[ Upstream commit d0d378ff451a66e486488eec842e507d28145813 ]
With CONFIG_FORTIFY_SOURCE, memcpy uses the declared size of operands to
detect buffer overflows. If src or dest is declared as a char, attempts to
copy more than byte will result in a fortify_panic().
Address this problem in mvebu_setup_boot_addr_wa() by declaring
mvebu_boot_wa_start and mvebu_boot_wa_end as character arrays. Also remove
a couple addressof operators to avoid "arithmetic on pointer to an
incomplete type" compiler error.
See commit 54a7d50b9205 ("x86: mark kprobe templates as character arrays,
not single characters") for a similar fix.
Fixes "detected buffer overflow in memcpy" error during init on some mvebu
systems (armada-370-xp, armada-375):
(fortify_panic) from (mvebu_setup_boot_addr_wa+0xb0/0xb4)
(mvebu_setup_boot_addr_wa) from (mvebu_v7_cpu_pm_init+0x154/0x204)
(mvebu_v7_cpu_pm_init) from (do_one_initcall+0x7c/0x1a8)
(do_one_initcall) from (kernel_init_freeable+0x1bc/0x254)
(kernel_init_freeable) from (kernel_init+0x8/0x114)
(kernel_init) from (ret_from_fork+0x14/0x2c)
Signed-off-by: Ethan Tuttle <ethan@ethantuttle.com>
Tested-by: Ethan Tuttle <ethan@ethantuttle.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
The file is missing definitions for some functions due to not
including two header files. Fix the following warnings by
including "pmsu.h" and <linux/mvebu-pmsu.h> in pmsu.c:
arch/arm/mach-mvebu/pmsu.c:127:5: warning: symbol 'mvebu_setup_boot_addr_wa' was not declared. Should it be static?
arch/arm/mach-mvebu/pmsu.c:267:5: warning: symbol 'armada_370_xp_pmsu_idle_enter' was not declared. Should it be static?
arch/arm/mach-mvebu/pmsu.c:313:5: warning: symbol 'armada_38x_do_cpu_suspend' was not declared. Should it be static?
arch/arm/mach-mvebu/pmsu.c:340:6: warning: symbol 'mvebu_v7_pmsu_idle_exit' was not declared. Should it be static?
arch/arm/mach-mvebu/pmsu.c:570:5: warning: symbol 'mvebu_pmsu_dfs_request' was not declared. Should it be static?
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Move cpufreq bits for mvebu into drivers/cpufreq/ directory, that's
where they really belong to.
Compiled tested only.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
That will allow us to avoid using cpufreq-dt platform data.
Pull ARM SoC platform updates from Olof Johansson:
"New and/or improved SoC support for this release:
Marvell Berlin:
- Enable standard DT-based cpufreq
- Add CPU hotplug support
Freescale:
- Ethernet init for i.MX7D
- Suspend/resume support for i.MX6UL
Allwinner:
- Support for R8 chipset (used on NTC's $9 C.H.I.P board)
Mediatek:
- SMP support for some platforms
Uniphier:
- L2 support
- Cleaned up SMP support, etc.
plus a handful of other patches around above functionality, and a few
other smaller changes"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits)
ARM: uniphier: rework SMP operations to use trampoline code
ARM: uniphier: add outer cache support
Documentation: EXYNOS: Update bootloader interface on exynos542x
ARM: mvebu: add broken-idle option
ARM: orion5x: use mac_pton() helper
ARM: at91: pm: at91_pm_suspend_in_sram() must be 8-byte aligned
ARM: sunxi: Add R8 support
ARM: digicolor: select pinctrl/gpio driver
arm: berlin: add CPU hotplug support
arm: berlin: use non-self-cleared reset register to reset cpu
ARM: mediatek: add smp bringup code
ARM: mediatek: enable gpt6 on boot up to make arch timer working
soc: mediatek: Fix random hang up issue while kernel init
soc: ti: qmss: make acc queue support optional in the driver
soc: ti: add firmware file name as part of the driver
Documentation: dt: soc: Add description for knav qmss driver
ARM: S3C64XX: Use PWM lookup table for mach-smartq
ARM: S3C64XX: Use PWM lookup table for mach-hmt
ARM: S3C64XX: Use PWM lookup table for mach-crag6410
ARM: S3C64XX: Use PWM lookup table for smdk6410
The broken-idle option can be activated from the coherency-fabric DT
node. This property allows to disable the idle capability, when the
hardware doesn't support it, like the Seagate Personal Cloud boards.
