path: root/arch/arm/mach-kirkwood
2011-05-16ARM: orion: Refactor the MPP code common in the orion platformAndrew Lunn
mv78xx0 and kirkwood use identical mpp code. It should also be possible to rewrite the orion5x mpp to use this platform code. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate setup of the crypto engine.Andrew Lunn
2011-05-16ARM: orion: Consolidate SATA platform setup.Andrew Lunn
2011-05-16ARM: orion: Consolidate USB platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the XOR platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the platform data setup for the watchdog.Andrew Lunn
2011-05-16ARM: orion: Consolidate SPI initialization.Andrew Lunn
This change removes the interrupt resource. The driver does not use it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate I2C initialization.Andrew Lunn
2011-05-16ARM: orion: Consolidate ethernet platform dataAndrew Lunn
2011-05-16ARM: kirkwood: Add support for RTC interrupts which allows RTC alarms.Andrew Lunn
Tested using the test program in Documentation/rtc.txt Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate the creation of the RTC platform data.Andrew Lunn
2011-05-16ARM: orion: Consolidate the creation of the uart platform data.Andrew Lunn
2011-05-16ARM: orion: Rename some constants to macros to make code more identicalAndrew Lunn
Changing eg 0xffffffff to DMA_BIT_MASK(32) etc allows easier side by side comparision of identical code which can be consolidated. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits) ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support ARM: 6838/1: etm: fix section mismatch warning ARM: 6837/1: remove unused pci_fixup_prpmc1100 ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC Fix the broken build for Marvell Dove platform. ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency ARM: 6834/1: perf: reset counters on all CPUs during initialisation ARM: 6833/1: perf: add required isbs() to ARMv7 backend ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile arm: mach-mx3: pcm043: add write-protect and card-detect for SD1 eukrea_mbimxsd51: add SD Card detect eukrea_mbimxsd25-baseboard: add SD card detect mx3/eukrea_mbimxsd-baseboard: add SD card detect support mx3/eukrea_mbimxsd-baseboard: fix gpio request ARM: mxs/mx28evk: add mmc device ARM: mxs/mx23evk: add mmc device ARM: mxs: dynamically allocate mmc device ARM: mx51_efika: update platform data for new mfd changes mx2/iomux: Set direction for CSPI2 pins ...
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/nico/orion into fixesRussell King
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17arm: mach-kirkwood: add led in sheevaplug-setup.cRobin Becker
This patch adds a second, red, led for the standard sheevaplug. The sheeva_esata mpp config is left unchanged. Tested on a standard sheevaplug Signed-off-by: Robin Becker <robin@reportlab.com> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion GPIO code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion GPIO code pass in GPIO-related platform info (GPIO controller base address, secondary base IRQ number, etc) explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] Kirkwood: make kirkwood_find_tclk() staticNicolas Pitre
2011-03-03[ARM] Kirkwood: t5325: add audio supportArnaud Patard
This patch declares the i2c audio codec and initialise audio. It's adding the alc5621 codec in the i2c board info and is calling kirkwood_audio_init() to initialize kirkwood audio. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] Kirkwood: initialize PCIE1 for QNAP TS-419P+Zintis Pētersons
Initialize PCIE1 on the 6282-based QNAP TS-419P+ since it has a Marvell 9125 SATA chip on each PCI bus. Signed-off-by: Zintis Pētersons <zintis.petersons@abcsolutions.lv> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] Kirkwood: enable PCIe for kexecEric Cooper
Use the machine-specific kexec_reinit hook to make sure PCIe is enabled before starting a new kernel. Signed-off-by: Eric Cooper <ecc@cmu.edu> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] Kirkwood: enable PCIe before reading device ID registerEric Cooper
PCIe may have been disabled (by kirkwood_clock_gate) if this kernel was started by kexec. Make sure PCIe is enabled before attempting to access the device ID register, otherwise the system will hang. Signed-off-by: Eric Cooper <ecc@cmu.edu> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
2011-01-06Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/mach-pxa/clock.c arch/arm/mach-pxa/clock.h
2010-12-08ARM: io: make iounmap() a simple macroRussell King
