path: root/arch/arm/mach-mmp
2011-08-11ARM: mmp: Change the way we use timer 0 as clockevent timer.Lennert Buytenhek
Instead of setting up a match interrupt for 'current_time + delta' on ->set_next_event(), program timer 0 to count down from 'delta - 1' and trigger an interrupt when it reaches zero. Signed-off-by: Lennert Buytenhek <buytenh@laptop.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-08-11ARM: mmp: Switch to using timer 1 as clocksource timer.Lennert Buytenhek
2011-08-11ARM: mmp: Also start timer 1 on boot.Lennert Buytenhek
Currently, arch-mmp/time.c uses timer 0 both as a clocksource timer and as a clockevent timer, the latter by setting up a comparator interrupt to match on 'current_time + delta'. This is problematic if delta is small enough, as that can lead to 'current_time + delta' already being in the past when comparator setup has finished, leading to the requested event not triggering. As there is also a silicon issue that requires stopping a timer's counter while writing to one of its match registers, we'll switch to using two separate timers -- timer 0 as clockevent timer, which we'll start and stop on every invocation of ->set_next_event(), and timer 1 as clocksource timer, which will be free-running. This first patch enables timer 1 on boot, so that we can use it as clocksource timer. Signed-off-by: Lennert Buytenhek <buytenh@laptop.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-08-11ARM: pxa168/gplugd: free correct GPIOTanmay Upadhyay
Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-08-11ARM: pxa168/gplugd: get rid of mfp-gplugd.hTanmay Upadhyay
Move definitions from mfp-gplugd.h to mfp-pxa168.h as they aren't gplugD specific. Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-20mmc: sdhci-pxa: move platform data to include/linux/platform_dataZhangfei Gao
As suggested by Arnd, move platform data to include/linux/platform_data in order to improve build coverage for the driver. Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: update mmp2 mmc resources in arch/armZhangfei Gao
Update MMP2 platform code to "sdhci-pxav3", following the driver rename. Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com> Acked-by: Philip Rakity <prakity@marvell.com> Acked-by: Mark F. Brown <mark.brown314@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-19ARM: Consolidate the clkdev header filesKyungmin Park
Now most of ARM machines has the alsmot same __clk_get/put() macro So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config Now there are only 3 caese. 1) define the clk structure with clkdev macro => Need to move clk structure to proper header file arch/arm/mach-versatile/include/mach/clkdev.h arch/arm/mach-realview/include/mach/clkdev.h arch/arm/mach-vexpress/include/mach/clkdev.h arch/arm/mach-integrator/include/mach/clkdev.h 2) export the __clk_get/put function at clock.c arch/arm/mach-shmobile/include/mach/clkdev.h 3) demuxing the clk source arch/arm/mach-u300/include/mach/clkdev.h Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-07-12ARM: mmp/dkb: enable max7312 gpio expanderHaojian Zhuang
Support max7312 gpio expander in TTC DKB. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-07-12ARM: pxa168: Add board support for gplugDTanmay Upadhyay
Tested UART console, Ethernet & I2C interfaces Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-07-12ARM: pxa168: Add support for EthernetTanmay Upadhyay
Add wrapper that creates resources for PXA168 Ethernet driver Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-07-12ARM: pxa168: Add support for UART3Tanmay Upadhyay
PXA168 has 3 onchip UARTs. Added support for the third one Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-07-12ARM: pxa: add clk_set_rate()Haojian Zhuang
Since there're mulitple clock rates in some device controllers, enable clk_set_rate() for this usage. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-07-06ARM: pxa168: correct nand pmu settingLei Wen
The original pair of <0x01db, 208000000> is invalid. Correct it to the valid value. The 6th bit of the NFC APMU register indicates NFC works whether at 156Mhz or 78Mhz. So 0x19b indicates NFC works at 156Mhz, and 0x1db indicates it works at 78Mhz. Signed-off-by: Lei Wen <leiwen@marvell.com> Cc: stable@kernel.org Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-07-06ARM: pxa910: correct nand pmu settingLei Wen
The original pair of <0x01db, 208000000> is invalid. Correct to the valid value. Signed-off-by: Lei Wen <leiwen@marvell.com> Cc: stable@kernel.org Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-05-07Merge branch 'zImage_fixes' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-05-07ARM: zImage: remove the static qualifier from global data variablesNicolas Pitre
