path: root/arch/arm/mach-lpc32xx
2017-05-24ARM/dmaengine: pl08x: pass reasonable memcpy settingsLinus Walleij
We cannot use bits from configuration registers as API between platforms and driver like this, abstract it out to two enums and mimic the stuff passed as device tree data. This is done to make it possible for the driver to generate the ccfg word on-the-fly so we can support more PL08x derivatives. Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-12-15Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "These are updates for platform specific code on 32-bit ARM machines, essentially anything that can not (yet) be expressed using DT files. Noteworthy changes include: - Added support for the TI DRA71x family of SoCs in mach-omap2, this is an new variant of the the DRA72x/DRA74x automotive infotainment chips we already supported for a while. - Added support for the ST STM32F746 SoC, the first Cortex-M7 based microcontroller we support, related to the smaller STM32F4 family. - Renesas adds support for r8a7743 and r8a7745 in mach-shmobile, see http://elinux.org/RZ-G - SMP is now supported on the OX820 platform - A lot of code in mach-omap2 gets removed as a follow-up to removing support for board files in the previous release - Davinci has some new work to improve USB support - For i.MX, the performance monitor now supports profiling the memory controller using 'perf'" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (95 commits) ARM: davinci: da830-evm: use gpio descriptor for mmc pins ARM: davinci: da850-evm: use gpio descriptor for mmc pins ARM: davinci: hawk: use gpio descriptor for mmc pins ARM: ARTPEC-6: add select MFD_SYSCON to MACH_ARTPEC6 ARM: davinci: da8xx: Fix ohci device name ARM: oxnas: Add OX820 config and makefile entry ARM: oxnas: Add OX820 SMP support ARM: davinci: PM: fix build when da850 not compiled in ARM: orion5x: remove legacy support of ls-chl ARM: integrator: drop EBI access use syscon ARM: BCM5301X: Add back handler ignoring external imprecise aborts ARM: davinci: PM: support da8xx DT platforms ARM: davinci: PM: cleanup: remove references to pdata ARM: davinci: PM: rework init, remove platform device ARM: Kconfig: Introduce MACH_STM32F746 flag ARM: mach-stm32: Add a new SOC - STM32F746 ARM: shmobile: document SK-RZG1E board ARM: shmobile: r8a7745: basic SoC support ARM: imx: mach-imx6ul: add imx6ull support ARM: zynq: Reserve correct amount of non-DMA RAM ...
2016-11-26ARM: lpc32xx: drop duplicate header device.hGeliang Tang
Drop duplicate header device.h from phy3250.c. Signed-off-by: Geliang Tang <geliangtang@gmail.com> Reviewed-by: Sylvain Lemieux <slemieux.tyco@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-10-25ARM: lpc32xx: remove unused header file clock.hVladimir Zapolskiy
The removed clock.h file is a leftover after moving the platform to a common clock framework driver, it contains unused "struct clk" definition, which under circumstances may coalesce with a generic "struct clk" declaration for clock consumers. Also remove useless include of the removed local file from a single source file mach-lpc32xx/pm.c. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Sylvain Lemieux <slemieux.tyco@gmail.com>
2016-10-25ARM: lpc32xx: remove unused header file mach/irqs.hVladimir Zapolskiy
The removed LPC32xx mach/irqs.h file is not included in any source code, function declaration lpc32xx_init_irq() is also unused, remove them as leftovers after switching to a new interrupt controller driver. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Sylvain Lemieux <slemieux.tyco@gmail.com>
2016-06-23arm: use of_platform_default_populate() to populateKefeng Wang
Use helper of_platform_default_populate() in linux/of_platform when possible, instead of calling of_platform_populate() with the default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Ray Jui <rjui@broadcom.com> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Rob Herring <robh@kernel.org> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-05-24ARM: lpc32xx: fix NR_IRQS confictArnd Bergmann
