path: root/arch/arm/mach-mx5
2011-08-08ARM: mx5: board-cpuimx51.c fixup irq_to_gpio() usageBen Dooks
irq_to_gpio() is being called on a GPIO so change to using gpio_to_irq() instead. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-08Merge commit 'v3.1-rc1' into imx-fixesSascha Hauer
2011-08-05ARM: iMX5: Don't enable DPLL if it already enabledJason Liu
If the DPLL is already enabled, don't try to enable it again. Since write to the DPLL control register will make the DPLL reset and which will cause some issues when some child module are sourced from this DPLL. Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-27dmaengine: imx-sdma: use platform_device_id to identify sdma versionShawn Guo
It might be not good to use software defined version to identify sdma device type, when hardware does not define such version. Instead, soc name is stable enough to define the device type. The patch uses platform_device_id rather than version number passed by platform data to identify sdma device type/version. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Vinod Koul <vinod.koul@intel.com>
2011-07-27mmc: sdhci-esdhc-imx: get rid of the uses of cpu_is_mx()Shawn Guo
The patch removes all the uses of cpu_is_mx(). Instead, it utilizes platform_device_id to distinguish the esdhc differences among SoCs. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Wolfram Sang <w.sang@pengutronix.de> Cc: Chris Ball <cjb@laptop.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Chris Ball <cjb@laptop.org>
2011-07-27mmc: sdhci-esdhc-imx: extend card_detect and write_protect support for mx5Shawn Guo
The patch extends card_detect and write_protect support to get mx5 family and more scenarios supported. The changes include: * Turn platform_data from optional to mandatory * Add cd_types and wp_types into platform_data to cover more use cases * Remove the use of flag ESDHC_FLAG_GPIO_FOR_CD * Adjust some machine codes to adopt the platform_data changes * Work around the issue that software reset will get card detection circuit stop working With this patch, card_detect and write_protect gets supported on mx5 based platforms. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Chris Ball <cjb@laptop.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Chris Ball <cjb@laptop.org>
2011-07-27net/fec: gasket needs to be enabled for some i.mxShawn Guo
On the recent i.mx (mx25/50/53), there is a gasket inside fec controller which needs to be enabled no matter phy works in MII or RMII mode. The current code enables the gasket only when phy interface is RMII. It's broken when the driver works with a MII phy. The patch uses platform_device_id to distinguish the SoCs that have the gasket and enables it on these SoCs for both MII and RMII mode. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reported-by: Troy Kisky <troy.kisky@boundarydevices.com> Cc: David S. Miller <davem@davemloft.net> Cc: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: David S. Miller <davem@davemloft.net>
2011-07-27serial/imx: get rid of the uses of cpu_is_mx1()Shawn Guo
The patch removes all the uses of cpu_is_mx1(). Instead, it uses the .id_table of platform_driver to distinguish the uart device type, IMX1_UART and IMX21_UART. The IMX21_UART type runs on all i.mx except i.mx1. A couple of !cpu_is_mx1 logic gets turned into is_imx21_uart, as the codes wrapped there are really IMX21 type uart specific. It also removes macro MX1_UCR3_REF25 and MX1_UCR3_REF30 which are not used anywhere. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Alan Cox <alan@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-26ARM: board-mx51_babbage: Fix UART2 registrationFabio Estevam
On MX51 Babbage board the RTS/CTS pins are not used on UART2 port. Fix the registration of this port. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-26efika: Fix board id detectionArnaud Patard (Rtp)
Current code is assuming that gpio_get_value() is returning 0 or 1 but it should be checking if the value is 0 or not. Not doing it properly is breaking the detection of the board (and thus the reboot of efika mx to2) when using the new mxc gpio driver, which relies on basic mmio gpio. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-26efikasb: fix gpio keys.Arnaud Patard (Rtp)
