Tell the PCI core about host bridge address translation so it can take
care of bus-to-resource conversion for us.
CC: Russell King <linux@arm.linux.org.uk>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
into for-armsoc
Now that most platforms don't need disable_fiq and arch_ret_to_user
macros, we can remove the empty macros or empty entry-macro.S files.
Acked-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Ryan Mallon <rmallon@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Remove the unneeded duplicate include.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
When this is the only content remaining in mach/system.h then the
whole file is removed.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: David Brown <davidb@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits)
x86/PCI: Expand the x86_msi_ops to have a restore MSIs.
PCI: Increase resource array mask bit size in pcim_iomap_regions()
PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES
PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT)
PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB
x86/PCI: amd: factor out MMCONFIG discovery
PCI: Enable ATS at the device state restore
PCI: msi: fix imbalanced refcount of msi irq sysfs objects
PCI: kconfig: English typo in pci/pcie/Kconfig
PCI/PM/Runtime: make PCI traces quieter
PCI: remove pci_create_bus()
xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources
x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus()
x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented()
x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan
sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources
sparc/PCI: convert to pci_create_root_bus()
sh/PCI: convert to pci_scan_root_bus() for correct root bus resources
powerpc/PCI: convert to pci_create_root_bus()
powerpc/PCI: split PHB part out of pcibios_map_io_space()
Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due
to the same patches being applied in other branches.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits)
arm: fix up some samsung merge sysdev conversion problems
firmware: Fix an oops on reading fw_priv->fw in sysfs loading file
Drivers:hv: Fix a bug in vmbus_driver_unregister()
driver core: remove __must_check from device_create_file
debugfs: add missing #ifdef HAS_IOMEM
arm: time.h: remove device.h #include
driver-core: remove sysdev.h usage.
clockevents: remove sysdev.h
arm: convert sysdev_class to a regular subsystem
arm: leds: convert sysdev_class to a regular subsystem
kobject: remove kset_find_obj_hinted()
m86k: gpio - convert sysdev_class to a regular subsystem
mips: txx9_sram - convert sysdev_class to a regular subsystem
mips: 7segled - convert sysdev_class to a regular subsystem
sh: dma - convert sysdev_class to a regular subsystem
sh: intc - convert sysdev_class to a regular subsystem
power: suspend - convert sysdev_class to a regular subsystem
power: qe_ic - convert sysdev_class to a regular subsystem
power: cmm - convert sysdev_class to a regular subsystem
s390: time - convert sysdev_class to a regular subsystem
Fix up conflicts with 'struct sysdev' removal from various platform
drivers that got changed:
- arch/arm/mach-exynos/cpu.c
- arch/arm/mach-exynos/irq-eint.c
- arch/arm/mach-s3c64xx/common.c
- arch/arm/mach-s3c64xx/cpu.c
- arch/arm/mach-s5p64x0/cpu.c
- arch/arm/mach-s5pv210/common.c
- arch/arm/plat-samsung/include/plat/cpu.h
- arch/powerpc/kernel/sysfs.c
and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus
resource fixups. This fixes the problem of "early" and "header" quirks
seeing incorrect root bus resources.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
The changes to arch/arm/mach-exynos/cpu.c were moved to
mach-exynos/common.c.
Remove the now empty arch_reset() from all the mach/system.h includes,
and remove its callsite. Remove arm_machine_restart() as this function
no longer does anything useful.
For samsung platforms, remove the include of mach/system-reset.h and
plat/system-reset.h from their respective mach/system.h headers as these
just define their arch_reset functions. As a result, the s3c2410 and
plat-samsung system-reset.h files are no longer referenced, so remove
these files entirely.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
The sysdev.h file should not be needed by any in-kernel code, so remove
the .h file from these random files that seem to still want to include
it.
The sysdev code will be going away soon, so this include needs to be
removed no matter what.
Cc: Jiandong Zheng <jdzheng@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: "Venkatesh Pallipadi
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
devel-stable
We only need to set the system up for a soft-restart if we're going to
be doing a soft-restart. Provide a new function (soft_restart()) which
does the setup and final call for this, and make platforms use it.
Eliminate the call to setup_restart() from the default handler.
