We are planning to share more code between different NAND based
devices (SPI NAND, OneNAND and raw NANDs), but before doing that
we need to move the existing include/linux/mtd/nand.h file into
include/linux/mtd/rawnand.h so we can later create a nand.h header
containing all common structure and function prototypes.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Peter Pan <peterpandong@micron.com>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Han Xu <han.xu@nxp.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-By: Harvey Hunt <harveyhuntnexus@gmail.com>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Some header files are never included outside of a mach-omap1
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
This allows us to get a bit further with SPARSE_IRQ and
MULTIARCH support.
Note that we now also rename omap_irq_flags to omap_l2_irq
as that's the omap_irq_flags naming is confusing. It just
contains the interrupt number for the l2 irq.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Pull ARM SoC board updates from Olof Johansson:
"This branch contains a set of various board updates for ARM platforms.
A few shmobile platforms that are stale have been removed, some
defconfig updates for various boards selecting new features such as
pinctrl subsystem support, and various updates enabling peripherals,
etc."
Fix up conflicts mostly as per Olof.
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits)
ARM: S3C64XX: Add dummy supplies for Glenfarclas LDOs
ARM: S3C64XX: Add registration of WM2200 Bells device on Cragganmore
ARM: kirkwood: Add Plat'Home OpenBlocks A6 support
ARM: Dove: update defconfig
ARM: Kirkwood: update defconfig for new boards
arm: orion5x: add DT related options in defconfig
arm: orion5x: convert 'LaCie Ethernet Disk mini v2' to Device Tree
arm: orion5x: basic Device Tree support
arm: orion5x: mechanical defconfig update
ARM: kirkwood: Add support for the MPL CEC4
arm: kirkwood: add support for ZyXEL NSA310
ARM: Kirkwood: new board USI Topkick
ARM: kirkwood: use gpio-fan DT binding on lsxl
ARM: Kirkwood: add Netspace boards to defconfig
ARM: kirkwood: DT board setup for Network Space Mini v2
ARM: kirkwood: DT board setup for Network Space Lite v2
ARM: kirkwood: DT board setup for Network Space v2 and parents
leds: leds-ns2: add device tree binding
ARM: Kirkwood: Enable the second I2C bus
ARM: mmp: select pinctrl driver
Just use BUG_ON() instead of constructions such as:
if (...)
BUG()
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression e;
- if (e) BUG();
+ BUG_ON(e);
// </smpl>
As discussed on linux-arm-kernel, we want to avoid
relative includes for the arch/arm/*omap* code:
http://www.spinics.net/lists/linux-omap/msg80520.html
Fix includes for fpga.h by making fpga.h local
to mach-omap1. The common code in plat-omap just
needs to know the struct h2p2_dbg_fpga, which can
be local to debug-leds.c.
This also fixes the braindead <../*.h> style includes
that got accidentally added with search and replace
during the cleanup.
omap_reserve() is a stub for omap1. So dropping
omap_reserve callback from all OMAP1 board files.
We cannot keep this in plat as it causes problems
with the ARM single zImage support.
Cc: Felipe Balbi <balbi@ti.com>
Cc: linux-pcmcia@lists.infradead.org
There's no need to have this file in plat/fpga.h. We can
make it local to plat-omap replacing fpga_read/write
functions directly with readb/writeb as that's how
they are already defined in fpga.h.
Note that 2420 based H4 is also using the fpga, so let's
keep the led support around in plat-omap until we flip
over mach-omap2 to device tree.
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-fbdev@vger.kernel.org
Cc: linux-usb@vger.kernel.org
This is only used by omap1.
We are moving omap2+ to use the device tree based pinctrl-single.c
and will be removing the old mux framework. This will remove the
omap1 specific parts from plat-omap.
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: spi-devel-general@lists.sourceforge.net
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the omap include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Cc: Kevin Hilman <khilman@ti.com>
Cc: "Benoît Cousson" <b-cousson@ti.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: Jean Pihet <j-pihet@ti.com>
Cc: J Keerthy <j-keerthy@ti.com>
Cc: linux-omap@vger.kernel.org
omap1 lcd platform data resides inside plat/board.h while it
should be inside include/linux/...
Move the omap1 lcd platform data to include/linux/omapfb.h.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Pull mtd update from David Woodhouse:
- More robust parsing especially of xattr data in JFFS2
- Updates to mxc_nand and gpmi drivers to support new boards and device tree
- Improve consistency of information about ECC strength in NAND devices
- Clean up partition handling of plat_nand
- Support NAND drivers without dedicated access to OOB area
- BCH hardware ECC support for OMAP
- Other fixes and cleanups, and a few new device IDs
Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to
added include files next to each other.
* tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits)
mtd: mxc_nand: move ecc strengh setup before nand_scan_tail
mtd: block2mtd: fix recursive call of mtd_writev
mtd: gpmi-nand: define ecc.strength
mtd: of_parts: fix breakage in Kconfig
mtd: nand: fix scan_read_raw_oob
mtd: docg3 fix in-middle of blocks reads
mtd: cfi_cmdset_0002: Slight cleanup of fixup messages
mtd: add fixup for S29NS512P NOR flash.
jffs2: allow to complete xattr integrity check on first GC scan
jffs2: allow to discriminate between recoverable and non-recoverable errors
mtd: nand: omap: add support for hardware BCH ecc
ARM: OMAP3: gpmc: add BCH ecc api and modes
mtd: nand: check the return code of 'read_oob/read_oob_raw'
mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw'
mtd: m25p80: Add support for Winbond W25Q80BW
jffs2: get rid of jffs2_sync_super
jffs2: remove unnecessary GC pass on sync
jffs2: remove unnecessary GC pass on umount
jffs2: remove lock_super
mtd: gpmi: add gpmi support for mx6q
Pull sweeping late_initcall cleanup for arm-soc from Olof Johansson:
"This is a patch series from Shawn Guo that moves from individual
late_initcalls() to using a member in the machine structure to invoke
a platform's late initcalls.
This cleanup is a step in the move towards multiplatform kernels since
it would reduce the need to check for compatible platforms in each and
every initcall."
Fix up trivial conflicts in arch/arm/mach-{exynos/mach-universal_c210.c,
imx/mach-cpuimx51.c, omap2/board-generic.c} due to changes nearby (and,
in the case of cpuimx51.c the board support being deleted)
* tag 'cleanup-initcall' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: ux500: use machine specific hook for late init
ARM: tegra: use machine specific hook for late init
ARM: shmobile: use machine specific hook for late init
ARM: sa1100: use machine specific hook for late init
ARM: s3c64xx: use machine specific hook for late init
ARM: prima2: use machine specific hook for late init
ARM: pnx4008: use machine specific hook for late init
ARM: omap2: use machine specific hook for late init
ARM: omap1: use machine specific hook for late init
ARM: msm: use machine specific hook for late init
ARM: imx: use machine specific hook for late init
ARM: exynos: use machine specific hook for late init
ARM: ep93xx: use machine specific hook for late init
ARM: davinci: use machine specific hook for late init
ARM: provide a late_initcall hook for platform initialization
Use the default partition parser, cmdlinepart, provided by the plat_nand driver.
Acked-by: Alexander Clouter <alex@digriz.org.uk>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
The H2, H3, Perseus2, and FSample board files all contain the same
duplicated code to handle NAND commands. That code is missing
some casts around conversions from unsigned long to void __iomem *.
Consolidate the duplicated code into a new file,
arch/arm/mach-omap1/board-nand.c. Resolve the sparse warnings by
adding appropriate casts:
arch/arm/mach-omap1/board-h2.c:193:9: warning: incorrect type in argument 1 (different base types)
arch/arm/mach-omap1/board-h2.c:193:9: expected void const volatile [noderef] <asn:2>*<noident>
arch/arm/mach-omap1/board-h2.c:193:9: got unsigned long
arch/arm/mach-omap1/board-perseus2.c:157:9: warning: incorrect type in argument 1 (different base types)
arch/arm/mach-omap1/board-perseus2.c:157:9: expected void const volatile [noderef] <asn:2>*<noident>
arch/arm/mach-omap1/board-perseus2.c:157:9: got unsigned long
arch/arm/mach-omap1/board-fsample.c:199:9: warning: incorrect type in argument 1 (different base types)
arch/arm/mach-omap1/board-fsample.c:199:9: expected void const volatile [noderef] <asn:2>*<noident>
arch/arm/mach-omap1/board-fsample.c:199:9: got unsigned long
arch/arm/mach-omap1/board-h3.c:195:9: warning: incorrect type in argument 1 (different base types)
arch/arm/mach-omap1/board-h3.c:195:9: expected void const volatile [noderef] <asn:2>*<noident>
arch/arm/mach-omap1/board-h3.c:195:9: got unsigned long
Thanks to Arnd Bergmann <arnd@arndb.de> for suggesting a cleaner
implementation of omap1_nand_cmd_ctl(), avoiding some casts.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Brian Swetland <swetland@google.com>
Cc: Imre Deak <imre.deak@nokia.com>
Cc: Greg Lonnon <glonnon@ridgerun.com>
Cc: Kevin Hilman <kjh@hilman.org>
Pull "ARM: global cleanups" from Arnd Bergmann:
"Quite a bit of code gets removed, and some stuff moved around, mostly
the old samsung s3c24xx stuff. There should be no functional changes
in this series otherwise. Some cleanups have dependencies on other
arm-soc branches and will be sent in the second round.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up trivial conflicts mainly due to #include's being changes on
both sides.
