Clockevent cleanup series from Shawn Guo.
Resolved move/change conflict in mach-pxa/time.c due to the sys_timer
cleanup.
* clocksource/cleanup:
clocksource: use clockevents_config_and_register() where possible
ARM: use clockevents_config_and_register() where possible
clockevents: export clockevents_config_and_register for module use
+ sync to Linux 3.8-rc3
arch/arm/mach-pxa/time.c
The clockevent core is able to figure out the best mult and shift,
calculate min_delta_ns and max_delta_ns, with the necessary info passed
into clockevents_config_and_register(). Use this combined configure
and register function where possible to make the codes less error prone
and gain some positive diff stat.
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Tested-by: Roland Stigge <stigge@antcom.de>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: David Brown <davidb@codeaurora.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Barry Song <baohua.song@csr.com>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Jason Cooper <jason@lakedaemon.net>
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c,
all the arch_decomp_wdog() definition at platform level is unneeded.
Remmove it.
Acked-by: Nicolas Pitre <nico@linaro.org>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Pinctrl driver is necessary for MMP DT & MMP2 DT platforms.
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
As suggested by Andrew Morton:
This is a pet peeve of mine. Any time there's a long list of items
(header file inclusions, kconfig entries, array initalisers, etc) and
someone wants to add a new item, they *always* go and stick it at the
end of the list.
Guys, don't do this. Either put the new item into a randomly-chosen
position or, probably better, alphanumerically sort the list.
lets sort all our select statements alphanumerically. This commit was
created by the following perl:
while (<>) {
while (/\\\s*$/) {
$_ .= <>;
undef %selects if /^\s*config\s+/;
if (/^\s+select\s+(\w+).*/) {
if (defined($selects{$1})) {
if ($selects{$1} eq $_) {
print STDERR "Warning: removing duplicated $1 entry\n";
} else {
print STDERR "Error: $1 differently selected\n".
"\tOld: $selects{$1}\n".
"\tNew: $_\n";
exit 1;
$selects{$1} = $_;
next;
if (%selects and (/^\s*$/ or /^\s+help/ or /^\s+---help---/ or
/^endif/ or /^endchoice/)) {
foreach $k (sort (keys %selects)) {
print "$selects{$k}";
undef %selects;
print;
if (%selects) {
It found two duplicates:
Warning: removing duplicated S5P_SETUP_MIPIPHY entry
Warning: removing duplicated HARDIRQS_SW_RESEND entry
and they are identical duplicates, hence the shrinkage in the diffstat
of two lines.
We have four testers reporting success of this change (Tony, Stephen,
Linus and Sekhar.)
Acked-by: Sekhar Nori <nsekhar@ti.com>
Pull ARM soc multiplatform enablement from Olof Johansson:
"This is a pretty significant branch. It's the introduction of the
first multiplatform support on ARM, and with this (and the later
branch) merged, it is now possible to build one kernel that contains
support for highbank, vexpress, mvebu, socfpga, and picoxcell. More
platforms will be convered over in the next few releases.
Two critical last things had to be done for this to be practical and
possible:
* Today each platform has its own include directory under
mach-<mach>/include/mach/*, and traditionally that is where a lot
of driver/platform shared definitions have gone, such as platform
data structures. They now need to move out to a common location
instead, and this branch moves a large number of those out to
include/linux/platform_data.
* Each platform used to list the device trees to compile for its
boards in mach-<mach>/Makefile.boot.
Both of the above changes will mean that there are some merge
conflicts to come (and some to resolve here). It's a one-time move
and once it settles in, we should be good for quite a while. Sorry
for the overhead."
Fix conflicts as per Olof.
* tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits)
ARM: add v7 multi-platform defconfig
ARM: msm: Move core.h contents into common.h
ARM: highbank: call highbank_pm_init from .init_machine
ARM: dtb: move all dtb targets to common Makefile
ARM: spear: move platform_data definitions
ARM: samsung: move platform_data definitions
ARM: orion: move platform_data definitions
ARM: vexpress: convert to multi-platform
ARM: initial multiplatform support
ARM: mvebu: move armada-370-xp.h in mach dir
ARM: vexpress: remove dependency on mach/* headers
ARM: picoxcell: remove dependency on mach/* headers
ARM: move all dtb targets out of Makefile.boot
ARM: picoxcell: move debug macros to include/debug
ARM: socfpga: move debug macros to include/debug
ARM: mvebu: move debug macros to include/debug
ARM: vexpress: move debug macros to include/debug
ARM: highbank: move debug macros to include/debug
ARM: move debug macros to common location
ARM: make mach/gpio.h headers optional
Pull ARM soc board specific updates from Olof Johansson:
"Misc board updates:
- Greg added a handful of boards to KS8695 (since he has stepped up
to maintain it).
- Qualcomm has added DT-only board support for a couple of their
newer SoCs.
- misc other updates for Samsung and Freescale boards."
Fix up trivial conflict in arch/arm/mach-shmobile/board-armadillo800eva.c
due to gpio device data being added next to hdmi device data that got moved.
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: msm: Allow 8960 and 8660 to compile together
ARM: msm: Allow msm_iomap-8x60 and msm_iomap-8960 to coexist
ARM: EXYNOS: Add generic PWM lookup support for SMDKV310
ARM: EXYNOS: Add generic PWM lookup support for SMDK4X12
ARM: EXYNOS: Use generic pwm driver in Origen board
ARM: shmobile: armadillo800eva: Add support RTC
ARM: ks8695: add board support for the OpenGear boards based on the KS8695
ARM: ks8695: add board support for the SnapGear boards based on the KS8695
ARM: dts: Add heartbeat gpio-leds support to Origen
ARM: dts: Use active low flag for gpio-keys on Origen
ARM: shmobile: marzen: enable thermal sensor
ARM: shmobile: marzen: fixup regulator id for smsc911x
ARM: shmobile: marzen: add SDHI0 support
ARM: mmp: enable debug uart port in defconfig
ARM: mmp: implement DEBUG_LL port choice
ARM: S3C64XX: Register audio platform devices for Bells on Cragganmore
ARM: S3C64XX: Update configuration for WM5102 module on Cragganmore
ARM: mx27pdk: Add audio support
ARM: ttc_dkb: add nand support
Pull ARM soc device tree updates from Olof Johansson:
"Device tree conversion and enablement branch. Mostly a bunch of new
bindings and setup for various platforms, but the Via/Winchip VT8500
platform is also converted over from being 100% legacy to now use
device tree for probing. More of that will come for 3.8."
Trivial conflicts due to removal of vt8500 files, and one documentation
file that was added with slightly different contents both here and in
the USb tree.
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (212 commits)
arm: vt8500: Fixup for missing gpio.h
ARM: LPC32xx: LED fix in PHY3250 DTS file
ARM: dt: mmp-dma: add binding file
arm: vt8500: Update arch-vt8500 to devicetree support.
arm: vt8500: gpio: Devicetree support for arch-vt8500
arm: vt8500: doc: Add device tree bindings for arch-vt8500 devices
arm: vt8500: clk: Add Common Clock Framework support
video: vt8500: Add devicetree support for vt8500-fb and wm8505-fb
serial: vt8500: Add devicetree support for vt8500-serial
rtc: vt8500: Add devicetree support for vt8500-rtc
arm: vt8500: Add device tree files for VIA/Wondermedia SoC's
ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support
ARM: tegra: Add Avionic Design Medcom-Wide support
ARM: tegra: Add Avionic Design Plutux support
ARM: tegra: Add Avionic Design Tamonten support
ARM: tegra: dts: Add pwm label
ARM: ux500: Fix SSP register address format
ARM: ux500: Apply tc3589x's GPIO/IRQ properties to HREF's DT
ARM: ux500: Remove redundant #gpio-cell properties from Snowball DT
ARM: ux500: Add all encompassing sound node to the HREF Device Tree
Pull ARM soc general cleanups from Olof Johansson:
"This is a large branch that contains a handful of different cleanups:
- Fixing up the I/O space remapping on PCI on ARM. This is a series
from Rob Herring that restructures how all pci devices allocate I/O
space, and it's part of the work to allow multiplatform kernels.