While testing the keys, I only checked that the key were generating an input event but unfortunately, they were not generating the right event. Fix that. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-26efikasb/mx: fix usbh1 initialisationArnaud Patard (Rtp)
mx51_initialize_usb_hw() support introduced a small error. The usbh1 has pdev->id equal to 1 not 0, so use pdev->id to make things less error-prone and to fix that. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-25Merge branch 'next/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (35 commits) ARM: msm: platsmp: determine number of CPU cores at boot time ARM: Tegra: Seaboard: Fix I2C bus numbering for ADT7461 ARM: Tegra: Trimslice: Tri-state DAP3 pinmux ARM: orion5x: fixup 5181 MPP mask check ARM: mxs-dma: include <linux/dmaengine.h> ARM: i.MX53: consistently use MX53_UART_PAD_CTRL for uart txd/rxd/rts/cts ARM: i.MX53: UARTn_CTS pin should not change RTS input select ARM: i.MX53: UARTn_TXD pin should not change RXD input select ARM: mx25: Fix typo on CAN1_RX pad setting iomux-mx53: add missing 'IOMUX_CONFIG_SION' for some I2C pad definitions ARM: NUC93X: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: LPC32XXX: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: CNS3XXX: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: i.MX53: Fix IOMUX type o's ARM i.MX dma: Fix burstsize settings mach-mx5: fix the I2C clock parents ARM: mxs/tx28: according to the TX28's datasheet D4-D7 are not used for MMC0 ARM i.MX23/28: platform-mxsfb: Add missing include of linux/dma-mapping.h ARM: mx53: Fix some interrupts marked as reserved. MXC: iomux-v3: correct NO_PAD_CTRL definition ... Fix up trivial conflict in arch/arm/mach-imx/mach-mx31_3ds.c
2011-07-22Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/imx: add device tree probe support spi/imx: copy gpio number passed by platform data into driver private data spi/imx: use soc name in spi device type naming scheme spi/imx: merge type SPI_IMX_VER_0_7 into SPI_IMX_VER_0_4 spi/imx: do not use spi_imx2_3 to name SPI_IMX_VER_2_3 function and macro spi/imx: use mx21 to name SPI_IMX_VER_0_0 function and macro spi/imx: do not make copy of spi_imx_devtype_data spi/dw: Add spi number into spi irq desc spi/tegra: Use engineering names in DT compatible property spi/fsl_spi: fix CPM spi driver mach-s3c2410: remove unused spi-gpio.h file spi: remove obsolete spi-s3c24xx-gpio driver mach-gta2: remove unused spi-gpio.h include mach-qt2410: convert to spi_gpio mach-jive: convert to spi_gpio spi/pxa2xx: Remove unavailable ssp_type from documentation spi/bfin_spi: uninline fat queue funcs spi/bfin_spi: constify pin array spi/bfin_spi: use structs for accessing hardware regs spi/topcliff-pch: Support new device ML7223 IOH ... Fix up trivial conflict in arch/arm/mach-ep93xx/Makefile
2011-07-14spi/imx: use soc name in spi device type naming schemeShawn Guo
Software defined version number is not stable enough to be used in device type naming scheme. The patch changes it to use implicit soc name for spi device type definition. In this way, we can easily align the naming scheme with device tree binding, which comes later. It removes fifosize from spi_imx_data and adds devtype there, so that fifosize can be set in an inline function according to devtype. Also, cpu_is_mx can be replaced by inline functions checking devtype. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-08gpio/mxc: get rid of the uses of cpu_is_mx()Shawn Guo
The patch removes all the uses of cpu_is_mx(). Instead, it utilizes platform_device_id to distinguish the different gpio types, IMX1_GPIO on i.mx1, IMX21_GPIO on i.mx21 and i.mx27, IMX31_GPIO on all other i.mx SoCs. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-07ARM: mach-mx5/mx53_ard: Add gpio_keys supportDaiane Angolini
Signed-off-by: Daiane Angolini <daiane.angolini@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM: mach-mx5/mx53_ard: Add missing definitionFabio Estevam
