path: root/arch/arm/mach-ks8695
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-12ARM: convert PCI defines to variablesRob Herring
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow multi-platform builds. This also removes the requirement for a platform to have a mach/hardware.h. The default values for i/o and mem are 0x1000 and 0x01000000, respectively. Per Arnd Bergmann, other values are likely to be incorrect, but this commit does not try to address that issue. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: pci: make pcibios_assign_all_busses use pci_has_flagRob Herring
Convert pcibios_assign_all_busses from a define to inline so platforms can control this setting. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: ks8695: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2011-01-03ARM: DMA: Replace page_to_dma()/dma_to_page() with pfn_to_dma()/dma_to_pfn()Russell King
Replace the page_to_dma() and dma_to_page() macros with their PFN equivalents. This allows us to map parts of memory which do not have a struct page allocated to them to bus addresses. This will be used internally by dma_alloc_coherent()/dma_alloc_writecombine(). Build tested on Versatile, OMAP1, IOP13xx and KS8695. Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-05ARM: 6520/1: Kconfig: add new symbol MIGHT_HAVE_PCIHans Ulli Kroll
Today more boards with arm cpu have selectable pci bus. This patch makes this more scalable and remove line continuations in Kconfig Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-07-27ARM: 6269/1: Add 'code' parameter for hook_fault_code()Kirill A. Shutemov
Add one more parameter to hook_fault_code() to be able to set 'code' field of struct fsr_info. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-23ARM: dma-mapping: provide dma_to_page()Russell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-By: Jamie Iles <jamie@jamieiles.com>
2009-11-05ARM: 5780/1: KS8695: Fix macro definition bug in regs-switch.czeal
NOTE: 1. Macro style is so strange. 2. The value 0xc0 is not match with KS8695 manual. It should be 0x0c. Signed-off-by: zeal <zealcook@gmail.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-08-05ARM: 5637/1: [KS8695] Don't reference CLOCK_TICK_RATE in driversAndrew Victor
Stop referencing CLOCK_TICK_RATE in the KS8695 drivers, rather refer to a KS8695_CLOCK_RATE. Issue pointed out by Russell King on arm-linux-kernel mailing list. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-30ARM: 5597/1: [PCI] reset all internal hardware prior PCI initializationYegor Yefremov
Make software reset to avoid freeze if PCI bus was messed up Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-24Merge branch 'highmem' into develRussell King
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-15[ARM] make page_to_dma() highmem awareNicolas Pitre
If a machine class has a custom __virt_to_bus() implementation then it must provide a __arch_page_to_dma() implementation as well which is _not_ based on page_address() to support highmem. This patch fixes existing __arch_page_to_dma() and provide a default implementation otherwise. The default implementation for highmem is based on __pfn_to_bus() which is defined only when no custom __virt_to_bus() is provided by the machine class. That leaves only ebsa110 and footbridge which cannot support highmem until they provide their own __arch_page_to_dma() implementation. But highmem support on those legacy platforms with limited memory is certainly not a priority. Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-02-10[ARM] 5372/1: ACS5K: Core board support for the ACS-5000Daniel Silverstone
This patch provides the core board support for the Brivo Systems LLC ACS-5000 master board for automated door/card-reader etc management. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> Signed-off-by: Vincent Sanders <vince@simtec.co.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-14[ARM] DSM320: Add support for the DSM320Daniel Silverstone
Add support for the D-Link DSM-320 Wireless Media Player which is based on the Micrel KS8695 SoC. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-14[ARM] KS8695: Add GPIO to IRQ mapping functionBen Dooks
Use the GPIOlib .to_irq call to map KS8695 GPIOs to the relevant IRQ line. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-14[ARM] KS8695: Fixup the KS8695 GPIO to be GPIOLIBDaniel Silverstone
This patch is as small a change as possible to the KS8695 GPIO layer to use GPIOLIB to allow the generic GPIO expanders and the like to be compiled. As a side-effect, we also remove __init_or_module from several functions which could be called by drivers such as i2c-gpio which could plausibly be compiled into a non-modular kernel. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> Signed-off-by: Vincent Sanders <vince@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-14[ARM] KS8695: Fix up device registration.Daniel Silverstone
