path: root/arch/arm/mach-ks8695/devices.c
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-14[ARM] KS8695: Fix up device registration.Daniel Silverstone
The KS8695 device.c provides registration functionality for the KS8695's various devices such as watchdog timers and ethernet devices. Rather than predicating those on the config options for the drivers, always register the platform devices so that a later built module can hook on. Also, the ethernet used to register virtual addresses in the platform data. This is wrong and so this patch changes them to physical addresses and also passes in the appropriate physical region for the PHY or Switch as appropriate. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4981/1: [KS8695] Simple LED driverAndrew Victor
Simple gpio-connected LED driver for KS8695 platforms. (Based on old AT91 LED driver) Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4331/3: Support for Micrel/Kendin KS8695 processorAndrew Victor
Add core support for the Kendin/Micrel KS8695 processor family. It is an ARM922-T based SoC with integrated USART, 4-port Ethernet Switch, WAN Ethernet port, and optional PCI Host bridge, etc. http://www.micrel.com/page.do?page=product-info/sys_on_chip.jsp This patch is based on earlier patches from Lennert Buytenhek, Ben Dooks and Greg Ungerer posted to the arm-linux-kernel mailing list in March 2006; and Micrel's 2.6.9 port. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
