This allows us to get a bit further with SPARSE_IRQ and
MULTIARCH support.
Note that we now also rename omap_irq_flags to omap_l2_irq
as that's the omap_irq_flags naming is confusing. It just
contains the interrupt number for the l2 irq.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
omap_reserve() is a stub for omap1. So dropping
omap_reserve callback from all OMAP1 board files.
We need to remove this from plat for ARM common zImage
support.
Also remove includes not needed by the omap_hsmmc.c driver.
Cc: linux-mmc@vger.kernel.org
Acked-by: Chris Ball <cjb@laptop.org>
Acked-by: Venkatraman S <svenkatr@ti.com>
[tony@atomide.com: fold in removal of unused driver includes]
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the omap include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Cc: Kevin Hilman <khilman@ti.com>
Cc: "Benoît Cousson" <b-cousson@ti.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: Jean Pihet <j-pihet@ti.com>
Cc: J Keerthy <j-keerthy@ti.com>
Cc: linux-omap@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into cleanup-makefile-sparse
smatch and string-wrapping cleanups for the OMAP subarch code.
These changes fix some of the more meaningful warnings that smatch
returns for the OMAP subarch code, and unwraps strings that are
wrapped at the 80-column boundary, to conform with the current
practice.
Basic build, boot, and PM logs are available here:
http://www.pwsan.com/omap/testlogs/warnings_a_cleanup_3.7/20120912025927/
There's no need to have these in plat-omap any longer. Note that these
could eventually be made local to mach-omap1 instead of being in mach.
But to do that, at least various driver access using omap7xxx.h registers
needs to be fixed first.
Cc: spi-devel-general@lists.sourceforge.net
Find and unwrap wrapped strings in the style:
pr_debug("clockdomain: hardware cannot set/clear wake up of "
"%s when %s wakes up\n", clkdm1->name, clkdm2->name);
Keeping these strings contiguous seems to be the current Linux kernel
policy.
The offending lines were found with the following command:
pcregrep -rnM '"\s*$\s*"' arch/arm/*omap*
While here, some messages have been clarified, some pr_warning(
... calls have been converted to pr_warn( ..., and some printk(KERN_*
... have been converted to pr_*.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
omap1 lcd platform data resides inside plat/board.h while it
should be inside include/linux/...
Move the omap1 lcd platform data to include/linux/omapfb.h.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
As the FS USB code is not being actively used for omap2+
there's no point keeping it around for omap2+.
Let's make the FS USB platform init code omap1 only so
we can remove the last user of omap_read/write for omap2+,
and simplify things for further USB, DMA, and device tree
related work.
While at it, also group the mach includes for the related
drivers.
Cc: linux-usb@vger.kernel.org
Acked-by: Felipe Balbi <balbi@ti.com>
arch/arm/mach-omap1/board-htcherald.c
arch/arm/mach-omap2/board-rx51-peripherals.c
arch/arm/plat-omap/include/plat/gpio.h
drivers/input/serio/ams_delta_serio.c
The following commits change gpio-omap to use dynamic
IRQ allocation:
25db711 gpio/omap: Fix IRQ handling for SPARSE_IRQ
384ebe1 gpio/omap: Add DT support to GPIO driver
With dynamic allocation of IRQ the usage of OMAP_GPIO_IRQ
is no longer valid. We must be using gpio_to_irq() instead.
Signed-off-by: Tarun Kanti DebBarma <tarun.kanti@ti.com>
[tony@atomide.com: updated comments]
Pull "ARM: global cleanups" from Arnd Bergmann:
"Quite a bit of code gets removed, and some stuff moved around, mostly
the old samsung s3c24xx stuff. There should be no functional changes
in this series otherwise. Some cleanups have dependencies on other
arm-soc branches and will be sent in the second round.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up trivial conflicts mainly due to #include's being changes on
both sides.
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits)
ep93xx: Remove unnecessary includes of ep93xx-regs.h
ep93xx: Move EP93XX_SYSCON defines to SoC private header
ep93xx: Move crunch code to mach-ep93xx directory
ep93xx: Make syscon access functions private to SoC
ep93xx: Configure GPIO ports in core code
ep93xx: Move peripheral defines to local SoC header
ep93xx: Convert the watchdog driver into a platform device.
ep93xx: Use ioremap for backlight driver
ep93xx: Move GPIO defines to gpio-ep93xx.h
ep93xx: Don't use system controller defines in audio drivers
ep93xx: Move PHYS_BASE defines to local SoC header file
ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver
ARM: EXYNOS: add clock registers for exynos4x12-cpufreq
PM / devfreq: update the name of EXYNOS clock registers that were omitted
ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock
ARM: EXYNOS: use static declaration on regarding clock
ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs
ARM: OMAP2+: Fix build error after merge
ARM: S3C24XX: remove call to s3c24xx_setup_clocks
There's no need to have these in plat/io.h.