With the change to sparse IRQs, the lpc32xx platform gets a warning about conflicting macros: In file included from arch/arm/mach-lpc32xx/irq.c:31:0: arch/arm/mach-lpc32xx/include/mach/irqs.h:115:0: warning: "NR_IRQS" redefined #define NR_IRQS 96 arch/arm/include/asm/irq.h:9:0: note: this is the location of the previous definition #define NR_IRQS NR_IRQS_LEGACY One such instance was in the old irq driver that is now removed by the previous patch, but any other file including mach/irqs.h still has the issue. Since none of them use this constant, we can just remove the old definition. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 8cb17b5ed017 ("irqchip: Add LPC32xx interrupt controller driver")
2016-05-24ARM: lpc32xx: remove legacy irq controller driverVladimir Zapolskiy
New NXP LPC32xx irq chip driver is used instead of a legacy one. [this also fixes a harmless build warning about the NR_IRQS redefinition] Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-05-18Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "We get support for three new 32-bit SoC platforms this time. The amount of changes in arch/arm for any of them is miniscule, as all the interesting code is in device driver subsystems (irqchip, clk, pinctrl, ...) these days. I'm listing them here, as the addition of the Kconfig statement is the main relevant milestone for a new platform. In each case, some drivers are are shared with existing platforms, while other drivers are added for v4.7 as well, or come in a later release. - The Aspeed platform is probably the most interesting one, this is what most whitebox servers use as their baseboard management controller. We get support for the very common ast2400 and ast2500 SoCs. The OpenBMC project focuses on this chip, and the LWN article about their ELC 2016 presentation at https://lwn.net/Articles/683320/ triggered the submission, but the code comes from IBM's OpenPOWER team rather than the team at Facebook. There are still a lot more drivers that need to get added over time, and I hope both teams can work together on that. - OXNAS is an old platform for Network Attached Storage devices from Oxford Semiconductor. There are models with ARM10 (!) and ARM11MPCore cores, but for now, we only support the original ARM9 based versions. The product lineup was subsequently part of PLX, Avago and now the new Broadcom Ltd. https://wiki.openwrt.org/doc/hardware/soc/soc.oxnas has some more information. - V2M-MPS2 is a prototyping platform from ARM for their Cortex-M cores and is related to the existing Realview / Versatile Express lineup, but without MMU. We now support various NOMMU platforms, so adding a new one is fairly straightforward. http://infocenter.arm.com/help/topic/com.arm.doc.100112_0100_03_en/ has detailed information about the platform. Other noteworthy updates: - Work on LPC32xx has resumed, and Vladimir Zapolskiy and Sylvain Lemieux are now maintaining the platform. This is an older ARM9 based platform from NXP (not Freescale), but it remains in use in embedded markets. - Kevin Hilman is now co-maintaining the Amlogic Meson platform for both 32-bit and 64-bit ARM, and started contributing some patches. - As is often the case, work on the OMAP platforms makes up the bulk of the actual SoC code changes in arch/arm, but there isn't a lot of that either" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits) MAINTAINERS: ARM/Amlogic: add co-maintainer, misc. updates MAINTAINERS: add ARM/NXP LPC32XX SoC specific drivers to the section MAINTAINERS: add new maintainers of NXP LPC32xx SoC MAINTAINERS: move ARM/NXP LPC32xx record to ARM section arm: Add Aspeed machine ARM: lpc32xx: remove duplicate const on lpc32xx_auxdata_lookup ARM: lpc32xx: remove leftovers of legacy clock source and provider drivers ARM: lpc32xx: remove reboot header file ARM: dove: Remove CLK_IS_ROOT ARM: orion5x: Remove CLK_IS_ROOT ARM: mv78xx0: Remove CLK_IS_ROOT ARM: davinci: da850: use clk->set_parent for async3 ARM: davinci: Move clock init after ioremap. MAINTAINERS: Update ARM Versatile Express platform entry ARM: vexpress/mps2: introduce MPS2 platform MAINTAINERS: add maintainer entry for ARM/OXNAS platform ARM: Add new mach-oxnas irqchip: versatile-fpga: add new compatible for OX810SE SoC ARM: uniphier: correct the call order of of_node_put() MAINTAINERS: fix stale TI DaVinci entries ...