commit 9203d59 (ARM:mach-mx5/mx53_ard: Add I2C2 and I2C3 support) missed to include the define for ARD_I2CPORTEXP_B. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM: mx53: Add keypad supportFabio Estevam
2011-07-07ARM: mx53: Add SSI suportFabio Estevam
2011-07-07ARM: mx53: Add support for missing UARTsFabio Estevam
MX53 has five UART ports. Add support for the missing UART4 and UART5 ports. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07dmaengine: imx-sdma: pass sdma firmware name via platform dataShawn Guo
It is not good to have cpu_name and to_version encoded into sdma firmware name as variables. For example, there are three TOs of imx51 soc, the sdma script never changes since TO1, which means all three TOs of imx51 uses TO1 version of sdma script. But we have to prepare three identical firmwares, sdma-imx51-to1.bin sdma-imx51-to2.bin and sdma-imx51-to3.bin, to have the kernel capable of running on all three TOs. The patch removes cpu_name and to_version from sdma platform data, and instead uses fw_name to pass the firmware name, so that we can pass the TO version where it's relevant and skip it where only one firmware exists. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM: mxc: clean up imx-dma device registrationShawn Guo
The patch follows the implementation of gpio-mxc device registration to break the concentrated imx-dma device registration into soc specific setup function. Then we can avoid the churn of "#ifdef" and the cpu_is_mx checking on such a long list, which makes no sense, considering more soc supports need to be added and we need to support single image for multiple socs in the long run. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM:mach-mx5/mx53_ard: Add I2C2 and I2C3 supportAndre Silva
Signed-off-by: Andre Silva <andre.silva@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM:mx53: Add I2C3 supportAndre Silva
2011-07-07ARM: mx51: Add support for low power suspend on MX51Dinh Nguyen
Adds initial low power suspend functionality to MX51. Supports "mem" and "standby" modes. Tested on mx51-babbage. Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com> Tested-by: Arnaud Patard <arnaud.patard@rtp-net.org> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM: mx53: Add SDMA clockFabio Estevam
2011-07-07ARM:mach-mx5/mx53_ard: Add Watchdog timer supportAndre Silva
2011-07-07ARM:mach-mx5/mx53_ard: Add ESDHC supportAndre Silva
2011-07-07ARM:mach-mx5/board-mx51_babbage: Add CD and WP GPIOsAndre Silva
2011-07-07ARM:mach-mx5/board-mx53_loco: Add CD and WP GPIOsAndre Silva
2011-07-07ARM: mach-mx5/mx53_ard: Add support for i.MX53 ARD boardAndre Silva
Signed-off-by: Andre Silva <andre.silva@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM: mx5/mx53_evk: Add support for LEDFabio Estevam
2011-07-07ARM: mx5/mx53_loco: Add support for LEDFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07Merge remote-tracking branch 'grant/gpio/next-mx' into devel-featuresSascha Hauer
Conflicts: arch/arm/mach-imx/mach-mx31_3ds.c arch/arm/mach-imx/mach-scb9328.c Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM i.MX: get rid of wrong MXC_INTERNAL_IRQ usageSascha Hauer
There are several occurences where MXC_INTERNAL_IRQ is assumed to be the start of the gpio interrupts. It was never meant this way. Replace these with gpio_to_irq. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-07-07ARM: mx5: convert to new leds-gpio registration helperUwe Kleine-König
This gets rid of per machine struct platform_device definitions and allows to move the platform data and led definition to .init.rodata. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM: mx5/mx51_babbage: Use gpio_request_array for USBH1 pinsFabio Estevam
Instead of using gpio_request followed by gpio_direction_output use gpio_request_array when requesting multiple pins. Also fixed the location of the delay for the reset and make the BABBAGE_USB_PHY_RESET to toggle. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07ARM: mx5/mx51_babbage: Move GPIO initialization for USB PHY Reset line to ↵Fabio Estevam
