path: root/arch/arm/mach-nomadik
2016-09-09ARM: nomadik: select MFD_SYSCONLinus Walleij
Since the Power Management Unit is using syscon to access a set of necessary hardware muxing, let's select MFD_SYSCON for the Nomadik subarchitecture. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-06-03ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIBLinus Walleij
This replaces: - "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can now be selected directly. - "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB is now selectable by everyone, so we need not declare our intent to select it. When ordering the symbols the following rationale was used: if the selects were in alphabetical order, I moved select GPIOLIB to be in alphabetical order, but if the selects were not maintained in alphabetical order, I just replaced "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB". Cc: Michael Büsch <m@bues.ch> Cc: arm@kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-11ARM: nomadik: move l2x0 setup to device treeLinus Walleij
The cache setup magic value in the Nomadik machine is plain wrong, the correct settings can be done using device tree in accordance with the settings from ST's own port. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-11ARM: nomadik: move hog code to use DT hogsLinus Walleij
Instead of introducing a board-specific DT node for biasing the MMC/SD and SATA ports, use the new device tree hogs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-31ARM: nomadik: device tree for NHK15 boardLinus Walleij
This adds a device tree for the Nomadik NHK15 development kit board. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-06-17ARM: use menuconfig for sub-arch menusRob Herring
The System Type menu is getting quite long with platforms and is inconsistent in handling of sub-arch specific options. Tidy up the menu by making platform options a menuconfig entry containing any platform specific config items. [arnd: change OMAP part according to suggestion from Tony Lindgren <tony@atomide.com>] Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-30ARM: l2c: nomadik: convert to generic l2c OF initialisationRussell King
Remove the explicit call to l2x0_of_init(), converting to the generic infrastructure instead. This also allows us to eliminate the .init_machine function as it is identical to the generic version. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-30ARM: l2c: nomadik: remove cache size overrideRussell King
The cache size should already be present in the L2 cache auxiliary control register: it is part of the integration process to configure the hardware IP. Most platforms get this right, yet still many cargo-cult program, and assume that they always need specifying to the L2 cache code. Remove them so we can find out which really need this. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-02-19ARM: centralize common multi-platform kconfig optionsRob Herring
Multi-platform requires various kconfig options to be selected, so platforms don't need to select them individually. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-11-28ARM: nomadik: get rid of explicit ethernet GPIO managementLinus Walleij
We used to set up the GPIO used for the SMC ethernet IRQ by requesting the GPIO line explicitly. As we recently established that specifying the GPIO controller as interrupt parent and requesting one of its interrupts by reference should be enough, we do away with this. Incidentally, the Nomadik GPIO chip driver handles this just fine: the IRQ is set up and fired as expected. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-07Merge branch 'clk-of-init-v2_for-3.13' of ↵Olof Johansson
https://github.com/shesselba/linux-dove into next/cleanup From Sebastian Hasselbarth: This is a patch set based on an RFC [1][2] sent earlier to provide a common arch/arm init for DT clock providers. Currently, the call to of_clk_init(NULL) to initialize DT clock providers is spread among several mach-dirs. Since most machs require DT clocks initialized before timers, no initcall can be used. By adding of_clk_init(NULL) to arch/arm time_init(), we can remove all mach-specific .init_time hooks that basically called of_clk_init and clocksource_of_init. In contrast to the RFC version, of_clk_init(NULL) is now only called if no custom .init_time callback is set. This allows some machs to still call clock init themselves, as not all can be converted now. Therefore, this patch sets drops conversion of mach-mvebu and mach-zynq. New machs that were introduced with v3.12-rc1 are also converted, except mach-u300 that requires clocks before irqs. * 'clk-of-init-v2_for-3.13' of https://github.com/shesselba/linux-dove: (29 commits) ARM: vt8500: remove custom .init_time hook ARM: vexpress: remove custom .init_time hook ARM: tegra: remove custom .init_time hook ARM: sunxi: remove custom .init_time hook ARM: sti: remove custom .init_time hook ARM: socfpga: remove custom .init_time hook ARM: rockchip: remove custom .init_time hook ARM: prima2: remove custom .init_time hook ARM: nspire: remove custom .init_time hook ARM: nomadik: remove custom .init_time hook ARM: mxs: remove custom .init_time hook ARM: kirkwood: remove custom .init_time hook ARM: imx: remove custom .init_time hook ARM: highbank: remove custom .init_time hook ARM: exynos: remove custom .init_time hook ARM: dove: remove custom .init_time hook ARM: bcm2835: remove custom .init_time hook ARM: bcm: provide common arch init for DT clocks ARM: call of_clk_init from default time_init handler ARM: vt8500: prepare for arch-wide .init_time callback ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-29ARM: nomadik: remove custom .init_time hookSebastian Hesselbarth
