path: root/arch/arm/mach-mv78xx0
2009-06-08[ARM] orion: convert gpio to use gpiolibErik Benada
Signed-off-by: Erik Benada <erikbenada@yahoo.ca> [ nico: fix locking, additional cleanups ] Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-05-22[ARM] add coherent DMA mask for mv643xx_ethNicolas Pitre
Since commit eb0519b5a1cf, mv643xx_eth is non functional on ARM because the platform device declaration does not include any coherent DMA mask and coherent memory allocations fail. Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-05-21[ARM] Orion: Remove explicit name for platform device resourcesMartin Michlmayr
Remove explicit names from platform device resources since they will automatically be named after the platform device they're associated with. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Acked-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-04-23[ARM] 5460/1: Orion: reduce namespace pollutionNicolas Pitre
Symbols like SOFT_RESET are way too generic to be exported at large. To avoid this, let's move the mbus bridge register defines into a separate file and include it where needed. This affects mach-kirkwood, mach-loki, mach-mv78xx0 and mach-orion5x simultaneously as they all share code in plat-orion which relies on those defines. Some other defines have been moved to narrower scopes, or simply deleted when they had no user. This fixes compilation problem with mpt2sas on the above listed platforms. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-19Merge branch 'master' of git://git.marvell.com/orion into develRussell King
Conflicts: arch/arm/mach-mx1/devices.c
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-15[ARM] mv78xx0: Add Marvell RD-78x00-mASA Reference Design supportLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Stanislav Samsonov <samsonov@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-03-03[ARM] mv78xx0: wire i2c supportRiku Voipio
All the pieces were ready, just matter of assembling them together. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-02-19[ARM] mv78xx0: enable eth2/eth3 on the mv78xx0 A0 development boardLennert Buytenhek
The A0 revision of the mv78xx0 development board has four ethernet ports, with PHY IDs 8-11, whereas the Z0 version has two, with PHY addresses 8-9. This patch configures the third and fourth ethernet port to use the PHY addresses on the A0 board to enable use of those ports -- if we are running on a Z0 board, the ge10/11 setup code in common.c will force these back to PHYless mode. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2009-02-19[ARM] mv78xx0: force eth2/eth3 to PHYless mode on pre-A0 siliconLennert Buytenhek
On pre-A0 revisions of the mv78xx0 SoC, the third and fourth ethernet interface are not brought out to pins, but are internally cross-connected, so if we run on pre-A0 silicon, we'll force eth2 and eth3 to PHYless mode. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2009-02-19[ARM] mv78xx0: distinguish between different chip steppingsLennert Buytenhek
During boot, identify which chip stepping we're running on (determined by looking at the first PCIe unit's device ID and revision registers), and print a message with the details about what we found. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2009-02-17[ARM] 5401/1: Orion: fix edge triggered GPIO interrupt supportNicolas Pitre
The GPIO interrupts can be configured as either level triggered or edge triggered, with a default of level triggered. When an edge triggered interrupt is requested, the gpio_irq_set_type method is called which currently switches the given IRQ descriptor between two struct irq_chip instances: orion_gpio_irq_level_chip and orion_gpio_irq_edge_chip. This happens via __setup_irq() which also calls irq_chip_set_defaults() to assign default methods to uninitialized ones. The problem is that irq_chip_set_defaults() is called before the irq_chip reference is switched, leaving the new irq_chip (orion_gpio_irq_edge_chip in this case) with uninitialized methods such as chip->startup() causing a kernel oops. Many solutions are possible, such as making irq_chip_set_defaults() global and calling it from gpio_irq_set_type(), or calling __irq_set_trigger() before irq_chip_set_defaults() in __setup_irq(). But those require modifications to the generic IRQ code which might have adverse effect on other architectures, and that would still be a fragile arrangement. Manually copying the missing methods from within gpio_irq_set_type() would be really ugly and it would break again the day new methods with automatic defaults are added. A better solution is to have a single irq_chip instance which can deal with both edge and level triggered interrupts. It is also a good idea to switch the IRQ handler instead, as the edge IRQ handler allows for one edge IRQ event to be queued as the IRQ is actually masked only when that second IRQ is received, at which point the hardware can queue an additional IRQ event, making edge triggered interrupts a bit more reliable. Tested-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08[ARM] 5361/1: mv78xx0: fix compilation errorNicolas Pitre
Commit ba84be2338d3 broke the build. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-20[ARM] mv78xx0: implement GPIO and GPIO interrupt supportLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-12-13Merge git://git.marvell.com/orion into develRussell King
2008-12-04[ARM] Orion: add the option to support different ehci phy initializationRonen Shitrit
The Orion ehci driver serves the Orion, kirkwood and DD Soc families. Since each of those integrate a different USB phy we should have the ability to use few initialization sequences or to leave the boot loader phy settings as is. Signed-off-by: Ronen Shitrit <rshitrit@marvell.com>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-19[ARM] mv78xx0: force link speed/duplex on eth2/eth3Lennert Buytenhek
On the mv78xx0 development board, eth2 and eth3 do not have corresponding PHYs, but are internally connected, as a way of facilitating communication between the two CPU cores. Since there are no PHYs, we need to tell the network driver explicitly to force the link on eth2 and eth3 up, to 1000 Mb/s full duplex. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-10-09Merge branch 'for-rmk' of git://git.marvell.com/orionRussell King
Merge branch 'orion-devel' into devel
2008-09-25[ARM] mv78xx0: wire up ethernet error interruptLennert Buytenhek
Wire up the ethernet port's error interrupt so that the mv643xx_eth driver can sleep for SMI event completion instead of having to busy-wait for it. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-09-05mv643xx_eth: remove force_phy_addr fieldLennert Buytenhek
Currently, there are two different fields in the mv643xx_eth_platform_data struct that together describe the PHY address -- one field (phy_addr) has the address of the PHY, but if that address is zero, a second field (force_phy_addr) needs to be set to distinguish the actual address zero from a zero due to not having filled in the PHY address explicitly (which should mean 'use the default PHY address'). If we are a bit smarter about the encoding of the phy_addr field, we can avoid the need for a second field -- this patch does that. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-09-05mv643xx_eth: smi sharing is a per-unit property, not a per-port oneLennert Buytenhek
Which top-level unit's SMI interface to use should be a property of the top-level unit, not of the individual ports. This patch moves the ->shared_smi pointer from the per-port platform data to the global platform data. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-09[ARM] Move include/asm-arm/plat-orion to arch/arm/plat-orion/include/platLennert Buytenhek
This patch performs the equivalent include directory shuffle for plat-orion, and fixes up all users. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-22[ARM] add Marvell 78xx0 ARM SoC supportStanislav Samsonov
The Marvell Discovery Duo (MV78xx0) is a family of ARM SoCs featuring (depending on the model) one or two Feroceon CPU cores with 512K of L2 cache and VFP coprocessors running at (depending on the model) between 800 MHz and 1.2 GHz, and features a DDR2 controller, two PCIe interfaces that can each run either in x4 or quad x1 mode, three USB 2.0 interfaces, two 3Gb/s SATA II interfaces, a SPI interface, two TWSI interfaces, a crypto accelerator, IDMA/XOR engines, a SPI interface, four UARTs, and depending on the model, two or four gigabit ethernet interfaces. This patch adds basic support for the platform, and allows booting on the MV78x00 development board, with functional UARTs, SATA, PCIe, GigE and USB ports. Signed-off-by: Stanislav Samsonov <samsonov@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
