Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
There is no good reason to duplicate the PCI menu in every architecture.
Instead provide a selectable HAVE_PCI symbol that indicates availability
of PCI support, and a FORCE_PCI symbol to for PCI on and the handle the
rest in drivers/pci.
Reviewed-by: Palmer Dabbelt <palmer@sifive.com>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Paul Burton <paul.burton@mips.com>
The MACH_ARMADA_375 and MACH_ARMADA_38X boards select ARM_ERRATA_753970,
but it was renamed to PL310_ERRATA_753970 by commit fa0ce4035d48 ("ARM:
7162/1: errata: tidy up Kconfig options for PL310 errata workarounds").
Fix the selects to use the new name.
Discovered with the
https://github.com/ulfalizer/Kconfiglib/blob/master/examples/list_undefined.py
script.
Fixes: fa0ce4035d48 ("ARM: 7162/1: errata: tidy up Kconfig options for
cc: stable@vger.kernel.org
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Following what has been done for other subsystems, move the remaining PCI
related code out of drivers/of/ and into drivers/pci/of.c
With this, we can kill a few kconfig symbols.
Signed-off-by: Rob Herring <robh@kernel.org>
[bhelgaas: minor whitespace, comment cleanups]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Frank Rowand <frowand.list@gmail.com>
Armada 38x SoCs along with legacy timer (time-armada-370-xp.c),
comprise generic Cortex-A9 global timer (arm_global_timer.c).
Enable its compilation. The system clocksource subsystem
will pick one of above two available ones in case the global
timer node is present in the device tree.
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Since the commit bd3677ff31a3 ("clk: mvebu: Remove corediv clock from
Armada XP"), the corediv clk is no more selected for Armada XP, however
this clock is used for Armada XP using the compatible
armada-370-corediv-clock.
While since commit 1594d568c6e3 ("clk: mvebu: Move corediv config to
mvebu config") Armada 38x and Armada 375 got corediv support again, not
only Armada XP was missed but also Armada 39x.
Actually all the SoC selecting MVEBU_V7 config need this clock:
git grep "\-corediv-clock" arch/arm/boot/dts
arch/arm/boot/dts/armada-370-xp.dtsi: compatible = "marvell,armada-370-corediv-clock";
arch/arm/boot/dts/armada-375.dtsi: compatible = "marvell,armada-375-corediv-clock";
arch/arm/boot/dts/armada-38x.dtsi: compatible = "marvell,armada-380-corediv-clock";
arch/arm/boot/dts/armada-39x.dtsi: compatible = "marvell,armada-390-corediv-clock"
This commit now fixes this behavior by letting MVEBU_V7 select
MVEBU_CLK_COREDIV.
Fixes: bd3677ff31a3 ("clk: mvebu: Remove corediv clock from Armada XP")
Cc: stable@vger.kernel.org
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
This replaces:
- "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can
now be selected directly.
- "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB
is now selectable by everyone, so we need not declare our
intent to select it.
When ordering the symbols the following rationale was used:
if the selects were in alphabetical order, I moved select GPIOLIB
to be in alphabetical order, but if the selects were not
maintained in alphabetical order, I just replaced
"select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB".
Cc: Michael Büsch <m@bues.ch>
Cc: arm@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk updates from Stephen Boyd:
"The clk changes for this release cycle are mostly dominated by new
device support in terms of LoC, but there has been some cleanup in the
core as well as the usual minor clk additions to various drivers.
