path: root/arch/arm/mach-omap1/board-nokia770.c
2011-06-20omap: Set separate timer init functions to avoid cpu_is_omap testsTony Lindgren
This is needed for the following patches so we can initialize the rest of the hardware timers later on. As with the init_irq calls, there's no need to do cpu_is_omap calls during the timer init as we only care about the major omap generation. This means that we can initialize the sys_timer with the .timer entries alone. Note that for now we just set stubs for the various sys_timer entries that will get populated in a later patch. The following patches will also remove the omap_dm_timer_init calls and change the init for the rest of the hardware timers to happen with an arch_initcall. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-16omap: Use separate init_irq functions to avoid cpu_is_omap tests earlyTony Lindgren
This allows us to remove cpu_is_omap calls from init_irq functions. There should not be any need for cpu_is_omap calls as at this point. During the timer init we only care about SoC generation, and not about subrevisions. The main reason for the patch is that we want to initialize only minimal omap specific code from the init_early call. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-02-09ARM: omap1/nokia770: mark some functions __initUwe Kleine-König
These are only called from omap_nokia770_init which is in .init.text, too. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-22Keyboard: omap-keypad: use matrix_keypad.hJanusz Krzysztofik
Most keypad drivers make use of the <linux/input/matrix_keypad.h> defined macros, structures and inline functions. Convert omap-keypad driver to use those as well, as suggested by a compile time warning, hardcoded into the OMAP <palt/keypad.h>. Created against linux-2.6.37-rc5. Tested on Amstrad Delta. Compile tested with omap1_defconfig and omap2plus_defconfig shrinked to board-h4. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Reviewed-by: Aaro Koskinen <aaro.koskinen@nokia.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-07OMAP: GPIO: Implement GPIO as a platform deviceVaradarajan, Charulatha
Implement GPIO as a platform device. GPIO APIs are used in machine_init functions. Hence it is required to complete GPIO probe before board_init. Therefore GPIO device register and driver register are implemented as postcore_initcalls. omap_gpio_init() does nothing now and this function would be removed in the next patch as it's usage is spread across most of the board files. Inorder to convert GPIO as platform device, modifications are required in clockxxxx_data.c file for OMAP1 so that device names can be used to obtain clock instead of getting clocks by name/NULL ptr. Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling or disabling the clocks, modify sysconfig settings and remove usage of clock FW APIs. Note 1: Converting GPIO driver to use runtime PM APIs is not done as a separate patch because GPIO clock names are different for various OMAPs and are different for some of the banks in the same CPU. This would need usage of cpu_is checks and bank id checks while using clock FW APIs in the gpio driver. Hence while making GPIO a platform driver framework, PM runtime APIs are used directly. Note 2: While implementing GPIO as a platform device, pm runtime APIs are used as mentioned above and modification is not done in gpio's prepare for idle/ resume after idle functions. This would be done in the next patch series and GPIO driver would be made to use dev_pm_ops instead of sysdev_class in that series only. Due to the above, the GPIO driver implicitly relies on CM_AUTOIDLE = 1 on its iclk for power management to work, since the driver never disables its iclk. This would be taken care in the next patch series (see Note 3 below). Refer to http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html for more details. Note 3: only pm_runtime_get_sync is called in gpio's probe() and pm_runtime_put* is never called. This is to make the implementation similar to the existing GPIO code. Another patch series would be sent to correct this. In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They are enabled/ disabled whenever required using clock framework APIs TODO: 1. Cleanup the GPIO driver. Use function pointers and register offest pointers instead of using hardcoded values 2. Remove all cpu_is_ checks and OMAP specific macros 3. Remove usage of gpio_bank array so that only instance specific information is used in driver code 4. Rename 'method'/ avoid it's usage 5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4 6. Modify gpio's prepare for idle/ resume after idle functions to use runtime pm implentation. Signed-off-by: Charulatha V <charu@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Reviewed-by: Basak, Partha <p-basak2@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> [tony@atomide.com: updated for bank specific revision and updated boards] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-08-04Merge branch 'devel-map-io' into omap-for-linusTony Lindgren
2010-07-16ARM: OMAP: Convert to use ->reserve method to reserve boot time memoryRussell King
2010-07-05Removing dead OMAP_DSPChristoph Egger
OMAP_DSP doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> [tony@atomide.com: updated to apply on top of already queued patches] Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: Move omap1 USB platform init code into mach-omap1/usb.cTony Lindgren
Move omap1 FS USB platform init code into mach-omap1/usb.c Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-09OMAP: OMAPFB: split omapfb.hTomi Valkeinen
Split arch/arm/plat-omap/include/mach/omapfb.h into two files: include/linux/omapfb.h - ioctls etc for userspace and some kernel stuff for board files drivers/video/omap/omapfb.h - for omapfb internal use This cleans up omapfb.h and also makes it easier for the upcoming new DSS driver to co-exist with the old driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-06-23OMAP1: remove duplicated #includeHuang Weiyi
Remove duplicated #include in arch/arm/mach-omap1/board-nokia770.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-06-23OMAP1: Fix N770 MMC supportAndrew de Quincey
Some of the N770's MMC configuration options seem to have been dropped. This patch adds them back in again. Note that only the .ocr_mask change was /critical/, but I've added the .max_freq setting back as well, as the original sources had it. Can anyone confirm if this is unnecessary? Secondly, there is support in the original code for a 4wire/higher speed mode. As I don't have the requisite N770 hardware (I think it was a rev2 N770?) to test this, I can't really add it back. Signed-off-by: Andrew de Quincey <adq@lidskialf.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-28ARM: OMAP1: Make 770 LCD workAndrew de Quincey
