[ Upstream commit 7a3b8758bd6e45f7b671723b5c9fa2b69d0787ae ]
Compile-testing the ixp4xx timer with CONFIG_OF enabled but
CONFIG_TIMER_OF disabled leads to a harmless warning:
arm-linux-gnueabi-ld: warning: orphan section `__timer_of_table' from `drivers/clocksource/timer-ixp4xx.o' being placed in section `__timer_of_table'
Move the select statement from the platform code into the driver
so it always gets enabled in configurations that rely on it.
Fixes: 40df14cc5cc0 ("clocksource/drivers/ixp4xx: Add OF initialization support")
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Link: https://lore.kernel.org/r/20210103135955.3808976-1-arnd@kernel.org
Converts ARM the text files to ReST, preparing them to be an
architecture book.
The conversion is actually:
- add blank lines and identation in order to identify paragraphs;
- fix tables markups;
- add some lists markups;
- mark literal blocks;
- adjust title markups.
At its new index.rst, let's add a :orphan: while this is not linked to
the main index.rst file, in order to avoid build warnings.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Reviewed-by Corentin Labbe <clabbe.montjoie@gmail.com> # For sun4i-ss
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/spdx
Pull still more SPDX updates from Greg KH:
"Another round of SPDX updates for 5.2-rc6
Here is what I am guessing is going to be the last "big" SPDX update
for 5.2. It contains all of the remaining GPLv2 and GPLv2+ updates
that were "easy" to determine by pattern matching. The ones after this
are going to be a bit more difficult and the people on the spdx list
will be discussing them on a case-by-case basis now.
Another 5000+ files are fixed up, so our overall totals are:
Files checked: 64545
Files with SPDX: 45529
Compared to the 5.1 kernel which was:
Files checked: 63848
Files with SPDX: 22576
This is a huge improvement.
Also, we deleted another 20000 lines of boilerplate license crud,
always nice to see in a diffstat"
* tag 'spdx-5.2-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/spdx: (65 commits)
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 507
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 506
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 505
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 504
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 503
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 502
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 501
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 499
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 498
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 497
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 496
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 495
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 491
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 490
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 489
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 488
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 487
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 486
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 485
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
Multiple ixp4xx specific files require macros from irqs.h that
were moved out from mach/irqs.h, e.g.:
arch/arm/mach-ixp4xx/vulcan-pci.c:41:19: error: this function declaration is not a prototype [-Werror,-Wstrict-prototypes]
arch/arm/mach-ixp4xx/vulcan-pci.c:49:10: error: implicit declaration of function 'IXP4XX_GPIO_IRQ' [-Werror,-Wimplicit-function-declaration]
return IXP4XX_GPIO_IRQ(INTA);
Include this header in all files that failed to build because of
that.
Fixes: dc8ef8cd3a05 ("ARM: ixp4xx: Convert to SPARSE_IRQ")
Platforms should not normally select all the device drivers, leave that
up to the user and the defconfig file.
In this case, we get a warning for randconfig builds:
WARNING: unmet direct dependencies detected for SERIAL_OF_PLATFORM
Depends on [n]: TTY [=y] && HAS_IOMEM [=y] && SERIAL_8250 [=n] && OF [=y]
Selected by [y]:
- MACH_IXP4XX_OF [=y] && ARCH_IXP4XX [=y]
Fixes: 9540724ca29d ("ARM: ixp4xx: Add device tree boot support")
Based on 1 normalized pattern(s):
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
59 temple place suite 330 boston ma 02111 1307 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1334 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de
675 mass ave cambridge ma 02139 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 441 file(s).
Reviewed-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Link: https://lkml.kernel.org/r/20190520071858.739733335@linutronix.de
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Remove duplicated include.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Pull ARM SoC platform updates from Olof Johansson:
"SoC updates, mostly refactorings and cleanups of old legacy platforms.
Major themes this release:
- Conversion of ixp4xx to a modern platform (drivers, DT, bindings)
- Moving some of the ep93xx headers around to get it closer to
multiplatform enabled.
