path: root/arch/arm/mach-kirkwood/sheevaplug-setup.c
2011-03-17arm: mach-kirkwood: add led in sheevaplug-setup.cRobin Becker
This patch adds a second, red, led for the standard sheevaplug. The sheeva_esata mpp config is left unchanged. Tested on a standard sheevaplug Signed-off-by: Robin Becker <robin@reportlab.com> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-02-23[ARM] eSATA SheevaPlug: correlate MPP to SD CD and SD WPJohn Holland
Accept SD CD and SD WP in accordance to http://plugcomputer.org/data/docs/Sheeva-PowerPlug-V1.3-GTI-090906.pdf on MPP 47 and 44 respectively on the eSATA SheevaPlug Signed-off-by: John Holland <john.holland@cellent-fs.de> Signed-off-by: Nicolas Pitre <nico@marvell.com> --
2010-02-23[ARM] eSATA SheevaPlug: configure SoC SATA interfaceJohn Holland
Enable the kirkwood SATA SoC interface on the eSATA SheevaPlug. Signed-off-by: John Holland <john.holland@cellent-fs.de> Signed-off-by: Nicolas Pitre <nico@marvell.com> --
2010-02-23[ARM] eSATA SheevaPlug basic board supportJohn Holland
Allow basic eSATA SheevaPlug board configuration and build. Signed-off-by: John Holland <john.holland@cellent-fs.de> Signed-off-by: Nicolas Pitre <nico@marvell.com> --
2009-06-08[ARM] Kirkwood: rationalize NAND setup a bitNicolas Pitre
Common resource and platform device structures are moved to common.c and only the partition table and chip delay remains a per board parameter. Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-06-08[ARM] Kirkwood: comment type fixNicolas Pitre
2009-03-15[ARM] Kirkwood: SheevaPlug LED supportNicolas Pitre
2009-03-15[ARM] Kirkwood: SheevaPlug USB Power Enable setupNicolas Pitre
Ideally, the default should be set to 0 and let the EHCI driver turn it on as needed. This makes USB usable in the mean time. Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-03-15[ARM] Kirkwood: Marvell SheevaPlug supportShadi Ammouri