This means that platforms arch_reset() function is no longer called with
the page tables prepared for a soft-restart, and caches will still be
enabled.
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Krzysztof Ha■asa <khc@pm.waw.pl>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
* 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits)
ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h>
ARM: 7104/1: plat-pxa: break out GPIO driver specifics
ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem
ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics
ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h>
ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h
ARM: 7083/1: rewrite U300 GPIO to use gpiolib
ARM: 7074/1: gpio: davinci: eliminate unused variable warnings
ARM: 7063/1: Orion: gpio: add missing include of linux/types.h
ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build
ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio
ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq
ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio
ARM: 7057/1: mach-pnx4008: rename GPIO header
ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h>
ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function
ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem
ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics
ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem
ARM: 7043/1: mach-ixp2000: rename GPIO header
Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
Boards used to specify zreladdr in their Makefile.boot with
zreladdr-y := x, so conflicting zreladdrs were silently overwritten.
This patch changes this to zreladdr-y += x, so that we end
up with multiple words in zreladdr in such a case. We can
detect this later and complain if necessary.
Some platforms (like OMAP not to name it) are doing rather complicated
hacks just to determine the base UART address to use. Let's give their
addruart macro some slack by providing an extra work register which will
allow for much needed cleanups.
This is basically a no-op as this commit is only adding the extra argument
to the macro but no one is using it yet.
Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Enabling the LEDs on the ks8695 doesn't even compile, fix it with
a proper include and also replace a <mach/gpio.h> with the proper
<linux/gpio.h>.
Cc: zeal <zealcook@gmail.com>
Acked-by: Daniel Silverstone <dsilvers@simtec.co.uk>
Acked-by: Simtec Linux Team <linux@simtec.co.uk>
The <mach/gpio.h> file is included from upper directories
and deal with generic GPIO and gpiolib stuff. Break out the
platform and driver specific defines and functions into its own
header file.
As per example from the other ARM boards, push the KS8695 GPIO
driver down to the GPIO subsystem so it can be consolidated.
Rather than marking the mach/gpio.h header files which want to use the
trivial GPIOLIB implementation, mark those which do not want to use it
instead. This means that by default, you get the trivial implementation
and only have to do something extra if you need to. This should
encourage the use of the trivial default implementation.
As an additional bonus, several gpio.h header files become empty.
Tested-by: Jamie Iles <jamie@jamieiles.com>
Many of the gpio_to_irq implementations use the gpiolib version of this
function. Provide the standard gpiolib gpio_to_irq() for everyone, but
allow platforms to override it if they wish. Add the neccessary
overrides for those platforms which do not use the standard definition.
Consolidate 24 trivial gpiolib implementions out of mach/gpio.h
into asm/gpio.h. This is basically the include of asm-generic/gpio.h
and the definition of gpio_get_value, gpio_set_value, and gpio_cansleep
as described in Documentation/gpio.txt
Tested-by: David Brown <davidb@codeaurora.org>
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: remove printks about disabled bridge windows
PCI: fold pci_calc_resource_flags() into decode_bar()
PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR
PCI: correct pcie_set_readrq write size
PCI: pciehp: change wait time for valid configuration access
x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems
PCI: ARI is a PCIe v2 feature
x86/PCI: quirks: Use pci_dev->revision
PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.
PCI hotplug: cpqphp: use pci_dev->vendor
PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device}
x86/PCI: config space accessor functions should not ignore the segment argument
PCI: Assign values to 'pci_obff_signal_type' enumeration constants
x86/PCI: reduce severity of host bridge window conflict warnings
PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI
PCI: PCIe AER: add aer_recover_queue
x86/PCI: select direct access mode for mmconfig option
PCI hotplug: Rename is_ejectable which also exists in dock.c
Aside of the usual motivation for constification, this function has a
history of being abused a hook for interrupt and other fixups so I turned
this function const ages ago in the MIPS code but it should be done
treewide.
Due to function pointer passing in varous places a few other functions
had to be constified as well.
