[ Upstream commit 844b85dda2f569943e1e018fdd63b6f7d1d6f08e ]
clang warns about an impossible condition when building with 32-bit
phys_addr_t:
arch/arm/mach-keystone/keystone.c:79:16: error: result of comparison of constant 51539607551 with expression of type 'phys_addr_t' (aka 'unsigned int') is always false [-Werror,-Wtautological-constant-out-of-range-compare]
mem_end > KEYSTONE_HIGH_PHYS_END) {
arch/arm/mach-keystone/keystone.c:78:16: error: result of comparison of constant 34359738368 with expression of type 'phys_addr_t' (aka 'unsigned int') is always true [-Werror,-Wtautological-constant-out-of-range-compare]
if (mem_start < KEYSTONE_HIGH_PHYS_START ||
Change the temporary variable to a fixed-size u64 to avoid the warning.
Reviewed-by: Nathan Chancellor <nathan@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Link: https://lore.kernel.org/r/20210323131814.2751750-1-arnd@kernel.org'
With future SoCs of keystone2 family, the generic compatible match
may not be sufficient to handle SoC specific handling. So introduce
matches based on SoC compatiblity.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
The init_meminfo() method is not about initialising meminfo - it's about
fixing up the physical to virtual translation so that we use a different
physical address space, possibly above the 4GB physical address space.
Therefore, the name "init_meminfo()" is confusing.
Rename it to pv_fixup() instead.
Tested-by: Murali Karicheri <m-karicheri2@ti.com>
There is no point platform code doing this, let's move it into the
generic code so it doesn't get duplicated.
Make the init_meminfo function return the offset to be applied to the
phys-to-virt translation constants. This allows us to move the update
into generic code, along with the requirements for this update.
This avoids platforms having to know the details of the phys-to-virt
translation support.
We ideally want the init_meminfo function to do nothing but return the
delta to be applied to PHYS_OFFSET - it should do nothing else. As we
can detect in platform init code whether we are running in the high
physical address space, move the platform notifier initialisation
entirely into the platform init code.
The definition
static const char *axxia_dt_match[] __initconst = {
defines a changable array of constant strings. That is you must not do:
*axxia_dt_match[0] = 'k';
but
axxia_dt_match[0] = "different string";
is fine. So the annotation __initconst is wrong and yields a compiler
error when other really const variables are added with __initconst.
As the struct machine_desc member dt_compat is declared as
const char *const *dt_compat;
making the arrays const is the better alternative over changing all
annotations to __initdata.
Laura's series removed the meminfo structure and its no longer available.
Update keystone code to remove the usage of it.
Reported-by: Russell King - ARM Linux <linux@arm.linux.org.uk>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Remove reset stuff in flavour of using keystone reset driver:
driver/power/reset/keystone-reset.c
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Tested-by: Grygorii Strashko <grygorii.strashko@ti.com>
With late code patching updates for LPAE machines has merged now and
memblock conversion from bootmem is on its way, Keystone can switch to
the coherent memory address space which starts beyond 4GB boundary.
The idmap alias needs are managed via virt_to_idmap() for boot purpose.
As suggested by Olof Johansson at
http://www.spinics.net/lists/arm-kernel/msg314009.html.
It be better just keeping a "ti,keystone" top-level compatible and
just using that to probe. If so we don't have to touch the file
for new boards in the future.
So use common "ti,keystone" compatible in keystone.c for all boards.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Olof Johansson <olof@lixom.net>
This patch add compatibility strings for k2hk, k2l and k2e EVMs
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Keystone PM bus makes use of generic PM clock core backend. Since
generic PM clock core uses platform bus notifiers to track events like
ADD_DEVICE/DEL_DEVICE and to fill clock lists per each device, we need
to initialise Keystone PM domains before the platform devices have been
created.
Hence, fix it by moving keystone_pm_runtime_init() before platform
devices have been populated.
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
Keystone II peripheral devices support 32-bit DMA and hence can access only
first 2GB of the memory address space. So set the platform dma_zone_size
to handle that case.
Fix the following compilation warning:
arch/arm/mach-keystone/keystone.c:74:2: warning: initialization from incompatible pointer type [enabled by default]
arch/arm/mach-keystone/keystone.c:74:2: warning: (near initialization for ‘__mach_desc_KEYSTONE.restart’) [enabled by default]
Signed-off-by: Vincent Stehlé <vincent.stehle@freescale.com>
Cc: Robin Holt <holt@sgi.com>
Cc: trivial@kernel.org
Add basic SMP support for Keystone machines. This does not
include support for CPU hotplug for now.
Cc: arm@kernel.org
Acked-by: Olof Johansson <olof@lixom.net>
Texas Instruments Keystone family of multi-core devices are
based on ARM Cortex A15. Patch adds basic definitions for a
new Keystone sub-architecture in ARM.
The TCI66xxK2H Communications Infrastructure Keystone SoCs
are member of the C66x family based on TI's new KeyStone 2
multi-core SoC Architecture designed specifically for high
performance wireless and networking infrastructure applications.
The SOCs contains many subsystems like Cortex A15 ARM CorePacs,
C66XX DSP CorePacs, MSMC memory controller, Tera Net bus,
IP Network, Navigator, Hyperlink, 1G/10G Ethernet, Radio layers
and queue based communication systems.
Cc: arm@kernel.org
