path: root/arch/arm/mach-ks8695
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2013-01-03ARM: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-07Merge branch 'late/fixes' into fixesOlof Johansson
This is a series from Arnd that fixes a number of compiler warnings when building defconfigs on ARM. * late/fixes: ARM: footbridge: nw_gpio_lock is raw_spin_lock ARM: mv78xx0: correct addr_map_cfg __initdata annotation ARM: footbridge: remove RTC_IRQ definition ARM: soc: dependency warnings for errata ARM: ks8695: __arch_virt_to_dma type handling ARM: rpc: check device_register return code in ecard_probe ARM: davinci: don't mark da850_register_cpufreq as __init ARM: iop13xx: fix iq81340sc_atux_map_irq prototype ARM: iop13xx: mark iop13xx_scan_bus as __devinit ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok ARM: s3c24xx: fix multiple section mismatch warnings ARM: at91: unused variable in at91_pm_verify_clocks ARM: at91: skip at91_io_desc definition for NOMMU ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM ARM: pxa: remove sharpsl_fatal_check function ARM: pxa: define palmte2_pxa_keys conditionally ARM: pxa: Wunused-result warning in viper board file ARM: shark: fix shark_pci_init return code Fixed trivial conflicts in arch/arm/mach-at91/setup.c. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-10-07ARM: ks8695: __arch_virt_to_dma type handlingArnd Bergmann
__arch_virt_to_dma expects a virtual address pointer, but the ks8695 implementation of this macro treats it as an integer. Adding a type cast avoids hundreds of identical warning messages. Without this patch, building acs5k_defconfig results in: arch/arm/include/asm/dma-mapping.h: In function 'virt_to_dma': arch/arm/include/asm/dma-mapping.h:60:2: warning: passing argument 1 of '__virt_to_phys' makes integer from pointer without a cast [enabled by default] arch/arm/include/asm/memory.h:172:60: note: expected 'long unsigned int' but argument is of type 'void *' In file included from include/linux/dma-mapping.h:73:0, from include/linux/skbuff.h:33, from security/commoncap.c:21: Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Daniel Silverstone <dsilvers@simtec.co.uk> Cc: Ben Dooks <ben-linux@fluff.org>
2012-10-01Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc board specific updates from Olof Johansson: "Misc board updates: - Greg added a handful of boards to KS8695 (since he has stepped up to maintain it). - Qualcomm has added DT-only board support for a couple of their newer SoCs. - misc other updates for Samsung and Freescale boards." Fix up trivial conflict in arch/arm/mach-shmobile/board-armadillo800eva.c due to gpio device data being added next to hdmi device data that got moved. * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: msm: Allow 8960 and 8660 to compile together ARM: msm: Allow msm_iomap-8x60 and msm_iomap-8960 to coexist ARM: EXYNOS: Add generic PWM lookup support for SMDKV310 ARM: EXYNOS: Add generic PWM lookup support for SMDK4X12 ARM: EXYNOS: Use generic pwm driver in Origen board ARM: shmobile: armadillo800eva: Add support RTC ARM: ks8695: add board support for the OpenGear boards based on the KS8695 ARM: ks8695: add board support for the SnapGear boards based on the KS8695 ARM: dts: Add heartbeat gpio-leds support to Origen ARM: dts: Use active low flag for gpio-keys on Origen ARM: shmobile: marzen: enable thermal sensor ARM: shmobile: marzen: fixup regulator id for smsc911x ARM: shmobile: marzen: add SDHI0 support ARM: mmp: enable debug uart port in defconfig ARM: mmp: implement DEBUG_LL port choice ARM: S3C64XX: Register audio platform devices for Bells on Cragganmore ARM: S3C64XX: Update configuration for WM5102 module on Cragganmore ARM: mx27pdk: Add audio support ARM: ttc_dkb: add nand support
2012-10-01Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc driver specific changes from Olof Johansson: - A long-coming conversion of various platforms to a common LED infrastructure - AT91 is moved over to use the newer MCI driver for MMC - Pincontrol conversions for samsung platforms - DT bindings for gscaler on samsung - i2c driver fixes for tegra, acked by i2c maintainer Fix up conflicts as per Olof. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) drivers: bus: omap_l3: use resources instead of hardcoded irqs pinctrl: exynos: Fix wakeup IRQ domain registration check pinctrl: samsung: Uninline samsung_pinctrl_get_soc_data pinctrl: exynos: Correct the detection of wakeup-eint node pinctrl: exynos: Mark exynos_irq_demux_eint as inline pinctrl: exynos: Handle only unmasked wakeup interrupts pinctrl: exynos: Fix typos in gpio/wkup _irq_mask pinctrl: exynos: Set pin function to EINT in irq_set_type of GPIO EINTa drivers: bus: Move the OMAP interconnect driver to drivers/bus/ i2c: tegra: dynamically control fast clk i2c: tegra: I2_M_NOSTART functionality not supported in Tegra20 ARM: tegra: clock: remove unused clock entry for i2c ARM: tegra: clock: add connection name in i2c clock entry i2c: tegra: pass proper name for getting clock ARM: tegra: clock: add i2c fast clock entry in clock table ARM: EXYNOS: Adds G-Scaler device from Device Tree ARM: EXYNOS: Add clock support for G-Scaler ARM: EXYNOS: Enable pinctrl driver support for EXYNOS4 device tree enabled platform ARM: dts: Add pinctrl node entries for SAMSUNG EXYNOS4210 SoC ARM: EXYNOS: skip wakeup interrupt setup if pinctrl driver is used ...
