateway 7001 series supportImre Kaloz
This patch provides support for the Gateway 7001 AccessPoint series. Updated to stay below the 80 char limit in uncompress.h Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Deepak Saxena <dsaxena@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-26[ARM] 4404/1: Trivial IXP42x Kconfig cleanupMichael-Luke Jones
Avila and IXDP4xx support were separated in 2.6.21 so this comment isn't correct any more. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-05[ARM] 4318/2: DSM-G600 Board SupportMichael-Luke Jones
This patch adds support for the D-Link DSM-G600 Rev A. This is an ARM XScale IXP4xx system relatively similar to the NSLU2 and NAS-100D already supported by mainline. An important difference is Gigabit Ethernet support using the Via Velocity chipset. This patch is the combined work of Michael Westerhof and Alessandro Zummo, with contributions from Michael-Luke Jones. This version addresses review comments from rmk and Deepak Saxena. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Michael Westerhof <mwester@dls.net> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4311/1: ixp4xx: add KIXRP435 platformRuslan V. Sushko
Add Intel KIXRP435 Reference Platform based on IXP43x processor. Fixed after review : access to cp15 removed in identification functions, used access to global processor_id instead Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com> Signed-off-by: Ruslan Sushko <rsushko@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] 4033/1: Add separate Avila board setup codeMichael-Luke Jones
This patch adds support for the Gateworks Avila Network Platform in a separate set of setup files to the IXDP425. This is necessary now that a driver for the Avila CF card slot is available. It also adds support for a minor variant on the Avila board known as the Loft, which has a different number of maximum PCI devices. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30Fix misc Kconfig typosMatt LaPlante
Fix various Kconfig typos. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[ARM] 3612/1: make pci bus optional for ixp4xx platformMilan Svoboda
Patch from Milan Svoboda IXP4XX platform can happily live without pci bus. This patch modifies Kconfig to support this option and modifies Makefile so pci only files are compiled only when pci is really selected. Patch is tested and ixdp465 runs fine with or without the pci bus.-- Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com>Signed-off-by: Deepak Saxena <dsaxena@plexity.net>Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-04[ARM] Trivial typo fixesEgry Gabor
Trivial typo fixes in Kconfig files (ARM). Signed-off-by: Egry Gabor <gaboregry@t-online.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-30[ARM] 3487/1: IXP4xx: Support non-PCI systemsDeepak Saxena
Patch from Deepak Saxena This patch allows for the addition of IXP4xx systems that do not make use of the PCI interface by moving the CONFIG_PCI symbol selection to be platform-specific instead of for all of IXP4xx. If at least one machine with PCI support is built, the PCI code will be compiled in, but when building !PCI, this will drastically shrink the kernel size. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-08[ARM] 3355/1: NSLU2: remove propmt dependsAlessandro Zummo
Patch from Alessandro Zummo The patch that would have made the NSLU2 kernel non compatible with other ixp4xx machs never entered the kernel. So it is actually safe to remove the prompt dependencies. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] 3215/1: Iomega NAS 100d (MACH_NAS100D) machine supportRod Whitby
Patch from Rod Whitby This patch adds support for a new arm/ixp4xx machine - the Iomega NAS 100d network attached storage product. The NAS100D is a consumer device containing a 266MHz Intel IXP420 processor, 16MB of flash, 64MB of RAM, a 160Gb internal IDE hard disk, and 802.11b/g wireless on an Atheros mini-PCI card. Work on porting the latest 2.6.x kernel to this device is being done by the NSLU2-Linux project (the same team who maintains the port to the Linksys NSLU2 device). In particular, the majority of this patch was authored by Alessandro Zummo, based on the work done for MACH_NSLU2 support by the NSLU2-Linux core team of developers. MACH_NAS100D (as implemented by this patch) can be enabled in jumbo ixp4xx kernels without any affect on the other machines supported by that kernel. This patch applies cleanly against 2.6.15-rc7 and should be trivial to apply to later kernel versions. It does not depend upon any other patches. Modified files (and number of lines inserted): arch/arm/mach-ixp4xx/Kconfig | 8 arch/arm/mach-ixp4xx/Makefile | 1 include/asm-arm/arch-ixp4xx/hardware.h | 1 include/asm-arm/arch-ixp4xx/irqs.h | 9 include/asm-arm/arch-ixp4xx/nas100d.h | 75 arch/arm/mach-ixp4xx/nas100d-pci.c | 77 arch/arm/mach-ixp4xx/nas100d-power.c | 69 arch/arm/mach-ixp4xx/nas100d-setup.c | 133 -- Rod Whitby (NSLU2-Linux project lead) Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3140/1: NSLU2 machine supportAlessandro Zummo
Patch from Alessandro Zummo This patch adds support for the LinkSys NSLU2 running with both big and little-endian kernels. The LinkSys NSLU2 is a cost engineered ARM, XScale 420 based system similar to the the Intel IXDP425 evaluation board. It uses the IXP4XX ARCH. While this patch applies independently of other patches the resultant kernel requires further patches to successfully use onboard devices, including the onboard flash. Since these patches are independent of this one they will be submitted separately. A defconfig is not included here because not all of the required drivers are actually in the kernel. We intend to provide one as soon as the patches will be incorporated in mainstream. This patch is the combined work of nslu2-linux.org Signed-off-by: John Bowler <jbowler@acm.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-16[PATCH] arm: fix help text for ixdp465akpm@osdl.org
) From: Russell King <rmk+lkml@arm.linux.org.uk> For some reason, this help text was missed when the file was last audited by the documentation referencing folk. Fix this incorrect documentation reference. Signed-off-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
