path: root/arch/arm/mach-mv78xx0/Makefile
2013-04-15arm: mach-mv78xx0: convert to use the mvebu-mbus driverThomas Petazzoni
This commit convers the mach-mv78xx0 sub-architecture to use the mvebu-mbus driver. We simply have to call mvebu_mbus_init() in the ->init_early() function, and modify the PCIe code so that it uses the new functions provided by mvebu-mbus to create the needed PCIe windows. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2010-02-23[ARM] MV78xx0: Support for Buffalo WXL (Terastation Duo)Sebastien Requiem
* Modification of Kconfig to add the Option * 1 new file : buffalo-wxl-setup.c This file is inspired from the db-78xx0-setup.c already present. The following is done: - Configure MPP Lines for the plateform (see my patch for MPP) This is taken from the stock kernel provided by buffalotech (the vendor) - GigaBit Ethernet - Sata - Uart are initiallized in a different way than on the dev board as we have one core only. - USB The kernel has been running for some days now on my plateform. Signed-off-by: Sebastien Requiem <sebastien@kolios.dk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-02-23[ARM] MV78XX0: MPP routines and definitionsSebastien Requiem
This patch is composed of two new files : - mpp.c which is mainly inspired by the same file as in mach-kirkwood - mpp.h that is written from the documentation provided by Marvell http://www.marvell.com/products/processors/embedded/discovery_innovation/HW_MV78100_OpenSource.pdf Moreover, due to some implementation problem, I have defined some MPPX_UNUSED that offer developers the possibility to SET MPP to some unused value (such as for Buffalo WXL). Note: This patch doesn't support MV78200 yet (only 78100 MPP lines have been written) Signed-off-by: Sebastien Requiem <sebastien@kolios.dk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-03-15[ARM] mv78xx0: Add Marvell RD-78x00-mASA Reference Design supportLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Stanislav Samsonov <samsonov@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-06-22[ARM] add Marvell 78xx0 ARM SoC supportStanislav Samsonov
The Marvell Discovery Duo (MV78xx0) is a family of ARM SoCs featuring (depending on the model) one or two Feroceon CPU cores with 512K of L2 cache and VFP coprocessors running at (depending on the model) between 800 MHz and 1.2 GHz, and features a DDR2 controller, two PCIe interfaces that can each run either in x4 or quad x1 mode, three USB 2.0 interfaces, two 3Gb/s SATA II interfaces, a SPI interface, two TWSI interfaces, a crypto accelerator, IDMA/XOR engines, a SPI interface, four UARTs, and depending on the model, two or four gigabit ethernet interfaces. This patch adds basic support for the platform, and allows booting on the MV78x00 development board, with functional UARTs, SATA, PCIe, GigE and USB ports. Signed-off-by: Stanislav Samsonov <samsonov@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