Signed-off-by: Vincent Donnefort <vdonnefort@gmail.com>
Fix the armada_370_xp_pmsu_idle_enter() function to use a CR_C
constant instead of a hard-coded constant in the assembly part.
This clean-up was suggested by Russell King.
Commit 548ae94c1cc7f ("ARM: mvebu: Disable CPU Idle on Armada 38x")
added two new pr_warn() messages in mach-mvebu/pmsu.c. However, these
messages lack the final new line, causing the next message to be
displayed on the same line.
This commit adds the missing ending newlines.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
On Armada 38x SoCs, under heavy I/O load, the system hangs when CPU
Idle is enabled. Waiting for a solution to this issue, this patch
disables the CPU Idle support for this SoC.
As CPU Hot plug support also uses some of the CPU Idle functions it is
also affected by the same issue. This patch disables it also for the
Armada 38x SoCs.
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: <stable@vger.kernel.org> # v3.17 +
of_device_ids (i.e. compatible strings and the respective data) are not
supposed to change at runtime. All functions working with of_device_ids
provided by <linux/of.h> work with const of_device_ids. So mark the
non-const structs in arch/arm as const, too.
While at it also add some __initconst annotations.
Acked-by: Jason Cooper <jason@lakedameon.net>
This commit adjusts the registration of the cpufreq-dt driver in the
mvebu platform to indicate to the cpufreq driver that the platform has
independent clocks for each CPU.
Acked-by: Jason Cooper <jason@lakedaemon.net>
This commit implements the CPU hotplug support for the Marvell Armada
38x platform. Similarly to what was done for the Armada XP, this
commit:
* Implements the ->cpu_die() function of SMP operations by calling
armada_38x_do_cpu_suspend() to enter the deep idle state for
CPUs going offline.
* Implements a dummy ->cpu_kill() function, simply needed for the
kernel to know we have CPU hotplug support.
* The mvebu_cortex_a9_boot_secondary() function makes sure to wake up
the CPU if waiting in deep idle state by sending an IPI before
deasserting the CPUs from reset. This is because
mvebu_cortex_a9_boot_secondary() is now used in two different
situations: for the initial boot of secondary CPUs (where CPU reset
deassert is used to wake up CPUs) and for CPU hotplug (where an IPI
is used to take CPU out of deep idle).
* At boot time, we exit from the idle state in the
->smp_secondary_init() hook.
This commit has been tested using CPU hotplug through sysfs
(/sys/devices/system/cpu/cpuX/online) and using kexec.
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1414669184-16785-5-git-send-email-gregory.clement@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This patch removes the unneeded include of the armada-370-xp.h header.
It also moves some declarations from this file into more accurate
places.
Finally, it also adds a comment explaining that we can't remove yet the
smp field in the dt machine struct due to backward compatibly of the
device tree.
In a few releases, when the old device tree will be obsolete, we will be
able to remove the smp field and then the armada-370-xp.h header.
Link: https://lkml.kernel.org/r/1414669184-16785-2-git-send-email-gregory.clement@free-electrons.com
The naming convention of this driver was always under the scanner, people
complained that it should have a more generic name than cpu0, as it manages all
CPUs that are sharing clock lines.
Also, in future it will be modified to support any number of clusters with
separate clock/voltage lines.
Lets rename it to 'cpufreq_dt' from 'cpufreq_cpu0'.