Defining iounmap() with arguments prevents it from being used as a function pointer, causing platforms to work around this. Instead, define it to be a simple macro. Do the same for __arch_io(re|un)map too. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-07Kirkwood: Add support for 6282 based QNAP devicesMartin Michlmayr
Add support for the QNAP NAS devices based on Marvell's 6282 Kirkwood chip (TS-119P+, TS-219P+ and TS-419P+). The differences to the 6281 based devices are: - Ethernet PHY address - GPIOs used for buttons (TS-119P+/TS-219P+) Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Acked-by: Saeed Bishara <saeed.bishara@gmail.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-11-19Merge branch 'next-samsung-asoc' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into for-2.6.38
2010-11-15ASoC: Add support for OpenRD UltimateArnaud Patard (Rtp)
OpenRD Ultimate & Client are similar machines so enable OpenRD client sound support on Ultimate too Tested-by: Robas Teodor <teodor.robas@gmail.com> Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/nico/orionRussell King
2010-11-05ARM: orion5x/kirkwood/mv78xx0: fix MPP configuration corner casesMike Rapoport
Wrong MPP configuration would cause <cpu>_mpp_conf loop infinitely because the mpp list iterator would not be incremented. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-25Kirkwood: add fan support for Network Space Max v2Simon Guinot
Signed-off-by: Simon Guinot <sguinot@lacie.com> Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-21[ARM] Kirkwood: restrict the scope of the PCIe reset workaroundNicolas Pitre
Commit 21f0ba90a447 "orion/kirkwood: reset PCIe unit on boot" made the reset of the PCIe unit unconditional. While this may fix problems on some targets, this also causes problems on other targets. Saeed Bishara <saeed@marvell.com> said about the original problem: "We couln't pinpoint the root cause of this issue, actually we failed to reproduce that issue." So let's restrict the reset of the PCIe unit only to the target where the original problem was observed. Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-21[ARM] Kirkwood: fix timer initialization for LaCie boardsSimon Guinot
Signed-off-by: Simon Guinot <sguinot@lacie.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-21[ARM] Kirkwood: enhance TCLK detectionSimon Guinot
According to the Marvell LSP, the Sample at Reset regiter bit 21 can be used to detect TCLK on 6281 and 6282 devices. This patch has only been tested on LaCie boards. Signed-off-by: Simon Guinot <sguinot@lacie.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-07[ARM] Kirkwood: add LED support for netxbig_v2 boardsSimon Guinot
Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-07leds: add LED driver for Big Network series LEDsSimon Guinot
This patch add a LED class driver for LEDs found on the LaCie 2Big and 5Big Network v2 boards. The LEDs are wired to a CPLD and are controlled through a GPIO extension bus. Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-09-19[ARM] Kirkwood: remove duplicated code in LaCie setup filesSimon Guinot
2010-09-19[ARM] Kirkwood: add LaCie d2 Network v2 supportSimon Guinot
2010-09-19[ARM] Kirkwood: support for Seagate DockStarEric Cooper
This patch adds support for the Seagate FreeAgent DockStar, a Marvell SheevaPlug variant. Signed-off-by: Eric Cooper <ecc@cmu.edu> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-09-19[ARM] OpenRD: Enable SD/UART selection for serial port 1Tanmay Upadhyay
This patch enables users to choose either the SDIO interface or UART1 (RS232/RS485). The selection can be done through kernel parameter. By default the port would be used for SDIO interface. Passing the string "kw_openrd_init_uart1=232" or "kw_openrd_init_uart1=485" enables either the RS-232 or RS-485 port respectively; disabling the SDIO interface. Anything else selects the default SDIO interface. "kw_openrd_init_uart1=485" is ignored on OpenRD-Base as it doesn't have RS485 port. Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Acked-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-09-19ARM: kirkwood: Unbreak PCIe I/O portArnaud Patard
The support for the 2 pcie port of the 6282 has broken i/o port by switching *_IO_PHYS_BASE and *_IO_BUS_BASE. In fact, the patches reintroduced the same bug solved by commit 35f029e2514be209eb0e88c7d927f3bcc42a5cc2. So, I'm adding back *_IO_BUS_BASE in resource declaration and fix definition of KIRKWOOD_PCIE1_IO_BUS_BASE. With this change, the xgi card on my t5325 is working again. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Cc: stable@kernel.org
