path: root/arch/arm/mach-omap1/board-innovator.c
2016-08-26ARM: OMAP1: use IS_ENABLED() instead of checking for built-in or moduleJavier Martinez Canillas
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either built-in or as a module, use that macro instead of open coding the same. Using the macro makes the code more readable by helping abstract away some of the Kconfig built-in and module enable details. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-01ARM: omap1: make headers more localArnd Bergmann
Some header files are never included outside of a mach-omap1 directory and do not need to be made visible in include/mach, so let's just move them all down one level. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Lindgren <tony@atomide.com>
2015-05-20ARM: omap1: Switch to use MULTI_IRQTony Lindgren
This allows us to get a bit further with SPARSE_IRQ and MULTIARCH support. Note that we now also rename omap_irq_flags to omap_l2_irq as that's the omap_irq_flags naming is confusing. It just contains the interrupt number for the l2 irq. Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-16ARM: OMAP: replace checks for CONFIG_USB_GADGET_OMAPPaul Bolle
Commit 193ab2a60700 ("usb: gadget: allow multiple gadgets to be built") apparently required that checks for CONFIG_USB_GADGET_OMAP would be replaced with checks for CONFIG_USB_OMAP. Do so now for the remaining checks for CONFIG_USB_GADGET_OMAP, even though these checks have basically been broken since v3.1. And, since we're touching this code, use the IS_ENABLED() macro, so things will now (hopefully) also work if USB_OMAP is modular. Fixes: 193ab2a60700 ("usb: gadget: allow multiple gadgets to be built") Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-31ARM: OMAP: Fix relative includes for fpga.hTony Lindgren
As discussed on linux-arm-kernel, we want to avoid relative includes for the arch/arm/*omap* code: http://www.spinics.net/lists/linux-omap/msg80520.html Fix includes for fpga.h by making fpga.h local to mach-omap1. The common code in plat-omap just needs to know the struct h2p2_dbg_fpga, which can be local to debug-leds.c. This also fixes the braindead <../*.h> style includes that got accidentally added with search and replace during the cleanup. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-18ARM: OMAP1: Remove omap_reserve() callback for all omap1 boardsLokesh Vutla
omap_reserve() is a stub for omap1. So dropping omap_reserve callback from all OMAP1 board files. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-17ARM: OMAP1: Move plat/tc.h to mach/tc.h for omap1Tony Lindgren
We cannot keep this in plat as it causes problems with the ARM single zImage support. Cc: Felipe Balbi <balbi@ti.com> Cc: linux-pcmcia@lists.infradead.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-17ARM: OMAP: Make plat/fpga.h local to arch/arm/plat-omapTony Lindgren
There's no need to have this file in plat/fpga.h. We can make it local to plat-omap replacing fpga_read/write functions directly with readb/writeb as that's how they are already defined in fpga.h. Note that 2420 based H4 is also using the fpga, so let's keep the led support around in plat-omap until we flip over mach-omap2 to device tree. Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: linux-fbdev@vger.kernel.org Cc: Felipe Balbi <balbi@ti.com> Cc: linux-usb@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-15ARM: OMAP: Split plat/mmc.h into local headers and platform_dataTony Lindgren
We need to remove this from plat for ARM common zImage support. Also remove includes not needed by the omap_hsmmc.c driver. Cc: linux-mmc@vger.kernel.org Acked-by: Chris Ball <cjb@laptop.org> Acked-by: Venkatraman S <svenkatr@ti.com> [tony@atomide.com: fold in removal of unused driver includes] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-20ARM: OMAP1: Move flash.h from plat to machTony Lindgren
This is only used by omap1. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-20ARM: OMAP1: Make plat/mux.h omap1 onlyTony Lindgren
We are moving omap2+ to use the device tree based pinctrl-single.c and will be removing the old mux framework. This will remove the omap1 specific parts from plat-omap. Acked-by: Felipe Balbi <balbi@ti.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: linux-usb@vger.kernel.org Cc: linux-pcmcia@lists.infradead.org Cc: spi-devel-general@lists.sourceforge.net Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-19ARM: omap: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the omap include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@ti.com> Cc: "Benoît Cousson" <b-cousson@ti.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Jean Pihet <j-pihet@ti.com> Cc: J Keerthy <j-keerthy@ti.com> Cc: linux-omap@vger.kernel.org
2012-06-04ARM: OMAP: Make FS USB omap1 onlyTony Lindgren
As the FS USB code is not being actively used for omap2+ there's no point keeping it around for omap2+. Let's make the FS USB platform init code omap1 only so we can remove the last user of omap_read/write for omap2+, and simplify things for further USB, DMA, and device tree related work. While at it, also group the mach includes for the related drivers. Cc: linux-usb@vger.kernel.org Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-08ARM: omap1: use machine specific hook for late initShawn Guo
Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com>
2012-03-29Merge branch 'fixes-gpio-to-irq' into fixesTony Lindgren
