All the boards booting with device tree use
drivers/pinctrl-single.c instead.
Note that mach-omap1 is still using the legacy mux,
so let's move the related Kconfig options from plat-omap
to mach-omap1.
Remove board support files for 10 years discontinued VoiceBlue board.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
The Kconfig symbol MACH_OMAP_HTCWIZARD got added in v2.6.30. It has
never been used. Its entry can safely be removed.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
As suggested by Andrew Morton:
This is a pet peeve of mine. Any time there's a long list of items
(header file inclusions, kconfig entries, array initalisers, etc) and
someone wants to add a new item, they *always* go and stick it at the
end of the list.
Guys, don't do this. Either put the new item into a randomly-chosen
position or, probably better, alphanumerically sort the list.
lets sort all our select statements alphanumerically. This commit was
created by the following perl:
while (<>) {
while (/\\\s*$/) {
$_ .= <>;
undef %selects if /^\s*config\s+/;
if (/^\s+select\s+(\w+).*/) {
if (defined($selects{$1})) {
if ($selects{$1} eq $_) {
print STDERR "Warning: removing duplicated $1 entry\n";
} else {
print STDERR "Error: $1 differently selected\n".
"\tOld: $selects{$1}\n".
"\tNew: $_\n";
exit 1;
$selects{$1} = $_;
next;
if (%selects and (/^\s*$/ or /^\s+help/ or /^\s+---help---/ or
/^endif/ or /^endchoice/)) {
foreach $k (sort (keys %selects)) {
print "$selects{$k}";
undef %selects;
print;
if (%selects) {
It found two duplicates:
Warning: removing duplicated S5P_SETUP_MIPIPHY entry
Warning: removing duplicated HARDIRQS_SW_RESEND entry
and they are identical duplicates, hence the shrinkage in the diffstat
of two lines.
We have four testers reporting success of this change (Tony, Stephen,
Linus and Sekhar.)
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Sekhar Nori <nsekhar@ti.com>
SX1 board requirese i2c, so select it in Kconfig, otherwise I have the
following build error:
arch/arm/mach-omap1/board-sx1.c: In function 'sx1_i2c_write_byte':
arch/arm/mach-omap1/board-sx1.c:58:2: error: implicit declaration of function 'i2c_get_adapter' [-Werror=implicit-function-declaration]
arch/arm/mach-omap1/board-sx1.c:58:7: warning: assignment makes pointer from integer without a cast [enabled by default]
arch/arm/mach-omap1/board-sx1.c:67:2: error: implicit declaration of function 'i2c_transfer' [-Werror=implicit-function-declaration]
arch/arm/mach-omap1/board-sx1.c:68:2: error: implicit declaration of function 'i2c_put_adapter' [-Werror=implicit-function-declaration]
arch/arm/mach-omap1/board-sx1.c: In function 'sx1_i2c_read_byte':
arch/arm/mach-omap1/board-sx1.c:82:7: warning: assignment makes pointer from integer without a cast [enabled by default]
cc1: some warnings being treated as errors
make[1]: *** [arch/arm/mach-omap1/board-sx1.o] Error 1
make: *** [arch/arm/mach-omap1] Error 2
make: *** Waiting for unfinished jobs....
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Pull "ARM: board specific updates" from Arnd Bergmann/Olof Johansson:
"These changes are all specific to one board only. We're trying to
keep the number of board files low, but generally board level updates
are ok on platforms that are working on moving towards DT based
probing, which will eventually lead to removing them.
The board-ams-delta.c board file gets a conflict between the removal
of ams_delta_config and the addition of a lot of other data. The
Kconfig file has two changes in the same line, and in exynos, the
power domain cleanup conflicts with the addition of the image sensor
device.
[olof: Amended a fix for a mismerge to board-omap4panda.c]
Signed-off-by: Olof Johansson <olof@lixom.net>"
Fixed up some fairly trivial conflicts manually.
