path: root/arch/arm/mach-mxs
2017-04-10ARM: mxs: add support for I2SE Duckbill 2 boardsMichael Heimpold
The Duckbill devices are small, pen-drive sized boards based on NXP's i.MX28 SoC. While the initial variants (Duckbill series) were equipped with a micro SD card slot only, the latest generation (Duckbill 2 series) have an additional internal eMMC onboard. To distinguish between both generations, a new device tree compatible string was introduced. To get the MAC address fixup applied, we need to check for this new string here, too. Signed-off-by: Michael Heimpold <michael.heimpold@i2se.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-08-09ARM: mxs: remove obsolete startup code for TX28Lothar Waßmann
The power and reset handling of the FEC ethernet driver is sufficient to get the ethernet PHY on the TX28 into a usable state. Remove the code that does the PHY initialization on startup. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-08-01Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "The cleanup branch keeps going down in size as we've completed a lot of the major legacy platform removals and conversions. A handful of changes this time around, some of the themes or larger sets are: - A bunch of i.MX cleanups around platform detection, init call cleanups - Misc fixes of missing/implicit includes - Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) ARM: mps2: fix typo ARM: s3c64xx: avoid warning about 'struct device_node' bus: mvebu-mbus: make mvebu_mbus_syscore_ops static bus: mvebu-mbus: fix __iomem on register pointers ARM: tegra: Remove board_init_funcs array ARM: iop: Fix indentation ARM: imx: remove cpu_is_mx*() ARM: imx: remove last call to cpu_is_mx5* ARM: imx: rework mx27_pm_init() call ARM: imx: deconstruct mx3_idle ARM: imx: deconstruct mxc_rnga initialization ARM: imx: remove cpu_is_mx1 check ARM: i.MX: Do not explicitly call l2x0_of_init() ARM: i.MX: system.c: Tweak prefetch settings for performance ARM: i.MX: system.c: Replace magic numbers ARM: i.MX: system.c: Remove redundant errata 752271 code ARM: i.MX: system.c: Convert goto to if statement ARM: Kirkwood: fix kirkwood_pm_init() declaration/type ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static ARM: orion5x: make orion5x_legacy_handle_irq static ...
2016-07-30Merge tag 'devicetree-for-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: - remove most of_platform_populate() calls in arch code. Now the DT core code calls it in the default case and platforms only need to call it if they have special needs - use pr_fmt on all the DT core print statements - CoreSight binding doc improvements to block name descriptions - add dt_to_config script which can parse dts files and list corresponding kernel config options - fix memory leak hit with a PowerMac DT - correct a bunch of STMicro compatible strings to use the correct vendor prefix - fix DA9052 PMIC binding doc to match what is actually used in dts files * tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits) documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table" xtensa: Fix build error due to missing include file MIPS: ath79: Add missing include file Fix spelling errors in Documentation/devicetree ARM: dts: fix STMicroelectronics compatible strings powerpc/dts: fix STMicroelectronics compatible strings Documentation: dt: i2c: use correct STMicroelectronics vendor prefix scripts/dtc: dt_to_config - kernel config options for a devicetree of: fdt: mark unflattened tree as detached of: overlay: add resolver error prints coresight: document binding acronyms Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties of: use pr_fmt prefix for all console printing of/irq: Mark initialised interrupt controllers as populated of: fix memory leak related to safe_name() Revert "of/platform: export of_default_bus_match_table" of: unittest: use of_platform_default_populate() to populate default bus memory: omap-gpmc: use of_platform_default_populate() to populate default bus bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus ...