Tested-by: Stephen Boyd <sboyd@codeaurora.org>
Unlike the Armada XP and the Armada 370, this SoC uses a Cortex A9
core. Consequently, the procedure to enter the idle state is
different: interaction with the SCU, not disabling snooping, etc.
Link: https://lkml.kernel.org/r/1406120453-29291-16-git-send-email-thomas.petazzoni@free-electrons.com
This commit introduces the cpuidle support for Armada 370. The main
difference compared to the already supported Armada XP is that the
Armada 370 has an issue caused by "a slow exit process from the deep
idle state due to heavy L1/L2 cache cleanup operations performed by
the BootROM software" (cf errata GL-BootROM-10).
To work around this issue, we replace the restart code of the BootROM
by some custom code located in an internal SRAM. For this purpose, we
use the common function mvebu_boot_addr_wa() introduced in the commit
"ARM: mvebu: Add a common function for the boot address work around".
The message in case of failure to suspend the system was switched from
the warn level to the debug level. Indeed due to the "slow exit
process from the deep idle state" in Armada 370, this situation
happens quite often. Using the debug level avoids spamming the kernel
logs, but still allows to enable it if needed.
Link: https://lkml.kernel.org/r/1406120453-29291-15-git-send-email-thomas.petazzoni@free-electrons.com
This driver will be able to manage the cpuidle for more SoCs than just
Armada 370 and XP. It will also support Armada 38x and potentially
other SoC of the Marvell Armada EBU family. To take this into account,
this patch renames the driver and its symbols.
It also changes the driver name from cpuidle-armada-370-xp to
cpuidle-armada-xp, because separate platform drivers will be
registered for the other SoC types. This change must be done
simultaneously in the cpuidle driver and in the PMSU code in order to
remain bisectable.
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Link: https://lkml.kernel.org/r/1406120453-29291-12-git-send-email-thomas.petazzoni@free-electrons.com
On some mvebu v7 SoCs (the ones using a Cortex-A9 core and not a PJ4B
core), the snoop disabling feature does not exist as the hardware
coherency is handled in a different way. Therefore, in preparation to
the introduction of the cpuidle support for those SoCs, this commit
modifies the mvebu_v7_psmu_idle_prepare() function to take several
flags, which allow to decide whether snooping should be disabled, and
whether we should use the deep idle mode or not.
Link: https://lkml.kernel.org/r/1406120453-29291-9-git-send-email-thomas.petazzoni@free-electrons.com
The resume address used by the cpuidle code will not always be the
same depending on the SoC. Using a local variable to store the resume
address allows to keep the same function for the PM notifier but with
a different address. This address will be set during the
initialization of the cpuidle logic in pmsu.c.
Link: https://lkml.kernel.org/r/1406120453-29291-8-git-send-email-thomas.petazzoni@free-electrons.com
In preparation to the addition of the cpuidle support for more SoCs,
this patch moves the Armada XP specific initialization to a separate
function.
Link: https://lkml.kernel.org/r/1406120453-29291-7-git-send-email-thomas.petazzoni@free-electrons.com
Most of the function related to the PMSU are not specific to the
Armada 370 or Armada XP SoCs. They can also be used for most of the
other mvebu ARMv7 SoCs, and will actually be used to support cpuidle
on Armada 38x.
Link: https://lkml.kernel.org/r/1406120453-29291-6-git-send-email-thomas.petazzoni@free-electrons.com
On some of the mvebu SoCs and due to internal BootROM issue, the CPU
initial jump code must be placed in the SRAM memory of the SoC. In
order to achieve this, we have to unmap the BootROM and at some
specific location where the BootROM was placed, create a dedicated
MBus window for the SRAM. This SRAM is initialized with a few
instructions of code that allows to jump to the real secondary CPU
boot address. The SRAM used is the Crypto engine one.
This work around is currently needed for booting SMP on Armada 375 Z1
and will be needed for cpuidle support on Armada 370. Instead of
duplicating the same code, this commit introduces a common function to
handle it: mvebu_setup_boot_addr_wa().
