the reset value of LPM[1:0] in CCM_CLPCR register is b'01, which means
system will enter into wait mode on next assertion of dsm_request signal.
In order to avoid the system unexpectly enter the wait mode during bootup
we need set the LPM mode to run mode explicity during early boot up phase,
Anytime, we want system to enter the wait mode, the sw procedure is:
mxc_cpu_lp_set(LP_MODE) -> set CCM_CLPCR register -> system enter wait mode
This patch also fix linux kernel reboot stress test on i.mx6dl, without this
patch linux kernel reboot test will fail random with error like this:
[ 12.091220] Bad mode in interrupt handler detected
[ 12.096056] Bad mode in interrupt handler detected
[ 12.100851] Internal error: Oops - bad mode: 0 [#1] PREEMPT SMP
Signed-off-by: Jason Liu <r64343@freescale.com>
In order to support one image for i.mx6q and i.mx6dl, we introduce
the below functions by diff the value reading from ANATOP ID register.
cpu_is_mx6q() and cpu_is_mx6dl()
The layout for the register defines:
Major Minor
i.MX6Q1.1: 6300 01
i.MX6Q1.0: 6300 00
i.MX6DL1.0: 6100 00
For the common bits shared across all i.mx6 ports, we can use:
cpu_is_mx6() for it.
Read the silicon version stored in ROM at address ox48.
Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
1.Need to add condition check after resum, or if we
didn't config L2 cache, build will fail.
2.Need to call the mxc_init_l2x0 instead of l2x0_init.
Signed-off-by: Anson Huang <b20788@freescale.com>
Adjust L2 cache parameter to improve both
performance and power consumption.
--OCRAM size is 256KB, confirmed by IC owner, the
OCRAM_Aliasd 0.75MB is mapped to the same 256KB
OCRAM.That means there is only 256KB physical
OCRAM.
--Enable arch_reset function on MX6Q, For SMP, we
need to clear the SRC_GPRx after the secondary
cores brought up, or the wdog reset will fail;
imx6 MSL files change, include clock change for ipu.
Signed-off-by: Jason Chen <jason.chen@freescale.com>
MSL code for bring up MX6 sabreauto board with Single core.
Merged from testbuild:imx6_bringup branch.
Singed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
Signed-off-by: Richard Zhu <r65037@freescale.com>
Signed-off-by: Anish Trivedi <anish@freescale.com>
Signed-off-by: Dong Aisheng <b29396@freescale.com>
Signed-off-by: Jason Chen <b02280@freescale.com>
Signed-off-by: Lily Zhang <r58066@freescale.com>
Signed-off-by: Sammy He <r62914@freescale.com>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Signed-off-by: Terry Lv <r65388@freescale.com>
Signed-off-by: Richard Zhao <richard.zhao@freescale.com>
Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
Merged-by: Zeng Zhaoming <b32542@freescale.com>
Reviewed-by: Jason Liu <r64343@freescale.com>
Reviewed-by: Frank Li <Frank.Li@freescale.com>
