Add end mark to pin array.
- use macro to be able to use quad and dual lite SOC
- remove spdif from the common_pads
Integrate S/PDIF support on standard Apalis MXM3 pins 215 (SPDIF1_OUT)
and 217 (SPDIF1_IN):
card 1: imxspdif [imx-spdif], device 0: IMX SPDIF mxc-spdif-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
Tested with Apalis iMX6Q 1GB V1.0A on Apalis Evaluation Board V1.0A
(JP25 1-2 S/PDIF OUT X21 and SPDIF1_IN X5-3).
function taken from board-mx6q_sabresd.c
- sgtl5000 is on I2C bus 1
- correct used voltages for vddd and vdda
- not (yet) working hdmi-phy i2c would require i2c1 to be
muxed between power i2c and ddc.
Make use of the new STMPE ADC driver to expose the four free ADC
channels on the STMPE811 to userspace.
- add a pinmux setting for all remaining CPU pins
- export APALIS GPIO1 .. GPIO8
- while at it remove a chatty debug printk
With the following vidargs HDMI & LVDS run in fullHD:
setenv vidargs video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 video=mxcfb1:dev=ldb,LDB-LG-LP156WF1,if=RGB666,ldb=spl1 video=mxcfb2:off video=mxcfb3:off fbmem=32M
With the following vidargs parallel RGB is 800x480 EDT 7"
setenv vidargs video=mxcfb0:dev=lcd,EDT-WVGA,if=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M
Register eMMC as the first mmc driver, so it gets always mmcblk0
Fixed mmc speed dependent pin setting to use the correct
controller to pins assignment
Use the speed dependent pin setting also for initial pinmuxing
Added all pinmuxing
Added touch driver platform data from Apalis T30
Initalize USB Host, so the ports get VBUS powered
HDMI I2C not yet working, so switch pinmuxing to use I2C2
Added all pinmuxing
Revert initial Apalis iMX6 bring-up related changes from the following
commit now that we have our own proper board file:
36e319203f8fc14a9747616c6d4a2a737252e3b4
Introduce proper board file with accompanying machine ID. For now just
re-cycle the actual number from Boundary's Nitrogen resp. Freescale's
Sabre.
While at it clean out some more irrelevant stuff and add some default
NFS boot arguments aka kernel command line.
- Pinmuxing
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
github.com:boundarydevices/linux-imx6 into boundary-imx_3.0.35_4.1.0