2016-05-11irqchip: Add LPC32xx interrupt controller driverVladimir Zapolskiy
The change adds improved support of NXP LPC32xx MIC, SIC1 and SIC2 interrupt controllers. This is a list of new features in comparison to the legacy driver: * irq types are taken from device tree settings, no more need to hardcode them, * old driver is based on irq_domain_add_legacy, which causes problems with handling MIC hardware interrupt 0 produced by SIC1, * there is one driver for MIC, SIC1 and SIC2, no more need to handle them separately, e.g. have two separate handlers for SIC1 and SIC2, * the driver does not have any dependencies on hardcoded register offsets, * the driver is much simpler for maintenance, * SPARSE_IRQS option is supported. Legacy LPC32xx interrupt controller driver was broken since commit 76ba59f8366f ("genirq: Add irq_domain-aware core IRQ handler"), which requires a private interrupt handler, otherwise any SIC1 generated interrupt (mapped to MIC hwirq 0) breaks the kernel with the message "unexpected IRQ trap at vector 00". The change disables compilation of a legacy driver found at arch/arm/mach-lpc32xx/irq.c, the file will be removed in a separate commit. Fixes: 76ba59f8366f ("genirq: Add irq_domain-aware core IRQ handler") Tested-by: Sylvain Lemieux <slemieux.tyco@gmail.com> Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2016-04-28ARM: lpc32xx: remove duplicate const on lpc32xx_auxdata_lookupVladimir Zapolskiy
Remove redundant duplicate const, which is found by smatch: arch/arm/mach-lpc32xx/phy3250.c:162:42: warning: duplicate const Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com> Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-04-28ARM: lpc32xx: remove leftovers of legacy clock source and provider driversVladimir Zapolskiy
After switching the platform to common clock framework there is no more need to keep dead code in arch/arm/mach-lpc32xx, which glued legacy clock source and clock provider drivers, remove the leftovers. Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com> Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-04-28ARM: lpc32xx: remove reboot header fileSylvain Lemieux
The header file "reboot.h" is no longer needed, following the migration of the restart code into the pnx4008 watchdog. Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-03-20Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "A few simple cleanups across multiple platforms, not much standing out: - lpc32xx removes its private implementation of the clk API, after generic code was merged in 4.5 - all unused Makefile.boot files get removed - a number of simplifications for shmobile - asm/clkdev.h gets replaced with the asm-generic version after all mach/clkdev.h implementations are gone" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: shmobile: Kconfig: Get rid of old comment ARM: shmobile: Consolidate SCU mapping code arm: lpc32xx: remove direct control of GPIOs from shared mach file arm: lpc32xx: remove selected HAVE_IDE arm: lpc32xx: switch to common clock framework ARM: Use generic clkdev.h header ARM: plat-versatile: Remove unused clock.c file ARM: netx: remove redundant "depends on ARCH_NETX" ARM: integrator: remove redundant select in Kconfig ARM: drop unused Makefile.boot of Multiplatform SoCs ARM: mvebu: add missing of_node_put() ARM: shmobile: r8a7779: Remove remainings of removed SCU boot setup code ARM: shmobile: Typo s/MIPDR/MPIDR/ ARM: shmobile: Add includes providing forward declarations ARM: shmobile: rcar-gen2: Make rcar_gen2_dma_contiguous static ARM: mv78xx0: use "depends on" instead of "if" after prompt
2016-03-19Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: - new drivers for: NI 903x/913x watchdog driver, WinSystems EBC-C384 watchdog timer and ARM SBSA watchdog driver - Support for NCT6102D devices - Improvements of the generic watchdog framework (improve restart handler, make set_timeout optional, introduce infrastructure triggered keepalives, ... - improvements on the pnx4008 watchdog driver - several smaller fixes and improvements * git://www.linux-watchdog.org/linux-watchdog: (28 commits) watchdog: Ensure that wdd is not dereferenced if NULL watchdog: imx2: Convert to use infrastructure triggered keepalives watchdog: dw_wdt: Convert to use watchdog infrastructure watchdog: Add support for minimum time between heartbeats watchdog: Make stop function