- Cleanups of Davinci
This also contains a few patches that were queued up as fixes before
5.1 but I didn't get sent in before release"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (123 commits)
ARM: debug-ll: add default address for digicolor
ARM: u300: regulator: add MODULE_LICENSE()
ARM: ep93xx: move private headers out of mach/*
ARM: ep93xx: move pinctrl interfaces into include/linux/soc
ARM: ep93xx: keypad: stop using mach/platform.h
ARM: ep93xx: move network platform data to separate header
ARM: stm32: add AMBA support for stm32 family
MAINTAINERS: update arch/arm/mach-davinci
ARM: rockchip: add missing of_node_put in rockchip_smp_prepare_pmu
ARM: dts: Add queue manager and NPE to the IXP4xx DTSI
soc: ixp4xx: qmgr: Add DT probe code
soc: ixp4xx: qmgr: Add DT bindings for IXP4xx qmgr
soc: ixp4xx: npe: Add DT probe code
soc: ixp4xx: Add DT bindings for IXP4xx NPE
soc: ixp4xx: qmgr: Pass resources
soc: ixp4xx: Remove unused functions
soc: ixp4xx: Uninline several functions
soc: ixp4xx: npe: Pass addresses as resources
ARM: ixp4xx: Turn the QMGR into a platform device
ARM: ixp4xx: Turn the NPE into a platform device
Since commit dccd2304cc90 ("ARM: 7430/1: sizes.h: move from asm-generic
to <linux/sizes.h>"), <asm/sizes.h> and <asm-generic/sizes.h> are just
wrappers of <linux/sizes.h>.
This commit replaces all <asm/sizes.h> and <asm-generic/sizes.h> to
prepare for the removal.
Link: http://lkml.kernel.org/r/1553267665-27228-1-git-send-email-yamada.masahiro@socionext.com
Instead of using hardcoded base address implicitly
obtained through <linux/io.h>, pass the physical base
for the QMGR block as a memory resource and remap
it in the driver.
Also pass the two IRQs as resources and obtain them
in the driver.
Use devm_* accessors and simplify the error path in the
process. Drop memory region request as this is done by
the devm_ioremap* functions.
Instead of using hardcoded base addresses implicitly
for the three NPE blocks as memory resources and remap
these in the driver.
Drop the memory request region business, this will
anyways be done by devm_* remapping functions.
Instead of registering everything related to the QMGR
unconditionally in the module_init() call (which will
never work with multiplatform) create a platform device
and probe the QMGR like any other device.
Put the device second in the list of devices added for
the platform so it is there when the dependent network
and crypto drivers probe later on.
This probe() path will not be taken unconditionally on
device tree boots, so remove the DT guard.
Instead of registering everything related to the NPE
and probe the NPE like any other device.
Put the device first in the list of devices added for
This moves the IXP4xx Queue Manager and Network Processing
Engine headers out of the <mack/*> include path as that is
incompatible with multiplatform.
The Network Processing Engine and Queue Manager are
versatile firmware components used by several IXP4xx
drivers.
Drivers are relying on getting access to these components
using <mach/*> headers which does not work with
multiplatform. We need to find a better place for the
drivers to live.
Let's first move them to drivers/soc and the start to
refactor a bit by passing resources and moving headers.
This patch introduce static IRQ assignments but that
will be fixed by later patches in this series.
This adds a minimal support for booting IXP4xx systems
from device tree.
We have to add hacks to the QMGR, NPE and notably also
ethernet and watchdog drivers so that they don't crash
the platform: these drivers are unconditionally starting
to grab regions of statically remapped IO space with no
concern of the device model or other platforms.
We will go in and properly fix these drivers as we go
along but for now this hack gets us to a place where we
can start working on proper device tree support for these
platforms.
This augments the IXP4xx to select and use the new
timer driver in drivers/clocksource and removes the old
code in the machine.
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
This deletes the old irq+gpiochip combo from the IXP4xx
machine and switches it over to use the new drivers merged
in respective subsystem.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
This localizes the <mach/irqs.h> header to the mach-ixp4xx
directory, removes NR_IRQS and switches IXP4xx over to using
SPARSE_IRQ.
This is a prerequisite for DT support.
All IXP4xx devices except the beeper passes the IRQ as a
resource, augment the NSLU2 beeper to do the same.
This is a prerequisite for SPARSE_IRQ.
This rewrites the IXP4xx to use MULTI_IRQ_HANDLER and
create an irqdomain for the irqchip in the platform. We
convert the timer to request the interrupt like any other
driver in the process.