2016-06-28clocksource/drivers/mxs: Add the COMPILE_TEST optionDaniel Lezcano
Change the Kconfig option logic to fullfil with the current approach. A new Kconfig option is added, CONFIG_MXS_TIMER and is selected by the platform. Then the clocksource's Kconfig is changed to make this option selectable by the user if the COMPILE_TEST option is set. Otherwise, it is up to the platform's Kconfig to select the timer. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2016-06-23arm: use of_platform_default_populate() to populateKefeng Wang
Use helper of_platform_default_populate() in linux/of_platform when possible, instead of calling of_platform_populate() with the default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Ray Jui <rjui@broadcom.com> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Rob Herring <robh@kernel.org> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-03ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIBLinus Walleij
This replaces: - "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can now be selected directly. - "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB is now selectable by everyone, so we need not declare our intent to select it. When ordering the symbols the following rationale was used: if the selects were in alphabetical order, I moved select GPIOLIB to be in alphabetical order, but if the selects were not maintained in alphabetical order, I just replaced "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB". Cc: Michael Büsch <m@bues.ch> Cc: arm@kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-28ARM: appropriate __init annotation for const dataNicolas Pitre
Init data marked const should be annotated with __initconst for correctness and not __initdata. In some cases the array gathering references to that data has to be marked const as well. This fixes LTO builds that otherwise fail with section mismatch errors. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-04-05Merge tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree changes from Arnd Bergmann: "A large part of the arm-soc patches are nowadays DT changes, adding support for new SoCs, boards and devices without changing kernel source. The plan is still to move the devicetree files out of the kernel tree and reduce the amount of churn going on here, but we keep finding reasons to delay doing that. Changes are really all over the place, with little sticking out particularly. We have contributions from a total of 116 people in this branch. Unfortunately, the size of this branch also causes a significant number of conflicts at the moment, typically when subsystem maintainers merge patches that change the driver at the same time as the dts files. In most cases this could be avoided because the dts changes are supposed to be compatible in both ways, and we are asking everyone to send ARM dts changes through our tree only" * tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits) dts: stmmac: Document the clocks property in the stmmac base document dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. ARM: STi: stih41x: Add support for the FSM Serial Flash Controller ARM: STi: stih416: Add support for the FSM Serial Flash Controller ARM: tegra: fix Dalmore pinctrl configuration ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND ARM: dts: Build all keystone dt blobs ARM: dts: keystone: Fix control register range for clktsip ARM: dts: keystone: Fix domain register range for clkfftc1 ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap ARM: dts: bcm21664: Add device tree files. ARM: DT: bcm21664: Device tree bindings ARM: efm32: properly namespace i2c location property ARM: efm32: fix unit address part in USART2 device nodes' names ARM: mvebu: Enable NAND controller in Armada 385-DB ARM: mvebu: Add support for NAND controller in Armada 38x SoC ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs ...
2014-02-19ARM: centralize common multi-platform kconfig optionsRob Herring
Multi-platform requires various kconfig options to be selected, so platforms don't need to select them individually. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-09ARM: mxs: Add support for the eukrea-cpuimx28.Eric Bénard
The following devices/functionalities were tested: * Main UART. * Ethernet0. * Ethernet1. * SD. * USB host. * USB otg. * Display(and its backlight). * Touchscreen. * Audio. * nand. * i2c and the pcf8563 device. * The gpio buttons. * The gpio leds. * Watchdog Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: devicetree@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Denis Carikli <denis@eukrea.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: imx28: add apf28 specific initialization (macaddr)Gwenhael Goavec-Merou
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: mxs: add support for I2SE's duckbill seriesMichael Heimpold
Signed-off-by: Michael Heimpold <mhei@heimpold.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-11-11Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Most of this branch consists of updates, additions and general churn of the device tree source files in the kernel (arch/arm/boot/dts). Besides that, there are a few things to point out: - Lots of platform conversion on OMAP2+, with removal of old board files for various platforms. - Final conversion of a bunch of ux500 (ST-Ericsson) platforms as well - Some updates to pinctrl and other subsystems. Most of these are for DT-enablement of the various platforms and acks have been collected" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (385 commits) ARM: dts: bcm11351: Use GIC/IRQ defines for sdio interrupts ARM: dts: bcm: Add missing UARTs for bcm11351 (bcm281xx) ARM: dts: bcm281xx: Add card detect GPIO ARM: dts: rename ARCH_BCM to ARCH_BCM_MOBILE (dt) ARM: bcm281xx: Add device node for the GPIO controller ARM: mvebu: Add Netgear ReadyNAS 104 board ARM: tegra: fix Tegra114 IOMMU register address ARM: kirkwood: add support for OpenBlocks A7 platform ARM: dts: omap4-panda: add DPI pinmuxing ARM: dts: AM33xx: Add RNG node ARM: dts: AM33XX: Add hwspinlock node ARM: dts: OMAP5: Add hwspinlock node ARM: dts: OMAP4: Add hwspinlock node ARM: dts: use 'status' property for PCIe nodes ARM: dts: sirf: add missed address-cells and size-cells for prima2 I2C ARM: dts: sirf: add missed cell, cs and dma channel for SPI nodes ARM: dts: sirf: add missed graphics2d iobg in atlas6 dts ARM: dts: sirf: add missed chhifbg node in prima2 and atlas6 dts ARM: dts: sirf: add missed memcontrol-monitor node in prima2 and atlas6 dts ARM: mvebu: Add the core-divider clock to Armada 370/XP ...