common place The USB PHY Reset GPIO can be configured in the same place as the other GPIOs. While at it rename the pin as BABBAGE_USB_PHY_RESET to make clearer its purpose. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-07-07mach-mx5: fix the I2C clock parentsLothar Waßmann
The clock from which the I2C timing is derived is the ipg_perclk not ipg_clk. I2C bus frequency was lower by a factor of ~8 due to the clock divider calculation being based on 66.5MHz IPG clock while the bus actually uses 8MHz ipg_perclk. Kernel version: 3.0.0-rc2 branch 'imx-for-next' of git://git.pengutronix.de/git/imx/linux-2.6 Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-06-06gpio/mxc: Change gpio-mxc into an upstanding gpio driverShawn Guo
The patch makes necessary changes on gpio-mxc as below to turn it into an upstanding gpio driver. * Add a list to save all mx2 ports references, so that mx2_gpio_irq_handler can walk through all interrupt status registers * Use readl/writel to replace mach-specific accessors __raw_readl/__raw_writel * Change mxc_gpio_init into mxc_gpio_probe function * Move "struct mxc_gpio_port" into gpio-mxc.c, as it needs not to be public at all, and also make some other cleanup on plat-mxc/include/mach/gpio.h at the same time And the patch then migrates mach-imx and mach-mx5 to the updated driver by adding corresponding platform devices. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-19ARM: mxc: don't allow to compile together i.MX51 and i.MX53Uwe Kleine-König
The two SoCs have different PHYS_OFFSETs so it's not (yet) possible to compile a single (working) kernel for these. LAKML-Reference: 1302464943-20721-4-git-send-email-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-05-19ARM: mxc: don't use the symbols in the CPU family choice to select othersUwe Kleine-König
The symbols in this choice should only be used to select between the available machines that can be built into a single kernel. As these sets (will) differ e.g. depending on ARM_PATCH_PHYS_VIRT and AUTO_ZRELADDR letting them select other symbols makes the logic more complex and needs to duplicate some things. So let the machines select the corresponding symbols (indirectly via SOC_XYZ). LAKML-Reference: 1302464943-20721-2-git-send-email-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-05-19ARM: mx51: Remove imx51_add_gpio_keysFabio Estevam
There is no need for using a MX51-specific version of imx_add_gpio_keys. Remove imx51_add_gpio_keys and use imx_add_gpio_keys instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> LAKML-Reference: 1302105926-20574-1-git-send-email-fabio.estevam@freescale.com Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-05-19ARM: mx5/mx53_loco: Fix build warning related to gpio_keys_button structureFabio Estevam
Fix the following warning: CC arch/arm/mach-mx5/board-mx53_loco.o arch/arm/mach-mx5/board-mx53_loco.c:203: warning: initialization discards qualifiers from pointer target type Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> LAKML-Reference: 1301881643-26040-1-git-send-email-festevam@gmail.com Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-05-19ARM: mx5/mx53_smd: Add esdhc supportFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> LAKML-Reference: 1301921449-32194-1-git-send-email-fabio.estevam@freescale.com Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-05-19ARM: imx: clean up the section marks of extern dataRichard Zhao
Signed-off-by: Richard Zhao <richard.zhao@linaro.org> LAKML-Reference: 1301566583-18947-1-git-send-email-richard.zhao@freescale.com Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-05-19ARM: imx: remove #includes already available from devices-common.hUwe Kleine-König
Most machine files include "devices-imxXX.h" which in turn includes <mach/devices-common.h>. The latter already includes many headers that the machine files don't need to include again. These were found by: $ grep \#include arch/arm/plat-mxc/include/mach/devices-common.h > tmpfile $ git grep -l 'devices-imx' arch/arm | xargs grep -f tmpfile -F (but I kept linux/init.h, linux/kernel.h and linux/platform_device.h) LAKML-Reference: 1298912674-15153-2-git-send-email-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