Core:
- parent tracking has been simplified
- CLK_IS_ROOT is now a no-op flag, cleaning up drivers has started
- of_clk_init() doesn't consider disabled DT nodes anymore
- clk_unregister() had an error path bug squashed
- of_clk_get_parent_count() has been fixed to only return unsigned ints
- HAVE_MACH_CLKDEV is removed now that the last arch user (ARM) is gone
New Drivers:
- NXP LPC18xx creg
- QCOM IPQ4019 GCC
- TI dm814x ADPLL
- i.MX6QP
Updates:
- Cyngus audio clks found on Broadcom iProc devices
- Non-critical fixes for BCM2385 PLLs
- Samsung exynos5433 updates for clk id errors, HDMI support,
suspend/resume simplifications
- USB, CAN, LVDS, and FCP clks on shmobile devices
- sunxi got support for more clks on new SoCs and went through a
minor refactoring/rewrite to use a simpler factor clk construct
- rockchip added some more clk ids and added suport for fraction
dividers
- QCOM GDSCs in msm8996
- A new devm helper to make adding custom actions simpler (acked by Greg)"
* tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (197 commits)
clk: bcm2835: fix check of error code returned by devm_ioremap_resource()
clk: renesas: div6: use RENESAS for #define
clk: renesas: Rename header file renesas.h
clk: max77{686,802}: Remove CLK_IS_ROOT
clk: versatile: Remove CLK_IS_ROOT
clk: sunxi: Remove use of variable length array
clk: fixed-rate: Remove CLK_IS_ROOT
clk: qcom: Remove CLK_IS_ROOT
doc: dt: add documentation for lpc1850-creg-clk driver
clk: add lpc18xx creg clk driver
clk: lpc32xx: fix compilation warning
clk: xgene: Add missing parenthesis when clearing divider value
clk: mb86s7x: Remove CLK_IS_ROOT
clk: x86: Remove clkdev.h and clk.h includes
clk: x86: Remove CLK_IS_ROOT
clk: mvebu: Remove CLK_IS_ROOT
clk: renesas: move drivers to renesas directory
clk: si5{14,351,70}: Remove CLK_IS_ROOT
clk: scpi: Remove CLK_IS_ROOT
clk: s2mps11: Remove CLK_IS_ROOT
The core clock does not depend on corediv, so enabling corediv
based on the clock is not really correct. Move the corediv
config option from the clock driver Kconfig to the mvebu Kconfig
so that it can be enabled by the MACH option instead.
This also enables corediv on Armada 375 and 38X, which was
previously missing.
Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com>
Cc: Michael Turquette <mturquette@baylibre.com>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Now that there is a ARMADA_370_XP_IRQ option to enable the irqchip
driver for Armada 370, XP, 375, 38x and 39x, let's select this option
when needed. Note that this selection is currently not mandatory
because ARMADA_370_XP_IRQ is for now always enabled when ARCH_MVEBU=y,
but this is something that we will change in the future, and therefore
we should make the relevant platforms select ARMADA_370_XP_IRQ when
needed.
Due to this, selecting GENERIC_IRQ_CHIP is no longer needed.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1455115621-22846-7-git-send-email-thomas.petazzoni@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Many ARM sub-architectures use prompts followed by "if" conditional,
but it is wrong.
Please notice the difference between
config ARCH_FOO
bool "Foo SoCs" if ARCH_MULTI_V7
and
config ARCH_FOO
bool "Foo SoCs"
depends on ARCH_MULTI_V7
These two are *not* equivalent!
In the former statement, it is not ARCH_FOO, but its prompt that
depends on ARCH_MULTI_V7. So, it is completely valid that ARCH_FOO
is selected by another, but ARCH_MULTI_V7 is still disabled. As it is
not unmet dependency, Kconfig never warns. This is probably not what
you want.
The former should be used only when you need to do so, and you really
understand what you are doing. (In most cases, it should be wrong!)
For enabling/disabling sub-architectures, the latter is always correct.
As a good side effect, this commit fixes some entries over 80 columns
(mach-imx, mach-integrator, mach-mbevu).
[Arnd: I note that there is not really a bug here, according to
the discussion that followed, but I can see value in being consistent
and in making the lines shorter]
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Jun Nie <jun.nie@linaro.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Krzysztof Halasa <khc@piap.pl>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
Since DT support is now available for the LEDs found on the LaCie
netxbig boards (Kirkwood-based), then the old-fashion netxbig board
setup file is no longer needed. This patch removes this file.
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
The PMU device contains an interrupt controller, power control and
resets. The interrupt controller is a little sub-standard in that
there is no race free way to clear down pending interrupts, so we try
to avoid problems by reducing the window as much as possible, and
clearing as infrequently as possible.