2013-10-05ARM: dts: mxs: Add MSR M28CU3 boardMarek Vasut
This board is based on the M28 SoM with custom baseboard. Supported are LEDs, ethernet, PWM, LCD, SD slots. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-29ARM: mxs: remove custom .init_time hookSebastian Hesselbarth
This patch converts clk-imx2[38] clocksource_of_init compatible init associated with fsl,imx2[38]-clkctrl. With arch/arm calling of_clk_init(NULL) from time_init(), we can now also remove custom .init_time hooks. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Mike Turquette <mturquette@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-18ARM: mxs: pm: Include "pm.h"Fabio Estevam
Fix the following sparse warning: arch/arm/mach-mxs/pm.c:37:13: warning: symbol 'mxs_pm_init' was not declared. Should it be static? Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-18ARM: mxs: Simplify detection of CrystalFontz boardsAlexandre Belloni
As all CrystalFontz boards are compatible with "crystalfontz,cfa10036", make it easier to add future boards. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-16ARM: mach-mxs: Remove "TO" string from revision fieldFabio Estevam
There is no need to print the silicon revision as "TO1.2", just print it as "1.2" instead: $ cat /sys/bus/soc/devices/soc0/revision 1.2 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-16ARM: mxs: Fix BUG() when invoking mxs_restart() from interrupt contextLothar Waßmann
The mxs_restart() function uses of_iomap() which triggers the following BUG_ON(in_interrupt()) when called in interrupt context (e.g. thru SYSRQ-B): SysRq : Resetting ------------[ cut here ]------------ kernel BUG at mm/vmalloc.c:1310! Internal error: Oops - BUG: 0 [#1] PREEMPT ARM Modules linked in: i2c_dev CPU: 0 PID: 0 Comm: swapper Not tainted 3.11.0-rc2-next-20130729-karo+ #196 task: c04e1c38 ti: c04d8000 task.ti: c04d8000 PC is at __get_vm_area_node.clone.25+0x34/0x140 LR is at get_vm_area_caller+0x38/0x44 pc : [<c008a988>] lr : [<c008b434>] psr: 20000013 sp : c04d9db0 ip : 00000001 fp : 00000001 r10: c8800000 r9 : 00000000 r8 : 000000d0 r7 : 00002000 r6 : 00000001 r5 : 00000001 r4 : 00002000 r3 : 00010000 r2 : 00000001 r1 : c04d9db0 r0 : 00002000 Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 0005317f Table: 46920000 DAC: 00000017 Process swapper (pid: 0, stack limit = 0xc04d81b8) Create the mapping upon startup from mxs_machine_init(). Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-16ARM: mxs: Allow DT clock providersLothar Waßmann
Add a call to of_clk_init() to register clocks defined in DT. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-02Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree changes from Arnd Bergmann: "These changes from 30 individual branches for the most part update device tree files, but there are also a few source code changes that have crept in this time, usually in order to atomically move over a driver from using hardcoded data to DT probing. A number of platforms change their DT files to use the C preprocessor, which is causing a bit of churn, but that is hopefully only this once" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits) ARM: at91: dt: rm9200ek: add spi support ARM: at91: dt: rm9200: add spi support ARM: at91/DT: at91sam9n12: add SPI DMA client infos ARM: at91/DT: sama5d3: add SPI DMA client infos ARM: at91/DT: fix SPI compatibility string ARM: Kirkwood: Fix the internal register ranges translation ARM: dts: bcm281xx: change comment to C89 style ARM: mmc: bcm281xx SDHCI driver (dt mods) ARM: nomadik: add the new clocks to the device tree clk: nomadik: implement the Nomadik clocks properly ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency ARM: dts: omap4-panda: Fix DVI EDID reads ARM: dts: omap4-panda: Add USB Host support arm: mvebu: enable mini-PCIe connectors on Armada 370 RD ARM: shmobile: irqpin: add a DT property to enable masking on parent ARM: dts: AM43x EPOS EVM support ARM: dts: OMAP5: Add bandgap DT entry ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone ...
