* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (278 commits)
arm: remove machine_desc.io_pg_offst and .phys_io
arm: use addruart macro to establish debug mappings
arm: return both physical and virtual addresses from addruart
arm/debug: consolidate addruart macros for CONFIG_DEBUG_ICEDCC
ARM: make struct machine_desc definition coherent with its comment
eukrea_mbimxsd-baseboard: Pass the correct GPIO to gpio_free
cpuimx27: fix compile when ULPI is selected
mach-pcm037_eet: fix compile errors
Fixing ethernet driver compilation error for i.MX31 ADS board
cpuimx51: update board support
mx5: add cpuimx51sd module and its baseboard
iomux-mx51: fix GPIO_1_xx 's IOMUX configuration
imx-esdhc: update devices registration
mx51: add resources for SD/MMC on i.MX51
iomux-mx51: fix SD1 and SD2's iomux configuration
clock-mx51: rename CLOCK1 to CLOCK_CCGR for better readability
clock-mx51: factorize clk_set_parent and clk_get_rate
eukrea_mbimxsd: add support for DVI displays
cpuimx25 & cpuimx35: fix OTG port registration in host mode
i.MX31 and i.MX35 : fix errate TLSbo65953 and ENGcm09472
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
This patch adds spi->mode support for the AMBA pl022 driver and
allows spidev to correctly alter SPI modes. Unused fields used in
the pl022 header file for the pl022_config_chip have been removed.
The ab8500 client driver selects the data transfer size instead
of the platform data.
For platforms that use the amba pl022 driver, the unused fields
in the controller data structure have been removed and the .mode
field in the SPI board info structure is used instead.
Signed-off-by: Kevin Wells <wellsk40@gmail.com>
Tested-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Platform support file for the PHY3250 mach id
