commit e383e871ab54f073c2a798a9e0bde7f1d0528de8 upstream.
The CONFIG_ARCH_REQUIRE_GPIOLIB is gone since commit 65053e1a7743
("gpio: delete ARCH_[WANTS_OPTIONAL|REQUIRE]_GPIOLIB") and all platforms
should explicitly select GPIOLIB to have it.
Link: https://lore.kernel.org/r/20200130195525.4525-1-krzk@kernel.org
Cc: <stable@vger.kernel.org>
Fixes: 65053e1a7743 ("gpio: delete ARCH_[WANTS_OPTIONAL|REQUIRE]_GPIOLIB")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
This patch Enable ARM L2 cache module in Nuvoton NPCM7xx BMC
by adding L2 cache parameters into NPCM7xx DT machine start structure.
At patch V7 arm: npcm: add basic support for Nuvoton BMCs we got comments
regarding the flags use in L2 cache module.
- https://www.spinics.net/lists/arm-kernel/msg613212.html
After checking again the L2 cache use in the NPCM7xx,
the only L2 cache flag we need to set is L2C_AUX_CTRL_SHARED_OVERRIDE
and it is done in the device tree:
https://patchwork.kernel.org/patch/10063497/
L2 cache flag mask allowed all the flag option.
Signed-off-by: Tomer Maimon <tmaimon77@gmail.com>
Modify configuration and MakeFile
for the Nuvoton NPCM and NPCM7xx BMC.
[arnd: took this one late, since it fixes some build problems
with the original commit]
Reviewed-by: Brendan Higgins <brendanhiggins@google.com>
Adds basic support for the Nuvoton NPCM750 BMC.
Signed-off-by: Brendan Higgins <brendanhiggins@google.com>
Reviewed-by: Tomer Maimon <tmaimon77@gmail.com>
Reviewed-by: Avi Fishman <avifishman70@gmail.com>
Tested-by: Tomer Maimon <tmaimon77@gmail.com>
Tested-by: Avi Fishman <avifishman70@gmail.com>