The interrupt support is implemented using an IRQ domain, and the
parent interrupt referenced in the standard DT way.
The power domains and reset support is closely related - there is a
defined sequence for powering down a domain which is tightly coupled
with asserting the reset. Hence, it makes sense to group these two
together, and in order to avoid any locking contention disrupting this
sequence, we avoid the use of syscon or regmap.
This patch adds the core PMU driver: power domains must be defined in
the DT file in order to make use of them. The reset controller can
be referenced in the standard way for reset controllers.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
This commit adds the core support for Armada 39x, which is quite
simple:
- a new Kconfig option which selects the appropriate clock and
pinctrl drivers as well as other common features (GIC, L2 cache,
SMP, etc.)
- a new DT_MACHINE_START which references the top-level compatible
strings supported for the Marvell Armada 39x.
- a new SMP enable-method. The mechanism to enable CPUs for Armada
39x appears to be the same as Armada 38x. However, we do not want
to use marvell,armada-380-smp in the Device Tree, in the case of
the discovery of a subtle difference in the future, which would
require changing the Device Tree. And the enable-method isn't a
compatible string: you can't specify several values and expect a
fallback on the second string if the first one isn't
supported. Therefore, we simply declare the SMP enable method
"marvell,armada-390-smp" as doing the same thing as the
"marvell,armada-380-smp" one.
next/soc
Merge "mvebu SoC changes for v3.17 (round 4)" from Jason Cooper:
- Armada XP
- Fix return value check in pmsu code
- Document URLs for new public datasheets (Thanks, Marvell & free-electrons!)
- Armada 370/38x
- Add cpuidle support
- mvebu
- Fix build when no platforms are selected
- Update EBU SoC status in docs
* tag 'mvebu-soc-3.17-4' of git://git.infradead.org/linux-mvebu: (21 commits)
Documentation: arm: misc updates to Marvell EBU SoC status
Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC
ARM: mvebu: fix build without platforms selected
ARM: mvebu: add cpuidle support for Armada 38x
ARM: mvebu: add cpuidle support for Armada 370
cpuidle: mvebu: add Armada 38x support
cpuidle: mvebu: add Armada 370 support
cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7
ARM: mvebu: export the SCU address
ARM: mvebu: make the snoop disabling optional in mvebu_v7_pmsu_idle_prepare()
ARM: mvebu: use a local variable to store the resume address
ARM: mvebu: make the cpuidle initialization more generic
ARM: mvebu: rename the armada_370_xp symbols to mvebu_v7 in pmsu.c
ARM: mvebu: use the common function for Armada 375 SMP workaround
ARM: mvebu: add a common function for the boot address work around
ARM: mvebu: sort the #include of pmsu.c in alphabetic order
ARM: mvebu: split again armada_370_xp_pmsu_idle_enter() in PMSU code
ARM: mvebu: fix return value check in armada_xp_pmsu_cpufreq_init()
clk: mvebu: extend clk-cpu for dynamic frequency scaling
ARM: mvebu: extend PMSU code to support dynamic frequency scaling
arch/arm/mach-mvebu/Kconfig
drivers/cpuidle/cpuidle-armada-370-xp.c
When building a multiplatform kernel that enables 'ARCH_MVEBU' but
none of the individual options under it, we get this link error:
arch/arm/mach-mvebu/built-in.o: In function `mvebu_armada375_smp_wa_init':
:(.text+0x190): undefined reference to `mvebu_setup_boot_addr_wa'
The best solution seems to be to ensure that in this configuration,
we don't actually build any of the mvebu code.