With arch/arm calling of_clk_init(NULL) from time_init(), we can now remove custom .init_time hooks. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-29clk: nomadik: declare OF clock providerSebastian Hesselbarth
Common clock framework allows to register clock providers to get called on of_clk_init() by using CLK_OF_DECLARE. This converts nomadik clock provider to make use of it and get rid of the mach specific clk init call. As clocks require system reset controller base address to be initialized each clock driver checks src_base and calls new nomadik_src_init if required. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mike Turquette <mturquette@linaro.org>
2013-09-29ARM: nomadik: remove mtu initalization from .init_timeSebastian Hesselbarth
Nomadik clock initialization is properly done in clk-nomadik since patch "clk: nomadik: set all timers to use 2.4 MHz TIMCLK". Therefore, this patch removes now redundant mtu initialization from .init_time callback. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-24ARM: nomadik: delete FSMC platform dataLinus Walleij
We now have device tree support for setting the NAND timings for FSMC from the device tree, so delete the last piece of platform data and auxdata. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-24ARM: nomadik: delete MMCI platform dataLinus Walleij
Now that we have a proper regulator set up for the MMCI driver and managed through the device tree, we no longer need the platform data providing the OCR voltages for the MMCI block. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-07ARM: nomadik: switch to use the Nomadik I2C driverLinus Walleij
Instead of using bit-banged I2C, let's use the actual I2C driver in the kernel. Since the I2C block may be communicating with things like the PMIC, we need to select it from the Kconfig just like the bit-banged adapter is selected today. The rest of the configuration for this driver can be done from the device tree. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-02Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree changes from Arnd Bergmann: "These changes from 30 individual branches for the most part update device tree files, but there are also a few source code changes that have crept in this time, usually in order to atomically move over a driver from using hardcoded data to DT probing. A number of platforms change their DT files to use the C preprocessor, which is causing a bit of churn, but that is hopefully only this once" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits) ARM: at91: dt: rm9200ek: add spi support ARM: at91: dt: rm9200: add spi support ARM: at91/DT: at91sam9n12: add SPI DMA client infos ARM: at91/DT: sama5d3: add SPI DMA client infos ARM: at91/DT: fix SPI compatibility string ARM: Kirkwood: Fix the internal register ranges translation ARM: dts: bcm281xx: change comment to C89 style ARM: mmc: bcm281xx SDHCI driver (dt mods) ARM: nomadik: add the new clocks to the device tree clk: nomadik: implement the Nomadik clocks properly ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency ARM: dts: omap4-panda: Fix DVI EDID reads ARM: dts: omap4-panda: Add USB Host support arm: mvebu: enable mini-PCIe connectors on Armada 370 RD ARM: shmobile: irqpin: add a DT property to enable masking on parent ARM: dts: AM43x EPOS EVM support ARM: dts: OMAP5: Add bandgap DT entry ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone ...
2013-05-26ARM: nomadik: move the pin configuration to DTLinus Walleij
This moves the pin configuration for the Nomadik over to the device tree using Gabriel's bindings. Remove the auxdata nailing down the name of the pin controller as this is no longer necessary. Cc: Gabriel Fernandez <gabriel.fernandez@st.com> Cc: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-26ARM: nomadik: add led and key for S8815Linus Walleij
This adds device tree hunks for the LED and userbutton on the USB S8815 board, and set up a heartbeat trigger on the LED and an escape key on the user button. Alter the defconfig to enable these standard DT-enabled GPIO drivers. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-24ARM: nomadik: Remove init_irq declaration in machine descriptionMaxime Ripard
Commit ebafed7a ("ARM: irq: Call irqchip_init if no init_irq function is specified") removed the need to explictly setup the init_irq field in the machine description when using only irqchip_init. Remove that declaration for nomadik as well. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-12ARM: nomadik: register clocksource from device treeLinus Walleij
This switches the Nomadik platform to also registering its clocksource from the device tree, removing unused support code as we go along. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-05-12ARM: nomadik: convert all clocks except timer to dtLinus Walleij
This moves all Nomadik clocks except the one used for the timer/clocksource over to the device tree. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-26clocksource: nomadik-mtu: fix up clocksource/timerLinus Walleij
The Nomadik clocksource driver has had a bad define making it impossible to use it for sched_clock() for a while. Fix this and also enable it for the Nomadik. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-03-19ARM: nomadik: hide MACH_NOMADIK_8815NHK in KconfigArnd Bergmann