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (82 commits)
i.MX35-PDK: Add Camera support
ARM : mx35: 3ds-board: add framebuffer device
pxa/hx4700: Remove pcmcia platform_device structure
ARM: pxa/hx4700: Reduce sleep mode battery discharge by 35%
ARM: pxa/hx4700: Remove unwanted request for GPIO105
ARM: EXYNOS: support Exynos4210-bus Devfreq driver on Nuri board
ARM: EXYNOS: Register JPEG on nuri
ARM: EXYNOS: Register JPEG on universal_c210
ARM: S5PV210: Enable JPEG on SMDKV210
ARM: S5PV210: Add JPEG board definition
ARM: EXYNOS: Enable JPEG on Origen
ARM: EXYNOS: Enable JPEG on SMDKV310
ARM: EXYNOS: Add __init attribute to universal_camera_init()
ARM: EXYNOS: Add __init attribute to nuri_camera_init()
ARM: S5PV210: Enable FIMC on SMDKC110
ARM: S5PV210: Enable FIMC on SMDKV210
ARM: S5PV210: Enable MFC on SMDKC110
ARM: S5PV210: Enable MFC on SMDKV210
ARM: EXYNOS: Enable G2D on SMDKV310
ARM: tegra: update defconfig
The McBSP driver stack has been moved to ASoC. The CONFIG_OMAP_MCBSP will
be removed since the CONFIG_SND_OMAP_SOC_MCBSP will trigger to build the
McBSP (audio) drivers.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
The Amstrad Delta on-board latch2 bit named MODEM_NRESET, now available
as a GPIO pin AMS_DELTA_GPIO_PIN_NMODEM_RESET, is used to power up/down
(bring into/out of a reset state) two distinct on-board devices
simultaneously: the modem, and the voice codec. As a consequence, that
bit is, or can be, manipulated concurrently by two drivers, or their
platform provided hooks.
Instead of updating those drivers to use the gpiolib API as a new method
of controlling the MODEM_NRESET pin state, like it was done to other
drivers accessing latch2 pins, and still being vulnerable to potential
concurrency conflicts, or trying to solve that sharing issue with a
custom piece of code, set up a fixed regulator device on top of that
GPIO pin, with the intention of updating both drivers to manipulate that
regulator, not the GPIO pin directly.
Before the ASoC driver is updated and the modem platform data expanded
with a power management callback for switching its power, the
ams_delta_latch_write() function, which still provides the old API for
accessing latch2 functionality from not updated drivers, is modified to
toggle the regulator instead of the MODEM_NRESET GPIO pin. A helper
function provided for balancing the regulator enable/disable operations,
together with the consumer data needed for tracking the regulator state,
will be removed once the drivers are updated.
Depends on patch series "ARM: OMAP1: ams-delta: replace custom I/O with
GPIO".
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Now that the Amstrad Delta on-board latches have been converted to GPIO
devices, use the generic driver to control on-board LEDs which hang off
those latches.
Once ready, ams-delta specific device drivers currently calling custom
ams_delta_latch[12]_write() functions can be updated to call generic
gpio_set_value() instead, which will make them less platform dependent.
Even more, some custom ams-delta only drivers can perhaps be dropped
from the tree after converting selected ams-delta platform devices to
follow generic GPIO based device models.
The latch_gpios[] table is initially filled with all latch1 and latch2
GPIO pins in order to register and initialize them from the board file
until those are handled by respective existing device drivers (leds,
nand, lcd, serio, asoc, serial). That table will get almost empty after
the transision process is completed, holding only pins not used by any
drivers / connected to unused devices, in order to initialize them from
the board file for power saving purposes.
The new ams_delta_latch_write() function is a unified replacement for
those removed ams_delta_latch[12]_write(), and serves as a temporary
wrapper over gpio_set_value(), providing the old API for those not yet
updated device drivers, and will be removed after all custom drivers are
converted or replaced.
For still better multi-OMAP1 support, expand omap1_rate_table with flags
for different SoC types and match them while selecting clock rates. The
idea is stolen from current omap24xx clock rate selection algorithm.
Since clkdev platform flag definitions are reused here, those had to be
expanded with one extra entry for OMAP1710 subtype, as this is the only
SoC for which we allow selection of the highest, 216 MHz rate.
Once done, remove no longer needed clock rate configure time options.
Tested on Amstrad Delta.