- A number of cleanup series for OMAP, moving and removing some
headers, sparse irq rework and in general preparation for
multiplatform.
- Final removal of all non-DT boards for Tegra, it is now
device-tree-only!
- Removal of a stale platform, nxp4008. It's an old mobile chipset
that is no longer in use, and was very likely never really used
with a mainline kernel. We have not been able to find anyone
interested in keeping it around in the kernel.
- Removal of the legacy dmaengine driver on tegra
+ A handful of other things that I haven't described above."
Fix up some conflicts with the staging tree (and because nxp4008 was
removed)
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (184 commits)
ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6
ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus
ARM: mmp: using for_each_set_bit to simplify the code
ARM: tegra: harmony: fix ldo7 regulator-name
ARM: OMAP2+: Make omap4-keypad.h local
ARM: OMAP2+: Make l4_3xxx.h local
ARM: OMAP2+: Make l4_2xxx.h local
ARM: OMAP2+: Make l3_3xxx.h local
ARM: OMAP2+: Make l3_2xxx.h local
ARM: OMAP1: Move irda.h from plat to mach
ARM: OMAP2+: Make hdq1w.h local
ARM: OMAP2+: Make gpmc-smsc911x.h local
ARM: OMAP2+: Make gpmc-smc91x.h local
ARM: OMAP1: Move flash.h from plat to mach
ARM: OMAP2+: Make debug-devices.h local
ARM: OMAP1: Move board-voiceblue.h from plat to mach
ARM: OMAP1: Move board-sx1.h from plat to mach
ARM: OMAP2+: Make omap-wakeupgen.h local
ARM: OMAP2+: Make omap-secure.h local
ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local
Pull clk framework update from Michael Turquette:
"The common clk framework changes for 3.7 are dominated by ARM platform
ports to the framework along with one MIPS port, one MFD port, one
minor framework enhancement and one helper function for platforms
expressing their clock data through device tree."
* tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linux:
clk: add of_clk_src_onecell_get() support
clk: ux500: Define smp_twd clock for u8500
mfd: dbx500: Provide a more accurate smp_twd clock
clk: ux500: Support for prmcu_rate clock
clk: Provide option for clk_get_rate to issue hw for new rate
clock: max77686: Add driver for Maxim 77686 32Khz crystal oscillator.
ARM: ux500: Switch to use common clock framework
clk: ux500: Clock definitions for u8500
clk: ux500: First version of clock definitions for ux500
clk: ux500: Adapt PRCMU and PRCC clocks for common clk
clk: versatile: make config option boolean
clk: add Loongson1B clock support
arm: mmp: make all SOCs use common clock by default
clk: mmp: add clock definition for mmp2
clk: mmp: add clock definition for pxa910
clk: mmp: add clock definition for pxa168
clk: mmp: add mmp specific clocks
clk: convert ARM RealView to common clk
clk: prima2: move from arch/arm/mach to drivers/clk
ARM: PRIMA2: convert to common clk and finish full clk tree
* multiplatform/platform-data:
ARM: nomadik: move platform_data definitions
ARM: w90x900: move platform_data definitions
ARM: vt8500: move platform_data definitions
ARM: tegra: move sdhci platform_data definition
ARM: sa1100: move platform_data definitions
ARM: pxa: move platform_data definitions
ARM: netx: move platform_data definitions
ARM: msm: move platform_data definitions
ARM: imx: move platform_data definitions
ARM: ep93xx: move platform_data definitions
ARM: davinci: move platform_data definitions
ARM: at91: move platform_data definitions
Conflicts due to removed files:
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-trimslice.c
Conflicts due to code removal:
arch/arm/mach-tegra/board-paz00.c
Context conflicts in:
drivers/mmc/host/sdhci-tegra.c
drivers/net/irda/pxaficp_ir.c
* 'board' of git://github.com/hzhuang1/linux:
Using for_each_set_bit() to simplify the code.