The nomadik multiplatform support made it possible to select MACH_NOMADIK_8815NHK without selecting ARCH_NOMADIK, which leads to build errors when we also select ARMv6/v7 targets. Adding the ifdef here restores the intended behavior. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-03-07ARM: nomadik: delete remnant include filesLinus Walleij
This deletes the leftover <mach/timex.h> and <mach/uncompress.h> and Makefile.boot that have no role in a multiplatform environment. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-07ARM: nomadik: convert to multiplatformLinus Walleij
This converts the Nomadik to run in multiplatform mode, including the defconfig change. After this the "uImage" target in the kernel tree will no longer work, but we do not care about this. Instead we generate the uImage from the zImage using mkimage or update the bootloader to accept bootz. Some minor updates to the defconfig are done as part of this. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-07ARM: nomadik: move debugmacro to debug includesLinus Walleij
This moves the Nomadik debug macro to the debug headers to make way for multiplatform support. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-07ARM: nomadik: delete IRQ headerLinus Walleij
This header is not used any more after the platform was switched to obtain resources from the device tree. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-21Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions from Arnd Bergmann: "These are device tree conversions for a number of platforms, with the intention of turning code from board files into device tree descriptions. Notable changes are: - davinci bindings for pinctrl, MTD, RTC, watchdog and i2c - nomadik bindings for all devices, removing the board files - bcm2835 bindings for mmc and i2c - tegra bindings for hdmi, keyboard, audio, as well as some updates - at91 bindings for hardware ecc and for devices on RM9200 - mxs bindings for cfa100xx - sunxi support for Miniand Hackberry board" * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (72 commits) Revert "sunxi: a10-cubieboard: Add user LEDs to the device tree" Revert "sunxi: a13-olinuxino: Add user LED to the device tree" clk: tegra: initialise parent of uart clocks ARM: tegra: remove clock-frequency properties from serial nodes clk: tegra: fix driver to match DT binding clk: tegra: local arrays should be static clk: tegra: Add missing spinlock for hclk and pclk clk: tegra: Implement locking for super clock clk: tegra: fix wrong clock index between se to sata_cold sunxi: a13-olinuxino: Add user LED to the device tree ARM: davinci: da850 DT: add support for machine reboot ARM: davinci: da850: add wdt DT node ARM: davinci: da850: add DT node for I2C0 ARM: at91: at91sam9n12: add DT parameters to enable PMECC ARM: at91: at91sam9x5: add DT parameters to enable PMECC ARM: at91: add EMAC bindings to RM9200 DT ARM: at91: add SSC bindings to RM9200 DT ARM: at91: add MMC bindings to RM9200 DT ARM: at91: Animeo IP: enable watchdog support ARM: nomadik: fix OF compilation regression ...
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-28ARM: nomadik: get rid of <mach/hardware.h>Linus Walleij
This was only used from the core machine, source it into the machine file and delete, also convert all direct references using the physical-to-virtual macros in this file to ioremap() and only default-remap the 4K used by the debug UART. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: delete old board filesLinus Walleij
The Device Tree support on Nomadik can do everything the old board files could do, so delete the old board files and make the nomadik select CONFIG_OF. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: migrate MMC/SD card support to device treeLinus Walleij
This moves over the MMC/SD card support to the device tree probe path. The special GPIO to bias the card detect line is kept, but the pin property is moved to the device tree as part of the MMC/SD card node. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: convert SMSC91x ethernet to device treeLinus Walleij
This converts the SMSC91x ethernet controller to use device tree. The existing solution from the board file, to request the GPIO triggering the ethernet IRQ from the board file is kept for the time being, but the GPIO number assignment is moved over to the device tree. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: move GPIO and pinctrl to device treeLinus Walleij
This moves the instances of the Nomadik pin controller and the Nomadik GPIO blocks (also handled by the GPIO driver) over to the device tree. A new compatible string is added to the pin control driver in the process. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: add FSMC NANDLinus Walleij
This adds the FSMC NAND driver and flash partitions to the Nomadik device tree. The only compatible string accepted by this driver is currently "st,spear600-fsmc-nand" which is inappropriate for this system, so this patch adds the compatible value "stericsson,fsmc-nand" as well. Cc: linux-mtd@vger.kernel.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: move remaining PrimeCells to device treeLinus Walleij
The two remaining PrimeCells, RNG and RTC, are migrated to the device tree for device tree boot. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: move pin maps to cpu fileLinus Walleij
Move the pinctrl maps over to the CPU file and register them right before the pin controller itself. This way the pinmaps will also benefit the device tree boot. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: initial devicetree supportLinus Walleij
