path: root/arch/arm/mach-mmp/clock.c
2011-07-12ARM: pxa: add clk_set_rate()Haojian Zhuang
Since there're mulitple clock rates in some device controllers, enable clk_set_rate() for this usage. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-02-12ARM: Consolidate clks_register() and similarRussell King
Most machine classes want some way to register a block of clk_lookup structures, and most do it by implementing a clks_register() type function which walks an array, or by open-coding a loop. Consolidate all this into clkdev_add_table(). Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-01[ARM] pxa: add apmu clock support in mmpHaojian Zhuang
2009-03-23[ARM] pxa: add base support for Marvell's PXA168 processor lineEric Miao
"""The MarvellĀ® PXA168 processor is the first in a family of application processors targeted at mass market opportunities in computing and consumer devices. It balances high computing and multimedia performance with low power consumption to support extended battery life, and includes a wealth of integrated peripherals to reduce overall BOM cost .... """ See http://www.marvell.com/featured/pxa168.jsp for more information. 1. Marvell Mohawk core is a hybrid of xscale3 and its own ARM core, there are many enhancements like instructions for flushing the whole D-cache, and so on 2. Clock reuses Russell's common clkdev, and added the basic support for UART1/2. 3. Devices are a bit different from the 'mach-pxa' way, the platform devices are now dynamically allocated only when necessary (i.e. when pxa_register_device() is called). Description for each device are stored in an array of 'struct pxa_device_desc'. Now that: a. this array of device description is marked with __initdata and can be freed up system is fully up b. which means board code has to add all needed devices early in his initializing function c. platform specific data can now be marked as __initdata since they are allocated and copied by platform_device_add_data() 4. only the basic UART1/2/3 are added, more devices will come later. Signed-off-by: Jason Chagas <chagas@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