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
* next/dt: (182 commits)
ARM: dt: tegra: whistler: configure power off
ARM: mxs: m28evk: Disable OCOTP OUI loading
ARM: imx6q: use pll2_pfd2_396m as the enfc_sel's parent
ARM: dts: imx6q-sabrelite: add usbotg pinctrl support
ARM: dts: imx23-olinuxino: Add USB host support
ARM: dts: imx6q-sabrelite: add usbmisc device
ARM: dts: mx23: Add USB resources
ARM: dts: mxs: Add ethernetX to macX aliases
ARM: msm: Remove non-DT targets from 8960
ARM: msm: Add DT support for 8960
ARM: msm: Move io mapping prototypes to common.h
ARM: msm: Rename board-msm8x60 to signify its DT only status
ARM: msm: Make 8660 a DT only target
ARM: msm: Move 8660 to DT timer
ARM: msm: Add DT support to msm_timer
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the pxa include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Acked-By: Stefan Schmidt <stefan@openezx.org>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
Cc: Harald Welte <laforge@openezx.org>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Tomas Cech <sleep_walker@suse.cz>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Dan Williams <djbw@fb.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: openezx-devel@lists.openezx.org
next/dt
* 'clk-3.7' of git://git.linaro.org/people/mturquette/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/boards
* 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
+ sync to 3.6-rc4
Signed-off-by: Chao Xie <xiechao.mail@gmail.com>
move mmp2 clock definition to another file. Then mmp2 can
choose common clock framework or private clock framework.
move pxa910 clock definition to another file. Then pxa910 can
move pxa168 clock definition to another file. Then pxa168 can
the clock.c is mmp private implementation, make it excluded
from common clock framework
git://gitorious.org/sirfprima2-kernel/sirfprima2-kernel into next/dt
This branch enables device tree bindings for the CSR Prima pin control
subsystem. All patches acked by Linus W (pinctrl maintainer).
* 'pinmux-dt' of git://gitorious.org/sirfprima2-kernel/sirfprima2-kernel:
pinctrl: sirf: add DT-binding pinmux mapping support
ARM: PRIMA2: rename prima2-cb.dts to prima2.dtsi as it only has SoC features
ARM: PRIMA2: add missing interrupts property for pinctrl node
+ sync to Linux 3.6-rc4
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
DEBUG_LL port must be choiced in arch-mmp. DEBUG_LL port should be
UART2 in TTC DKB. And it should be UART3 in brownstone.
The tauros2_init has argument, change the calling of tauros2_init
to support argument.
Fix the wrong logic: we should use || instead of &&
Cc: Leo Yan <leoy@marvell.com>
Signed-off-by: Yuanhan Liu <yliu.null@gmail.com>
Add NAND support for dkb platform.
Signed-off-by: Lei Wen <leiwen@marvell.com>
arch/arm/mach-mmp/gplugd.c:195:13: error: ‘MMP_NR_IRQS’ undeclared here
(not in a function)
make[1]: *** [arch/arm/mach-mmp/gplugd.o] Error 1
Include <mach/irqs.h> to fix this issue.
Commit 157d2644cb0c1e71a18baaffca56d2b1d0ebf10f ("ARM: pxa: change gpio
to platform device") removed all includes of mach/gpio-pxa.h. It kept
this unused header in the tree. Using it can't work, as it itself
includes the non-existent header plat/gpio-pxa.h. This header can safely
be removed.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
While supporting board in non-DT mode, icu_data[i]->cascade_irq isn't
assigned with correct value.