We bump all IRQs to 16+offset to avoid using IRQ 0 and
set NR_IRQS to 512 (the default for most systems).
This conveniently fits with the first 16 IRQs being
pre-allocated when using SPARSE_IRQ.
This is a prerequisite for SPARSE_IRQ and DT boot.
There is no good reason to duplicate the PCI menu in every architecture.
Instead provide a selectable HAVE_PCI symbol that indicates availability
of PCI support, and a FORCE_PCI symbol to for PCI on and the handle the
rest in drivers/pci.
Reviewed-by: Palmer Dabbelt <palmer@sifive.com>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Paul Burton <paul.burton@mips.com>
platform_nand_xxx definitions are just used by the plat_nand driver.
Let's move those definitions out of the core/driver-agnostic rawnand.h
header.
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
We regularly have new NAND controller drivers that are making use of
fields/hooks that we want to get rid of but can't because of all the
legacy drivers that we might break if we do.
So, instead of removing those fields/hooks, let's move them to a
sub-struct which is clearly documented as deprecated.
We start with the ->IO_ADDR_{R,W] fields.
Let's make the raw NAND API consistent by patching all helpers and
hooks to take a nand_chip object instead of an mtd_info one or
remove the mtd_info object when both are passed.
In order to do that, we first need to update the platform_nand_ctrl
hooks to take a nand_chip object instead of an mtd_info.
We add temporary plat_nand_xxx() wrappers to the do the mtd -> chip
conversion, but those will be dropped when patching nand_chip hooks to
take a nand_chip object.
Reviewed-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
I used bad names in my clumsiness when rewriting many board
files to use GPIO descriptors instead of platform data. A few
had the platform_device ID set to -1 which would indeed give
the device name "i2c-gpio".
But several had it set to >=0 which gives the names
"i2c-gpio.0", "i2c-gpio.1" ...
Fix the offending instances in the ARM tree. Sorry for the
mess.
Fixes: b2e63555592f ("i2c: gpio: Convert to use descriptors")
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: Simon Guinot <simon.guinot@sequanux.org>
Reported-by: Simon Guinot <simon.guinot@sequanux.org>
The w1 master driver includes a complete open drain emulation
reimplementation among other things.
This converts the driver and all board files using it to use
GPIO descriptors associated with the device to look up the
GPIO wire, as well ass the optional pull-up GPIO line.
When probed from the device tree, the driver will just pick
descriptors and use them right off. For the two board files
in the kernel, we add descriptor lookups so we do not need
to keep any old platform data handling around for the GPIO
lines.
As the platform data is also a state container for this driver,
we augment it to contain the GPIO descriptors.
w1_gpio_write_bit_dir() and w1_gpio_write_bit_val() are gone
since this pair was a reimplementation of open drain emulation
which is now handled by gpiolib.
The special "linux,open-drain" flag is a bit of mishap here:
it has the same semantic as the same flags in I2C: it means
that something in the platform is setting up the line as
open drain behind our back. We handle this the same way as
in I2C.
To drive the pull-up, we need to bypass open drain emulation
in gpiolib for the line, and this is done by driving it high
using gpiod_set_raw_value() which has been augmented to have
the semantic of overriding the open drain emulation.
We also augment the documentation to reflect the way to pass
GPIO descriptors from the machine.
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
This changes all DEFINE_TIMER() callbacks to use a struct timer_list
pointer instead of unsigned long. Since the data argument has already been
removed, none of these callbacks are using their argument currently, so
this renames the argument to "unused".
Done using the following semantic patch:
@match_define_timer@
declarer name DEFINE_TIMER;
identifier _timer, _callback;
DEFINE_TIMER(_timer, _callback);
@change_callback depends on match_define_timer@
identifier match_define_timer._callback;
type _origtype;
identifier _origarg;
void
-_callback(_origtype _origarg)
+_callback(struct timer_list *unused)
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"This contains two bigger than usual tree-wide changes this time. They
all have proper acks, caused no merge conflicts in linux-next where
they have been for a while. They are namely:
- to-gpiod conversion of the i2c-gpio driver and its users (touching
arch/* and drivers/mfd/*)
- adding a sbs-manager based on I2C core updates to SMBus alerts
(touching drivers/power/*)
Other notable changes:
- i2c_boardinfo can now carry a dev_name to be used when the device
is created. This is because some devices in ACPI world need fixed
names to find the regulators.