Link: https://lkml.kernel.org/r/7339332.ZE2mWIdyDh@wuerfel
Merge "mvebu SoC changes for v3.17" from Jason Cooper:
- kirkwood
* add setup file for netxbig LEDs (non-trivial DT binding doesn't exist yet)
- mvebu
* staticize where needed
* add CPU hotplug for Armada XP
* add public datasheet for Armada 370
* don't apply thermal quirk by default
* get SoC ID from the system controller when possible
* tag 'mvebu-soc-3.17' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: Staticize mvebu_cpu_reset_init
ARM: mvebu: Staticize armada_370_xp_cpu_pm_init
ARM: mvebu: Staticize armada_375_smp_cpu1_enable_wa
ARM: mvebu: Use system controller to get the soc id when possible
ARM: mvebu: Use the a standard errno in mvebu_get_soc_id
ARM: mvebu: Don't apply the thermal quirk if the SoC revision is unknown
Documentation: arm: add URLs to public datasheets for the Marvell Armada 370 SoC
ARM: mvebu: implement CPU hotplug support for Armada XP
ARM: mvebu: export PMSU idle enter/exit functions
ARM: mvebu: slightly refactor/rename PMSU idle related functions
ARM: mvebu: remove stub implementation of CPU hotplug on Armada 375/38x
ARM: Kirkwood: Add setup file for netxbig LEDs
ARM: mvebu: mark armada_370_xp_pmsu_idle_prepare() as static
Merge "mvebu fixes for v3.16" from Jason Cooper:
- mvebu
- Fix broken SoC ID detection
- Select ARM_CPU_SUSPEND for v7
- Remove armada38x compatible string (no users yet)
- kirkwood
- Fix phy-connection-type on GuruPlug board
* tag 'mvebu-fixes-3.16' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: Fix the improper use of the compatible string armada38x using a wildcard
ARM: dts: kirkwood: fix phy-connection-type for Guruplug
ARM: mvebu: select ARM_CPU_SUSPEND for Marvell EBU v7 platforms
ARM: mvebu: Fix broken SoC ID detection
There is currently no DT binding for the CPLD which controls the LEDs
on the Net 2Big and Net 5Big. So use a platform device.
Link: https://lkml.kernel.org/r/1401132591-26305-2-git-send-email-andrew@lunn.ch
Tested-by: Simon Guinot <simon.guinot@sequanux.org>
On Marvell Armada platforms, the PMSU (Power Management Service Unit)
controls a number of power management related activities, needed for
things like suspend/resume, CPU hotplug, cpuidle or even simply SMP.
Since cpuidle support was added for Armada XP, the pmsu.c file in
arch/arm/mach-mvebu/ calls the cpu_suspend() and cpu_resume() ARM
functions, which are only available when
CONFIG_ARM_CPU_SUSPEND=y. Therefore, configurations that have
CONFIG_ARM_CPU_SUSPEND disabled due to PM_SLEEP being disabled no
longer build properly, due to undefined references to cpu_suspend()
and cpu_resume().
To fix this, this patch simply ensures CONFIG_ARM_CPU_SUSPEND is
always enabled for Marvell EBU v7 platforms. Doing things in a more
fine-grained way would require a lot of #ifdef-ery in pmsu.c to
isolate the parts that use cpu_suspend()/cpu_resume(), and those parts
would anyway have been needed as soon as either one of suspend/resume,
CPU hotplug or cpuidle was enabled.
Reported-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Link: https://lkml.kernel.org/r/1402488397-31381-1-git-send-email-thomas.petazzoni@free-electrons.com
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Currently the mvebu boards need to detect the SoC revision in order to apply
some quirks needed to workaround issues found on I2C and thermal controllers
present only in very early SoC.
This detection requires PCI address translation to work, so we need to
explicitly select OF_ADDRESS_PCI.
This can be considered a partial revert of the following commit, that
wrongly removed the option selection:
commit 55400f3a1f89e39761f45c19f6e4235a329c400b
Author: Rob Herring <robh@kernel.org>
Date: Tue Apr 22 14:15:52 2014 -0500
ARM: mvebu: clean-up unneeded kconfig selects
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Link: https://lkml.kernel.org/r/1402347165-19988-1-git-send-email-ezequiel.garcia@free-electrons.com
Acked-by: Rob Herring <robh@kernel.org>
The System Type menu is getting quite long with platforms and is
inconsistent in handling of sub-arch specific options. Tidy up the menu
by making platform options a menuconfig entry containing any platform
specific config items.
