[ Upstream commit 4aa64677330beeeed721b4b122884dabad845d66 ]
WARNING: vmlinux.o(.text+0x13250): Section mismatch in reference from the function acs5k_i2c_init() to the (unknown reference) .init.data:(unknown)
The function acs5k_i2c_init() references
the (unknown reference) __initdata (unknown).
This is often because acs5k_i2c_init lacks a __initdata
annotation or the annotation of (unknown) is wrong.
Some header files are never included outside of a mach-ks8695
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Acked-by: Greg Ungerer <gerg@uclinux.org>
This patch moves the pca953x.h header from include/linux/i2c to
include/linux/platform_data and updates existing support accordingly.
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Clockevent cleanup series from Shawn Guo.
Resolved move/change conflict in mach-pxa/time.c due to the sys_timer
cleanup.
* clocksource/cleanup:
clocksource: use clockevents_config_and_register() where possible
ARM: use clockevents_config_and_register() where possible
clockevents: export clockevents_config_and_register for module use
+ sync to Linux 3.8-rc3
arch/arm/mach-pxa/time.c
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
The <mach/gpio.h> file is included from upper directories
and deal with generic GPIO and gpiolib stuff. Break out the
platform and driver specific defines and functions into its own
header file.
Cc: zeal <zealcook@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Daniel Silverstone <dsilvers@simtec.co.uk>
Acked-by: Simtec Linux Team <linux@simtec.co.uk>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
This patch provides the core board support for the Brivo Systems
LLC ACS-5000 master board for automated door/card-reader etc
management.
Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk>
Signed-off-by: Vincent Sanders <vince@simtec.co.uk>