The KS8695 device.c provides registration functionality for the KS8695's various devices such as watchdog timers and ethernet devices. Rather than predicating those on the config options for the drivers, always register the platform devices so that a later built module can hook on. Also, the ethernet used to register virtual addresses in the platform data. This is wrong and so this patch changes them to physical addresses and also passes in the appropriate physical region for the PHY or Switch as appropriate. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-11-30[ARM] Add a common typesafe __io implementationRussell King
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b, add a typesafe __io implementation for platforms to use. Convert platforms to use this new simple typesafe implementation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-30[ARM] gpio_free might sleep, arm architectureUwe Kleine-König
According to the documentation gpio_free should only be called from task context only. To make this more explicit add a might sleep to all implementations. This patch changes the gpio_free implementations for the arm architecture. DaVinci is skipped on purpose to simplify the merge process for patches switching it over to use gpiolib as per request by David Brownell. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Cc: David Brownell <david-b@pacbell.net> Cc: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09Merge branches 'machtypes', 'core', 'ep93xx', 'ks8695', 'netdev' and ↵Russell King
'sa1100' into devel
2008-10-09[ARM] 5297/1: [KS8695] Fix two compile-time warningsAndrew Victor
Fix two warnings when compiling for the KS8695 processor. arch/arm/include/asm/dma-mapping.h: In function 'dma_to_virt': arch/arm/include/asm/dma-mapping.h:40: warning: return makes pointer from integer without a cast Section mismatch in reference from the function pcibios_fixup_bus() to the (unknown reference) .devinit.text:(unknown) The function pcibios_fixup_bus() references the (unknown reference) __devinit (unknown). This is often because pcibios_fixup_bus lacks a __devinit annotation or the annotation of (unknown) is wrong. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5296/1: [KS8695] Replace macro's with trailing underscores.Andrew Victor
Replace Macro names that have trailing underscores. Also use the IOPD() macro instead of a hard-coded bit-shift (for better readability). Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Eliminate useless includes of asm/mach-types.hRussell King
There are 43 includes of asm/mach-types.h by files that don't reference anything from that file. Remove these unnecessary includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-17[ARM] 4981/1: [KS8695] Simple LED driverAndrew Victor
Simple gpio-connected LED driver for KS8695 platforms. (Based on old AT91 LED driver) Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Merge branches 'at91', 'ep93xx', 'iop', 'kprobes', 'ks8695', 'misc', 'msm', ↵Russell King
's3c2410', 'sa1100' and 'vfp' into devel * at91: (24 commits) [ARM] 4615/4: sam926[13]ek buttons updated [ARM] 4765/1: [AT91] AT91CAP9A-DK board support [ARM] 4764/1: [AT91] AT91CAP9 core support [ARM] 4738/1: at91sam9261: Remove udc pullup enabling in board initialisation [ARM] 4761/1: [AT91] Board-support for NEW_LEDs [ARM] 4760/1: [AT91] SPI CS0 errata on AT91RM9200 [ARM] 4759/1: [AT91] Buttons on CSB300 [ARM] 4758/1: [AT91] LEDs [ARM] 4757/1: [AT91] UART initialization [ARM] 4756/1: [AT91] Makefile cleanup [ARM] 4755/1: [AT91] NAND update [ARM] 4754/1: [AT91] SSC library support [ARM] 4753/1: [AT91] Use DMA_BIT_MASK [ARM] 4752/1: [AT91] RTT, RTC and WDT peripherals on SAM9 [ARM] 4751/1: [AT91] ISI peripheral on SAM9263 [ARM] 4750/1: [AT91] STN LCD displays on SAM9261 [ARM] 4734/1: at91sam9263ek: include IRQ for Ethernet PHY [ARM] 4646/1: AT91: configurable HZ, default to 128 [ARM] 4688/1: at91: speed-up irq processing [ARM] 4657/1: AT91: Header definition update ... * ep93xx: [ARM] 4671/1: ep93xx: remove obsolete gpio_line_* operations [ARM] 4670/1: ep93xx: implement IRQT_BOTHEDGE gpio irq sense type [ARM] 4669/1: ep93xx: simplify GPIO code and cleanups [ARM] 4668/1: ep93xx: implement new GPIO API * iop: [ARM] 4770/1: GLAN Tank: correct physmap_flash_data width field [ARM] 4732/1: GLAN Tank: register rtc-rs5c372 i2c device [ARM] 4708/1: iop: update defconfigs for 2.6.24 * kprobes: ARM kprobes: let's enable it ARM kprobes: special hook for the kprobes breakpoint handler ARM kprobes: prevent some functions involved with kprobes from being probed ARM kprobes: don't let a single-stepped stmdb corrupt the