Conflicts: arch/arm/mach-omap1/board-htcherald.c arch/arm/mach-omap2/board-rx51-peripherals.c arch/arm/plat-omap/include/plat/gpio.h drivers/input/serio/ams_delta_serio.c
2012-03-29ARM: OMAP: boards: Fix OMAP_GPIO_IRQ usage with gpio_to_irq()Tarun Kanti DebBarma
The following commits change gpio-omap to use dynamic IRQ allocation: 25db711 gpio/omap: Fix IRQ handling for SPARSE_IRQ 384ebe1 gpio/omap: Add DT support to GPIO driver With dynamic allocation of IRQ the usage of OMAP_GPIO_IRQ is no longer valid. We must be using gpio_to_irq() instead. Signed-off-by: Tarun Kanti DebBarma <tarun.kanti@ti.com> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-03-27Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: global cleanups" from Arnd Bergmann: "Quite a bit of code gets removed, and some stuff moved around, mostly the old samsung s3c24xx stuff. There should be no functional changes in this series otherwise. Some cleanups have dependencies on other arm-soc branches and will be sent in the second round. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial conflicts mainly due to #include's being changes on both sides. * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits) ep93xx: Remove unnecessary includes of ep93xx-regs.h ep93xx: Move EP93XX_SYSCON defines to SoC private header ep93xx: Move crunch code to mach-ep93xx directory ep93xx: Make syscon access functions private to SoC ep93xx: Configure GPIO ports in core code ep93xx: Move peripheral defines to local SoC header ep93xx: Convert the watchdog driver into a platform device. ep93xx: Use ioremap for backlight driver ep93xx: Move GPIO defines to gpio-ep93xx.h ep93xx: Don't use system controller defines in audio drivers ep93xx: Move PHYS_BASE defines to local SoC header file ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver ARM: EXYNOS: add clock registers for exynos4x12-cpufreq PM / devfreq: update the name of EXYNOS clock registers that were omitted PM / devfreq: update the name of EXYNOS clock register ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock ARM: EXYNOS: use static declaration on regarding clock ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs ARM: OMAP2+: Fix build error after merge ARM: S3C24XX: remove call to s3c24xx_setup_clocks ...
2012-03-13Merge branch 'next/cleanup-exynos-clock' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup * 'next/cleanup-exynos-clock' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver ARM: EXYNOS: add clock registers for exynos4x12-cpufreq PM / devfreq: update the name of EXYNOS clock registers that were omitted PM / devfreq: update the name of EXYNOS clock register ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock ARM: EXYNOS: use static declaration on regarding clock ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs (includes an update to v3.3-rc6)
2012-02-24ARM: OMAP1: Move most of plat/io.h into local iomap.hTony Lindgren
There's no need to have these in plat/io.h. While at it, clean up the includes to group them like they typically are grouped. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-02-23OMAP1: pass LCD config with omapfb_set_lcd_config()Tomi Valkeinen
LCD config for old omapfb driver is passed with OMAP_TAG_LCD from board files or from the bootloader. In an effort to remove OMAP_TAG_LCD, this patch adds omapfb_set_lcd_config() function that the board files can call to set the LCD config. This has the drawback that configuration can no longer come from the bootloader. Of the boards supported by the kernel, this should only affect N770 which depends on the data from the bootloader. This patch adds an LCD config for N770 to its board files, but that is most probably broken. Fixing this would need information about the HW setup in N770 boards. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-02-21ARM: OMAP1: Fix out-of-bounds array access for InnovatorTony Lindgren
Otherwise we can get the following on some compilers: arch/arm/mach-omap1/board-innovator.c:419:19: warning: array subscript is above array bounds [-Warray-bounds] arch/arm/mach-omap1/board-innovator.c:425:19: warning: array subscript is above array bounds [-Warray-bounds] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-01-05ARM: restart: omap: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-17ARM: 7159/1: OMAP: Introduce local common.h filesTony Lindgren
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>, there's no need to keep local prototypes in non-local headers. Add mach-omap1/common.h and mach-omap2/common.h and move the local prototypes there from plat/common.h and mach/omap4-common.h. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-01Merge branch 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits) ARM: OMAP: Warn if omap_ioremap is called before SoC detection ARM: OMAP: Move set_globals initialization to happen in init_early ARM: OMAP: Map SRAM later on with ioremap_exec() ARM: OMAP: Remove calls to SRAM allocations for framebuffer ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done ARM: OMAP1: Use generic map_io, init_early and init_irq arm/dts: OMAP3+: Add mpu, dsp and iva nodes arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver ARM: OMAP2+: l3-noc: Add support for device-tree ARM: OMAP2+: board-generic: Add i2c static init ARM: OMAP2+: board-generic: Add DT support to generic board arm/dts: Add support for OMAP3 Beagle board arm/dts: Add initial device tree support for OMAP3 SoC arm/dts: Add support for OMAP4 SDP board arm/dts: Add support for OMAP4 PandaBoard arm/dts: Add initial device tree support for OMAP4 SoC ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration of: Add helpers to get one string in multiple strings property ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures ... Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
