path: root/arch/arm/mach-netx
2011-05-26ARM: 6827/1: mach-netx: delete hardcoded periphidLinus Walleij
The periphid of the AMBA CLCD controller is hardcoded to a value that the CLCD driver does not even support. Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23clocksource: convert ARM 32-bit up counting clocksourcesRussell King
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300 to use the generic mmio clocksource recently introduced. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Acked-by: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: netx: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2010-12-22ARM: netx: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-21ARM: 6484/1: fix compile warning in mm/init.cAnand Gadiyar
Commit 7c63984b86 (ARM: do not define VMALLOC_END relative to PAGE_OFFSET) changed VMALLOC_END to be an explicit value. Before this, it was relative to PAGE_OFFSET and therefore converted to unsigned long as PAGE_OFFSET is an unsigned long. This introduced the following build warning. Fix this by changing the explicit defines of VMALLOC_END to be unsigned long. CC arch/arm/mm/init.o arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:606: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int' Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Acked-by: Uwe Kleine-K <u.kleine-koenig@pengutronix.dee> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-01ARM: do not define VMALLOC_END relative to PAGE_OFFSETNicolas Pitre
VMALLOC_END is supposed to be an absolute value, while PAGE_OFFSET may vary depending on the selected user:kernel memory split mode through CONFIG_VMSPLIT_*. In fact, the goal of moving PAGE_OFFSET down is to accommodate more directly addressed RAM by the kernel below the vmalloc area, and having VMALLOC_END move along PAGE_OFFSET is rather against the very reason why PAGE_OFFSET can be moved in the first place. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-08-13netx: Use get_irqnr_preamble to initialize base registerUwe Kleine-König
This patch optimizes the irq handling a bit. Now the base register is only computed once per irq exception instead of at least twice. Moreover the mov+add sequence is simplified to an ldr (which might save some cycles depending on memory timing). Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2009-05-07[ARM] VIC: Add power management deviceBen Dooks
Add power management support to the VIC by registering each VIC as a system device to get suspend/resume events going. Since the VIC registeration is done early, we need to record the VICs in a static array which is used to add the system devices later once the initcalls are run. This means there is now a configuration value for the number of VICs in the system. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30trivial: fix typo "virual" -> "virtual"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <ukleinek@strlen.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08[ARM] fix netxRussell King
2fcfe6b872b21639dcffbaf3ca2a84ec01d104e0 missed out on the cpumask updates; update netx for these changes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-06arm: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-19Merge branch 'for-rmk' of git://git.pengutronix.de/git/ukl/linux-2.6 into develRussell King
2008-12-09netx: define register MEMCRUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-09netx/xc: add a few "const"s to fix compiler warningsUwe Kleine-König
the fixed warnings are: arch/arm/mach-netx/xc.c: In function ‘xc_request_firmware’: arch/arm/mach-netx/xc.c:152: warning: assignment discards qualifiers from pointer target type arch/arm/mach-netx/xc.c:162: warning: assignment discards qualifiers from pointer target type Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-09netx: add support for clockeventsUwe Kleine-König
This is based on a patch by Luotao Fu <lfu@pengutronix.de> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Luotao Fu <lfu@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-09netx: Use a cpp symbol for the clocksource timer numberUwe Kleine-König
instead of hardcoding the same value each time. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-12-09mach-netx/time.c: codingstyle cleanupUwe Kleine-König
To prevent cluttering the next patches with noop noise, do the cleanup in this separate patch: - use tab to indent - break comments before column 80 Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-11-30Merge branch 'clks' into develRussell King
2008-11-30[ARM] netx: fix simple clk APIRussell King
... to only return the framebuffer clock for the framebuffer device. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-30[ARM] Add a common typesafe __io implementationRussell King
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b, add a typesafe __io implementation for platforms to use. Convert platforms to use this new simple typesafe implementation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] move MAX_DMA_ADDRESS to mach/memory.hRussell King
Move the definition of MAX_DMA_ADDRESS from mach/dma.h to mach/memory.h, thereby placing it along side its relative, ISA_DMA_THRESHOLD. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09Merge branch 'pxa-all' into develRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/include/mach/hardware.h arch/arm/mach-pxa/spitz.c
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Remove references to "make dep"Adrian Bunk
"make dep" is no longer required in kernel 2.6, but was still mentioned in some places. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28[ARM] Fix timer damage from d3d74453c34f8fd87674a8cf5b8a327c68f22e99Russell King
Move the xtime write mode seqlock into timer_tick(), so it only surrounds the call to do_timer(). This avoids a deadlock in update_process_times() ... hrtimer_get_softirq_time() which tries to get a read mode seqlock on xtime, thereby preventing booting. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-05[ARM] 4641/2: netX: fix kobject_name typeRobert Schwebel
With commit 5984a2fc7e7c9ab118e78ae9799e98fc4ade40f9 kobject_name() is correctly being used to access the name field of kobj, but that function needs a pointer to a kobject, not the kobject itself. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-31[ARM] Fix netx_defconfig regressionRussell King
Fix: CC arch/arm/mach-netx/xc.o arch/arm/mach-netx/xc.c: In function 'request_xc': arch/arm/mach-netx/xc.c:192: error: 'struct kobject' has no member named 'name' arch/arm/mach-netx/xc.c:196: error: 'struct kobject' has no member named 'name' arch/arm/mach-netx/xc.c:200: error: 'struct kobject' has no member named 'name' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clocksource: fixup is_continous changes on ARMThomas Gleixner
Fixup the is_contionous replacement by a flag field. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[ARM] 4013/1: clocksource driver for netxSascha Hauer
Add a clocksource driver for netx systems Signed-off-by: Luotao Fu <lfu@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