exception stack ARM kprobes: add the kprobes hook to the page fault handler ARM kprobes: core code ARM kprobes: instruction single-stepping support * ks8695: [ARM] 4603/1: KS8695: debugfs interface to view pin state [ARM] 4601/1: KS8695: PCI support * misc: [ARM] remove duplicate includes [ARM] CONFIG_DEBUG_STACK_USAGE [ARM] 4689/1: small comment wrap fix [ARM] 4687/1: Trivial arch/arm/kernel/entry-common.S comment fix [ARM] 4666/1: ixp4xx: fix sparse warnings in include/asm-arm/arch-ixp4xx/io.h [ARM] remove reference to non-existent MTD_OBSOLETE_CHIPS [SERIAL] 21285: Report baud rate back via termios [ARM] Remove pointless casts from void pointers, [ARM] Misc minor interrupt handler cleanups [ARM] Remove at91_lcdc.h [ARM] ARRAY_SIZE() cleanup [ARM] Update mach-types * msm: [ARM] msm: dma support for MSM7X00A [ARM] msm: board file for MACH_HALIBUT (QCT MSM7200A) [ARM] msm: irq and timer support for ARCH_MSM7X00A [ARM] msm: core platform support for ARCH_MSM7X00A * s3c2410: (33 commits) [ARM] 4795/1: S3C244X: Add armclk and setparent call [ARM] 4794/1: S3C24XX: Comonise S3C2440 and S3C2442 clock code [ARM] 4793/1: S3C24XX: Add IRQ->GPIO pin mapping function [ARM] 4792/1: S3C24XX: Remove warnings from debug-macro.S [ARM] 4791/1: S3C2412: Make fclk a parent of msysclk [ARM] 4790/1: S3C2412: Fix parent selection for msysclk. [ARM] 4789/1: S3C2412: Add missing CLKDIVN register values [ARM] 4788/1: S3C24XX: Fix paramet to s3c2410_dma_ctrl if S3C2410_DMAF_AUTOSTART used. [ARM] 4787/1: S3C24XX: s3c2410_dma_request() should return the allocated channel number [ARM] 4786/1: S3C2412: Add SPI FIFO controll constants [ARM] 4785/1: S3C24XX: Add _SHIFT definitions for S3C2410_BANKCON registers [ARM] 4784/1: S3C24XX: Fix GPIO restore glitches [ARM] 4783/1: S3C24XX: Add s3c2410_gpio_getpull() [ARM] 4782/1: S3C24XX: Define FIQ_START for any FIQ users [ARM] 4781/1: S3C24XX: DMA suspend and resume support [ARM] 4780/1: S3C2412: Allow for seperate DMA channels for TX and RX [ARM] 4779/1: S3C2412: Add s3c2412_gpio_set_sleepcfg() call [ARM] 4778/1: S3C2412: Add armclk and init from DVS state [ARM] 4777/1: S3C24XX: Ensure clk_set_rate() checks the set_rate method for the clk [ARM] 4775/1: s3c2410: fix compilation error if only s3c2442 cpu is selected ... * sa1100: [ARM] sa1100: add clock source support * vfp: [ARM] 4584/2: ARMv7: Add Advanced SIMD (NEON) extension support [ARM] 4583/1: ARMv7: Add VFPv3 support [ARM] 4582/2: Add support for the common VFP subarchitecture
2008-01-28[ARM] Fix timer damage from d3d74453c34f8fd87674a8cf5b8a327c68f22e99Russell King
Move the xtime write mode seqlock into timer_tick(), so it only surrounds the call to do_timer(). This avoids a deadlock in update_process_times() ... hrtimer_get_softirq_time() which tries to get a read mode seqlock on xtime, thereby preventing booting. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4603/1: KS8695: debugfs interface to view pin stateAndrew Victor
This patch adds a debug interface (if CONFIG_DEBUG_FS is selected) to display the basic configuration and current state of the GPIO pins on the Kendin/Micrel KS8695 processor. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] 4601/1: KS8695: PCI supportAndrew Victor
This patch adds support for the PCI Host controller integrated in the Kendin/Micrel KS8695 processor. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-08-14[ARM] 4549/1: KS8695: Fix build errorsAndrew Victor
The PCI driver has not been merged yet, so comment out call to ks8695_init_pci() for now. Also fix some incorrectly marked __init and __initdata sections. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] ks8695: no need to include linux/ptrace.hRussell King
arch/arm/mach-ks8695/irq.c doesn't need to include linux/ptrace.h so remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4377/1: KS8695: GPIO driverAndrew Victor
Driver to control the GPIO pins on the KS8695 processor. The driver natively supports the Generic GPIO interface. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4333/2: KS8695: Micrel Development boardAndrew Victor
Board support and default configuration file for the Micrel/Kendin KS8695 Development board. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] 4331/3: Support for Micrel/Kendin KS8695 processorAndrew Victor
Add core support for the Kendin/Micrel KS8695 processor family. It is an ARM922-T based SoC with integrated USART, 4-port Ethernet Switch, WAN Ethernet port, and optional PCI Host bridge, etc. http://www.micrel.com/page.do?page=product-info/sys_on_chip.jsp This patch is based on earlier patches from Lennert Buytenhek, Ben Dooks and Greg Ungerer posted to the arm-linux-kernel mailing list in March 2006; and Micrel's 2.6.9 port. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