While at it, clean up the includes to group them
like they typically are grouped.
LCD config for old omapfb driver is passed with OMAP_TAG_LCD from board
files or from the bootloader. In an effort to remove OMAP_TAG_LCD, this
patch adds omapfb_set_lcd_config() function that the board files can
call to set the LCD config.
This has the drawback that configuration can no longer come from the
bootloader. Of the boards supported by the kernel, this should only
affect N770 which depends on the data from the bootloader. This patch
adds an LCD config for N770 to its board files, but that is most
probably broken. Fixing this would need information about the HW setup
in N770 boards.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>,
there's no need to keep local prototypes in non-local headers.
Add mach-omap1/common.h and mach-omap2/common.h and move the
local prototypes there from plat/common.h and mach/omap4-common.h.
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits)
ARM: OMAP: Warn if omap_ioremap is called before SoC detection
ARM: OMAP: Move set_globals initialization to happen in init_early
ARM: OMAP: Map SRAM later on with ioremap_exec()
ARM: OMAP: Remove calls to SRAM allocations for framebuffer
ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done
ARM: OMAP1: Use generic map_io, init_early and init_irq
arm/dts: OMAP3+: Add mpu, dsp and iva nodes
arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver
ARM: OMAP2+: l3-noc: Add support for device-tree
ARM: OMAP2+: board-generic: Add i2c static init
ARM: OMAP2+: board-generic: Add DT support to generic board
arm/dts: Add support for OMAP3 Beagle board
arm/dts: Add initial device tree support for OMAP3 SoC
arm/dts: Add support for OMAP4 SDP board
arm/dts: Add support for OMAP4 PandaBoard
arm/dts: Add initial device tree support for OMAP4 SoC
ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node
ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration
of: Add helpers to get one string in multiple strings property
ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures
Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
Theis resolves lots of simple conflicts between the omap
cleanup and the mach/memory.h removal series.
arch/arm/mach-imx/mach-cpuimx27.c
arch/arm/mach-omap1/board-ams-delta.c
arch/arm/mach-omap1/board-generic.c
arch/arm/mach-omap1/board-h2.c
arch/arm/mach-omap1/board-h3.c
arch/arm/mach-omap1/board-nokia770.c
arch/arm/mach-omap1/board-osk.c
arch/arm/mach-omap1/board-palmte.c
arch/arm/mach-omap1/board-palmtt.c
arch/arm/mach-omap1/board-palmz71.c
arch/arm/mach-omap1/board-sx1.c
arch/arm/mach-omap1/board-voiceblue.c
arch/arm/mach-omap1/io.c
arch/arm/mach-omap2/io.c
arch/arm/plat-omap/io.c
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
This allows removing omap hacks for map_io allowing generic
map_io.
Note that in the future we can't do cpu_is_omapxxxx detection
until in init_early. This means that board-innovator.c now
assumes 15xx only, and board-generic.c assumes 16xx only.
This is best fixed later on by passing the SoC type from
device tree.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
This is needed for the following patches so we can initialize the
rest of the hardware timers later on.
As with the init_irq calls, there's no need to do cpu_is_omap calls
during the timer init as we only care about the major omap generation.
This means that we can initialize the sys_timer with the .timer
entries alone.
Note that for now we just set stubs for the various sys_timer entries
that will get populated in a later patch. The following patches will
also remove the omap_dm_timer_init calls and change the init for the
rest of the hardware timers to happen with an arch_initcall.
Reviewed-by: Kevin Hilman <khilman@ti.com>
This allows us to remove cpu_is_omap calls from init_irq functions.
There should not be any need for cpu_is_omap calls as at this point.
During the timer init we only care about SoC generation, and not about
subrevisions.
The main reason for the patch is that we want to initialize only
minimal omap specific code from the init_early call.
Eliminates the following sparse warnings:
arch/arm/mach-omap1/board-htcherald.c:334:34: warning: symbol 'htcpld_chips' was not declared. Should it be static?
arch/arm/mach-omap1/board-htcherald.c:369:34: warning: symbol 'htcpld_pfdata' was not declared. Should it be static?
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Most keypad drivers make use of the <linux/input/matrix_keypad.h>
defined macros, structures and inline functions.
Convert omap-keypad driver to use those as well, as suggested by a
compile time warning, hardcoded into the OMAP <palt/keypad.h>.
Created against linux-2.6.37-rc5.
Tested on Amstrad Delta.