2013-07-02Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "This contains cleanups as preparation for other branches adding new features, we pulled 16 branches for 9 platforms into this one. Most notable here is the removal of support for ATAGS based OMAP4 systems. Since all OMAP4 machines are fully functional with DT based booting in 3.10, we can remove a lot of code here. Also noteworthy is Maxime Ripard's cleanup of the machine descriptors, which means we need no machine descriptors in a lot more cases and can boot additional machines by just having the respective device drivers enabled." * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (76 commits) ARM: picoxcell: remove .nr_irqs reference ARM: s5p64x0: avoid build warning for uncompress.h ARM: SAMSUNG: Remove unused plat/regs-watchdog.h header ARM: SAMSUNG: Remove legacy watchdog reset code ARM: SAMSUNG: Let platforms use the new watchdog reset driver ARM: SAMSUNG: Add watchdog reset driver ARM: SAMSUNG: Use local definitions of watchdog registers watchdog: s3c2410_wdt: Use local register definitions ARM: S5P64X0: Use common uncompress.h part for plat-samsung ARM: SAMSUNG: Consolidate uncompress subroutine ARM: at91: drop rm9200dk board support ARM: dts: msm: Fix merge resolution ARM: OMAP1: Remove dma.h ARM: OMAP1: Remove legacy irda.h and irda setup from board files ARM: OMAP1: Remove duplicated DMA channel definitions ARM: OMAP1: Remove McBSP DMA channel definitions ARM: OMAP2+: Remove dma.h ARM: OMAP2+: hwmod: Remove remaining DMA channel definitions ARM: OMAP2+: Remove duplicated DMA channel definitions ARM: OMAP2+: Remove AES crypto device DMA channel definitions ...
2013-06-27can: flexcan: Use a regulator to control the CAN transceiverFabio Estevam
Instead of using a GPIO to turn on/off the CAN transceiver, it is better to use a regulator as some systems may use a PMIC to power the CAN transceiver. Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2013-06-24ARM: mxs: don't select HAVE_PWMArnd Bergmann
The HAVE_PWM symbol is only for legacy platforms that provide the PWM API without using the generic framework. MXS actually uses that framework, and selecting the symbol anyway might cause build errors like drivers/built-in.o: In function `pwm_beeper_resume': :(.text+0x1f4fc0): undefined reference to `pwm_config' :(.text+0x1f4fc8): undefined reference to `pwm_enable' drivers/built-in.o: In function `pwm_beeper_suspend': :(.text+0x1f4ffc): undefined reference to `pwm_disable' when CONFIG_PWM is disabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Shawn Guo <shawn.guo@linaro.org>
2013-06-24ARM: mxs: stub out mxs_pm_init for !CONFIG_PMArnd Bergmann
When building a kernel without CONFIG_PM, we get a link error from referencing mxs_pm_init in the machine descriptor. This defines a macro to NULL for that case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: mxs: dt: Add Crystalfontz CFA-10057 device treeBrian Lilly
The CFA-10057 is a breakout board for the CFA-10036 that has Ethernet, USB and a 4.3" LCD screen on it. Signed-off-by: Brian Lilly <brian@crystalfontz.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: mxs: dt: Add the Crystalfontz CFA-10055 device treeBrian Lilly
The CFA-10055 is yet another breakout board for the CFA-10036, and is basically a CFA-10037, with the screen and LCD controller found on the CFA-10049. Signed-off-by: Brian Lilly <brian@crystalfontz.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: mxs: Use soc bus infrastructureFabio Estevam
Using the soc bus infrastructure is helpful for reporting several SoC related information such as: family, machine, SoC name and SoC revision. $ cat /sys/bus/soc/devices/soc0/family Freescale MXS Family $ cat /sys/bus/soc/devices/soc0/machine Freescale i.MX28 Evaluation Kit $ cat /sys/bus/soc/devices/soc0/soc_id i.MX28 $ cat /sys/bus/soc/devices/soc0/revision TO1.2 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: mxs: Remove init_irq declaration in machine descriptionMaxime Ripard
