path: root/arch/arm/mach-mediatek
2015-11-10Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "New and/or improved SoC support for this release: Marvell Berlin: - Enable standard DT-based cpufreq - Add CPU hotplug support Freescale: - Ethernet init for i.MX7D - Suspend/resume support for i.MX6UL Allwinner: - Support for R8 chipset (used on NTC's $9 C.H.I.P board) Mediatek: - SMP support for some platforms Uniphier: - L2 support - Cleaned up SMP support, etc. plus a handful of other patches around above functionality, and a few other smaller changes" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits) ARM: uniphier: rework SMP operations to use trampoline code ARM: uniphier: add outer cache support Documentation: EXYNOS: Update bootloader interface on exynos542x ARM: mvebu: add broken-idle option ARM: orion5x: use mac_pton() helper ARM: at91: pm: at91_pm_suspend_in_sram() must be 8-byte aligned ARM: sunxi: Add R8 support ARM: digicolor: select pinctrl/gpio driver arm: berlin: add CPU hotplug support arm: berlin: use non-self-cleared reset register to reset cpu ARM: mediatek: add smp bringup code ARM: mediatek: enable gpt6 on boot up to make arch timer working soc: mediatek: Fix random hang up issue while kernel init soc: ti: qmss: make acc queue support optional in the driver soc: ti: add firmware file name as part of the driver Documentation: dt: soc: Add description for knav qmss driver ARM: S3C64XX: Use PWM lookup table for mach-smartq ARM: S3C64XX: Use PWM lookup table for mach-hmt ARM: S3C64XX: Use PWM lookup table for mach-crag6410 ARM: S3C64XX: Use PWM lookup table for smdk6410 ...
2015-10-14ARM: mediatek: add smp bringup codeYingjoe Chen
Add support for booting secondary CPUs on mt6589, mt8127 and mt8135. Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-10-14ARM: mediatek: enable gpt6 on boot up to make arch timer workingMatthias Brugger
We enable GTP6 which ungates the arch timer clock. In the future this should be done in the bootloader. Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com> Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com>
2015-07-23ARM: mediatek: Add regmap to mediatek KconfigMatthias Brugger
Mediatek SoC needs the regmap/syscon infrastructure. The infrastructure is used by the clock and pinctrl driver. This patch adds MD_SYSCON to Kconfig for all Mediatek devices. Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-03-10ARM: mediatek: enable the pin controllerMatthias Brugger
This patch enables the pin controller for Mediatek SoCs. Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-01-20ARM: mediatek: Add config options for mediatek SoCs.Yingjoe Chen
The upcoming MTK pinctrl driver have a big pin table for each SoC and we don't want to bloat the kernel binary if we don't need it. Add config options so we can build for one SoC only. Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2014-12-09Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Arnd Bergmann: "The DT branch adds a lot of new stuff for additional SoC and board support. The branch is the largest one and contains 513 out of the total 972 non-merge arm-soc changesets for 3.19. Most of the changes are about enabling additional on-chip devices for existing machines, but there are also an unusual number of new SoC types being added this time: - AMLogic Meson8 - ARM Realview in DT mode - Allwinner A80 - Broadcom BCM47081 - Broadcom Cygnus - Freescale LS1021A - Freescale Vybrid 500 series - Mediatek MT6592, MT8127, MT8135 - STMicroelectronics STiH410 - Samsung Exynos4415 The level of support for the above differs widely, some are just stubs with nothing more than CPU, memory and a UART, but others are fairly complete. As usual, these get extended over time. There are also many new boards getting added, this is the list of model strings that are showing up in new dts files: - ARM RealView PB1176 - Altera SOCFPGA Arria 10 - Asus RT-N18U (BCM47081) - Buffalo WZR-1750DHP (BCM4708) - Buffalo WZR-600DHP2 (BCM47081) - Cygnus Enterprise Phone (BCM911360_ENTPHN) - D-Link DIR-665 - Google Spring - IGEP COM MODULE Rev. G (TI OMAP AM/DM37x) - IGEPv2 Rev. F (TI OMAP AM/DM37x) - LS1021A QDS Board - LS1021A TWR Board - LeMaker Banana Pi - MarsBoard RK3066 - MediaTek MT8127 Moose Board - MediaTek MT8135 evaluation board - Mele M3 - Merrii A80 Optimus Board - Netgear R6300 V2 (BCM4708) - Nomadik STN8815NHK - NovaTech OrionLXm - Olimex A20-OLinuXino-LIME2 - Raspberry Pi Model B+ - STiH410 B2120 - Samsung Monk board - Samsung Rinato board - Synology DS213j - Synology DS414 - TBS2910 Matrix ARM mini PC - TI AM5728 BeagleBoard-X15 - Toradex Colibri VF50 on Colibri Evaluation Board - Zynq ZYBO Development Board Other notable changes include: - exynos: cleanup of existing dts files - mvebu: improved pinctrl support for Armada 370/XP - nomadik: restructuring dts files - omap: added CAN bus support - shmobile: added clock support for some SoCs - shmobile: added sound support for some SoCs - sirf: reset controller support - sunxi: continuing the relicensing under dual GPL/MIT - sunxi: lots of new on-chip device support - sunxi: working simplefb support (long awaited) - various: provide stdout-path property for earlycon" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits) ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured Revert "ARM: dts: rockchip: temporarily disable smp on rk3288" ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2 ARM: BCM5301X: Add DT for Asus RT-N18U ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP ARM: BCM5301X: Add DT for Netgear R6300 V2 ARM: BCM5301X: Add buttons for Netgear R6250 ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file arm: dts: zynq: Add Digilent ZYBO board arm: dts: zynq: Move crystal freq. to board level doc: dt: vendor-prefixes: Add Digilent Inc Documentation: devicetree: Fix Xilinx VDMA specification ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188 ARM: dts: rockchip: add label property for leds on Radxa Rock ARM: BCM5301X: Add LEDs for Netgear R6250 V1 ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file ARM: dts: add sysreg phandle to i2c device nodes for exynos ARM: dts: Remove unused bootargs from exynos3250-rinato ARM: dts: add board dts file for Exynos3250-based Monk board ...
2014-11-14ARM: mediatek: Add basic support for mt6592Howard Chen
* A dtsi for boards based on Mediatek MT6592 SoCs * Compatible string in arch/arm/mach-mediatek/mediatek.c Signed-off-by: Howard Chen <ibanezchen@gmail.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2014-11-14ARM: mediatek: Fix description for mediatek SoCsJoe.C
We support more MediaTek SoCs now, update the description. Signed-off-by: Joe.C <yingjoe.chen@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2014-11-12ARM: mediatek: Add basic support for mt8135Joe.C
This adds a basic dtsi for MT8135 based SoC. Signed-off-by: Joe.C <yingjoe.chen@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2014-11-12ARM: mediatek: Add basic support for mt8127Joe.C
This adds a basic dtsi for MT8127 SoC. Signed-off-by: Joe.C <yingjoe.chen@mediatek.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2014-07-22arm: add basic support for Mediatek MT6589 boardsMatthias Brugger
This adds a generic devicetree board file and a dtsi for boards based on MT6589 SoCs from Mediatek. Apart from the generic parts (gic, clocks) the only component currently supported are the timers. Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