Link: https://lkml.kernel.org/r/1406120453-29291-4-git-send-email-thomas.petazzoni@free-electrons.com
Sorting the headers in alphabetic order will help to reduce conflicts
when adding new headers later.
Link: https://lkml.kernel.org/r/1406120453-29291-3-git-send-email-thomas.petazzoni@free-electrons.com
do_armada_370_xp_cpu_suspend() and armada_370_xp_pmsu_idle_prepare(),
have been merged into a single function called
armada_370_xp_pmsu_idle_enter() by the commit "bbb92284b6c8 ARM:
mvebu: slightly refactor/rename PMSU idle related functions", in
prepare for the introduction of the CPU hotplug support for Armada XP.
But for cpuidle the prepare function will be common to all the mvebu
SoCs that use the PMSU, while the suspend function will be specific to
each SoC. Keeping the prepare function separate will help reducing
code duplication while new SoC support is added.
Link: https://lkml.kernel.org/r/1406120453-29291-2-git-send-email-thomas.petazzoni@free-electrons.com
In case of error, the function clk_get() returns ERR_PTR()
and never returns NULL. The NULL test in the return value
check should be replaced with IS_ERR().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Link: https://lkml.kernel.org/r/1406038688-26417-1-git-send-email-weiyj_lk@163.com
This commit adds the necessary code in the Marvell EBU PMSU driver to
support dynamic frequency scaling. In essence, what this new code does
is that it:
* registers the frequency operating points supported by the CPU;
* registers a clock notifier of the CPU clocks. The notifier function
listens to the newly introduced APPLY_RATE_CHANGE event, and uses
that to finalize the frequency transition by doing the part of the
procedure that involves the PMSU;
* registers a platform device for the cpufreq-generic driver, which
will take care of the CPU frequency transitions.
Link: https://lkml.kernel.org/r/1404920715-19834-3-git-send-email-thomas.petazzoni@free-electrons.com
In the inline asm part of the function armada_370_xp_pmsu_idle_enter()
the input operand was used. The intent here was to let the compiler
choose this register so it could do the optimization it
needed.
However an input operand is not supposed to be modified by the inline
asm code. This can lead to improper generated instructions.
In some case generated instruction the compiler made the choice to
reuse the same register to store the return value. But in the assembly
part this register was modified, so it can lead to return an wrong
value.
The fix is to use a clobber. Thanks to this the compiler will know
that the value of this register will be modified.
Link: https://lkml.kernel.org/r/1404483736-16938-1-git-send-email-gregory.clement@free-electrons.com
On Marvell Armada XP, when a CPU comes back from deep idle state of
cpuidle, it restarts its execution at armada_370_xp_cpu_resume(),
which puts back the CPU into the coherency, and then calls the generic
cpu_resume() function.
While this works on little-endian configurations, it doesn't work on
big-endian configurations because the CPU restarts in little-endian,
and therefore must be switched back to big-endian to operate
properly. To achieve this, a 'setend be' instruction must be executed
in big-endian configurations. However, the ARM_BE8() macro that is
used to implement nice compile-time conditional for ARM LE vs. ARM BE8
is not easily usable in inline assembly.
Therefore, this patch moves the armada_370_xp_cpu_resume() C function,
which was anyway just a block of inline assembly, into a proper
pmsu_ll.S file, and adds the appropriate ARM_BE8(setend be)
instruction.
Without this patch, an Armada XP big endian configuration with cpuidle
enabled fails to boot, as it hangs as soon as one of the CPU hits the
deep idle state.
Link: https://lkml.kernel.org/r/1404130165-3593-1-git-send-email-thomas.petazzoni@free-electrons.com
'armada_370_xp_cpu_pm_init' is local to this file.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Link: https://lkml.kernel.org/r/1403610235-22654-3-git-send-email-sachin.kamat@samsung.com
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
The PMSU idle enter/exit functions will be needed for the CPU hotplug
implementation on Armada XP, so this commit removes their static
qualifier, and adds the appropriate prototypes in armada-370-xp.h.
