Remove dead code.
Signed-off-by: Ranjani Vaidyanathan <Ranjani.Vaidyanathan@freescale.com>
procedure
Backport busfreq patch from 3.10.x kernel:
2d1f2b76919e13d8744cc8579316c002f832c675
The ddr frequency change code was responsible for some random kernel crashes.
This was due to the fact that L1 and L2 caches were not correctly flushed/synced
during the frequency change procedure.
This patch attempts to fix the issue by:
1. Ensure that every active core put into wfe flushes and disables its L1.
2. All cores (except the one executing the ddr freq change code) informs the SCU
that it going into a power down state after flushing and disabling its L1. It
also removes itself out the SMP cluster.
3. Variables shared across cores are stored in non-cacheable IRAM space.
4. SCU power status register is used to identify if all cores have reached a quiscent state
before the core running the ddr freq change code proceeds further.
The DDR freq code had an incorrect workaround for ERR005778.
ERR005778 MMDC: DDR Controller’s measure unit may return an incorrect value
when operating below 100 MHz
Workarounds:
To workaround this issue, following steps should be performed by software:
1. Prior to reducing the DDR frequency (528 MHz), read the measure unit count bits
(MU_UNIT_DEL_NUM).
2. Bypass the automatic measure unit when below 100 MHz, by setting the measure unit bypass
enable bit (MU_BYP_EN).
3. Double the measure unit count value read in step 1 and program it in the measure unit bypass
bit (MU_BYP_VAL) of the MMDC PHY Measure Unit Register, for the reduced frequency
operation below 100 MHz.
Software should re-enable the measure unit when operating at the higher frequencies, by clearing
the measure unit bypass enable bit (MU_BYP_EN). This code should be executed out of Internal
RAM or a non-DDR based external memory.
This patch fixes the code to follow the workaround specified in the errata
document.
change procedure
A missing end of comment inadvertently ensured that the DLL off
procedure was executed even when the DLL was already disabled (switching
from 24MHz to 50MHz and vice-versa).
This patch fixes the above issue. And also ensures that automatic entry into
self-refresh is enabled for both DLL ON and DLL OFF modes.
Whenever DDR is explicitly put into self-refresh, we need to ensure
that no access are made to the DDR. All the bus masters excpet ARM
are shutdown gracefully.
The ARM core can continue to access the DDR due to:
1. Speculative accesses
This can be prevented by flushing the Branch Target Address Cache
2. Aggressive Prefetching
This can be minimized by adding nops.
Apart from this the TLB architecture in ARM does not guarantee that
an entry remains in the TLB unless its explicitly locked. Even if
free slots are available an entry maybe evicted. So flushing the TLB
does not guarantee a page table walk will not happen.
The solution is to put a minimized page table in IRAM that can be used when
DDR is in self-refresh. The IRAM page tables should have entries for IRAM,
AIPS1 and AIPS2 as these entries will be needed by the code that puts DDR
into self-refresh. It should not contain any entries that point to the DDR.
This patch set accomplishes the following:
1. Set the IRAM to be mapped as 1M sections in the high mem region.
This makes it possible to create entries for the IRAM code in the
IRAM page table. We need to ensure that both the DDR and IRAM page
table have mapping for the IRAM code.
2. Ensure the IRAM, AIPS1, AIPS2 have entries in the IRAM page table.
3. Save TTBR1
4. Set TTBR1 to point to the page tables stored in IRAM. Switch to using
TTBR1 before DDR is put into self-refresh. Ensure the following settings:
a. TTBCR.N = 1
This means the 0-2G virtual address space is translated using TTBR0
and 2G-4G is translated using TTBR1.
b. Set TTBCR.PD0 = 1
With this setting page table walks using TTBR0 are disabled.
4. After the DDR has exited self-refresh, reset TTBCR to 0 (TTBR0 will
be used for translations now).
5. Restore TTBR1
Even though TTBR1 is only used to decode the top 2G of virtual address
space, ARM requires that we allocate the entire 16KB for the page table.
To minimize IRAM/OCRAM required, we put the code in the bottom 8K and
page table entries in the top 8K.
This requires the low power code be optimized to occupy as little space
as possible. Only the WFI and suspend code that puts DDR into self-refresh
is located in this 8k. The DDR frequency code that also puts the DDR into
self-refresh need not be located in this 8K region. Currently this patch
allocates a separate 4K region in IRAM for the DDR frequency change code.
Additional conditions to be met:
1. Disable L2 when DDR is in self-refresh.
2. Ensure that L1 and branch prediction are disabled when we
are switching to IRAM page tables, based on recommendation from
ARM.
This patch also dynamically calculate size of all the code that puts
DDR into self-refresh (low power and ddr freq change).
(cherry picked from commit 67779bf67ebf4daddea33693f42cf01eced14bd9)
The DDR freq change code and the low power WFI code in
MX6SL runs from non-cacheable but bufferable IRAM space.