To be able to relocate the .bss section at run time independently from the rest of the code, we must make sure that no GOTOFF relocations are used with .bss symbols. This usually means that no global variables can be marked static unless they're also const. Let's remove the static qualifier from current offenders, or turn them into const variables when possible. Next commit will ensure the build fails if one of those is reintroduced due to otherwise enforced coding standards for the kernel. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com>
2011-04-12ARM: mmp: align NR_BUILTIN_GPIO with gpio interrupt numberHaojian Zhuang
Avoid to mismatch between NR_BUILTIN_GPIO and gpio interrupt number. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-04-12ARM: pxa: always clear LPM bits for PXA168 MFPRHaojian Zhuang
Bit[9:7] should always be zero in PXA168. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-21ARM: pxa2xx: reorganize I2C filesSebastian Andrzej Siewior
This patch moves the platform data definition from arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so it can be accessed from x86 the same way as on ARM. This change should make no functional change to the PXA code. The move is verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig pxa910_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-15ARM: mmp: PXA910 drive strength FAST using wrong valuePhilip Rakity
Drive strength for PXA910 is a 2 bit value but because of the mapping in plat-pxa/mfp.h needs to be shifted up one bit to handle real location in mfp registers. (MMP2 and PXA910 drive strength start at bit 11 while PXA168 starts at bit 10). Values 0, 1, 2, and 3 effectively need to be 0, 2, 4, and 6 to fit into register. 8 does not work. Signed-off-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-15ARM: mmp: MMP2 drive strength FAST using wrong valuePhilip Rakity
Drive strength for MMP2 is a 2 bit value but because of the mapping in plat-pxa/mfp.h needs to be shifted up one bit to handle real location in mfp registers. (MMP2 and PXA910 drive strength start at bit 11 while PXA168 starts at bit 10). Values 0, 1, 2, and 3 effectively need to be 0, 2, 4, and 6 to fit into register. 8 does not work. Signed-off-by: Philip Rakity <prakity@marvell.com> Tested-by: John Watlington <wad@laptop.org> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-13ARM: mmp: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2011-01-06Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/mach-pxa/clock.c arch/arm/mach-pxa/clock.h
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2011-01-06Merge branch 'smp' into miscRussell King
Conflicts: arch/arm/kernel/entry-armv.S arch/arm/mm/ioremap.c
2011-01-05Merge branch 'clksrc' into develRussell King
Conflicts: arch/arm/mach-vexpress/v2m.c arch/arm/plat-omap/counter_32k.c arch/arm/plat-versatile/Makefile
2010-12-22ARM: mmp: convert sched_clock() to use new infrastructureRussell King
Convert mmp to use the new sched_clock() infrastructure for extending 32bit counters to full 64-bit nanoseconds. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: ensure all sched_clock() implementations are notrace markedRussell King
ftrace requires sched_clock() to be notrace. Ensure that all implementations are so marked. Also make sure that they include linux/sched.h Also ensure OMAP clocksource read functions are marked notrace as they're used for sched_clock() too. Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Will Deacon <will.deacon@arm.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Tested-by: Eric Miao <eric.y.miao@gmail.com> Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: mmp: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-20ARM: mmp: refactored 5V regulator support using fixed-regulatorMark F. Brown
Signed-off-by: Mark F. Brown <mark.brown314@gmail.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-20ARM: mmp: correct the naming of GPIOxx_GPIO definitionsEric Miao
2010-12-18ARM: mmp: select CPU_PJ4Haojian Zhuang
Since CPU_PJ4 is shared between PXA95x and MMP2, select CPU_PJ4 in MMP2 configuration. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: mmp: fix the typo - MMP2 is compatible with ARMv7Haojian Zhuang
2010-12-16ARM: mmp: append brownstone supportHaojian Zhuang
2010-12-16ARM: mmp: add usb clock for pxa168/pxa910cxie4
Signed-off-by: Chao Xie <chao.xie@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: mmp: add sd card to jasperZhangfei Gao
Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com> Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: mmp: add mmc resourceZhangfei Gao
2010-11-30ARM: mmp2: remove not used clk_rtcJason Chagas
RTC clock will remain at 32KHz and powered on, there is no need for it at this moment. Signed-off-by: Jason Chagas <jason.chagas@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-03ARM: mmp: fix cpuid detection on mmp2Haojian Zhuang
Fix typo error on cpu_is_mmp2(). Correct cpu_readid_id() to read_cpuid_id(). Append missing parenthesis. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-09ARM: mmp: update cpuid of pxa168 and pxa910Haojian Zhuang
Correct the cpuid of pxa168 and pxa910. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