Link: https://lkml.kernel.org/r/1401481098-23326-4-git-send-email-thomas.petazzoni@free-electrons.com
The CPU hotplug code will need to call into PMSU functions to enter
and exit from deep idle states. However, the deep idle state is
currently entered by a function called do_armada_370_xp_cpu_suspend()
whose name really suggests it's an internal function, but we need to
export it to other files in mach-mvebu.
Therefore, this commit:
* Merges the code of do_armada_370_xp_cpu_suspend() into
armada_370_xp_pmsu_idle_prepare(), into a single function called
armada_370_xp_pmsu_idle_enter(), which prepares the PMSU for deep
idle, and then enters the deep idle state. This code will be common
to both cpuidle and CPU hotplug.
* For symetry, it renames the armada_370_xp_pmsu_idle_restore()
function to armada_370_xp_pmsu_idle_exit().
We also remove the 'noinline' qualifier for these functions, which
apparently had no reason to be here.
Link: https://lkml.kernel.org/r/1401481098-23326-3-git-send-email-thomas.petazzoni@free-electrons.com
The armada_370_xp_pmsu_idle_prepare() function is only used internally
to pmsu.c, so there's no reason to not use the static qualifier.
Link: https://lkml.kernel.org/r/1401116474-31221-1-git-send-email-thomas.petazzoni@free-electrons.com
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The cpuidle is a platform driver so we register the device just after
the initialization of the board in an arch_initcall.
Link: https://lkml.kernel.org/r/1397488214-20685-12-git-send-email-gregory.clement@free-electrons.com
In order to have well encapsulated code, we use notifier callbacks for
CPU_PM_ENTER and CPU_PM_EXIT inside the mvebu power management code.
Link: https://lkml.kernel.org/r/1397488214-20685-10-git-send-email-gregory.clement@free-electrons.com
The cpu idle support will need to access to Power Management Service
Unit. This commit adds the architecture related functions that will be
used in the idle path of the cpuidle driver.
Link: https://lkml.kernel.org/r/1397488214-20685-9-git-send-email-gregory.clement@free-electrons.com
This commit adds a function which adjusts the PMSU configuration to
automatically power down the L2 and coherency fabric when we enter a
certain idle state.
This feature is part of the Power Management Service Unit of the
Armada 370 and Armada XP SoCs.
Link: https://lkml.kernel.org/r/1397488214-20685-8-git-send-email-gregory.clement@free-electrons.com
Since the Armada 38x PMSU registers are slightly different than the
Armada 370/XP PMSU ones, we introduce a new compatible string
"armada-380-pmsu" in the PMSU driver. These differences are not
visible for the current usage of the PMSU, but they might become
visible in the future.
Link: https://lkml.kernel.org/r/1397483648-26611-8-git-send-email-thomas.petazzoni@free-electrons.com
The pmsu.c driver contained an armada_xp_boot_cpu() function that sets
the boot address of a secondary CPUs and deasserts the reset. However,
the Armada 375 needs a slightly different logic, so it makes more
sense to move this code into the Armada XP specific platsmp.c.
In order to achieve this, the mvebu_pmsu_set_cpu_boot_addr() function
is exported. It will be needed for both the Armada XP and Armada 38x
SMP implementations.
Link: https://lkml.kernel.org/r/1397483648-26611-2-git-send-email-thomas.petazzoni@free-electrons.com
Setting the start (or boot) address of a CPU is no more used only
during SMP bring up on Armada 370/XP, but it will also be used by the
CPU idle function of Armada XP, and by the Armada 38x SMP support.
Therefore this commit creates a separate PMSU function to set the boot
address of a CPU with the PMSU.
Link: https://lkml.kernel.org/r/1397483433-25836-7-git-send-email-thomas.petazzoni@free-electrons.com
The initial binding for PMSU was wrong, as it didn't take into account
all the registers from the PMSU and moreover it referred to the CPU
reset registers which are not part of PMSU.