- the designware driver got a long discussed overhaul of its PM
handling. img-scb and davinci got PM support, too.
- at24 driver has way better OF support. And it has a new maintainer.
Thanks Bartosz for stepping up!
The rest is regular driver updates and fixes"
* 'i2c/for-4.15' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (55 commits)
ARM: sa1100: simpad: Correct I2C GPIO offsets
i2c: aspeed: Deassert reset in probe
eeprom: at24: Add OF device ID table
MAINTAINERS: new maintainer for AT24 driver
i2c: nuc900: remove platform_data, too
i2c: thunderx: Remove duplicate NULL check
i2c: taos-evm: Remove duplicate NULL check
i2c: Make i2c_unregister_device() NULL-aware
i2c: xgene-slimpro: Support v2
i2c: mpc: remove useless variable initialization
i2c: omap: Trigger bus recovery in lockup case
i2c: gpio: Add support for named gpios in DT
dt-bindings: i2c: i2c-gpio: Add support for named gpios
i2c: gpio: Local vars in probe
i2c: gpio: Augment all boardfiles to use open drain
i2c: gpio: Enforce open drain through gpiolib
gpio: Make it possible for consumers to enforce open drain
power: supply: sbs-message: fix some code style issues
power: supply: sbs-battery: remove unchecked return var
Pull timer updates from Thomas Gleixner:
"Yet another big pile of changes:
- More year 2038 work from Arnd slowly reaching the point where we
need to think about the syscalls themself.
- A new timer function which allows to conditionally (re)arm a timer
only when it's either not running or the new expiry time is sooner
than the armed expiry time. This allows to use a single timer for
multiple timeout requirements w/o caring about the first expiry
time at the call site.
- A new NMI safe accessor to clock real time for the printk timestamp
work. Can be used by tracing, perf as well if required.
- A large number of timer setup conversions from Kees which got
collected here because either maintainers requested so or they
simply got ignored. As Kees pointed out already there are a few
trivial merge conflicts and some redundant commits which was
unavoidable due to the size of this conversion effort.
- Avoid a redundant iteration in the timer wheel softirq processing.
- Provide a mechanism to treat RTC implementations depending on their
hardware properties, i.e. don't inflict the write at the 0.5
seconds boundary which originates from the PC CMOS RTC to all RTCs.
No functional change as drivers need to be updated separately.
- The usual small updates to core code clocksource drivers. Nothing
really exciting"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (111 commits)
timers: Add a function to start/reduce a timer
pstore: Use ktime_get_real_fast_ns() instead of __getnstimeofday()
timer: Prepare to change all DEFINE_TIMER() callbacks
netfilter: ipvs: Convert timers to use timer_setup()
scsi: qla2xxx: Convert timers to use timer_setup()
block/aoe: discover_timer: Convert timers to use timer_setup()
ide: Convert timers to use timer_setup()
drbd: Convert timers to use timer_setup()
mailbox: Convert timers to use timer_setup()
crypto: Convert timers to use timer_setup()
drivers/pcmcia: omap1: Fix error in automated timer conversion
ARM: footbridge: Fix typo in timer conversion
drivers/sgi-xp: Convert timers to use timer_setup()
drivers/pcmcia: Convert timers to use timer_setup()
drivers/memstick: Convert timers to use timer_setup()
drivers/macintosh: Convert timers to use timer_setup()
hwrng/xgene-rng: Convert timers to use timer_setup()
auxdisplay: Convert timers to use timer_setup()
sparc/led: Convert timers to use timer_setup()
mips: ip22/32: Convert timers to use timer_setup()
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
We now handle the open drain mode internally in the I2C GPIO
driver, but we will get warnings from the gpiolib that we
override the default mode of the line so it becomes open
drain.
We can fix all in-kernel users by simply passing the right
flag along in the descriptor table, and we already touched
all of these files in the series so let's just tidy it up.