2012-09-22Merge branch 'cleanup/__iomem' into next/cleanupOlof Johansson
__iomem annotation cleanup branch from Arnd. * cleanup/__iomem: (21 commits) net: seeq: use __iomem pointers for MMIO video: da8xx-fb: use __iomem pointers for MMIO scsi: eesox: use __iomem pointers for MMIO serial: ks8695: use __iomem pointers for MMIO input: rpcmouse: use __iomem pointers for MMIO ARM: samsung: use __iomem pointers for MMIO ARM: spear13xx: use __iomem pointers for MMIO ARM: sa1100: use __iomem pointers for MMIO ARM: prima2: use __iomem pointers for MMIO ARM: nomadik: use __iomem pointers for MMIO ARM: msm: use __iomem pointers for MMIO ARM: lpc32xx: use __iomem pointers for MMIO ARM: ks8695: use __iomem pointers for MMIO ARM: ixp4xx: use __iomem pointers for MMIO ARM: iop32x: use __iomem pointers for MMIO ARM: iop13xx: use __iomem pointers for MMIO ARM: integrator: use __iomem pointers for MMIO ARM: imx: use __iomem pointers for MMIO ARM: ebsa110: use __iomem pointers for MMIO ARM: at91: use __iomem pointers for MMIO ... Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-19ARM: ks8695: use __iomem pointers for MMIOArnd Bergmann
ARM is moving to stricter checks on readl/write functions, so we need to use the correct types everywhere. Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-09-07Merge branch 'ks8695/boards' into next/boardsOlof Johansson
* ks8695/boards: ARM: ks8695: add board support for the OpenGear boards based on the KS8695 ARM: ks8695: add board support for the SnapGear boards based on the KS8695
2012-09-07ARM: ks8695: add board support for the OpenGear boards based on the KS8695Greg Ungerer
A number of boards produced by OpenGear and based on the Micrel KS8695 SoC. Add board support to the KS8695 kernel code to support them. The following machine type entries will need to be added back into the mach-types file with these in mainline: cm4008 MACH_CM4008 CM4008 624 cm41xx MACH_CM41XX CM41XX 672 cm4002 MACH_CM4002 CM4002 876 im42xx MACH_IM42XX IM42XX 1105 im4004 MACH_IM4004 IM4004 1400 Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-07ARM: ks8695: add board support for the SnapGear boards based on the KS8695Greg Ungerer
A number of boards produced by SnapGear are based on the Micrel KS8695 SoC. Add board support to the KS8695 kernel code to support them. The following machine type entries will need to be added back into the mach-types file with these in mainline: lite300 MACH_LITE300 LITE300 408 se4200 MACH_SE4200 SE4200 809 sg310 MACH_SG310 SG310 1564 Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-05ARM: ks8695: convert to generic time and clocksourceLinus Walleij
Old platforms using ancient gettimeoffset() and other arcane APIs are standing in the way of cleaning up the ARM kernel. The gettimeoffset() was also broken: it would try to read out the timer counter value, while this would not work (the counter statically returns the initially programmed value) so the implementation would anyway fall back to a homebrew version of jiffie calculation. This is an attempt at blind-coding a generic time and clocksource driver for the platform by way of a datasheet and looking at the old code. Tested-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-05ARM: ks8695: delete resume hook from timerLinus Walleij
This system does not support suspend/resume so let's skip this hook altogether. Tested-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-05ARM: ks8695: use [readl|writel]_relaxed()Linus Walleij
I have no clue why __raw* macros are used here, but I strongly suspect there is no good reason at all for this, so removing another bad example. Tested-by: Greg Ungerer <gerg@snapgear.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-05ARM: ks8695: merge the timer header into the timer driverLinus Walleij
This <mach/regs-timer.h> is broadcasted in the entire kernel for no good reason, since it's only used by the timer driver. Merge it into the driver. Tested-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-08-01ARM: mach-ks8695: remove leds driver, since nobody use itBryan Wu
Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Acked-by: Andrew Victor <linux@maxim.org.za>
2012-05-13ARM: PCI: provide a default bus scan implementationRussell King