optional watchdog: Introduce WDOG_HW_RUNNING flag watchdog: Introduce hardware maximum heartbeat in watchdog core watchdog: Make set_timeout function optional arm: lpc32xx: remove restart handler arm: lpc32xx: phy3250 remove restart hook watchdog: pnx4008: restart: support "cmd" from userspace watchdog: pnx4008: add support for soft reset watchdog: pnx4008: add restart handler watchdog: pnx4008: update logging during power-on watchdog: tangox_wdt: test clock rate to avoid division by 0 watchdog: atlas7_wdt: test clock rate to avoid division by 0 watchdog: s3c2410_wdt: Add max and min timeout values Watchdog: introduce ARM SBSA watchdog driver Documentation: add sbsa-gwdt driver documentation watchdog: Add watchdog timer support for the WinSystems EBC-C384 ...
2016-03-16arm: lpc32xx: remove restart handlerSylvain Lemieux
Remove the restart handler from "mach-lpc32xx"; this functionality is now available in the pnx4008 watchdog driver. Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2016-03-16arm: lpc32xx: phy3250 remove restart hookSylvain Lemieux
Remove the restart hook assignment from phy3250; this functionality is now managed by the pnx4008 watchdog driver. Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2016-03-09dma, mm/pat: Rename dma_*_writecombine() to dma_*_wc()Luis R. Rodriguez
Rename dma_*_writecombine() to dma_*_wc(), so that the naming is coherent across the various write-combining APIs. Keep the old names for compatibility for a while, these can be removed at a later time. A guard is left to enable backporting of the rename, and later remove of the old mapping defines seemlessly. Build tested successfully with allmodconfig. The following Coccinelle SmPL patch was used for this simple transformation: @ rename_dma_alloc_writecombine @ expression dev, size, dma_addr, gfp; @@ -dma_alloc_writecombine(dev, size, dma_addr, gfp) +dma_alloc_wc(dev, size, dma_addr, gfp) @ rename_dma_free_writecombine @ expression dev, size, cpu_addr, dma_addr; @@ -dma_free_writecombine(dev, size, cpu_addr, dma_addr) +dma_free_wc(dev, size, cpu_addr, dma_addr) @ rename_dma_mmap_writecombine @ expression dev, vma, cpu_addr, dma_addr, size; @@ -dma_mmap_writecombine(dev, vma, cpu_addr, dma_addr, size) +dma_mmap_wc(dev, vma, cpu_addr, dma_addr, size) We also keep the old names as compatibility helpers, and guard against their definition to make backporting easier. Generated-by: Coccinelle SmPL Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: airlied@linux.ie Cc: akpm@linux-foundation.org Cc: benh@kernel.crashing.org Cc: bhelgaas@google.com Cc: bp@suse.de Cc: dan.j.williams@intel.com Cc: daniel.vetter@ffwll.ch Cc: dhowells@redhat.com Cc: julia.lawall@lip6.fr Cc: konrad.wilk@oracle.com Cc: linux-fbdev@vger.kernel.org Cc: linux-pci@vger.kernel.org Cc: luto@amacapital.net Cc: mst@redhat.com Cc: tomi.valkeinen@ti.com Cc: toshi.kani@hp.com Cc: vinod.koul@intel.com Cc: xen-devel@lists.xensource.com Link: http://lkml.kernel.org/r/1453516462-4844-1-git-send-email-mcgrof@do-not-panic.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-11arm: lpc32xx: remove direct control of GPIOs from shared mach fileVladimir Zapolskiy
The change removes GPIO configuration and control of LCD, backlight and SD voltage regulators from the shared among all LPC32xx boards mach file, Phytec PHY3250 board should have the description of these regulators in its DTS file. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-02-11arm: lpc32xx: switch to common clock frameworkVladimir Zapolskiy
The change switches NXP LPC32xx platforms to LPC32xx clock driver powered by common clock framework, this obsoletes mach-lpc32xx/clock.o legacy clock driver and thus it is removed. Legacy timer driver mach-lpc32xx/timer.o strictly depends on legacy clock support, but fortunately an existing LPC32xx clock source and clock event driver completely replaces it, and thus it can be removed as well. Noticeably platform UART driver directly operates on LPC32xx source control block registers, remove this dependency to avoid overlapping with common clock framework driver, also this guarantees that UART is working expectedly. Tested-by: Sylvain Lemieux <slemieux@tycoint.com> Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-08-05Merge branch 'queue/irq/arm' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next/cleanup Merge "ARM: Interrupt cleanups and API