Cc: Steven Miao <realmz6@gmail.com>
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Wu, Aaron <Aaron.Wu@analog.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
This converts the GPIO-based I2C-driver to using GPIO
descriptors instead of the old global numberspace-based
GPIO interface. We:
- Convert the driver to unconditionally grab two GPIOs
from the device by index 0 (SDA) and 1 (SCL) which
will work fine with device tree and descriptor tables.
The existing device trees will continue to work just
like before, but without any roundtrip through the
global numberspace.
- Brutally convert all boardfiles still passing global
GPIOs by registering descriptor tables associated with
the devices instead so this driver does not need to keep
supporting passing any GPIO numbers as platform data.
There is no stepwise approach as elegant as this, I
strongly prefer this big hammer over any antsteps for this
conversion. This way the old GPIO numbers go away and
NEVER COME BACK.
Special conversion for the different boards utilizing
I2C-GPIO:
- EP93xx (arch/arm/mach-ep93xx): pretty straight forward as
all boards were using the same two GPIO lines, just define
these two in a lookup table for "i2c-gpio" and register
these along with the device. None of them define any
other platform data so just pass NULL as platform data.
This platform selects GPIOLIB so all should be smooth.
The pins appear on a gpiochip for bank "G" as pins 1 (SDA)
and 0 (SCL).
- IXP4 (arch/arm/mach-ixp4): descriptor tables have to
be registered for each board separately. They all use
"IXP4XX_GPIO_CHIP" so it is pretty straight forward.
Most board define no other platform data than SCL/SDA
so they can drop the #include of <linux/i2c-gpio.h> and
assign NULL to platform data.
The "goramo_mlr" (Goramo Multilink Router) board is a bit
worrisome: it implements its own I2C bit-banging in the
board file, and optionally registers an I2C serial port,
but claims the same GPIO lines for itself in the board file.
This is not going to work: there will be competition for the
GPIO lines, so delete the optional extra I2C bus instead, no
I2C devices are registered on it anyway, there are just hints
that it may contain an EEPROM that may be accessed from
userspace. This needs to be fixed up properly by the serial
clock using I2C emulation so drop a note in the code.
- KS8695 board acs5k (arch/arm/mach-ks8695/board-acs5.c)
has some platform data in addition to the pins so it needs to
be kept around sans GPIO lines. Its GPIO chip is named
"KS8695" and the arch selects GPIOLIB.
- PXA boards (arch/arm/mach-pxa/*) use some of the platform
data so it needs to be preserved here. The viper board even
registers two GPIO I2Cs. The gpiochip is named "gpio-pxa" and
- SA1100 Simpad (arch/arm/mach-sa1100/simpad.c) defines a GPIO
I2C bus, and the arch selects GPIOLIB.
- Blackfin boards (arch/blackfin/bf533 etc) for these I assume
their I2C GPIOs refer to the local gpiochip defined in
arch/blackfin/kernel/bfin_gpio.c names "BFIN-GPIO".
The arch selects GPIOLIB. The boards get spiked with
IF_ENABLED(I2C_GPIO) but that is a side effect of it
being like that already (I would just have Kconfig select
I2C_GPIO and get rid of them all.) I also delete any
platform data set to 0 as it will get that value anyway
from static declartions of platform data.
- The MIPS selects GPIOLIB and the Alchemy machine is using
two local GPIO chips, one of them has a GPIO I2C. We need
to adjust the local offset from the global number space here.
The ATH79 has a proper GPIO driver in drivers/gpio/gpio-ath79.c
and AFAICT the chip is named "ath79-gpio" and the PB44
PCF857x expander spawns from this on GPIO 1 and 0. The latter
board only use the platform data to specify pins so it can be
cut altogether after this.
- The MFD Silicon Motion SM501 is a special case. It dynamically
spawns an I2C bus off the MFD using sm501_create_subdev().
We use an approach to dynamically create a machine descriptor
table and attach this to the "SM501-LOW" or "SM501-HIGH"
gpiochip. We use chip-local offsets to grab the right lines.
We can get rid of two local static inline helpers as part
of this refactoring.
