path: root/arch/arm/mach-mmp/tavorevb.c
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-08-05[ARM] mmp: rename pxa_map_io() to mmp_map_io()Eric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-08-05[ARM] mmp: remove never supported .boot_params for MMPEric Miao
2009-03-23[ARM] pxa: add base support for pxa910-based TavorEVBEric Miao
Signed-off-by: Bin Yang <bin.yang@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