Make 770 LCD work by adding clk_add_alias(). Also remove the old unused functions. Note that the clk_add_alias() could probably be moved to arch/arm/clkdev.c later on. Cc: linux-fbdev-devel@lists.sourceforge.net Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Imre Deak <imre.deak@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com
2009-05-25ARM: OMAP1: Misc clean-upTony Lindgren
Remove unnecessary Kconfig line and allow compile of MBOX_FWK. Also allow building USB on Nokia 770. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-04-23ARM: OMAP1: Fix mmc_set_power GPIO usageLadislav Michl
Simple simplification... Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP: get rid of OMAP_TAG_USB, v2Felipe Balbi
OMAP_TAGS should vanish soon since they're not generic arm tags. Most of them can be converted to a platform_data or parsed from a command line like e.g. serial tag. For OMAP_TAG_USB we just let boards call omap_usb_init() passing a pointer to omap_usb_config. Patch updated by Tony for mainline, basically make n770 and h4 compile. Also folded in a fix for OSK by David Brownell <dbrownell@users.sourceforge.net>. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-01-15ARM: OMAP: Remove unused platform devices, v3Tony Lindgren
This patch removes old platform devices. Alsa should now be using the ASoC driver. For boards not yet using ASoC, please see sound/soc/omap/osk5912.c. Add dummy aic23_power_up and aic23_power_down functions for 770 to keep things compiling. Remove references to omap_gpio_switch, and unused h2_nand_dev_ready function. This patch is based on an earlier patch by Arun KS. Cc: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Arun KS <arunks@mistralsolutions.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10omap mmc: Add better MMC low-level initTony Lindgren
This will simplify the MMC low-level init, and make it more flexible to add support for a newer MMC controller in the following patches. The patch rearranges platform data and gets rid of slot vs controller confusion in the old data structures. Also fix device id numbering in the clock code. Some code snippets are based on an earlier patch by Russell King <linux@arm.linux.org.uk>. Cc: Pierre Ossman <drzeus-mmc@drzeus.cx> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP: Switch to gpio_request/free callsJarkko Nikula
Switch to gpio_request/free calls Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10ARM: OMAP: switch to standard gpio get/set callsDavid Brownell
This patch replaces some legacy OMAP GPIO calls with the "new" (not really, any more!) calls that work on most platforms. The calls addressed by this patch are the simple ones to get and set values ... for code that's in mainline, including the implementations of those calls. Except for the declarations and definitions of those calls, all of these changes were performed by a simple SED script. Plus, a few "if() set() else set()" branches were merged by hand. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] OMAP1: N770: Convert audio_pwr_sem in a mutexMatthias Kaehlcke
ARM: OMAP1: N770: The semaphore audio_pwr_sem is used as a mutex. Convert it to the mutex API [akpm@linux-foundation.org: include mutex.h] Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-08ARM: OMAP1: Misc clean-upTony Lindgren
This patch cleans up omap1 files to sync up with linux-omap tree: - Remove omap-generic MMC config as it should be defined in board-*.c files instead of using board-generic.c - New style I2C board_info from David Brownell <dbrownell@users.sourceforge.net> - Init section fixes from Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP1: Use I2C bus registration helper for omap1Jarkko Nikula
This patch starts using introduced I2C bus registration helper by cleaning up registration currently done in various places and by doing necessary board file modifications. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-01-26[ARM] remove duplicate includesLucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-18ARM: OMAP1: Fix compile for board-nokia770Daniel Walker
Fix compile for board-nokia770 Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-09-20ARM: OMAP: N770: add missing LCD, LCD controller, touchscreen device ↵Imre Deak
registration These were left out from the board file when merging these drivers, add them here. Call GPIO init from the board file as well, since the platform device init code uses the GPIO API. Signed-off-by: Imre Deak <imre.deak@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Removed hwa742 init for now as it needs some clock updates. Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-09-20ARM: OMAP: Sync board specific files with linux-omapTony Lindgren
This patch syncs omap board specific files with linux-omap tree. Patch consists mostly of driver updates done in linux-omap tree for drivers not yet in mainline kernel. Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: Add missing includes to board-nokia770Dirk Behme
Add missing includes to board-nokia770 to make it compile again. Signed-off-by: Dirk Behme <dirk.behme_at_gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-03-02ARM: OMAP: board-nokia770: correct lcd nameArnaud Patard
Some time ago, the 'lcd_lph8923' device was renamed to 'lcd_mipid' but the board-nokia770.c file was not updated accordingly, leading to not working lcd. This one-liner fixe the trouble. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-12-05WorkQueue: Fix up arch-specific work items where possibleDavid Howells
Fix up arch-specific work items where possible to use the new work_struct and delayed_work structs. Three places that enqueue bits of their stack and then return have been marked with #error as this is not permitted. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-29[PATCH] OMAP: Update OMAP1/2 boards to give keymapsize and other pdataKomal Shah
This patch adds keymapsize, delay and debounce flag in the keypad platform data for various TI OMAP1/2 based boards like F-sample, H2, H3, Innovator, Nokia770, OSK, Perseus and H4. Signed-off-by: Komal Shah <komal_shah802003@yahoo.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02[ARM] 3433/1: ARM: OMAP: 8/8 Update board filesTony Lindgren
Patch from Tony Lindgren This patch syncs OMAP board support with linux-omap tree. The highlights of the patch are: - Add support for Nokia 770 by Juha Yrjola - Add support for Samsung Apollon by Kyungmin Park - Add support for Amstrad E3 videophone by Jonathan McDowell - Remove board-netstar.c board support as requested by Ladislav Michl - Do platform_device registration in board files by Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
