path: root/arch/arm/mach-mv78xx0/db78x00-bp-setup.c
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2009-03-03[ARM] mv78xx0: wire i2c supportRiku Voipio
All the pieces were ready, just matter of assembling them together. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-02-19[ARM] mv78xx0: enable eth2/eth3 on the mv78xx0 A0 development boardLennert Buytenhek
The A0 revision of the mv78xx0 development board has four ethernet ports, with PHY IDs 8-11, whereas the Z0 version has two, with PHY addresses 8-9. This patch configures the third and fourth ethernet port to use the PHY addresses on the A0 board to enable use of those ports -- if we are running on a Z0 board, the ge10/11 setup code in common.c will force these back to PHYless mode. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-10-19[ARM] mv78xx0: force link speed/duplex on eth2/eth3Lennert Buytenhek
On the mv78xx0 development board, eth2 and eth3 do not have corresponding PHYs, but are internally connected, as a way of facilitating communication between the two CPU cores. Since there are no PHYs, we need to tell the network driver explicitly to force the link on eth2 and eth3 up, to 1000 Mb/s full duplex. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-09-05mv643xx_eth: remove force_phy_addr fieldLennert Buytenhek
Currently, there are two different fields in the mv643xx_eth_platform_data struct that together describe the PHY address -- one field (phy_addr) has the address of the PHY, but if that address is zero, a second field (force_phy_addr) needs to be set to distinguish the actual address zero from a zero due to not having filled in the PHY address explicitly (which should mean 'use the default PHY address'). If we are a bit smarter about the encoding of the phy_addr field, we can avoid the need for a second field -- this patch does that. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-22[ARM] add Marvell 78xx0 ARM SoC supportStanislav Samsonov
The Marvell Discovery Duo (MV78xx0) is a family of ARM SoCs featuring (depending on the model) one or two Feroceon CPU cores with 512K of L2 cache and VFP coprocessors running at (depending on the model) between 800 MHz and 1.2 GHz, and features a DDR2 controller, two PCIe interfaces that can each run either in x4 or quad x1 mode, three USB 2.0 interfaces, two 3Gb/s SATA II interfaces, a SPI interface, two TWSI interfaces, a crypto accelerator, IDMA/XOR engines, a SPI interface, four UARTs, and depending on the model, two or four gigabit ethernet interfaces. This patch adds basic support for the platform, and allows booting on the MV78x00 development board, with functional UARTs, SATA, PCIe, GigE and USB ports. Signed-off-by: Stanislav Samsonov <samsonov@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