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: Ben Dooks <ben.dooks@codethink.co.uk>
Drop the arguments from the macro and adjust all callers with the
following script:
perl -pi -e 's/DEFINE_TIMER\((.*), 0, 0\);/DEFINE_TIMER($1);/g;' \
$(git grep DEFINE_TIMER | cut -d: -f1 | sort -u | grep -v timer.h)
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> # for m68k parts
Acked-by: Guenter Roeck <linux@roeck-us.net> # for watchdog parts
Acked-by: David S. Miller <davem@davemloft.net> # for networking parts
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Kalle Valo <kvalo@codeaurora.org> # for wireless parts
Cc: linux-mips@linux-mips.org
Cc: Petr Mladek <pmladek@suse.com>
Cc: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: Sebastian Reichel <sre@kernel.org>
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: linux1394-devel@lists.sourceforge.net
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: linux-s390@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Ursula Braun <ubraun@linux.vnet.ibm.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Harish Patil <harish.patil@cavium.com>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Michael Reed <mdr@sgi.com>
Cc: Manish Chopra <manish.chopra@cavium.com>
Cc: Len Brown <len.brown@intel.com>
Cc: linux-pm@vger.kernel.org
Cc: Tejun Heo <tj@kernel.org>
Cc: Julian Wiedmann <jwi@linux.vnet.ibm.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Mark Gross <mark.gross@intel.com>
Cc: linux-watchdog@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: netdev@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Link: https://lkml.kernel.org/r/1507159627-127660-11-git-send-email-keescook@chromium.org
From Boris:
This pull request contains the following core changes:
* Fix memory leaks in the core
* Remove unused NAND locking support
* Rename nand.h into rawnand.h (preparing support for spi NANDs)
* Use NAND_MAX_ID_LEN where appropriate
* Fix support for 20nm Hynix chips
* Fix support for Samsung and Hynix SLC NANDs
and the following driver changes:
* Various cleanup, improvements and fixes in the qcom driver
* Fixes for bugs detected by various static code analysis tools
* Fix mxc ooblayout definition
* Add a new part_parsers to tmio and sharpsl platform data in order to
define a custom list of partition parsers
* Request the reset line in exclusive mode in the sunxi driver
* Fix a build error in the orion-nand driver when compiled for ARMv4
* Allow 64-bit mvebu platforms to select the PXA3XX driver
We are planning to share more code between different NAND based
devices (SPI NAND, OneNAND and raw NANDs), but before doing that
we need to move the existing include/linux/mtd/nand.h file into
include/linux/mtd/rawnand.h so we can later create a nand.h header
containing all common structure and function prototypes.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Peter Pan <peterpandong@micron.com>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Han Xu <han.xu@nxp.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-By: Harvey Hunt <harveyhuntnexus@gmail.com>
An empty macro definition can cause unexpected behavior, in
case of the ixp4xx ioport_unmap, we get two warnings:
drivers/net/wireless/marvell/libertas/if_cs.c: In function 'if_cs_release':
drivers/net/wireless/marvell/libertas/if_cs.c:826:3: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
ioport_unmap(card->iobase);
drivers/vfio/pci/vfio_pci_rdwr.c: In function 'vfio_pci_vga_rw':
drivers/vfio/pci/vfio_pci_rdwr.c:230:15: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses]
is_ioport ? ioport_unmap(iomem) : iounmap(iomem);
This uses an inline function to define the macro in a safer way.
ixp4xx defines the arguments to its __indirect_writesb() and other
functions as pointers to fixed-size data. This is not necessarily
wrong, and it works most of the time, but it causes warnings in
at least one driver:
drivers/net/ethernet/smsc/smc91x.c: In function 'smc_rcv':
drivers/net/ethernet/smsc/smc91x.c:495:21: error: passing argument 2 of '__indirect_readsw' from incompatible pointer type [-Werror=incompatible-pointer-types]
SMC_PULL_DATA(lp, data, packet_len - 4);
All other definitions of the same functions pass void pointers,
so doing the same here avoids the warnings.
This typo is quite common. Fix it and add it to the spelling file so
that checkpatch catches it earlier.
Link: http://lkml.kernel.org/r/20170317011131.6881-2-sboyd@codeaurora.org
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
There is no point in having an extra type for extra confusion. u64 is
unambiguous.
Conversion was done with the following coccinelle script:
@rem@
-typedef u64 cycle_t;
@fix@
typedef cycle_t;
-cycle_t
+u64
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Drop duplicate header gpio.h from dsmg600-setup.c.
