In order to fix the performance issue on ENET when WAIT mode
is activated, route the ENET interrupts to a GPIO on all MX6DL boards.
This patch must be applied on top of:
MX6Q/DL-Fix Ethernet performance issue when WAIT mode is active
808863866d2c17aeb3e70a7fcd094bd96db4b601
bae4d40849f3acdd9663f5a0857c9415ed7e6d5d
Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
ECSPI pin MX6DL_PAD_EIM_D17__ECSPI1_MISO is configured overlap by epdc
MX6DL_PAD_EIM_D17__GPIO_3_17, so that SPI-NOR flash can't work normally.
From schematic of ARM2 board, epdc and spi share this pin if plug epdc
daughter board. But SPI-NOR is on ARM2 mother board, so it should be config
well firstly. So we make sure SPI-NOR work successfully by default. But if
enable epdc , SPI-NOR on ARM2 will work fail.
Signed-off-by: Robin Gong <B38343@freescale.com>
Added enable_pins/disable_pins functions for Mx6q/dl arm2 HDMI.
Added HDMI DDC IOMUX setting.
Signed-off-by: Sandor Yu <R01008@freescale.com>
- Added EPDC and EPD PMIC (Maxim 17135) to MX6Q ARM2 board file
- Added EPDC-related IOMUX and GPIO settings
- Added EPDC clock configuration settings to clock file
- Updated config files with EPDC and Maxim 17135 config entries
Signed-off-by: Danny Nold <dannynold@freescale.com>
- Fix GPIO_16 IOMUX config.
- Config GPIO_16 pad to ENET_ANATOP_ETHERNET_REF_OUT.
- IEEE-1588 ts_clk, S/PDIF in and i2c3 are mutually exclusive,
because all of them use GPIO_16, so it only for one function
work at a moment.
- Test result:
Enet work fine at 100/1000Mbps in TO1.1.
IEEE 1588 timestamp is convergent.
Signed-off-by: Fugang Duan <B38611@freescale.com>
i.mx6dl and i.mx6q share the same ARM2 board due to the pin-pin
compatible between them.
Signed-off-by: Jason Liu <r64343@freescale.com>