[arnd: change OMAP part according to suggestion from
Tony Lindgren <tony@atomide.com>]
This config exists entirely to hide the cpufreq menu from the
kernel configuration unless a platform has selected it. Nothing
is actually built if this config is 'Y' and it just leads to more
patches that add a select under a platform Kconfig so that some
other CPUfreq option can be chosen. Let's remove the option so
that we can always enable CPUfreq drivers on ARM platforms.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull part one of ARM SoC updates from Olof Johansson:
"A quite large set of SoC updates this cycle. In no particular order:
- Multi-cluster power management for Samsung Exynos, adding support
for big.LITTLE CPU switching on EXYNOS5
- SMP support for Marvell Armada 375 and 38x
- SMP rework on Allwinner A31
- Xilinx Zynq support for SOC_BUS, big endian
- Marvell orion5x platform cleanup, modernizing the implementation
and moving to DT.
- _Finally_ moving Samsung Exynos over to support MULTIPLATFORM, so
that their platform can be enabled in the same kernel binary as
most of the other v7 platforms in the tree. \o/
The work isn't quite complete, there's some driver fixes still
needed, but the basics now work.
New SoC support added:
- Freescale i.MX6SX
- LSI Axxia AXM55xx SoCs
- Samsung EXYNOS 3250, 5260, 5410, 5420 and 5800
- STi STIH407
plus a large set of various smaller updates for different platforms.
I'm probably missing some important one here"
* tag 'soc-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (281 commits)
ARM: exynos: don't run exynos4 l2x0 setup on other platforms
ARM: exynos: Fix "allmodconfig" build errors in mcpm and hotplug
ARM: EXYNOS: mcpm rename the power_down_finish
ARM: EXYNOS: Enable mcpm for dual-cluster exynos5800 SoC
ARM: EXYNOS: Enable multi-platform build support
ARM: EXYNOS: Consolidate Kconfig entries
ARM: EXYNOS: Add support for EXYNOS5410 SoC
ARM: EXYNOS: Support secondary CPU boot of Exynos3250
ARM: EXYNOS: Add Exynos3250 SoC ID
ARM: EXYNOS: Add 5800 SoC support
ARM: EXYNOS: initial board support for exynos5260 SoC
clk: exynos5410: register clocks using common clock framework
ARM: debug: qcom: add UART addresses to Kconfig help for APQ8084
ARM: sunxi: allow building without reset controller
Documentation: devicetree: arm: sort enable-method entries
ARM: rockchip: convert smp bringup to CPU_METHOD_OF_DECLARE
clk: exynos5250: Add missing sysmmu clocks for DISP and ISP blocks
ARM: dts: axxia: Add reset controller
power: reset: Add Axxia system reset driver
ARM: axxia: Adding defconfig for AXM55xx
When targetting ARCH_MULTIPLATFORM, we may include support for SoCs with
PCI-capable devices (e.g. mach-virt with virtio-pci).
This patch allows PCI support to be selected for these SoCs by selecting
CONFIG_MIGHT_HAVE_PCI when CONFIG_ARCH_MULTIPLATFORM=y and removes the
individual selections from multi-platform enabled SoCs.
Bring in the cleanup branch due to conflicts in new additions. Should really
have been the base before the other branch, but this way works too.
* cleanup/kconfig:
ARM: qcom: clean-up unneeded kconfig selects
ARM: bcm: clean-up unneeded kconfig selects
Remove platform device instantiating of the audio, which results in
board-t5325.c being removed. A DT node will be added to take its
place.
Link: https://lkml.kernel.org/r/1399141819-23924-7-git-send-email-andrew@lunn.ch
HAVE_ARM_TWD depends on SMP, so we should only select it if
SMP is enabled, as the others platforms do.
Link: https://lkml.kernel.org/r/1398339276-5754-1-git-send-email-ezequiel.garcia@free-electrons.com
This commit adds the SMP support for Armada 375 and Armada 38x. It
turns out that the SMP logic for both of these SOCs are fairly
similar, the only differences being:
* A different method to set the secondary CPU boot address
* An Armada 375 specific workaround needed for the early Z1 stepping,
added by the following patch.