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for kernel v4.6. There is quite a
lot of interesting stuff going on.
The patches to other subsystems and arch-wide are ACKed as far as
possible, though I consider things like per-arch <asm/gpio.h> as
essentially a part of the GPIO subsystem so it should not be needed.
Core changes:
- The gpio_chip is now a *real device*. Until now the gpio chips
were just piggybacking the parent device or (gasp) floating in
space outside of the device model.
We now finally make GPIO chips devices. The gpio_chip will create
a gpio_device which contains a struct device, and this gpio_device
struct is kept private. Anything that needs to be kept private
from the rest of the kernel will gradually be moved over to the
gpio_device.
- As a result of making the gpio_device a real device, we have added
resource management, so devm_gpiochip_add_data() will cut down on
overhead and reduce code lines. A huge slew of patches convert
almost all drivers in the subsystem to use this.
- Building on making the GPIO a real device, we add the first step of
a new userspace ABI: the GPIO character device. We take small
steps here, so we first add a pure *information* ABI and the tool
"lsgpio" that will list all GPIO devices on the system and all
lines on these devices.
We can now discover GPIOs properly from userspace. We still have
not come up with a way to actually *use* GPIOs from userspace.
- To encourage people to use the character device for the future, we
have it always-enabled when using GPIO. The old sysfs ABI is still
opt-in (and can be used in parallel), but is marked as deprecated.
We will keep it around for the foreseeable future, but it will not
be extended to cover ever more use cases.
Cleanup:
- Bjorn Helgaas removed a whole slew of per-architecture <asm/gpio.h>
includes.
This dates back to when GPIO was an opt-in feature and no shared
library even existed: just a header file with proper prototypes was
provided and all semantics were up to the arch to implement. These
patches make the GPIO chip even more a proper device and cleans out
leftovers of the old in-kernel API here and there.
Still some cruft is left but it's very little now.
- There is still some clamping of return values for .get() going on,
but we now return sane values in the vast majority of drivers and
the errorpath is sanitized. Some patches for powerpc, blackfin and
unicore still drop in.
- We continue to switch the ARM, MIPS, blackfin, m68k local GPIO
implementations to use gpiochip_add_data() and cut down on code
lines.
- MPC8xxx is converted to use the generic GPIO helpers.
- ATH79 is converted to use the generic GPIO helpers.
New drivers:
- WinSystems WS16C48
- Acces 104-DIO-48E
- F81866 (a F7188x variant)
- Qoric (a MPC8xxx variant)
- TS-4800
- SPI serializers (pisosr): simple 74xx shift registers connected to
SPI to obtain a dirt-cheap output-only GPIO expander.
- Texas Instruments TPIC2810
- Texas Instruments TPS65218
- Texas Instruments TPS65912
- X-Gene (ARM64) standby GPIO controller"
* tag 'gpio-v4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (194 commits)
Revert "Share upstreaming patches"
gpio: mcp23s08: Fix clearing of interrupt.
gpiolib: Fix comment referring to gpio_*() in gpiod_*()
gpio: pca953x: Fix pca953x_gpio_set_multiple() on 64-bit
gpio: xgene: Fix kconfig for standby GIPO contoller
gpio: Add generic serializer DT binding
gpio: uapi: use 0xB4 as ioctl() major
gpio: tps65912: fix bad merge
Revert "gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free"
gpio: omap: drop dev field from gpio_bank structure
gpio: mpc8xxx: Slightly update the code for better readability
gpio: mpc8xxx: Remove *read_reg and *write_reg from struct mpc8xxx_gpio_chip
gpio: mpc8xxx: Fixup setting gpio direction output
gpio: mcp23s08: Add support for mcp23s18
dt-bindings: gpio: altera: Fix altr,interrupt-type property
gpio: add driver for MEN 16Z127 GPIO controller
gpio: timberdale: Switch to devm_ioremap_resource()
gpio: ts4800: Add IMX51 dependency
gpiolib: rewrite gpiodev_add_to_list
ixp4xx and pxa25x both use this driver and provide a slightly
different set of register definitions for it. Aside from that,
the definition in the ixp4xx-regs.h header conflicts with the
on in the pxa27x device driver when compile-testing that:
In file included from ../drivers/usb/gadget/udc/pxa27x_udc.c:37:0:
../drivers/usb/gadget/udc/pxa27x_udc.h:26:0: warning: "UDCCR" redefined
#define UDCCR 0x0000 /* UDC Control Register */
In file included from ../arch/arm/mach-ixp4xx/include/mach/hardware.h:27:0,
from ../arch/arm/mach-ixp4xx/include/mach/io.h:18,
from ../arch/arm/include/asm/io.h:194,
from ../include/linux/io.h:25,
from ../include/linux/irq.h:24,
from ../drivers/usb/gadget/udc/pxa27x_udc.c:23:
../arch/arm/mach-ixp4xx/include/mach/ixp4xx-regs.h:415:0: note: this is the location of the previous definition
#define UDCCR IXP4XX_USB_REG(IXP4XX_USB_BASE_VIRT+0x0000)
This addresses both issues by moving all the definitions into the
pxa25x_udc driver itself. It turns out the only difference between
them was 'UDCCS_IO_ROF', and that could well be a mistake when it
was incorrectly copied from pxa25x to ixp4xx.