To: Anton Vorontsov <avorontsov@mvista.com>
To: Chris Metcalf <cmetcalf@tilera.com>
To: Colin Cross <ccross@android.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
To: Eric Miao <eric.y.miao@gmail.com>
To: Erik Gilling <konkers@android.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
To: "H. Peter Anvin" <hpa@zytor.com>
To: Imre Kaloz <kaloz@openwrt.org>
To: Ingo Molnar <mingo@redhat.com>
To: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
To: Jesse Barnes <jbarnes@virtuousgeek.org>
To: Krzysztof Halasa <khc@pm.waw.pl>
To: Lennert Buytenhek <kernel@wantstofly.org>
To: Matt Turner <mattst88@gmail.com>
To: Nicolas Pitre <nico@fluxnic.net>
To: Olof Johansson <olof@lixom.net>
To: Richard Henderson <rth@twiddle.net>
To: Russell King <linux@arm.linux.org.uk>
To: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-pci@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: x86@kernel.org
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow
multi-platform builds. This also removes the requirement for a platform to
have a mach/hardware.h.
The default values for i/o and mem are 0x1000 and 0x01000000, respectively.
Per Arnd Bergmann, other values are likely to be incorrect, but this commit
does not try to address that issue.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Convert pcibios_assign_all_busses from a define to inline so platforms can
control this setting.
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Convert to the new function names. Automated with coccinelle.
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
Replace the page_to_dma() and dma_to_page() macros with their PFN
equivalents. This allows us to map parts of memory which do not have
a struct page allocated to them to bus addresses. This will be used
internally by dma_alloc_coherent()/dma_alloc_writecombine().
Build tested on Versatile, OMAP1, IOP13xx and KS8695.
Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Today more boards with arm cpu have selectable pci bus.
This patch makes this more scalable and remove line continuations in
Kconfig
Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
Rather than checking the MMU status in every instance of addruart, do it
once in kernel/debug.S, and change the existing addruart macros to
return both physical and virtual addresses. The main debug code can then
select the appropriate address to use.
This will also allow us to retreive the address of a uart for the MMU
state that we're not current in.
Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com>
and Tony Lindgren <tony@atomide.com>, and fix for versatile express from
Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Jason Wang <jason77.wang@gmail.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Add one more parameter to hook_fault_code() to be able to set 'code'
field of struct fsr_info.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
Tested-By: Jamie Iles <jamie@jamieiles.com>
NOTE:
1. Macro style is so strange.
2. The value 0xc0 is not match with KS8695 manual. It should be 0x0c.
Signed-off-by: zeal <zealcook@gmail.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
Stop referencing CLOCK_TICK_RATE in the KS8695 drivers, rather refer
to a KS8695_CLOCK_RATE.
Issue pointed out by Russell King on arm-linux-kernel mailing list.
Signed-off-by: Andrew Victor <linux@maxim.org.za>
Make software reset to avoid freeze if PCI bus was messed up
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
OMAP wishes to pass state to the boot loader upon reboot in order to
instruct it whether to wait for USB-based reflashing or not. There is
already a facility to do this via the reboot() syscall, except we ignore
the string passed to machine_restart().
This patch fixes things to pass this string to arch_reset(). This means
that we keep the reboot mode limited to telling the kernel _how_ to
perform the reboot which should be independent of what we request the
boot loader to do.
If a machine class has a custom __virt_to_bus() implementation then it
must provide a __arch_page_to_dma() implementation as well which is
_not_ based on page_address() to support highmem.
This patch fixes existing __arch_page_to_dma() and provide a default
implementation otherwise. The default implementation for highmem is
based on __pfn_to_bus() which is defined only when no custom
__virt_to_bus() is provided by the machine class.
That leaves only ebsa110 and footbridge which cannot support highmem
until they provide their own __arch_page_to_dma() implementation.
But highmem support on those legacy platforms with limited memory is
certainly not a priority.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
This patch provides the core board support for the Brivo Systems
LLC ACS-5000 master board for automated door/card-reader etc
management.
Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk>
Signed-off-by: Vincent Sanders <vince@simtec.co.uk>
pxa, s3c
arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function)
arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function)
arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function)
arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function)
arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function)
arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function)
arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB'
arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function)
arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function)
arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function)
arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function)
arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function)
arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function)
arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function)
arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction'
arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function)
arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function)
arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function)
arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function)