Other than that, the patch is fairly straightforward and adds the
usual platsmp and headsmp code, defining the smp_operations structure
that is referenced from the DT_MACHINE structures.
Link: https://lkml.kernel.org/r/1397483648-26611-9-git-send-email-thomas.petazzoni@free-electrons.com
Contrary to the Armada 370 and XP that used the PJ4B Marvell cores,
the Armada 375 and Armada 38x use the ARM Cortex-A9. A consequence of
this is that the unit responsible for the coherency between CPUs is
now the ARM SCU, and not the Marvell coherency unit (which is still
present to do coherency with I/O devices).
Therefore this commit:
* Ensures that the selection of the Armada 375 or Armada 38x SoC
support enables the ARM SCU support in the kernel.
* Make sure to initialize the SCU at boot time.
Link: https://lkml.kernel.org/r/1397483228-25625-6-git-send-email-thomas.petazzoni@free-electrons.com
Add the SoC Family, device ID and revision to /sys/bus/soc.
Link: https://lkml.kernel.org/r/1393955507-26436-1-git-send-email-andrew@lunn.ch
Multi-platform support implies all these options are already selected and
individual platforms don't need to select them.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Pull ARM SoC specific changes from Arnd Bergmann:
"Lots of changes specific to one of the SoC families. Some that stick
out are:
- mach-qcom gains new features, most importantly SMP support for the
newer chips (Stephen Boyd, Rohit Vaswani)
- mvebu gains support for three new SoCs: Armada 375, 380 and 385
(Thomas Petazzoni and Free-electrons team)
- SMP support for Rockchips (Heiko Stübner)
- Lots of i.MX changes (Shawn Guo)
- Added support for BCM5301x SoC (Hauke Mehrtens)
- Multiplatform support for Marvell Kirkwood and Dove (Andrew Lunn
and Sebastian Hesselbarth doing the final part of a long journey)
- Unify davinci platforms and remove obsolete ones (Sekhar Nori, Arnd
Bergmann)"
* tag 'soc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (126 commits)
ARM: sunxi: Select HAVE_ARM_ARCH_TIMER
ARM: cache-tauros2: remove ARMv6 code
ARM: mvebu: don't select CONFIG_NEON
ARM: davinci: fix DT booting with default defconfig
ARM: configs: bcm_defconfig: enable bcm590xx regulator support
ARM: davinci: remove tnetv107x support
MAINTAINERS: Update ARM STi maintainers
ARM: restrict BCM_KONA_UART to ARCH_BCM_MOBILE
ARM: bcm21664: Add board support.
ARM: sunxi: Add the new watchog compatibles to the reboot code
ARM: enable ARM_HAS_SG_CHAIN for multiplatform
ARM: davinci: remove da8xx_omapl_defconfig
ARM: davinci: da8xx: fix multiple watchdog device registration
ARM: davinci: add da8xx specific configs to davinci_all_defconfig
ARM: davinci: enable da8xx build concurrently with older devices
ARM: BCM5301X: workaround suppress fault
ARM: BCM5301X: add early debugging support
ARM: BCM5301X: initial support for the BCM5301X/BCM470X SoCs with ARM CPU
ARM: mach-bcm: Remove GENERIC_TIME
ARM: shmobile: APMU: Fix warnings due to improper printk formats
Pull ARM SoC cleanups from Arnd Bergmann:
"These cleanup patches are mainly move stuff around and should all be
harmless. They are mainly split out so that other branches can be
based on top to avoid conflicts.