[tony@atomide.com: updated comments]
Commit a66cb3454f220f49f900646ebdc76cb943319eb7 (ARM: OMAP: Map SRAM
later on with ioremap_exec()) moved the SRAM init to happen later
to remove a dependency to early SoC detection for map_io.
This broke booting on some boards not using Kconfig option for
OMAP_CLOCKS_SET_BY_BOOTLOADER as the dpll1 reprogramming would
cause the following error:
kernel BUG at arch/arm/plat-omap/sram.c:226!
Internal error: Oops - undefined instruction: 0 [#1] PREEMPT
Modules linked in:
CPU: 0 Not tainted (3.2.0-rc1-e3 #9)
PC is at omap_sram_reprogram_clock+0x28/0x30
LR is at omap1_select_table_rate+0x88/0xb4
pc : [<c001b0c4>] lr : [<c0019f54>] psr: 600000d3
sp : c035bf10 ip : c035bf20 fp : c035bf1c
r10: c035bfd4 r9 : 54029252 r8 : c03f8120
r7 : c0362b50 r6 : 00b71b00 r5 : c03873cc r4 : c0362b40
r3 : 00000000 r2 : c0362b40 r1 : 0000010a r0 : 00002cb0
Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
Control: 0000317f Table: 10004000 DAC: 00000017
Process swapper (pid: 0, stack limit = 0xc035a270)
Stack: (0xc035bf10 to 0xc035c000)
bf00: c035bf3c c035bf20 c0019f54 c001b0ac
bf20: 00001000 00002cb3 00000004 c035ed4c c035bf74 c035bf40 c033ea24 c0019edc
bf40: c02f526c 00000002 00000015 bc058c9b 93111a16 c035335c 02000000 c035ed4c
bf60: c035ed4c c03f8120 c035bf84 c035bf78 c00194c4 c033e8ec c035bfc4 c035bf88
bf80: c033bc24 c00194a0 c035bf90 c035bf98 00000000 00000000 00000000 00000000
bfa0: 00000001 00000000 c0354678 c035ece4 10004000 103532f4 c035bff4 c035bfc8
bfc0: c0338574 c033b598 00000000 00000000 00000000 c035467c 0000317d c035c03c
bfe0: c0354678 c035ece4 00000000 c035bff8 10008040 c0338508 00000000 00000000
Backtrace:
[<c001b09c>] (omap_sram_reprogram_clock+0x0/0x30) from [<c0019f54>] (omap1_select_table_rate+0x88/0xb4)
[<c0019ecc>] (omap1_select_table_rate+0x0/0xb4) from [<c033ea24>] (omap1_clk_init+0x148/0x334)
r7:c035ed4c r6:00000004 r5:00002cb3 r4:00001000
[<c033e8dc>] (omap1_clk_init+0x0/0x334) from [<c00194c4>] (omap1_init_early+0x34/0x48)
r8:c03f8120 r7:c035ed4c r6:c035ed4c r5:02000000 r4:c035335c
[<c0019490>] (omap1_init_early+0x0/0x48) from [<c033bc24>] (setup_arch+0x69c/0x79c)
[<c033b588>] (setup_arch+0x0/0x79c) from [<c0338574>] (start_kernel+0x7c/0x2f4)
[<c03384f8>] (start_kernel+0x0/0x2f4) from [<10008040>] (0x10008040)
r7:c035ece4 r6:c0354678 r5:c035c03c r4:0000317d
Code: 0a000002 e1a0e00f e12fff13 e89da800 (e7f001f2)
Fix this by adding omap1_clk_late_init() that only reprograms dpll1
if the bootloader rate is less than 60MHz. This also allows removing
of the OMAP_CLOCKS_SET_BY_BOOTLOADER option.
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
For omap15xx and 730 we need to use the MPU timer
as the 32K timer is not available. For omap16xx
we want to use the 32K timer because of PM. Fix this
by allowing to build in both timers.
This patches removes a config option that was used to select a FIQ
handler to be build for Amstrad Delta, as required by the on-board serio
interface driver. Not having any problem reports received since it was
introduced in 2.6.35, the FIQ handler can now be built and initialized by
default, thus reqiring no extra config option.