Signed-off-by: Felipe Balbi <balbi@kernel.org>
We're planning to remove the gpiochip_add() function to swith
to gpiochip_add_data() with NULL for data argument.
Cc: arm@kernel.org
Pull MTD updates from Brian Norris:
"Generic MTD:
- populate the MTD device 'of_node' field (and get a proper 'of_node'
symlink in sysfs)
This yielded some new helper functions, and changes across a
variety of drivers
- partitioning cleanups, to prepare for better device-tree based
partitioning in the future
Eliminate a lot of boilerplate for drivers that want to use
OF-based partition parsing
The DT bindings for this didn't settle yet, so most non-cleanup
portions are deferred for a future release
NAND:
- embed a struct mtd_info inside struct nand_chip
This is really long overdue; too many drivers have to do the same
silly boilerplate to allocate and link up two "independent"
structs, when in fact, everyone is assuming there is an exact 1:1
relationship between a NAND chips struct and its underlying MTD.
This aids improved helpers and should make certain abstractions
easier in the future.
Also causes a lot of churn, helped along by some automated code
transformations
- add more core support for detecting (and "correcting") bitflips in
erased pages; requires opt-in by drivers, but at least we kill a
few bad implementations and hopefully stave off future ones
- pxa3xx_nand: cleanups, a few fixes, and PM improvements
- new JZ4780 NAND driver
SPI NOR:
- provide default erase function, for controllers that just want to
send the SECTOR_ERASE command directly
- fix some module auto-loading issues with device tree
("jedec,spi-nor")
- error handling fixes
- new Mediatek QSPI flash driver
Other:
- cfi: force valid geometry Kconfig (finally!)
This one used to trip up randconfigs occasionally, since bots
aren't deterred by big scary "advanced configuration" menus
More? Probably. See the commit logs"
* tag 'for-linus-20160112' of git://git.infradead.org/linux-mtd: (168 commits)
mtd: jz4780_nand: replace if/else blocks with switch/case
mtd: nand: jz4780: Update ecc correction error codes
mtd: nandsim: use nand_get_controller_data()
mtd: jz4780_nand: remove useless mtd->priv = chip assignment
staging: mt29f_spinand: make use of nand_set/get_controller_data() helpers
mtd: nand: make use of nand_set/get_controller_data() helpers
ARM: make use of nand_set/get_controller_data() helpers
mtd: nand: add helpers to access ->priv
mtd: nand: jz4780: driver for NAND devices on JZ4780 SoCs
mtd: nand: jz4740: remove custom 'erased check' implementation
mtd: nand: diskonchip: remove custom 'erased check' implementation
mtd: nand: davinci: remove custom 'erased check' implementation
mtd: nand: use nand_check_erased_ecc_chunk in default ECC read functions
mtd: nand: return consistent error codes in ecc.correct() implementations
doc: dt: mtd: new binding for jz4780-{nand,bch}
mtd: cfi_cmdset_0001: fixing memory leak and handling failed kmalloc
mtd: spi-nor: wait until lock/unlock operations are ready
mtd: tests: consolidate kmalloc/memset 0 call to kzalloc
jffs2: use to_delayed_work
mtd: nand: assign reasonable default name for NAND drivers