change preparation" from Thomas Gleixner: The following patch series contains the following changes: - Consolidation of chained interrupt handler setup/removal - Switch to functions which avoid a redundant interrupt descriptor lookup - Preparation of interrupt flow handlers for the 'irq' argument removal * 'queue/irq/arm' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ARM/orion/gpio: Prepare gpio_irq_handler for irq argument removal ARM/pxa: Prepare balloon3_irq_handler for irq argument removal ARM/pxa: Prepare *_irq_handler for irq argument removal ARM/dove: Prepare pmu_irq_handler for irq argument removal ARM/sa1111: Prepare sa1111_irq_handler for irq argument removal ARM/locomo: Prepare locomo_handler for irq argument removal ARM, irq: Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc ARM/LPC32xx: Use irq_set_handler_locked() ARM/irq: Use access helper irq_data_get_affinity_mask() ARM/locomo: Consolidate chained IRQ handler install/remove ARM/orion: Consolidate chained IRQ handler install/remove Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-28ARM: kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Gregory Clement <gregory.clement@free-electrons.com> Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Imre Kaloz <kaloz@openwrt.org> Acked-by: Krzysztof Halasa <khalasa@piap.pl> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Roland Stigge <stigge@antcom.de> Cc: Tony Lindgren <tony@atomide.com> Cc: Daniel Mack <daniel@zonque.org> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Simtec Linux Team <linux@simtec.co.uk> Cc: Kukjin Kim <kgene@kernel.org> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-omap@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-28ARM: appropriate __init annotation for const dataNicolas Pitre
Init data marked const should be annotated with __initconst for correctness and not __initdata. In some cases the array gathering references to that data has to be marked const as well. This fixes LTO builds that otherwise fail with section mismatch errors. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-17ARM/lpc32xx/timer: Migrate to new 'set-state' interfaceViresh Kumar
Migrate lpc32xx driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Cc: Roland Stigge <stigge@antcom.de> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2015-07-13ARM/LPC32xx: Use irq_set_handler_locked()Thomas Gleixner
Use irq_set_handler_locked() as it avoids a redundant lookup of the irq descriptor. Search and replacement was done with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org
2015-07-01Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "This contains: - a series of fixes for interrupt drivers to prevent a potential race when installing a chained interrupt handler - a fix for cpumask pointer misuse - a fix for using the wrong interrupt number from struct irq_data - removal of unused code and outdated comments - a few new helper functions which allow us to cleanup the interrupt handling code further in 4.3 I decided against doing the cleanup at the end of this merge window and rather do the preparatory steps for 4.3, so we can run the final ABI change at the end of the 4.3 merge window with less risk" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) ARM/LPC32xx: Use irq not hwirq for __irq_set_handler_locked() genirq: Implement irq_set_handler_locked()/irq_set_chip_handler_name_locked() genirq: Introduce helper irq_desc_get_irq() genirq: Remove irq_node() genirq: Clean up outdated comments related to include/linux/irqdesc.h mn10300: Fix incorrect use of irq_data->affinity MIPS/ralink: Fix race in installing chained IRQ handler MIPS/pci: Fix race in installing chained IRQ handler MIPS/ath25: Fix race in installing chained IRQ handler MIPS/ath25: Fix race in installing chained IRQ handler m68k/psc: Fix race in installing chained IRQ handler avr32/at32ap: Fix race in installing chained IRQ handler sh/intc: Fix race in installing chained IRQ handler sh/intc: Fix potential race in installing chained IRQ handler pinctrl/sun4i: Fix race in installing chained IRQ handler pinctrl/samsung: Fix race in installing chained IRQ handler pinctrl/samsung: Fix race in installing chained IRQ handler pinctrl/exynos: Fix race in installing chained IRQ handler pinctrl/st: Fix race in installing chained IRQ handler pinctrl/adi2: Fix race in installing chained IRQ handler ...