Most PCI implementations perform simple root bus scanning. Rather than having each group of platforms provide a duplicated bus scan function, provide the PCI configuration ops structure via the hw_pci structure, and call the root bus scanning function from core ARM PCI code. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-13ARM: PCI: get rid of pci_std_swizzle()Russell King
Most PCI implementations use the standard PCI swizzle function, which handles the well defined behaviour of PCI-to-PCI bridges which can be found on cards (eg, four port ethernet cards.) Rather than having almost every platform specify the standard swizzle function, make this the default when no swizzle function is supplied. Therefore, a swizzle function only needs to be provided when there is something exceptional which needs to be handled. This gets rid of the swizzle initializer from 47 files, and leaves us with just two platforms specifying a swizzle function: ARM Integrator and Chalice CATS. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-03-23Merge branch 'for-armsoc' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #1 ARM updates from Russell King: "This one covers stuff which Arnd is waiting for me to push, as this is shared between both our trees and probably other trees elsewhere. Essentially, this contains: - AMBA primecell device initializer updates - mostly shrinking the size of the device declarations in platform code to something more reasonable. - Getting rid of the NO_IRQ crap from AMBA primecell stuff. - Nicolas' idle cleanups. This in combination with the restart cleanups from the last merge window results in a great many mach/system.h files being deleted." Yay: ~80 files, ~2000 lines deleted. * 'for-armsoc' of git://git.linaro.org/people/rmk/linux-arm: (60 commits) ARM: remove disable_fiq and arch_ret_to_user macros ARM: make entry-macro.S depend on !MULTI_IRQ_HANDLER ARM: rpc: make default fiq handler run-time installed ARM: make arch_ret_to_user macro optional ARM: amba: samsung: use common amba device initializers ARM: amba: spear: use common amba device initializers ARM: amba: nomadik: use common amba device initializers ARM: amba: u300: use common amba device initializers ARM: amba: lpc32xx: use common amba device initializers ARM: amba: netx: use common amba device initializers ARM: amba: bcmring: use common amba device initializers ARM: amba: ep93xx: use common amba device initializers ARM: amba: omap2: use common amba device initializers ARM: amba: integrator: use common amba device initializers ARM: amba: realview: get rid of private platform amba_device initializer ARM: amba: versatile: get rid of private platform amba_device initializer ARM: amba: vexpress: get rid of private platform amba_device initializer ARM: amba: provide common initializers for static amba devices ARM: amba: make use of -1 IRQs warn ARM: amba: u300: get rid of NO_IRQ initializers ...
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-06ARM: remove bunch of now unused mach/io.h filesRob Herring
Now that many platforms don't need mach/io.h, remove the unused ones. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-02-23arm/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-02-10ARM, KS8695: Only include linux/gpio.h once in arch/arm/mach-ks8695/leds.cJesper Juhl
Remove the unneeded duplicate include. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-20ARM: big removal of now unused arch_idle()Nicolas Pitre
When this is the only content remaining in mach/system.h then the whole file is removed. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits) x86/PCI: Expand the x86_msi_ops to have a restore MSIs. PCI: Increase resource array mask bit size in pcim_iomap_regions() PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT) PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB x86/PCI: amd: factor out MMCONFIG discovery PCI: Enable ATS at the device state restore PCI: msi: fix imbalanced refcount of msi irq sysfs objects PCI: kconfig: English typo in pci/pcie/Kconfig PCI/PM/Runtime: make PCI traces quieter PCI: remove pci_create_bus() xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus() x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented() x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources sparc/PCI: convert to pci_create_root_bus() sh/PCI: convert to pci_scan_root_bus() for correct root bus resources powerpc/PCI: convert to pci_create_root_bus() powerpc/PCI: split PHB part out of pcibios_map_io_space() ... Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due to the same patches being applied in other branches.
