path: root/arch/arm/mach-kirkwood/Kconfig
2010-12-07Kirkwood: Add support for 6282 based QNAP devicesMartin Michlmayr
Add support for the QNAP NAS devices based on Marvell's 6282 Kirkwood chip (TS-119P+, TS-219P+ and TS-419P+). The differences to the 6281 based devices are: - Ethernet PHY address - GPIOs used for buttons (TS-119P+/TS-219P+) Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Acked-by: Saeed Bishara <saeed.bishara@gmail.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-09-19[ARM] Kirkwood: add LaCie d2 Network v2 supportSimon Guinot
Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-09-19[ARM] Kirkwood: support for Seagate DockStarEric Cooper
This patch adds support for the Seagate FreeAgent DockStar, a Marvell SheevaPlug variant. Signed-off-by: Eric Cooper <ecc@cmu.edu> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: add LaCie Network Space Max v2 supportSimon Guinot
2010-07-16[ARM] Marvell OpenRD-Ultimate machine supportDmytro Milinevskyy
This patch adds support for the OpenRD Ultimate machine (could be found at http://www.arm.linux.org.uk/developer/machines/list.php?id=2884) Signed-off-by: Dmytro Milinevskyy <milinevskyy@gmail.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Kirkwood: Add support for HP t5325 Thin ClientMartin Michlmayr
Add support for the HP t5325 Thin Client. This thin client is based on a Marvell Kirkwood chip at 1.2 GHz and features 512 MB RAM, 512 MB SATA-attached flash and an XGI Volari Z11 GPU. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-05-03[ARM] Kirkwood: add LaCie 5Big Network v2 supportSimon Guinot
2010-05-03[ARM] Kirkwood: add LaCie 2Big Network v2 supportSimon Guinot
2010-05-03[ARM] Kirkwood: Marvell GuruPlug supportSiddarth Gore
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0 GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot References: http://www.globalscaletechnologies.com/t-guruplugdetails.aspx http://plugcomputer.org This patch is for GuruPlug Plus, but it supports Standard version as well. Signed-off-by: Siddarth Gore <gores@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-02-25Merge branch 'for-rmk' of git://git.marvell.com/orion into devel-stableRussell King
2010-02-23[ARM] eSATA SheevaPlug basic board supportJohn Holland
Allow basic eSATA SheevaPlug board configuration and build. Signed-off-by: John Holland <john.holland@cellent-fs.de> Signed-off-by: Nicolas Pitre <nico@marvell.com> --
2010-02-09[ARM] Kirkwood: add LaCie Internet Space v2 supportSimon Guinot
The Internet and Network Space v2 boards are very close. The only difference is that there is no USB type B plug wired on the Internet Space v2. Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-02-05[ARM] kirkwood: combine support for openrd base/client supportAlexander Clouter
Inspired by the mach-ep93xx flattening work, there is really not much difference between the OpenRD base and client board support so they should be merged together. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Acked-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2009-12-10[ARM] Kirkwood: Add LaCie Network Space v2 supportSimon Guinot
2009-11-13[ARM] Kirkwood: Add QNAP TS-110/TS-210 to Kconfig help textMartin Michlmayr
Add two new models from QNAP to the help text. They are compatible with the TS-119/TS-219 and therefore supported by the current code. The only difference is that they have less RAM (256 MB instead of 512 MB), a slower CPU (800 MHz vs 1.2 GHz) and a plastic case. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-11-13[ARM] Kirkwood: Add support for QNAP TS-41x Turbo NASMartin Michlmayr
Add support for the QNAP TS-410, TS-410U, TS-419P and TS-419U Turbo NAS. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-08-10[ARM] Kirkwood: Marvell OpenRD-Base board supportDhaval Vasa
reference: http://open-rd.org http://code.google.com/p/openrd This patch is tested for: 1. Boot from DRAM/NAND flash 2. NAND read/write/erase 3. GbE0 4. USB read/write FIXME: 1. SD/UART1 selection 2. MPP configuration (currently, default) 3. PEX Signed-off-by: Dhaval Vasa <dhaval.vasa@einfochips.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-06-08[ARM] Kirkwood: add Marvell 88F6281 GTW GE board supportLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2009-03-23[ARM] Kirkwood: Add support for QNAP TS-119/TS-219 Turbo NASMartin Michlmayr
Add support for the QNAP TS-119 and TS-219 Turbo NAS devices. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-03-15[ARM] Kirkwood: Marvell SheevaPlug supportShadi Ammouri
2008-06-22[ARM] add Marvell Kirkwood (88F6000) SoC supportSaeed Bishara
The Marvell Kirkwood (88F6000) is a family of ARM SoCs based on a Shiva CPU core, and features a DDR2 controller, a x1 PCIe interface, a USB 2.0 interface, a SPI controller, a crypto accelerator, a TS interface, and IDMA/XOR engines, and depending on the model, also features one or two Gigabit Ethernet interfaces, two SATA II interfaces, one or two TWSI interfaces, one or two UARTs, a TDM/SLIC interface, a NAND controller, an I2S/SPDIF interface, and an SDIO interface. This patch adds supports for the Marvell DB-88F6281-BP Development Board and the RD-88F6192-NAS and the RD-88F6281 Reference Designs, enabling support for the PCIe interface, the USB interface, the ethernet interfaces, the SATA interfaces, the TWSI interfaces, the UARTs, and the NAND controller. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