The patch below updates broken web addresses in the arch directory.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
Add KConfig entry for one of the OMAP1 DVFS rates that was missing it.
Based on the surrounding rate KConfigs and the oscillator frequency,
this patch marks it as valid for all OMAP1 platforms -- Richard,
Tuukka, Tony, perhaps you can comment if this does not look right?
In the long term, all of these CONFIG_OMAP_ARM_*MHZ should be removed.
The OPP settings should be associated with the platform information in
the structure data (perhaps by extending the omap_chip defines). The
selection of which rates to use should be handled at runtime; rates
that are impossible due to xtal frequency mismatch or SoC-type
mismatch should not be included. If implemented correctly, this
should save some CPU time and some memory on OMAP1 kernels.
Reported-by: Christoph Egger <siccegge@cs.fau.de>
Reported-by: The VAMOS Research Project <vamos@i4.informatik.uni-erlangen.de>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Richard Woodruff <r-woodruff2@ti.com>
Cc: Tuukka Tikkanen <tuukka.tikkanen@nokia.com>
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
This will make Kconfig look nicer for selecting omap processor type
processing
This patch introduces a Fast Interrupt Request (FIQ) handler for Amstrad Delta
(E3) videophone. The handler's purpose is to process interrupts generated by a
GPIO line that a serial keyboard clock hangs off. It collects consecutive bits
into words, pushing them into a buffer, then requests a higher level interrupt
after one or more words are ready for further processing by a keyboard port
driver.
The handler also processes interrupts generated by two other GPIO lines, used
by other on-board supported devices, by simply requesting a higher level
interrupt, that in turn should invoke those device's specific irq handlers.
IRQ12 line, not used by OMAP1510 hardware (described as reserved), has been
choosen as a higher level interrupt source.
This patch introduces support for the HTC Herald (T-Mobile
Wing, etc.) series of smart phones -- board support and LCD
panel settings.
Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com>
The l3_ocpi_ck clock is needed on omap7xx processors for USB.
Additionally, bit 8 of the SOFT_REQ_REG needs to be enabled for
the usb_dc_ck on omap7xx, which is a different bit than that
of the omap16xx-defined clock of the same name.
I added a provision for the usb_dc_ck and l3_ocpi_ck clocks as
dc_clk and hhc_clk, respectively, for omap7xx CPUs. Additionally,
I added a check in machine_without_vbus_sense for all omap7xx
devices, as presently I know of no omap7xx-based devices that
have vbus sense, and it made more sense to me to use a cpu check
here than to spell out each machine one at a time. Finally, DMA
is disabled for omap7xx, as it causes problems with these chips.
Cc: linux-usb@vger.kernel.org
Cc: David Brownell <dbrownell@users.sourceforge.net>
Remove unnecessary Kconfig line and allow compile of MBOX_FWK.
Also allow building USB on Nokia 770.
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Build system changes.
Signed-off-by: Zebediah C. McClure <zmc@lurian.net>
Rather than:
config CPU_BLAH
bool
depends on ARCH_FOO || MACH_BAR
default y if ARCH_FOO || MACH_BAR
arrange for ARCH_FOO and MACH_BAR to select CPU_BLAH directly.
Acked-by: Nicolas Pitre <nico@marvell.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
Acked-by: Brian Swetland <swetland@google.com>
Acked-by: Eric Miao <eric.miao@marvell.com>
Acked-by: Nicolas Bellido <ml@acolin.be>
This adds basic support for Siemens SX1. More patches are available,
with video driver, mixer, and serial ports working. That is enough to
do gsm calls with right userland.
Signed-off-by: Pavel Machek <pavel@suse.cz>
This patch adds board file and necessary includes for Palm Tungsten|T.
Palmz71 specific things - board file.
General update of the board file for Palm Tungsten E. Registers the
platform devices contained in the PDA (ROM chip, keypad, infra-red)
and updates the configuration for USB and MMC, whose config values
were previously guessed in most cases due to lack of documentation
(and now are confirmed by a number of users). Macros for GPIO pins are
moved to a file in include/asm-arm/arch-omap.
