path: root/arch/arm/mach-msm/board-mahimahi.c
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-17ARM: platform fixups: remove mdesc argument to fixup functionRussell King
Get rid of the mdesc pointer in the fixup function call. No one uses the mdesc pointer, it shouldn't be modified anyway, and we can't wrap it, so let's remove it. Platform files found by: $ regexp=$(git grep -h '\.fixup.*=' arch/arm | sed 's!.*= *\([^,]*\),* *!\1!' | sort -u | tr '\n' '|' | sed 's,|$,,;s,|,\\|,g') $ git grep $regexp arch/arm Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-21ARM: mach-msm: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-01-28msm: Clean up useless ifdefsStepan Moskovchenko
Remove ifdefs that do nothing, either from having the code between them previously removed, or from having been accidentally added to the wrong file. Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-05-12arm: msm: add board file for Nexus One (ie. mahimahi)Daniel Walker
This adds a basic board file without Kconfig changes. Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
