path: root/arch/arm/mach-ixp4xx/vulcan-pci.c
2012-05-13ARM: PCI: provide a default bus scan implementationRussell King
Most PCI implementations perform simple root bus scanning. Rather than having each group of platforms provide a duplicated bus scan function, provide the PCI configuration ops structure via the hw_pci structure, and call the root bus scanning function from core ARM PCI code. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-13ARM: PCI: get rid of pci_std_swizzle()Russell King
Most PCI implementations use the standard PCI swizzle function, which handles the well defined behaviour of PCI-to-PCI bridges which can be found on cards (eg, four port ethernet cards.) Rather than having almost every platform specify the standard swizzle function, make this the default when no swizzle function is supplied. Therefore, a swizzle function only needs to be provided when there is something exceptional which needs to be handled. This gets rid of the swizzle initializer from 47 files, and leaves us with just two platforms specifying a swizzle function: ARM Integrator and Chalice CATS. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-05-27ixp4xx/vulcan: add PCI supportMarc Zyngier
Add PCI support for the Vulcan board, supporting USB and CF ports. The PC/104 bus (actually a hack on the second CarBus slot) is not currently supported. Signed-off-by: Marc Zyngier <maz@misterjones.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