Compile tested with omap1_defconfig and omap2plus_defconfig shrinked to
board-h4.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Reviewed-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Patch fix following compilation warning:
arch/arm/mach-omap1/board-htcherald.c:442:
warning: large integer implicitly truncated to unsigned type
Hopefully this is just a typo.
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Implement GPIO as a platform device.
GPIO APIs are used in machine_init functions. Hence it is
required to complete GPIO probe before board_init. Therefore
GPIO device register and driver register are implemented as
postcore_initcalls.
omap_gpio_init() does nothing now and this function would be
removed in the next patch as it's usage is spread across most
of the board files.
Inorder to convert GPIO as platform device, modifications are
required in clockxxxx_data.c file for OMAP1 so that device names
can be used to obtain clock instead of getting clocks by
name/NULL ptr.
Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling
or disabling the clocks, modify sysconfig settings and remove usage
of clock FW APIs.
Note 1: Converting GPIO driver to use runtime PM APIs is not done as a
separate patch because GPIO clock names are different for various OMAPs
and are different for some of the banks in the same CPU. This would need
usage of cpu_is checks and bank id checks while using clock FW APIs in
the gpio driver. Hence while making GPIO a platform driver framework,
PM runtime APIs are used directly.
Note 2: While implementing GPIO as a platform device, pm runtime APIs
are used as mentioned above and modification is not done in gpio's
prepare for idle/ resume after idle functions. This would be done
in the next patch series and GPIO driver would be made to use dev_pm_ops
instead of sysdev_class in that series only.
Due to the above, the GPIO driver implicitly relies on
CM_AUTOIDLE = 1 on its iclk for power management to work, since the
driver never disables its iclk.
This would be taken care in the next patch series (see Note 3 below).
Refer to
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html
for more details.
Note 3: only pm_runtime_get_sync is called in gpio's probe() and
pm_runtime_put* is never called. This is to make the implementation
similar to the existing GPIO code. Another patch series would be sent
to correct this.
In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They
are enabled/ disabled whenever required using clock framework APIs
TODO:
1. Cleanup the GPIO driver. Use function pointers and register
offest pointers instead of using hardcoded values
2. Remove all cpu_is_ checks and OMAP specific macros
3. Remove usage of gpio_bank array so that only
instance specific information is used in driver code
4. Rename 'method'/ avoid it's usage
5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4
6. Modify gpio's prepare for idle/ resume after idle functions
to use runtime pm implentation.
Signed-off-by: Charulatha V <charu@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Reviewed-by: Basak, Partha <p-basak2@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
[tony@atomide.com: updated for bank specific revision and updated boards]
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits)
omap: complete removal of machine_desc.io_pg_offst and .phys_io
omap: UART: fix wakeup registers for OMAP24xx UART2
omap: Fix spotty MMC voltages
ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h
serial: omap-serial: fix signess error
OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish
omap: dma: Fix buffering disable bit setting for omap24xx
omap: serial: Fix the boot-up crash/reboot without CONFIG_PM
OMAP3: PM: fix scratchpad memory accesses for off-mode
omap4: pandaboard: enable the ehci port on pandaboard
omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set
omap4: pandaboard: remove unused hsmmc definition
OMAP: McBSP: Remove null omap44xx ops comment
OMAP: McBSP: Swap CLKS source definition
OMAP: McBSP: Fix CLKR and FSR signal muxing
OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks
OMAP: control: move plat-omap/control.h to mach-omap2/control.h
OMAP: split plat-omap/common.c
OMAP: McBSP: implement functional clock switching via clock framework
OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c
Fixed up trivial conflicts in arch/arm/mach-omap2/
{board-zoom-peripherals.c,devices.c} as per Tony
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
As noted by Michał Mirosław <mirqus@gmail.com>, the voltages should
cover the supported voltage range, or support only one voltage.
As all these boards are using a GPIO to enable the power, chances
are that only 3.3V cards are supported on these boards.
Reported-by: Michał Mirosław <mirqus@gmail.com>
This change adds in MMC and I2C support to the HTC Herald board, as well
as adding the HTCPLD driver for the PLD used on this phone. It also
adds in the gpio-keys entries for the front directional keys and
selector and the cursor keys on the slide-out keyboard, and gpio-leds
support for the LEDs attached to the htcpld.
Additionally, SPI bus support (using the spi100k driver) and
touchscreen support (using the ads7846 driver) were added.
Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com>
Move omap1 FS USB platform init code into mach-omap1/usb.c
These files include linux/bootmem.h without using anything from this
file; remove the unnecessary include.
This change implements USB client side support into the HTC
Herald board configuration. It uses a similar, but updated
algorithm to initialize the USB as is used in the linwizard
project.
This patch introduces support for the HTC Herald (T-Mobile
Wing, etc.) series of smart phones -- board support and LCD
panel settings.
