This is needed for the following patches so we can initialize the
rest of the hardware timers later on.
As with the init_irq calls, there's no need to do cpu_is_omap calls
during the timer init as we only care about the major omap generation.
This means that we can initialize the sys_timer with the .timer
entries alone.
Note that for now we just set stubs for the various sys_timer entries
that will get populated in a later patch. The following patches will
also remove the omap_dm_timer_init calls and change the init for the
rest of the hardware timers to happen with an arch_initcall.
Reviewed-by: Kevin Hilman <khilman@ti.com>
This allows us to remove cpu_is_omap calls from init_irq functions.
There should not be any need for cpu_is_omap calls as at this point.
During the timer init we only care about SoC generation, and not about
subrevisions.
The main reason for the patch is that we want to initialize only
minimal omap specific code from the init_early call.
Eliminates the following sparse warning:
arch/arm/mach-omap1/board-innovator.c:368:13: warning: symbol 'innovator_mmc_init' was not declared. Should it be static?
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Most keypad drivers make use of the <linux/input/matrix_keypad.h>
defined macros, structures and inline functions.
Convert omap-keypad driver to use those as well, as suggested by a
compile time warning, hardcoded into the OMAP <palt/keypad.h>.
Created against linux-2.6.37-rc5.
Tested on Amstrad Delta.
Compile tested with omap1_defconfig and omap2plus_defconfig shrinked to
board-h4.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Reviewed-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
No need to call this early from init_irq. Also recent changes
initialize GPIO now later, so calling gpio_request from init_irq
will make it fail.
While at it, also remove the unnecessary EXPORT_SYMBOL.
Implement GPIO as a platform device.
GPIO APIs are used in machine_init functions. Hence it is
required to complete GPIO probe before board_init. Therefore
GPIO device register and driver register are implemented as
postcore_initcalls.
omap_gpio_init() does nothing now and this function would be
removed in the next patch as it's usage is spread across most
of the board files.
Inorder to convert GPIO as platform device, modifications are
required in clockxxxx_data.c file for OMAP1 so that device names
can be used to obtain clock instead of getting clocks by
name/NULL ptr.
Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling
or disabling the clocks, modify sysconfig settings and remove usage
of clock FW APIs.
Note 1: Converting GPIO driver to use runtime PM APIs is not done as a
separate patch because GPIO clock names are different for various OMAPs
and are different for some of the banks in the same CPU. This would need
usage of cpu_is checks and bank id checks while using clock FW APIs in
the gpio driver. Hence while making GPIO a platform driver framework,
PM runtime APIs are used directly.
Note 2: While implementing GPIO as a platform device, pm runtime APIs
are used as mentioned above and modification is not done in gpio's
prepare for idle/ resume after idle functions. This would be done
in the next patch series and GPIO driver would be made to use dev_pm_ops
instead of sysdev_class in that series only.
Due to the above, the GPIO driver implicitly relies on
CM_AUTOIDLE = 1 on its iclk for power management to work, since the
driver never disables its iclk.
This would be taken care in the next patch series (see Note 3 below).
Refer to
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html
for more details.
Note 3: only pm_runtime_get_sync is called in gpio's probe() and
pm_runtime_put* is never called. This is to make the implementation
similar to the existing GPIO code. Another patch series would be sent
to correct this.
In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They
are enabled/ disabled whenever required using clock framework APIs
TODO:
1. Cleanup the GPIO driver. Use function pointers and register
offest pointers instead of using hardcoded values
2. Remove all cpu_is_ checks and OMAP specific macros
3. Remove usage of gpio_bank array so that only
instance specific information is used in driver code
4. Rename 'method'/ avoid it's usage
5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4
6. Modify gpio's prepare for idle/ resume after idle functions
to use runtime pm implentation.
Signed-off-by: Charulatha V <charu@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Reviewed-by: Basak, Partha <p-basak2@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
[tony@atomide.com: updated for bank specific revision and updated boards]
Looks like some boards are calling gpio_request from init_irq.
This will make the request_irq fail, as GPIO will be initialized
as postcore_initcall.
Reported-by: Paul Walmsley <paul@pwsan.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
Move omap1 FS USB platform init code into mach-omap1/usb.c
Convert OMAP based boards to use physmap-flash. Refreshed against today's
Linux omap kernel tree
Cc: linux-mtd@lists.infradead.org
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Use smc91x_platdata to setup smc91x, so we can get rid of OMAP specific stuff
in smc91x driver
Commit 15ac408ee5a509053a765b816e9179515329369f removed enabled_uart
and OMAP_TAG_UART. This works for mach-omap2, but causes issues on
mach-omap1 for some boards as the mach-omap1 serial.c was muxing
pins based on the enabled_uart flag for 15xx.
Fix this by muxing pins in board-*.c files for the 15xx boards for
the uart ports that had enabled_uart flag set before the commit
above.
Tested on Amsdtrad Delta only.
Note that in the future we should add support for powering down
the uarts with a timer like mach-omap2/serial.c does. Otherwise
the enabled uarts will be blocking retention-while-idle.
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
OMAP tags are deprecrated so drop them.
Drop UART config data which decides which UARTs to enable during boot.
This is no longer necessary since serial core code disables clocks
after inactivity.
Background: with new UART idle code, all on-chip UARTs are idled using
a configurable inactivity timer (default 5 seconds.) After the
inactivity timer, UART clocks are disabled automatically.
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
OMAP_TAGS should vanish soon since they're not generic arm tags.