Notable changes are:
- We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no
longer used (Uwe Kleine-König)
- The Qualcomm MSM platform is split out into legacy mach-msm and
new-style mach-qcom, to allow easier maintainance of the new
hardware support without regressions (Kumar Gala)
- A rework of some of the Kconfig logic to simplify multiplatform
support (Rob Herring)
- Samsung Exynos gets closer to supporting multiplatform (Sachin
Kamat and others)
- mach-bcm3528 gets merged into mach-bcm (Stephen Warren)
- at91 gains some common clock framework support (Alexandre Belloni,
Jean-Jacques Hiblot and other French people)"
* tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits)
ARM: hisi: select HAVE_ARM_SCU only for SMP
ARM: efm32: allow uncompress debug output
ARM: prima2: build reset code standalone
ARM: at91: add PWM clock
ARM: at91: move sam9261 SoC to common clk
ARM: at91: prepare common clk transition for sam9261 SoC
ARM: at91: updated the at91_dt_defconfig with support for the ADS7846
ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek
ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs
ARM: at91: dt: Add at91sam9261 dt SoC support
ARM: at91: switch sam9rl to common clock framework
ARM: at91/dt: define main clk frequency of at91sam9rlek
ARM: at91/dt: define at91sam9rl clocks
ARM: at91: prepare common clk transition for sam9rl SoCs
ARM: at91: prepare sam9 dt boards transition to common clk
ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek
ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs
ARM: at91: Add at91sam9rl DT SoC support
ARM: at91: prepare at91sam9rl DT transition
ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig
CONFIG_NEON is meant to be user-selectable. Turning it on
unconditionally means we can't build a smaller kernel when
we don't need it, and causes build errors if CONFIG_VFP
is not also enabled.
To still have neon enabled however, we need to turn it on
now in multi_v7_defconfig and mvebu_v7_defconfig.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Gregory Clement <gregory.clement@free-electrons.com>
next/soc
Merge "mvebu soc changes for v3.15 (incremental #3)" from Jason Cooper:
- dove
- move devicetree code from mach-dove/ to mach-mvebu/ :-)
* tag 'mvebu-soc-3.15-3' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: move DT Dove to MVEBU
next/soc
Merge "mvebu soc changes for v3.15 (incremental pull #2)" from Jason Cooper:
- mvebu
- Add Armada 375, 380 and 385 SoCs
- kirkwood
- move kirkwood DT support to mach-mvebu
- add mostly DT support for HP T5325 thin client
* tag 'mvebu-soc-3.15-2' of git://git.infradead.org/linux-mvebu:
ARM: kirkwood: Add HP T5325 thin client
ARM: kirkwood: select dtbs based on SoC
ARM: kirkwood: Remove redundant kexec code
ARM: mvebu: Armada 375/38x depend on MULTI_V7
ARM: mvebu: Simplify headers and make local
ARM: mvebu: Enable mvebu-soc-id on Kirkwood
ARM: mvebu: Let kirkwood use the system controller for restart
ARM: mvebu: Move kirkwood DT boards into mach-mvebu
ARM: MM Enable building Feroceon L2 cache controller with ARCH_MVEBU
ARM: Fix default CPU selection for ARCH_MULTI_V5
ARM: MM: Add DT binding for Feroceon L2 cache
ARM: orion: Move cache-feroceon-l2.h out of plat-orion
ARM: mvebu: Add ARCH_MULTI_V7 to SoCs
ARM: kirkwood: ioremap memory control register
ARM: kirkwood: ioremap the cpu_config register before using it.
ARM: kirkwood: Separate board-dt from common and pcie code.
ARM: kirkwood: Drop printing the SoC type and revision
ARM: kirkwood: Convert mv88f6281gtw_ge switch setup to DT
ARM: kirkwood: Give pm.c its own header file.