2012-01-07Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits) arm: fix up some samsung merge sysdev conversion problems firmware: Fix an oops on reading fw_priv->fw in sysfs loading file Drivers:hv: Fix a bug in vmbus_driver_unregister() driver core: remove __must_check from device_create_file debugfs: add missing #ifdef HAS_IOMEM arm: time.h: remove device.h #include driver-core: remove sysdev.h usage. clockevents: remove sysdev.h arm: convert sysdev_class to a regular subsystem arm: leds: convert sysdev_class to a regular subsystem kobject: remove kset_find_obj_hinted() m86k: gpio - convert sysdev_class to a regular subsystem mips: txx9_sram - convert sysdev_class to a regular subsystem mips: 7segled - convert sysdev_class to a regular subsystem sh: dma - convert sysdev_class to a regular subsystem sh: intc - convert sysdev_class to a regular subsystem power: suspend - convert sysdev_class to a regular subsystem power: qe_ic - convert sysdev_class to a regular subsystem power: cmm - convert sysdev_class to a regular subsystem s390: time - convert sysdev_class to a regular subsystem ... Fix up conflicts with 'struct sysdev' removal from various platform drivers that got changed: - arch/arm/mach-exynos/cpu.c - arch/arm/mach-exynos/irq-eint.c - arch/arm/mach-s3c64xx/common.c - arch/arm/mach-s3c64xx/cpu.c - arch/arm/mach-s5p64x0/cpu.c - arch/arm/mach-s5pv210/common.c - arch/arm/plat-samsung/include/plat/cpu.h - arch/powerpc/kernel/sysfs.c and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
2012-01-06arm/PCI: convert to pci_scan_root_bus() for correct root bus resourcesBjorn Helgaas
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus resource fixups. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: remove the now empty arch_reset()Russell King
Remove the now empty arch_reset() from all the mach/system.h includes, and remove its callsite. Remove arm_machine_restart() as this function no longer does anything useful. For samsung platforms, remove the include of mach/system-reset.h and plat/system-reset.h from their respective mach/system.h headers as these just define their arch_reset functions. As a result, the s3c2410 and plat-samsung system-reset.h files are no longer referenced, so remove these files entirely. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-05ARM: restart: ks8695: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-21driver-core: remove sysdev.h usage.Kay Sievers
The sysdev.h file should not be needed by any in-kernel code, so remove the .h file from these random files that seem to still want to include it. The sysdev code will be going away soon, so this include needs to be removed no matter what. Cc: Jiandong Zheng <jdzheng@broadcom.com> Cc: Scott Branden <sbranden@broadcom.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: "Venkatesh Pallipadi Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2011-12-05Merge branch 'vmalloc' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-11-26ARM: big removal of now unused vmalloc.h filesNicolas Pitre
2011-11-21ARM: restart: only perform setup for restart when soft-restartingRussell King
We only need to set the system up for a soft-restart if we're going to be doing a soft-restart. Provide a new function (soft_restart()) which does the setup and final call for this, and make platforms use it. Eliminate the call to setup_restart() from the default handler. This means that platforms arch_reset() function is no longer called with the page tables prepared for a soft-restart, and caches will still be enabled. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Krzysztof Ha■asa <khc@pm.waw.pl> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-27Merge branch 'gpio' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits) ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h> ARM: 7104/1: plat-pxa: break out GPIO driver specifics ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h> ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h ARM: 7083/1: rewrite U300 GPIO to use gpiolib ARM: 7074/1: gpio: davinci: eliminate unused variable warnings ARM: 7063/1: Orion: gpio: add missing include of linux/types.h ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio ARM: 7057/1: mach-pnx4008: rename GPIO header ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h> ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem ARM: 7043/1: mach-ixp2000: rename GPIO header ... Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-08-22ARM: 7037/1: mach-ks8695: fix GPIO LEDsLinus Walleij
Enabling the LEDs on the ks8695 doesn't even compile, fix it with a proper include and also replace a <mach/gpio.h> with the proper <linux/gpio.h>. Cc: zeal <zealcook@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Daniel Silverstone <dsilvers@simtec.co.uk> Acked-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-22ARM: 7036/1: mach-ks8695: break out GPIO driver specificsLinus Walleij
The <mach/gpio.h> file is included from upper directories and deal with generic GPIO and gpiolib stuff. Break out the platform and driver specific defines and functions into its own header file. Cc: zeal <zealcook@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Daniel Silverstone <dsilvers@simtec.co.uk> Acked-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-22ARM: 7035/1: mach-ks8695: move GPIO driver to GPIO subsystemLinus Walleij
As per example from the other ARM boards, push the KS8695 GPIO driver down to the GPIO subsystem so it can be consolidated. Cc: zeal <zealcook@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Daniel Silverstone <dsilvers@simtec.co.uk> Acked-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-21ARM: mach-ks8695: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
