path: root/arch/arm/mach-msm/devices.h
2011-02-28msm: clock: Migrate to clkdevStephen Boyd
Migrating to clkdev has several advantages: * Less code in mach-msm/clock.c * A more robust clk_get() implementation * clk_add_alias() support * clk_get_sys() support In general, this will help board authors setup clock aliases and break the dependency on device pointers in the clock tables. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2011-01-28msm: serial: Add MSM8960 serial supportStepan Moskovchenko
Add the device definitions and platform data to support the console serial port on MSM8960 Simulator and RUMI3 targets. Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-12-16MSM: Add USB suport for QSD8x50Pavankumar Kondeti
OTG driver takes care of putting hardware into low power mode. Hence make peripheral and host devices as children of OTG device and let runtime PM takes care of notifying peripheral and host state to OTG device. VBUS power up and shutdown routines are implemented by modem processor. As RPC infrastructure is not available, configure USB in peripheral only mode. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-12-15msm: initial framebuffer supportDaniel Walker
Initial framebuffer components. Add board-trout-panel.c as well as platform parts to enable the framebuffer. This code comes directly from Google's tree. Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-05-13msm: Add extern for 7x30 clock list.Daniel Walker
Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org> Signed-off-by: Gregory Bean <gbean@codeaurora.org> Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
2010-05-13msm: add extern for 8x50 clock list.Daniel Walker
2010-05-13msm: generalize clock support.Daniel Walker
The 'PCOM' method of clock control (commands issued to the radio CPU) is shared across several (but not all) Qualcomm SOCs. Generalize this clock mechanism so these other SOCs can be added. Signed-off-by: Gregory Bean <gbean@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
2008-10-22[ARM] msm: clean up iomap and devicesBrian Swetland
- Add some more peripherals (sdcc, etc) to the iomap. - Remove virtual base addresses for devices that we should be passing physical addresses to drivers via resources and ioremap()ing. - don't try to use uarts for ll debug once the mmu is enabled due to problems with the peripheral window - make base addresses void __iomem * and fixup irq.c and timer.c - Remove common.c and bring in devices.c/devices.h similar to the PXA architecture. Signed-off-by: Brian Swetland <swetland@google.com>