Its possible for an eviction to occur from the L1
and/or L2 sync buffers after the DDR has been put into
self-refresh. This will cause the system to hang. To
avoid this ensure that the L1/L2 sync buffers are drained
properly.
Following is the info from ARM on L2 store buffers:
You can use L2 sync operation to drain L2store buffer manually,
and the store buffer would be drained in such conditions:
* store buffer slot is immediately drained if targeting
device memory area
* store buffer slots are drained as soon as they are full
* store buffer is drained at each strongly ordered read
occurrence in slave ports
* store buffer is drained at each strongly ordered write
* as soon as all three slots of the store buffer contain data,
the least recently accessed slot starts draining
* if a hazard is detected in a store buffer slot , that slot
is drained to resolve the hazard
* store buffer slots are drained when a lock ed transaction is
received by one slave port
* store buffer slots are drained when a transaction targeting
the configuration registers is received by one slave port
* store buffer slots are automatically drained after 256 cycles
of presence in the store buffer.
You can refer to 2.5.3 Store buffer operation of PL310 trm(r3p3, DDI0246H)
for the detail.
You have to apply the explicit cache sync operation, which should be
followed by DSB, before entering the low power mode. And the bit0 of
the cache sync register(base offset 0x730) should be polling to guarantee
that the PL310 has finished sync operation.
PL310 owns three 256 bit entry store buffer & eviction buffer, and
four 256 bit LFB & LRB, and Cache sync would complete when all buffers,
LRB, LFB, STB, and EB, are empty.
The actual overhead should be close to your L3 access latency.
Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
on Sabresd board, IPG_PERCLK will be fixed on 6Mhz once system enter low bus,
and never restore to 22Mhz which be set in boot. It means some device clock
which sourcing from IPG_PERCLK such as I2C will be slow down. The root cause is
that there is workaround for GPT timer of Arik TO1.0 in mx6_ddr_freq.S. GPT
clock source from IPG_PERCLK on TO1.0 and should be fixed on 6Mhz. But for
TO1.1 and TO1.2 ,the workaround should be removed.
Signed-off-by: Robin Gong <B38343@freescale.com>
50M -> 528M bus freq change will cause system hang, root
cause is that we didn't set 50M as DLL off mode, it should
be DLL off mode.
And make sure bus, axi, ahb, ipg and ipg_perclk are at right
freq during all setpoints.
Can't disable PU LDO again if it is not enabled.
Signed-off-by: Anson Huang <b20788@freescale.com>
As DDR freq change is by modifying CCM register directly,
we need to update the clock tree as well, or the clock
tree will be broken. Also, we need to make sure the clock
rate counting is right.
DLL ON/OFF code randomly hangs waiting for the CON_ACK bit
to be set when a CON_REQ is asserted.
Fix this by adding a delay after the MMDC automatic power savings
mode is disabled.
IPU_HSP clocks should NOT be sourced from MMDC clock since the
MMDC clock can be scaled.
Move the IPU_HSP clock to be sourced from PLL3_PFD_540M instead.
Also don't source AXI_CLK from periph_clk as this domain is
scaled between 528MHz, 400MHz and 24MHz. Move AXI_CLK
clock to be sourced from PLL3_PFD_540M too.
When the system needs to enter low power mode, AXI_CLK is switched
from PLL3_PFD_540M to periph_clk. And then switched back
when low power mode is exited.
The code will print a warning message if PLL3_PFD_540M is
relocked to a different frequency when IPU_HSP or axi_clk is
sourced from it.
Currently remove the support for 400Mhz DDR working point for
MX6Q since we can get IPU underruns during the DDR frequency
transitions.
The DDR freq change code needs to ensure that all bus clocks
donot exceed max frequency during the frequency transition.
Added support for changing DDR frequency on MX6DL.
During system IDLE, DDR freq can drop down to 24MHz
if none of the devices that need high AHB frequency
are active.
Changed the DDR code to handle both MX6Q and MX6DL
DDR and IOMUX settings.
Fixed bug associated incorrect IRAM memory allocation
used to store DDR and IOMUX data.
The DDR frequency needs to be at 50MHz for low power audio
playback. So added a new low power mode for audio.
Set the AHB to 25MHz, AXI to 50MHz and DDR to 50MHz in this
mode.
Add support for scaling the bus frequency (both DDR
and ahb_clk).
The DDR and AHB_CLK are dropped to 24MHz when all devices
that need high AHB frequency are disabled and the CORE
frequency is at the lowest setpoint.
The DDR is dropped to 400MHz for the video playback usecase.
In this mode the GPU, FEC, SATA etc are disabled.
To scale the bus frequency, its necessary that all cores
except the core that is executing the DDR frequency change
are in WFE. This is achieved by generating interrupts on
un-used interrupts (Int no 139, 144, 145 and 146).