Pull arm-soc board specific changes from Olof Johansson:
"While we generally attempt to get rid of board specific files and
replace them with device tree based descriptions, a lot of platforms
have not come that far:
In shmobile, we add two new board files because their recently started
effort to add DT support has not proceeded enough to use it for all of
the important hardware.
In Kirkwood, we are adding support for new boards with a combination
of DT and board file contents in multiple cases.
pxa/mmp and imx are extending support for existing board files but not
adding new ones."
Fix up trivial conflicts in arch/arm/mach-{mmp/ttc_dkb.c,shmobile/{Kconfig,Makefile}}
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits)
ARM: shmobile: fix smp build
ARM: kirkwood: Add support for RaidSonic IB-NAS6210/6220 using devicetree
kirkwood: Add iconnect support
orion/kirkwood: create a generic function for gpio led blinking
kirkwood/orion: fix orion_gpio_set_blink
ARM: kirkwood: Define DNS-320/DNS-325 NAND in fdt
kirkwood: Allow nand to be configured via. devicetree
mtd: Add orion_nand devicetree bindings
ARM: kirkwood: Basic support for DNS-320 and DNS-325
ARM: mach-shmobile: Use DT_MACHINE for armadillo 800 eva
ARM: mach-shmobile: Use DT_MACHINE for KZM9G
ARM: pxa: hx4700: Add Synaptics NavPoint touchpad
ARM: pxa: Use REGULATOR_SUPPLY macro
ARM: mach-shmobile: kzm9g: enable SMP boot
ARM: mach-shmobile: kzm9g: defconfig update
ARM: mach-shmobile: kzm9g: add PCF8757 gpio-key
ARM: mach-shmobile: kzm9g: add SDHI support
ARM: mach-shmobile: kzm9g: add MMCIF support
ARM: mach-shmobile: kzm9g: correct screen direction
ARM: mach-shmobile: sh73a0.h: add GPIO_NR
add suspend/resume functionality for pxa910
Signed-off-by: Chao Xie <chao.xie@marvell.com>
Signed-off-by: Raul Xiong <xjian@marvell.com>
Add 88pm860x into ttc_dkb, and it will impact the suspend/resume
of pxa910
MMP2 can enter system sleep level during suspend.
It can be waken up by PMIC interrupt, RTC/ALARM.
Move APBC_REG, APMU_REG and CIU_REG definition to addr-map.h
driver only need include addr-map.h to get access of the
registers.
Signed-off-by: Neil Zhang <zhangwm@marvell.com>
Suppot gpio/irq/timer in mmp-dt driver. Support PXA910 also in mmp-dt
driver.
Parse timer from DTS file. Avoid to use hardcoding marco for register.
Merge irq-pxa168 and irq-mmp2. And support device tree also.
Since CONFIG_SPARSE_IRQ is enabled in arch-mmp, base irq starts from
NR_IRQS_LEGACY.
Append CONFIG_MACH_MMP2_DT.
CONFIG_MACH_MMP_DT is used to ARMv5 DT support. CONFIG_MACH_MMP2_DT
is used to ARMv7 DT support. These two machine support can't be
selected at the same time.
Since irq_domain_add_simple() is removed, remove it in mmp-dt.c also.
The ehci-mv can support PXA168, PXA910 and PXA920, use this driver to
support pxa168 SPH usb.
There is an U2O OTG controller on ttc dkb, this patch is going to enable
it.
At this moment, it can only works in device mode, because when works in
host mode, it needs to supply vbus, but we have no vbus driver added
at this moment. Once the vbus driver is added, I'll prepar another
patch to enable the switch function.
Add usb device support for Marvell PXA910.
Actually PXA920 will use the same device.