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits)
ep93xx: Remove unnecessary includes of ep93xx-regs.h
ep93xx: Move EP93XX_SYSCON defines to SoC private header
ep93xx: Move crunch code to mach-ep93xx directory
ep93xx: Make syscon access functions private to SoC
ep93xx: Configure GPIO ports in core code
ep93xx: Move peripheral defines to local SoC header
ep93xx: Convert the watchdog driver into a platform device.
ep93xx: Use ioremap for backlight driver
ep93xx: Move GPIO defines to gpio-ep93xx.h
ep93xx: Don't use system controller defines in audio drivers
ep93xx: Move PHYS_BASE defines to local SoC header file
ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver
ARM: EXYNOS: add clock registers for exynos4x12-cpufreq
PM / devfreq: update the name of EXYNOS clock registers that were omitted
ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock
ARM: EXYNOS: use static declaration on regarding clock
ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs
ARM: OMAP2+: Fix build error after merge
ARM: S3C24XX: remove call to s3c24xx_setup_clocks
There's no need to have these in plat/io.h.
While at it, clean up the includes to group them
like they typically are grouped.
Some OMAP1 board files define LCD platform_devices, but there are no
corresponding LCD drivers for those in the kernel. Thus remove these LCD
devices.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
LCD config for old omapfb driver is passed with OMAP_TAG_LCD from board
files or from the bootloader. In an effort to remove OMAP_TAG_LCD, this
patch adds omapfb_set_lcd_config() function that the board files can
call to set the LCD config.
This has the drawback that configuration can no longer come from the
bootloader. Of the boards supported by the kernel, this should only
affect N770 which depends on the data from the bootloader. This patch
adds an LCD config for N770 to its board files, but that is most
probably broken. Fixing this would need information about the HW setup
in N770 boards.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>,
there's no need to keep local prototypes in non-local headers.
Add mach-omap1/common.h and mach-omap2/common.h and move the
local prototypes there from plat/common.h and mach/omap4-common.h.
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits)
ARM: OMAP: Warn if omap_ioremap is called before SoC detection
ARM: OMAP: Move set_globals initialization to happen in init_early
ARM: OMAP: Map SRAM later on with ioremap_exec()
ARM: OMAP: Remove calls to SRAM allocations for framebuffer
ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done
ARM: OMAP1: Use generic map_io, init_early and init_irq
arm/dts: OMAP3+: Add mpu, dsp and iva nodes
arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver
ARM: OMAP2+: l3-noc: Add support for device-tree
ARM: OMAP2+: board-generic: Add i2c static init
ARM: OMAP2+: board-generic: Add DT support to generic board
arm/dts: Add support for OMAP3 Beagle board
arm/dts: Add initial device tree support for OMAP3 SoC
arm/dts: Add support for OMAP4 SDP board
arm/dts: Add support for OMAP4 PandaBoard
arm/dts: Add initial device tree support for OMAP4 SoC
ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node
ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration
of: Add helpers to get one string in multiple strings property
ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures
Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
Theis resolves lots of simple conflicts between the omap
cleanup and the mach/memory.h removal series.
arch/arm/mach-imx/mach-cpuimx27.c
arch/arm/mach-omap1/board-ams-delta.c
arch/arm/mach-omap1/board-generic.c
arch/arm/mach-omap1/board-nokia770.c
arch/arm/mach-omap1/board-osk.c
arch/arm/mach-omap1/board-palmte.c
arch/arm/mach-omap1/board-palmtt.c
arch/arm/mach-omap1/board-palmz71.c
arch/arm/mach-omap1/board-sx1.c
arch/arm/mach-omap1/board-voiceblue.c
arch/arm/mach-omap1/io.c
arch/arm/mach-omap2/io.c
arch/arm/plat-omap/io.c
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
This allows removing omap hacks for map_io allowing generic
map_io.