2015-06-26ARM/LPC32xx: Use irq not hwirq for __irq_set_handler_locked()Thomas Gleixner
irq_data->hwirq is not guaranteed to be the same as irq_data->irq. It might be in that particular case, but it's wrong nevertheless. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Roland Stigge <stigge@antcom.de>
2015-05-06ARM: lpc32xx: convert to use clkdev_add_table()Russell King
We have always had an efficient way of registering a table of clock lookups - it's called clkdev_add_table(). However, some people seem to really love writing inefficient and unnecessary code. Convert LPC32xx to use the correct interface. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-09-10ARM: LPC32xx: Fix reset functionRoland Stigge
In the recent change to the reset function API (commit 7b6d864b48d95e6ea1df7df64475b9cb9616dcf9), the mode argument changed from a char to an enum. lpc23xx_restart() only handles REBOOT_SOFT and REBOOT_HARD, but the new kernel code emits REBOOT_COLD (0) on reboots now which leads to lpc32xx simply not rebooting (but halting). This patch fixes this by just resetting unconditionally as on other platforms (e.g. mach-bcm2835). Pulling lpc32xx_watchdog_reset() into lpc23xx_restart() since the while() in lpc23xx_restart() is part of the procedure anyway and lpc32xx_watchdog_reset() isn't used anywhere else anymore. Signed-off-by: Roland Stigge <stigge@antcom.de>
2014-06-02mmc: mmci: Enforce DMA configuration through DTUlf Hansson
Remove the option to provide DMA configuration as platform data, enforce it through DT. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Roland Stigge <stigge@antcom.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-04-05Merge tag 'fixes-non-critical-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC non-critical bug fixes from Arnd Bergmann: "Lots of isolated bug fixes that were not found to be important enough to be submitted before the merge window or backported into stable kernels. The vast majority of these came out of Arnd's randconfig testing and just prevents running into build-time bugs in configurations that we do not care about in practice" * tag 'fixes-non-critical-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits) ARM: at91: fix a typo ARM: moxart: fix CPU selection ARM: tegra: fix board DT pinmux setup ARM: nspire: Fix compiler warning IXP4xx: Fix DMA masks. Revert "ARM: ixp4xx: Make dma_set_coherent_mask common, correct implementation" IXP4xx: Fix Goramo Multilink GPIO conversion. Revert "ARM: ixp4xx: fix gpio rework" ARM: tegra: make debug_ll code build for ARMv6 ARM: sunxi: fix build for THUMB2_KERNEL ARM: exynos: add missing include of linux/module.h ARM: exynos: fix l2x0 saved regs handling ARM: samsung: select CRC32 for SAMSUNG_PM_CHECK ARM: samsung: select ATAGS where necessary ARM: samsung: fix SAMSUNG_PM_DEBUG Kconfig logic ARM: samsung: allow serial driver to be disabled ARM: s5pv210: enable IDE support in MACH_TORBRECK ARM: s5p64x0: fix building with only one soc type ARM: s3c64xx: select power domains only when used ARM: s3c64xx: MACH_SMDK6400 needs HSMMC1 ...