Commit ebafed7a ("ARM: irq: Call irqchip_init if no init_irq function is specified") removed the need to explictly setup the init_irq field in the machine description when using only irqchip_init. Remove that declaration for mxs as well. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-03can: flexcan: remove HAVE_CAN_FLEXCAN Kconfig symbolMarc Kleine-Budde
This patch removes the Kconfig symbol HAVE_CAN_FLEXCAN from arch/{arm,powerpc} and allowing compilation unconditionally on all arm and powerpc platforms. This brings a bigger compile time coverage and removes the following dependency warning found by Arnd Bergmann: warning: (SOC_IMX28 && SOC_IMX25 && SOC_IMX35 && IMX_HAVE_PLATFORM_FLEXCAN && SOC_IMX53 && SOC_IMX6Q) selects HAVE_CAN_FLEXCAN which has unmet direct dependencies (NET && CAN && CAN_DEV) Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2013-05-24ARM: mxs: remove the .map_io declarationMaxime Ripard
Now that the ARM core code calls debug_ll_io_init, we can remove it from the machine_desc declaration. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-05-07Merge tag 'dt-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree updates (part 2) from Arnd Bergmann: "These are mostly new device tree bindings for existing drivers, as well as changes to the device tree source files to add support for those devices, and a couple of new boards, most notably Samsung's Exynos5 based Chromebook. The changes depend on earlier platform specific updates and touch the usual platforms: omap, exynos, tegra, mxs, mvebu and davinci." * tag 'dt-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits) ARM: exynos: dts: cros5250: add EC device ARM: dts: Add sbs-battery for exynos5250-snow ARM: dts: Add i2c-arbitrator bus for exynos5250-snow ARM: dts: add mshc controller node for Exynos4x12 SoCs ARM: dts: Add chip-id controller node on Exynos4/5 SoC ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree ARM: davinci: da850-evm: add SPI flash support ARM: davinci: da850: override SPI DT node device name ARM: davinci: da850: add SPI1 DT node spi/davinci: add DT binding documentation spi/davinci: no wildcards in DT compatible property ARM: dts: mvebu: Convert mvebu device tree files to 64 bits ARM: dts: mvebu: introduce internal-regs node ARM: dts: mvebu: Convert all the mvebu files to use the range property ARM: dts: mvebu: move all peripherals inside soc ARM: dts: mvebu: fix cpus section indentation ARM: davinci: da850: add EHRPWM & ECAP DT node ARM/dts: OMAP3: fix pinctrl-single configuration ARM: dts: Add OMAP3430 SDP NOR flash memory binding ARM: dts: Add NOR flash bindings for OMAP2420 H4 ...
2013-05-02Merge tag 'multiplatform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform updates from Olof Johansson: "More multiplatform enablement for ARM platforms. The ones converted in this branch are: - bcm2835 - cns3xxx - sirf - nomadik - msx - spear - tegra - ux500 We're getting close to having most of them converted! One of the larger platforms remaining is Samsung Exynos, and there are a bunch of supporting patches in this merge window for it. There was a patch in this branch to a early version of multiplatform conversion, but it ended up being reverted due to need of more bake time. The revert commit is part of the branch since it would have required rebasing multiple dependent branches and they were stable by then" * tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms clocksource: nomadik-mtu: fix up clocksource/timer Revert "ARM: exynos: enable multiplatform support" ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ" ARM: exynos: enable multiplatform support rtc: s3c: make header file local mtd: onenand/samsung: make regs-onenand.h file local thermal/exynos: remove unnecessary header inclusions mmc: sdhci-s3c: remove platform dependencies ARM: samsung: move mfc device definition to s5p-dev-mfc.c ARM: exynos: move debug-macro.S to include/debug/ ARM: exynos: prepare for sparse IRQ ARM: exynos: introduce EXYNOS_ATAGS symbol ARM: tegra: build assembly files with -march=armv7-a ARM: Push selects for TWD/SCU into machine entries ARM: ux500: build hotplug.o for ARMv7-a ARM: ux500: move to multiplatform ARM: ux500: make remaining headers local ARM: ux500: make irqs.h local to platform ARM: ux500: get rid of <mach/[hardware|db8500-regs].h> ...