Signed-off-by: Andrzej Zaborowski <balrog@zabor.org>
arch/arm/mach-omap1/Kconfig:41:warning: 'select' used by config
symbol 'MACH_OMAP_H3' refers to undefined symbol 'GPIOEXPANDER_OMAP'
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (28 commits)
ARM: OMAP: Fix GCC-reported compile time bug
ARM: OMAP: restore CONFIG_GENERIC_TIME
ARM: OMAP: partial LED fixes
ARM: OMAP: add SoSSI clock (call propagate_rate for childrens)
ARM: OMAP: FB sync with N800 tree (support for dynamic SRAM allocations)
ARM: OMAP: Sync framebuffer headers with N800 tree
ARM: OMAP: Mostly cosmetic to sync up with linux-omap tree
ARM: OMAP: Fix gpmc header
ARM: OMAP: Add mailbox support for IVA
[ARM] armv7: add Makefile and Kconfig entries
[ARM] armv7: add support for asid-tagged VIVT I-cache
[ARM] armv7: add dedicated ARMv7 barrier instructions
[ARM] armv7: Add ARMv7 cacheid macros
[ARM] armv7: add support for ARMv7 cores.
[ARM] Fix ARM branch relocation range
[ARM] 4363/1: AT91: Remove legacy PIO definitions
[ARM] 4361/1: AT91: Build error
ARM: OMAP: Sync core code with linux-omap
ARM: OMAP: Sync headers with linux-omap
ARM: OMAP: h4 must have blinky leds!!
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4.
This patch syncs omap specific core code with linux-omap.
Most of the changes are needed to fix bitrot caused by
driver updates in linux-omap tree.
More fixes to build breakage from the work_struct changes ... this updates
the tps65010 driver. Plus, fix some dependencies related to the way it's
used on the OMAP OSK: force static linking there, since the resulting
kernel can't link.
NOTE that until the i2c core gets fixed to work without SMBUS_QUICK,
kernels needing this driver must still use "tps65010.force=0,0x48" on the
command line.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Jean Delvare <khali@linux-fr.org>
This patch adds core support for the TI F-Sample Board (OMAP 850).
Signed-off-by: Brian Swetland <swetland@google.com>
Patch from Tony Lindgren
This patch syncs OMAP board support with linux-omap tree.
The highlights of the patch are:
- Add support for Nokia 770 by Juha Yrjola
- Add support for Samsung Apollon by Kyungmin Park
- Add support for Amstrad E3 videophone by Jonathan McDowell
- Remove board-netstar.c board support as requested by Ladislav Michl
- Do platform_device registration in board files by Komal Shah et al.
This patch syncs the mainline kernel with linux-omap tree.
- Omap1 serial pport and framebuffer init updates by Imre Deak
- Add support for omap310 processor and Palm Tungsten E PDA
by Laurent Gonzales, Romain Goyet, et al. Omap310 and
omap1510 processors are now handled as omap15xx.
- Omap1 specific changes to shared omap clock framework
by Tony Lindgren
- Omap1 specific changes to shared omap pin mux framework
by Tony Lindgren
- Other misc fixes, such as update memory timings for smc91x,
omap1 specific device initialization etc.
- Convert more drivers to register resources in board-*.c to take
advantage of the driver model by David Brownell and Ladislav Michl
- Use set_irq_type() for GPIO interrupts instead of
omap_set_gpio_edge_ctrl() by David Brownell
- Add minimal support for handling optional add-on boards, such as
OSK Mistral board with LCD and keypad, by David Brownell
- Minimal support for loading functions to SRAM by Tony Lindgren
- Wake up from serial port by muxing RX lines temporarily into GPIO
interrupts by Tony Lindgren
- 32KHz sched_clock by Tony Lindgren and Juha Yrjola
and omap2
This patch by Paul Mundt and other OMAP developers modifies
ARM specific Kconfig to allow sharing code between OMAP1 and
OMAP2 architectures.
In order to share code between OMAP1 and OMAP2, all OMAP1
specific code is moved into mach-omap1 directory in the
following patch. A new mach-omap2 directory will be added
later on.