Support basic device tree boot on the Nomadik. Implement the support in the cpu file with the intent of deleting the board files later. At this stage IRQ controllers, system timer, l2x0 cache, UARTs and thus console boot is fully functional. Patch out the code adding devices by initcalls for now so as not to disturb the boot. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-28ARM: nomadik: move last custom calls to pinctrlLinus Walleij
The I2C pins were still set up using custom nmk_* calls, move these to use the pinctrl mapping table instead. There was also a remaining call to turn the Ethernet pin to GPIO, and this is now done implicitly by the GPIO-to-pinctrl range translation calls. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-14Merge tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/cleanup From Rob Herring: Initial irqchip init infrastructure and GIC and VIC clean-ups This creates irqchip initialization infrastructure from Thomas Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips and adapted to use the new infrastructure. All DT enabled platforms using GIC and VIC are converted over to use the new irqchip_init. * tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux: irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h ARM: picoxcell: use common irqchip_init function ARM: spear: use common irqchip_init function irqchip: Move ARM VIC to drivers/irqchip ARM: samsung: remove unused tick.h ARM: remove unneeded vic.h includes ARM: remove mach .handle_irq for VIC users ARM: VIC: set handle_arch_irq in VIC initialization ARM: VIC: shrink down vic.h irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h ARM: use common irqchip_init for GIC init irqchip: Move ARM GIC to drivers/irqchip ARM: remove mach .handle_irq for GIC users ARM: GIC: set handle_arch_irq in GIC initialization ARM: GIC: remove direct use of gic_raise_softirq ARM: GIC: remove assembly ifdefs from gic.h ARM: mach-ux500: use SGI0 to wake up the other core arm: add set_handle_irq() to register the parent IRQ controller handler function irqchip: add basic infrastructure irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS Fixed up massive merge conflicts with the timer cleanup due to adjacent changes: Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-bcm/board_bcm.c arch/arm/mach-cns3xxx/cns3420vb.c arch/arm/mach-ep93xx/adssphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/simone.c arch/arm/mach-ep93xx/snappercl15.c arch/arm/mach-ep93xx/ts72xx.c arch/arm/mach-ep93xx/vision_ep9307.c arch/arm/mach-highbank/highbank.c arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-msm/board-dt-8960.c arch/arm/mach-netx/nxdb500.c arch/arm/mach-netx/nxdkn.c arch/arm/mach-netx/nxeb500hmi.c arch/arm/mach-nomadik/board-nhk8815.c arch/arm/mach-picoxcell/common.c arch/arm/mach-realview/realview_eb.c arch/arm/mach-realview/realview_pb1176.c arch/arm/mach-realview/realview_pb11mp.c arch/arm/mach-realview/realview_pba8.c arch/arm/mach-realview/realview_pbx.c arch/arm/mach-socfpga/socfpga.c arch/arm/mach-spear13xx/spear1310.c arch/arm/mach-spear13xx/spear1340.c arch/arm/mach-spear13xx/spear13xx.c arch/arm/mach-spear3xx/spear300.c arch/arm/mach-spear3xx/spear310.c arch/arm/mach-spear3xx/spear320.c arch/arm/mach-spear3xx/spear3xx.c arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/board-dt-tegra30.c arch/arm/mach-u300/core.c arch/arm/mach-ux500/board-mop500.c arch/arm/mach-ux500/cpu-db8500.c arch/arm/mach-versatile/versatile_ab.c arch/arm/mach-versatile/versatile_dt.c arch/arm/mach-versatile/versatile_pb.c arch/arm/mach-vexpress/v2m.c include/asm-generic/vmlinux.lds.h
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-12irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.hRob Herring
Now that we have VIC moved to drivers/irqchip and all VIC DT init for platforms using irqchip_init, move gic.h and update the remaining includes. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: linux-samsung-soc@vger.kernel.org
2013-01-12ARM: remove unneeded vic.h includesRob Herring
Numerous includes of asm/hardware/vic.h aren't needed, so remove them. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-By: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: linux-samsung-soc@vger.kernel.org Cc: patches@opensource.wolfsonmicro.com Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-12ARM: remove mach .handle_irq for VIC usersRob Herring
Now that the VIC initialization sets up the handle_arch_irq pointer, we can remove it for all machines and make it static. Move vic_handle_irq to avoid a forward declaration. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Rajeev Kumar <rajeev-dlh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2013-01-03ARM: nomadik: bump the IRQ numbers againLinus Walleij
Bump the IRQ numbers from offset at 1 (right above NO_IRQ) to 32. This is the painful way to learn that if you're using SPARSE_IRQ and avoid to define .nr_irqs in your machine, the first 16 IRQs will be pre-allocated, and the IRQdomain code (as the VIC core code before it) will then assume that all IRQ descriptors are pre-allocated, and 16 of them are - by somebody else. So mapping the IRQs will fail in irq_create_mapping(). Moving the offset upward rids us of this problem. Cc: Rob Herring <rob.herring@calxeda.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-03ARM: nomadik: delete dangling includeLinus Walleij
This reference to the old include header for the FSMC NAND MTD driver was somehow left in place, get rid of it. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