2011-11-01Merge branch 'depends/rmk/memory_h' into next/cleanup2Arnd Bergmann
Theis resolves lots of simple conflicts between the omap cleanup and the mach/memory.h removal series. Conflicts: arch/arm/mach-imx/mach-cpuimx27.c arch/arm/mach-omap1/board-ams-delta.c arch/arm/mach-omap1/board-generic.c arch/arm/mach-omap1/board-h2.c arch/arm/mach-omap1/board-h3.c arch/arm/mach-omap1/board-nokia770.c arch/arm/mach-omap1/board-osk.c arch/arm/mach-omap1/board-palmte.c arch/arm/mach-omap1/board-palmtt.c arch/arm/mach-omap1/board-palmz71.c arch/arm/mach-omap1/board-sx1.c arch/arm/mach-omap1/board-voiceblue.c arch/arm/mach-omap1/io.c arch/arm/mach-omap2/board-generic.c arch/arm/mach-omap2/io.c arch/arm/plat-omap/io.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-19ARM: OMAP1: Use generic map_io, init_early and init_irqTony Lindgren
This allows removing omap hacks for map_io allowing generic map_io. Note that in the future we can't do cpu_is_omapxxxx detection until in init_early. This means that board-innovator.c now assumes 15xx only, and board-generic.c assumes 16xx only. This is best fixed later on by passing the SoC type from device tree. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-21ARM: mach-omap1: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-08ARM: gpio: convert includes of mach/gpio.h and asm/gpio.h to linux/gpio.hRussell King
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h before we start consolidating the individual platform implementations of the gpio header files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-20omap: Set separate timer init functions to avoid cpu_is_omap testsTony Lindgren
This is needed for the following patches so we can initialize the rest of the hardware timers later on. As with the init_irq calls, there's no need to do cpu_is_omap calls during the timer init as we only care about the major omap generation. This means that we can initialize the sys_timer with the .timer entries alone. Note that for now we just set stubs for the various sys_timer entries that will get populated in a later patch. The following patches will also remove the omap_dm_timer_init calls and change the init for the rest of the hardware timers to happen with an arch_initcall. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-16omap: Use separate init_irq functions to avoid cpu_is_omap tests earlyTony Lindgren
This allows us to remove cpu_is_omap calls from init_irq functions. There should not be any need for cpu_is_omap calls as at this point. During the timer init we only care about SoC generation, and not about subrevisions. The main reason for the patch is that we want to initialize only minimal omap specific code from the init_early call. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-01-27arm: mach-omap1: board-innovator: make innovator_mmc_init() staticAaro Koskinen
Eliminates the following sparse warning: arch/arm/mach-omap1/board-innovator.c:368:13: warning: symbol 'innovator_mmc_init' was not declared. Should it be static? Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-22Keyboard: omap-keypad: use matrix_keypad.hJanusz Krzysztofik
Most keypad drivers make use of the <linux/input/matrix_keypad.h> defined macros, structures and inline functions. Convert omap-keypad driver to use those as well, as suggested by a compile time warning, hardcoded into the OMAP <palt/keypad.h>. Created against linux-2.6.37-rc5. Tested on Amstrad Delta. Compile tested with omap1_defconfig and omap2plus_defconfig shrinked to board-h4. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Reviewed-by: Aaro Koskinen <aaro.koskinen@nokia.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-20omap1: Fix innovator FPGA init for multi-omapTony Lindgren
No need to call this early from init_irq. Also recent changes initialize GPIO now later, so calling gpio_request from init_irq will make it fail. While at it, also remove the unnecessary EXPORT_SYMBOL. Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-07OMAP: GPIO: Implement GPIO as a platform deviceVaradarajan, Charulatha
Implement GPIO as a platform device. GPIO APIs are used in machine_init functions. Hence it is required to complete GPIO probe before board_init. Therefore GPIO device register and driver register are implemented as postcore_initcalls. omap_gpio_init() does nothing now and this function would be removed in the next patch as it's usage is spread across most of the board files. Inorder to convert GPIO as platform device, modifications are required in clockxxxx_data.c file for OMAP1 so that device names can be used to obtain clock instead of getting clocks by name/NULL ptr. Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling or disabling the clocks, modify sysconfig settings and remove usage of clock FW APIs. Note 1: Converting GPIO driver to use runtime PM APIs is not done as a separate patch because GPIO clock names are different for various OMAPs and are different for some of the banks in the same CPU. This would need usage of cpu_is checks and bank id checks while using clock FW APIs in the gpio driver. Hence while making GPIO a platform driver framework, PM runtime APIs are used directly. Note 2: While implementing GPIO as a platform device, pm runtime APIs are used as mentioned above and modification is not done in gpio's prepare for idle/ resume after idle functions. This would be done in the next patch series and GPIO driver would be made to use dev_pm_ops instead of sysdev_class in that series only. Due to the above, the GPIO driver implicitly relies on CM_AUTOIDLE = 1 on its iclk for power management to work, since the driver never disables its iclk. This would be taken care in the next patch series (see Note 3 below). Refer to http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html for more details. Note 3: only pm_runtime_get_sync is called in gpio's probe() and pm_runtime_put* is never called. This is to make the implementation similar to the existing GPIO code. Another patch series would be sent to correct this. In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They are enabled/ disabled whenever required using clock framework APIs TODO: 1. Cleanup the GPIO driver. Use function pointers and register offest pointers instead of using hardcoded values 2. Remove all cpu_is_ checks and OMAP specific macros 3. Remove usage of gpio_bank array so that only instance specific information is used in driver code 4. Rename 'method'/ avoid it's usage 5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4 6. Modify gpio's prepare for idle/ resume after idle functions to use runtime pm implentation. Signed-off-by: Charulatha V <charu@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Reviewed-by: Basak, Partha <p-basak2@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> [tony@atomide.com: updated for bank specific revision and updated boards] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-07omap: Fix gpio_request calls to happen as arch_initcallTony Lindgren
Looks like some boards are calling gpio_request from init_irq. This will make the request_irq fail, as GPIO will be initialized as postcore_initcall. Reported-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-08-04Merge branch 'devel-map-io' into omap-for-linusTony Lindgren
2010-07-16ARM: OMAP: Convert to use ->reserve method to reserve boot time memoryRussell King
2010-07-05omap: Move omap1 USB platform init code into mach-omap1/usb.cTony Lindgren
Move omap1 FS USB platform init code into mach-omap1/usb.c Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap: convert boards to use physmap-flashLadislav Michl
Convert OMAP based boards to use physmap-flash. Refreshed against today's Linux omap kernel tree Cc: linux-mtd@lists.infradead.org Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: use smc91x_platdata to setup smc91xLadislav Michl
Use smc91x_platdata to setup smc91x, so we can get rid of OMAP specific stuff in smc91x driver Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-10Merge branch '7xx-iosplit-plat' with omap-fixesTony Lindgren
2009-10-22omap1: Fix redundant UARTs pin muxing that can break other hardware supportJanusz Krzysztofik
Commit 15ac408ee5a509053a765b816e9179515329369f removed enabled_uart and OMAP_TAG_UART. This works for mach-omap2, but causes issues on mach-omap1 for some boards as the mach-omap1 serial.c was muxing pins based on the enabled_uart flag for 15xx. Fix this by muxing pins in board-*.c files for the 15xx boards for the uart ports that had enabled_uart flag set before the commit above. Tested on Amsdtrad Delta only. Note that in the future we should add support for powering down the uarts with a timer like mach-omap2/serial.c does. Otherwise the enabled uarts will be blocking retention-while-idle. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-08-28OMAP: UART: drop OMAP_TAG_UART, enable all UARTs, auto-disabled on idleKalle Valo
OMAP tags are deprecrated so drop them. Drop UART config data which decides which UARTs to enable during boot. This is no longer necessary since serial core code disables clocks after inactivity. Background: with new UART idle code, all on-chip UARTs are idled using a configurable inactivity timer (default 5 seconds.) After the inactivity timer, UART clocks are disabled automatically. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP: get rid of OMAP_TAG_USB, v2Felipe Balbi
OMAP_TAGS should vanish soon since they're not generic arm tags. Most of them can be converted to a platform_data or parsed from a command line like e.g. serial tag. For OMAP_TAG_USB we just let boards call omap_usb_init() passing a pointer to omap_usb_config. Patch updated by Tony for mainline, basically make n770 and h4 compile. Also folded in a fix for OSK by David Brownell <dbrownell@users.sourceforge.net>. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP: No need to include board-innovator.h from hardware.hTony Lindgren
Move the defines to the board file and remove the now unnecessary header file. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-01-15ARM: OMAP: Remove unused platform devices, v3Tony Lindgren
This patch removes old platform devices. Alsa should now be using the ASoC driver. For boards not yet using ASoC, please see sound/soc/omap/osk5912.c. Add dummy aic23_power_up and aic23_power_down functions for 770 to keep things compiling. Remove references to omap_gpio_switch, and unused h2_nand_dev_ready function. This patch is based on an earlier patch by Arun KS. Cc: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Arun KS <arunks@mistralsolutions.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