2014-03-21ARM: lpc32xx: export lpc32xx_return_iram_sizeArnd Bergmann
This symbol is used by the lpc_eth driver, which may be a loadable module. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Roland Stigge <stigge@antcom.de>
2014-03-12ARM: 7999/1: arch/arm/mach-lpc32xx-remove-irqf-disabledMichael Opdenacker
This patch removes the use of the IRQF_DISABLED flag from arch/arm/mach-lpc32xx/timer.c It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-02-18Merge tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux into ↵Olof Johansson
next/cleanup This cleanup series gets rid of <mach/timex.h> for platforms not using ARCH_MULTIPLATFORM. (For multi-platform code it's already unused since 387798b (ARM: initial multiplatform support).) To make this work some code out of arch/arm needed to be adapted. The respective changes got acks by their maintainers to be taken via armsoc (with Andrew Morton substituting for Alessandro Zummo as rtc maintainer). Compared to the previous pull request there was another patch added that fixes a (non-critical) regression on ixp4xx. Olof Johansson asked to not squash this fix into the original commit to save him from the need to reverify the series. * tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux: ARM: ixp4xx: fix timer latch calculation ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, too ARM: rpc: stop using <mach/timex.h> ARM: ixp4xx: stop using <mach/timex.h> input: ixp4xx-beeper: don't use symbols from <mach/timex.h> ARM: at91: don't use <mach/timex.h> ARM: ep93xx: stop using mach/timex.h ARM: mmp: stop using mach/timex.h ARM: netx: stop using mach/timex.h ARM: sa1100: stop using mach/timex.h clocksource: sirf/marco+prima2: drop usage of CLOCK_TICK_RATE rtc: pxa: drop unused #define TIMER_FREQ rtc: at91sam9: include <mach/hardware.h> explicitly ARM/serial: at91: switch atmel serial to use gpiolib Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-12-03ARM: lpc32xx: move custom GPIO headerLinus Walleij
Move <mach/gpio-lpc32xx.h> to <linux/platform_data/gpio-lpc32xx.h>. Acked-by: Roland Stigge <stigge@antcom.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-03ARM: lpc32xx: delete local <mach/gpio.h> headerLinus Walleij
This header is not used by anything, and since the arch does not specify NEED_MACH_GPIO_H it is not included into <linux/gpio.h> either. Delete it. Acked-by: Roland Stigge <stigge@antcom.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-25ARM: debug: move 8250 debug include into arch/arm/include/debug/Russell King
Now that the 8250 debug include can stand alone without requiring platforms to provide any macros, move it into the debug directory so it can be directly included. This allows us to get rid of a lot of debug-macros include files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart phys/virt address configuration optionsRussell King
Move the definition of the UART register addresses out of the platform specific header file into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart register shift configuration optionRussell King
Move the definition of the UART register shift out of the platform specific header file into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-05dmaengine: PL08x: Avoid collisions with get_signal() macroMark Brown
As pointed out by Arnd Bergmann there is a get_signal macro definied in linux/signal.h which can conflict with the platform data callback function of the same name leading to confusing errors from the compiler (especially if signal.h manages to get pulled into the driver itself due to header dependencies). Avoid such errors by renaming get_signal and put_signal in the platform data to get_xfer_signal and put_xfer_signal. Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-14ARM: use clockevents_config_and_register() where possibleShawn Guo
The clockevent core is able to figure out the best mult and shift, calculate min_delta_ns and max_delta_ns, with the necessary info passed into clockevents_config_and_register(). Use this combined configure and register function where possible to make the codes less error prone and gain some positive diff stat. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Tested-by: Roland Stigge <stigge@antcom.de> Acked-by: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: David Brown <davidb@codeaurora.org> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Barry Song <baohua.song@csr.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-12ARM: LPC32xx: Add the motor PWM clockAlban Bedel