2013-05-02Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "This branch contains part 1 of the platform updates for 3.10. Among the highlights: - Support for the new Atmel Cortex-A5 based platforms (SAMA5D3) - New support for CSR SiRFatlas6 SoCs - A handful of updates for NVidia T114 (a.k.a. Tegra 4) - A bunch of updates for the shmobile platforms - A handful of updates for davinci - A few updates for Qualcomm MSM - Plus a handful of other patches, defconfig updates, etc." * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (135 commits) ARM: tegra: pm: fix build error w/o PM_SLEEP ARM: davinci: ensure global variables are declared ARM: davinci: sram.c: fix incorrect type in assignment ARM: davinci: da8xx dt: make file local symbols static ARM: davinci: da8xx: add remoteproc support ARM: socfpga: Upgrade clk driver for socfpga to make use of dts clock entries ARM: socfpga: Add clock entries into device tree ARM: socfpga: Enable soft reset ARM: EXYNOS: replace cpumask by the corresponding macro ARM: EXYNOS: handle properly the return values ARM: EXYNOS: factor out the idle states ARM: OMAP4: Enable fix for Cortex-A9 erratas ARM: OMAP2+: Export SoC information to userspace ARM: OMAP2+: SoC name and revision unification ARM: OMAP2+: Move common part of late init into common function ARM: tegra: pm: remove duplicated include from pm.c ARM: davinci: da850: override mmc DT node device name ARM: davinci: da850: add mmc DT entries mmc: davinci_mmc: add DT support ARM: SAMSUNG: check processor type before cache restoration in resume ...
2013-04-04ARM: mxs: move display timing configurations into device treeShawn Guo
Move display timing configurations into device tree, so that the auxdata for mxsfb driver can be killed. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-04ARM: mxs: remove unneeded enet_out clk initializationShawn Guo
With fec driver taking care of enet_out clk, most of board setup do not need to enable enet_out clk. So remove them. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-04ARM: mxs: enable multiplatform buildShawn Guo
Remove files that are not needed by multiplatform build, and make necessary changes on Kconfig to enable multiplatform build. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-04ARM: mxs: rename debug-macro.S for multiplatform buildShawn Guo
Rename arch/arm/mach-mxs/include/mach/debug-macro.S to arch/arm/include/debug/mxs.S for multiplatform build. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-04ARM: mxs: call mxs_pm_init() as a machine_desc hookShawn Guo
The device_initcall is not a friend of multiplatform build. Call mxs_pm_init() as a machine_desc hook instead of device_initcall. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: remove unused headersShawn Guo
Most of the stuff in the headers are used nowhere now. Move a few things that are useful for mach-mxs.c into there and remove the headers. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: merge imx23 and imx28 into one machine_descShawn Guo
Most of the function hooks are same between imx23 and imx28 machine_desc, so merge them into one. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: remove common.hShawn Guo
All three remaining functions declared in common.h are implemented by clock driver. Create header include/linux/clk/mxs.h to contain them and remove common.h. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: move mxs_get_ocotp() into mach-mxs.cShawn Guo
All the users of mxs_get_ocotp() are in mach-mxs.c. Move the function into mach-mxs.c, make it a static function, and then remove ocotp.c. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: remove mm.cShawn Guo
The static mapping is used nowhere now. Hence mm.c can be removed completely. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: use debug_ll_io_init for low-level debugShawn Guo
The only user of the static mapping done in mx23_map_io and mx28_map_io is low-level debug now. Use debug_ll_io_init() instead, so that the static mapping is used nowhere and can be removed completely later. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: get ocotp base address from device treeShawn Guo
Instead of using the static definitions, get ocotp base address from device tree with mapping. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: remove system.cShawn Guo
There is no user of function mxs_reset_block() now. Let's move mxs_restart() into mach-mxs.c as a static function and remove system.c completely. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