Most of them can be converted to a platform_data or parsed
from a command line like e.g. serial tag.
For OMAP_TAG_USB we just let boards call omap_usb_init()
passing a pointer to omap_usb_config.
Patch updated by Tony for mainline, basically make
n770 and h4 compile. Also folded in a fix for OSK
by David Brownell <dbrownell@users.sourceforge.net>.
Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com>
Move the defines to the board file and remove the now unnecessary
header file.
This patch removes old platform devices. Alsa should now
be using the ASoC driver. For boards not yet using ASoC,
please see sound/soc/omap/osk5912.c.
Add dummy aic23_power_up and aic23_power_down functions for 770
to keep things compiling.
Remove references to omap_gpio_switch, and unused h2_nand_dev_ready
function.
This patch is based on an earlier patch by Arun KS.
Cc: Jarkko Nikula <jarkko.nikula@nokia.com>
Signed-off-by: Arun KS <arunks@mistralsolutions.com>
Add low-level initialization for hsmmc controller. Merged into
this patch patch are various improvments and board support by
Grazvydas Ignotas and David Brownell.
Also change wire4 to be wires, as some newer controllers support
8 data lines.
Cc: Pierre Ossman <drzeus-mmc@drzeus.cx>
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This will simplify the MMC low-level init, and make it more
flexible to add support for a newer MMC controller in the
following patches.
The patch rearranges platform data and gets rid of slot vs
controller confusion in the old data structures. Also fix
device id numbering in the clock code.
Some code snippets are based on an earlier patch by
Russell King <linux@arm.linux.org.uk>.
Switch to gpio_request/free calls
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
This patch starts using introduced I2C bus registration helper by cleaning
up registration currently done in various places and by doing necessary
board file modifications.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Change the comments to C style
Signed-off-by: David Cohen <david.cohen@indt.org.br>
smc91x is shared between many different platforms. Each platform needs
to specify the interrupt type, and in some cases the irq type depends
on more than just the build configuration - it depends on runtime
checks.
Rather than throwing this code into the SMC_IRQ_FLAGS definition, provide
a way for these flags to be passed via the IRQ resource itself.
Note that IRQF_TRIGGER_* constants are intentionally defined to correspond
with the IORESOURCE_IRQ_* interrupt type flags, in much the same way that
the low bits of PCI iomem resources correspond with the BAR flag bits.
Also provide a way to configure smc91x to read the IRQ flags from the
resource. Once all platforms have been converted over (signified
by all definitions of SMC_IRQ_FLAGS being -1) SMC_IRQ_FLAGS should
be removed.
Acked-by: Nicolas Pitre <nico@cam.org>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Minor GPIO cleanups: remove needless #include, and omap_gpio_init()
should be __init, as well as all the board init code calling it.
This patch adds keymapsize, delay and debounce flag in the keypad platform
data for various TI OMAP1/2 based boards like F-sample, H2, H3, Innovator,
Nokia770, OSK, Perseus and H4.
Signed-off-by: Komal Shah <komal_shah802003@yahoo.com>
Add bitbang SPI driver for Innovator 1510 touchscreen, using the new
framework. Compile-tested only.
Add platform driver init-code required by the aic23-alsa driver to
omap-innovator.
Signed-off-by: Mika Laitio <lamikr@cc.jyu.fi>
Patch from Tony Lindgren
This patch syncs OMAP board support with linux-omap tree.
The highlights of the patch are:
- Add support for Nokia 770 by Juha Yrjola
- Add support for Samsung Apollon by Kyungmin Park
- Add support for Amstrad E3 videophone by Jonathan McDowell
- Remove board-netstar.c board support as requested by Ladislav Michl
- Do platform_device registration in board files by Komal Shah et al.
This patch fixes the low-level IO init for omap1 boards.
Patch from Nicolas Pitre
This field is redundent since it must be equal to PHYS_OFFSET anyway.
Now that no code uses it anymore, mark it deprecated and remove all
initializations from the tree.
Signed-off-by: Nicolas Pitre <nico@cam.org>
This patch syncs the mainline kernel with linux-omap tree.
- Omap1 serial pport and framebuffer init updates by Imre Deak
- Add support for omap310 processor and Palm Tungsten E PDA
by Laurent Gonzales, Romain Goyet, et al. Omap310 and
omap1510 processors are now handled as omap15xx.
- Omap1 specific changes to shared omap clock framework
by Tony Lindgren
- Omap1 specific changes to shared omap pin mux framework
by Tony Lindgren
- Other misc fixes, such as update memory timings for smc91x,
omap1 specific device initialization etc.
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
Patch from Deepak Saxena
OMAP map_desc.pfn conversion
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
- Convert more drivers to register resources in board-*.c to take
advantage of the driver model by David Brownell and Ladislav Michl
- Use set_irq_type() for GPIO interrupts instead of
omap_set_gpio_edge_ctrl() by David Brownell
- Add minimal support for handling optional add-on boards, such as
OSK Mistral board with LCD and keypad, by David Brownell
- Minimal support for loading functions to SRAM by Tony Lindgren
- Wake up from serial port by muxing RX lines temporarily into GPIO
interrupts by Tony Lindgren
- 32KHz sched_clock by Tony Lindgren and Juha Yrjola
This patch by various OMAP developers syncs the OMAP
specific arch files with the linux-omap tree.
directory
This patch by Paul Mundt and other OMAP developers
moves OMAP1 board files into mach-omap1 directory.
