Now most of ARM machines has the alsmot same __clk_get/put() macro
So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files
But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config
Now there are only 3 caese.
1) define the clk structure with clkdev macro => Need to move clk structure to proper header file
arch/arm/mach-versatile/include/mach/clkdev.h
arch/arm/mach-realview/include/mach/clkdev.h
arch/arm/mach-vexpress/include/mach/clkdev.h
arch/arm/mach-integrator/include/mach/clkdev.h
2) export the __clk_get/put function at clock.c
arch/arm/mach-shmobile/include/mach/clkdev.h
3) demuxing the clk source
arch/arm/mach-u300/include/mach/clkdev.h
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Rather than checking the MMU status in every instance of addruart, do it
once in kernel/debug.S, and change the existing addruart macros to
return both physical and virtual addresses. The main debug code can then
select the appropriate address to use.
This will also allow us to retreive the address of a uart for the MMU
state that we're not current in.
Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com>
and Tony Lindgren <tony@atomide.com>, and fix for versatile express from
Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Jason Wang <jason77.wang@gmail.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Move the Nomadik GPIO driver to plat-nomadik so that it can also be used
on the Ux500 platform.
The mach-nomadik include/mach/gpio.h is replaced by one that includes
the one now in plat-nomadik, so that code doesn't need to include the
one in plat specifically, and can instead use <linux/gpio.h> as usual.
Acked-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Makes it consistent with VMALLOC_START
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com>
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
Introduce the plat-nomadik folder for ST-Ericsson
machines including the existing nomadik 8815 architecture.
This also moves the existing MTU (MultiTimerUnit)
of nomadik 8815 to the proposed plat-nomadik and adds
HAS_MTU. The patch has been re-based to 2.6.32-rc6
Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com>
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
This patch adds the basic infrastructure for the Nomadik 8815
CPU and the "Nomadik Hardware Kit" NHK8815. This patch only
includes the serial console and core stuff, no drivers.