The Power Management Unit Service block also controls the Coherency
Fabric subsystem. These registers are needed for the CPU idle
implementation for the Armada 370/XP, it allows to enter a deep CPU
idle state where the Coherency Fabric and the L2 cache are powered
down.
This commit adds support for a new compatible for the PMSU node which
includes the registers related to the coherency fabric. It also keeps
compatibility with the old compatible string.
Link: https://lkml.kernel.org/r/1397483433-25836-5-git-send-email-thomas.petazzoni@free-electrons.com
Until now, the PMSU driver was using of_iomap() to map its registers,
but of_iomap() doesn't call request_mem_region(). This commit fixes
the memory mapping code of the PMSU to do so, which will also be
useful for a later commit since we will need to adjust the resource
base address and size for Device Tree backward compatibility.
Link: https://lkml.kernel.org/r/1397483433-25836-4-git-send-email-thomas.petazzoni@free-electrons.com
This commit changes the PMSU driver to no longer map itself the CPU
reset registers, and instead call into the CPU reset driver to
deassert the secondary CPUs for SMP booting.
In order to provide Device Tree backward compatibility, the CPU reset
driver is extended to not only support its official compatible string
"marvell,armada-370-cpu-reset", but to also look at the PMSU
compatible string "marvell,armada-370-xp-pmsu" to find the CPU reset
registers address. This allows old Device Tree to work correctly with
newer kernel versions. Therefore, the CPU reset driver implements the
following logic:
* If one of the normal compatible strings
"marvell,armada-370-cpu-reset" is found, then we map its first
memory resource as the CPU reset registers.
* Otherwise, if none of the normal compatible strings have been
found, we look for the "marvell,armada-370-xp-pmsu" compatible
string, and we map the second memory as the CPU reset registers.
Link: https://lkml.kernel.org/r/1397483433-25836-3-git-send-email-thomas.petazzoni@free-electrons.com
This patch fixes conflicting types for 'set_cpu_coherent' and fixes the
following sparse warnings.
arch/arm/mach-mvebu/system-controller.c:42:38:
warning: symbol 'armada_370_xp_system_controller' was not declared. Should it be static?
arch/arm/mach-mvebu/system-controller.c:49:38:
warning: symbol 'orion_system_controller' was not declared. Should it be static?
arch/arm/mach-mvebu/system-controller.c:67:6:
warning: symbol 'mvebu_restart' was not declared. Should it be static?
arch/arm/mach-mvebu/coherency.c:31:15:
warning: symbol 'coherency_phys_base' was not declared. Should it be static?
arch/arm/mach-mvebu/coherency.c:48:5:
warning: symbol 'set_cpu_coherent' was not declared. Should it be static?
arch/arm/mach-mvebu/coherency.c:123:12:
warning: symbol 'coherency_init' was not declared. Should it be static?
arch/arm/mach-mvebu/pmsu.c:38:5: warning:
symbol 'armada_xp_boot_cpu' was not declared. Should it be static?
arch/arm/mach-mvebu/pmsu.c:61:12: warning:
symbol 'armada_370_xp_pmsu_init' was not declared. Should it be static?
arch/arm/mach-mvebu/platsmp.c:49:13: warning:
symbol 'set_secondary_cpus_clock' was not declared. Should it be static?
arch/arm/mach-mvebu/platsmp.c:97:13: warning:
symbol 'armada_xp_smp_prepare_cpus' was not declared. Should it be static?
arch/arm/mach-mvebu/hotplug.c:24:12: warning:
symbol 'armada_xp_cpu_die' was not declared. Should it be static?
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Add of_node_put to properly decrement the refcount when we are
done using a given node.
Reviewed-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
arch/arm/mach-mvebu/armada-370-xp.c
The Armada 370 and Armada XP SOCs have a power management service unit
which is responsible for powering down and waking up CPUs and other
SOC units. This patch adds support for this unit.
Signed-off-by: Yehuda Yitschak <yehuday@marvell.com>