ARM: mvebu: Rename the ARCH_MVEBU menu option
into next/soc
i.MX SoC changes for 3.15 from Shawn Guo:
- Support suspend from ocram (DDR IO floating) for imx6 platforms
- Add cpuidle support for imx6sl
- Sparse warning fixes for imx6sl and vf610 clock code
- Remove PWM platform code
- Support ptp and rmii clock from pad
- Support WEIM CS GPR configuration
- Random cleanups and defconfig updates
* tag 'imx-soc-3.15' of git://git.linaro.org/people/shawnguo/linux-2.6: (373 commits)
ARM: imx6: drop .text.head section annotation from headsmp.S
ARM: imx6: build suspend-imx6.o with CONFIG_SOC_IMX6
ARM: imx6: rename pm-imx6q.c to pm-imx6.c
ARM: imx6: introduce CONFIG_SOC_IMX6 for i.MX6 common stuff
ARM: imx6: do not call imx6q_suspend_init() with !CONFIG_SUSPEND
ARM: imx6: call suspend_set_ops() from suspend routine
ARM: imx6: build headsmp.o only on CONFIG_SMP
ARM: imx6: move v7_cpu_resume() into suspend-imx6.S
ARM i.MX6q: Mark VPU and IPU AXI transfers as cacheable, increase IPU priority
ARM: imx6q: Add GPR6 and GPR7 register definitions for iomuxc gpr
bus: imx-weim: support CS GPR configuration
ARM: mach-imx: Kconfig: Remove IMX_HAVE_PLATFORM_IMX2_WDT from SOC_IMX53
ARM: imx_v6_v7_defconfig: Select CONFIG_DEBUG_FS
ARM: mach-imx: Select CONFIG_SRAM at ARCH_MXC level
ARM: imx: add speed grading check for i.mx6 soc
ARM: imx: avoid calling clk APIs in idle thread which may cause schedule
ARM: imx6q: support ptp and rmii clock from pad
ARM: imx6q: remove unneeded clk lookups
ARM: imx_v6_v7_defconfig: Select CONFIG_MMC_UNSAFE_RESUME
ARM: imx_v4_v5_defconfig: Select CONFIG_MMC_UNSAFE_RESUME
With all the DT support preparation done, we are able to move Dove
to MVEBU easily. Legacy non-DT mach-dove is left untouched to rot
for a while before removal.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Convert the kirkwood t5325-setup.c to mostly device tree for
mach-mvebu. Part of the audio setup needs to remain in C for the
moment until suitable bindings are designed and implemented. So add
board code, triggered by the compatibility string.
During this release cycle, we're adding the new Armada 375, 380, and 385
SoCs. We're also migrating DT kirkwood boards into mach-mvebu. The
kirkwood changes make the different SoCs in mach-mvebu/ depend on
MULTI_V7 or MULTI_V5 as appropriate.
We add this dependency to the new SoCs so that when the branches are
merged, everything is as it should be.
Acked-by: Andrew Lunn <andrew@lunn.ch>
Move the kirkwood DT support into mach-mvebu, and make them part of
ARCH_MULTI_V5. Minimal changes have been made in order to make it
boot. Cleanup of the header files and integration with mvebu will
take place in following patches.
In order to help Debian transition between mach-kirkwood and
mach-mvebu, the DTS files are compiled for both, allowing Debian to
continue using mach-kirkwood until all remaining boards are supported
by mach-mvebu. Debian is then expected to simply swap from
mach-kirkwood to mach-mvebu and mach-kirkwood will be removed.
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Prepare mach-mvebu to house both ARCH_MULTI_V7 and ARCH_MULTI_V5
systems by adding ARCH_MULTI_V7 to the existing SOCs.
The previous name "Marvell SOCs with Device Tree support" is a bit
ambiguous and not too informative for users. Instead, use a more
appropriate name.
This commit adds the basic support for the Armada 380 and Armada 385
SOCs. These SoCs share most of their IP with the Armada 370/XP
SoCs. The main difference is the use of a Cortex A9 CPU instead of the
PJ4B CPU. The Armada 380 is a single core Cortex-A9, while the Armada
385 is a dual-core Cortex-A9.
The support is introduced in board-v7.c, together with Armada 370/XP,
but a separate DT structure is added, because Armada 38x will need a
different set of SMP operations when the SMP support is introduced.
This commit adds the basic support for the Armada 375 SOCs. These SoCs
share most of their IP with the Armada 370/XP SoCs. The main
difference is the use of a Cortex A9 CPU instead of the PJ4B CPU. The
interrupt controller and the L2 cache controller are also different
they are respectively the GIC and the PL310.
but a separate DT structure is added, because Armada 375 will need a
Until now, the CPU_PJ4B Kconfig option was selected by
MACH_ARMADA_MVEBU, i.e for all Armada MVEBU SOCs. In preparation to
the introduction of Cortex-A9 based Armada MVEBU SOCs, this selection
is moved down to the Armada 370 and Armada XP specific options.