Note that in the future we can't do cpu_is_omapxxxx detection
until in init_early. This means that board-innovator.c now
assumes 15xx only, and board-generic.c assumes 16xx only.
This is best fixed later on by passing the SoC type from
device tree.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
This is needed for the following patches so we can initialize the
rest of the hardware timers later on.
As with the init_irq calls, there's no need to do cpu_is_omap calls
during the timer init as we only care about the major omap generation.
This means that we can initialize the sys_timer with the .timer
entries alone.
Note that for now we just set stubs for the various sys_timer entries
that will get populated in a later patch. The following patches will
also remove the omap_dm_timer_init calls and change the init for the
rest of the hardware timers to happen with an arch_initcall.
Reviewed-by: Kevin Hilman <khilman@ti.com>
This allows us to remove cpu_is_omap calls from init_irq functions.
There should not be any need for cpu_is_omap calls as at this point.
During the timer init we only care about SoC generation, and not about
subrevisions.
The main reason for the patch is that we want to initialize only
minimal omap specific code from the init_early call.
Most keypad drivers make use of the <linux/input/matrix_keypad.h>
defined macros, structures and inline functions.
Convert omap-keypad driver to use those as well, as suggested by a
compile time warning, hardcoded into the OMAP <palt/keypad.h>.
Created against linux-2.6.37-rc5.
Tested on Amstrad Delta.
Compile tested with omap1_defconfig and omap2plus_defconfig shrinked to
board-h4.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Reviewed-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Implement GPIO as a platform device.
GPIO APIs are used in machine_init functions. Hence it is
required to complete GPIO probe before board_init. Therefore
GPIO device register and driver register are implemented as
postcore_initcalls.
omap_gpio_init() does nothing now and this function would be
removed in the next patch as it's usage is spread across most
of the board files.
Inorder to convert GPIO as platform device, modifications are
required in clockxxxx_data.c file for OMAP1 so that device names
can be used to obtain clock instead of getting clocks by
name/NULL ptr.
Use runtime pm APIs (pm_runtime_put*/pm_runtime_get*) for enabling
or disabling the clocks, modify sysconfig settings and remove usage
of clock FW APIs.
Note 1: Converting GPIO driver to use runtime PM APIs is not done as a
separate patch because GPIO clock names are different for various OMAPs
and are different for some of the banks in the same CPU. This would need
usage of cpu_is checks and bank id checks while using clock FW APIs in
the gpio driver. Hence while making GPIO a platform driver framework,
PM runtime APIs are used directly.
Note 2: While implementing GPIO as a platform device, pm runtime APIs
are used as mentioned above and modification is not done in gpio's
prepare for idle/ resume after idle functions. This would be done
in the next patch series and GPIO driver would be made to use dev_pm_ops
instead of sysdev_class in that series only.
Due to the above, the GPIO driver implicitly relies on
CM_AUTOIDLE = 1 on its iclk for power management to work, since the
driver never disables its iclk.
This would be taken care in the next patch series (see Note 3 below).
Refer to
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg39112.html
for more details.
Note 3: only pm_runtime_get_sync is called in gpio's probe() and
pm_runtime_put* is never called. This is to make the implementation
similar to the existing GPIO code. Another patch series would be sent
to correct this.
In OMAP3 and OMAP4 gpio's debounce clocks are optional clocks. They
are enabled/ disabled whenever required using clock framework APIs
TODO:
1. Cleanup the GPIO driver. Use function pointers and register
offest pointers instead of using hardcoded values
2. Remove all cpu_is_ checks and OMAP specific macros
3. Remove usage of gpio_bank array so that only
instance specific information is used in driver code
4. Rename 'method'/ avoid it's usage
5. Fix the non-wakeup gpios handling for OMAP2430, OMAP3 & OMAP4
6. Modify gpio's prepare for idle/ resume after idle functions
to use runtime pm implentation.
Signed-off-by: Charulatha V <charu@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Reviewed-by: Basak, Partha <p-basak2@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
[tony@atomide.com: updated for bank specific revision and updated boards]
Looks like some boards are calling gpio_request from init_irq.
This will make the request_irq fail, as GPIO will be initialized
as postcore_initcall.
Reported-by: Paul Walmsley <paul@pwsan.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
This way we get pin muxing out of plat-omap and can convert H4 to use the
new mux functions.
Note that it should be safe to assume we can mux all the keypad pins
except on H4 which may have Menelaus connected.
Convert OMAP based boards to use physmap-flash. Refreshed against today's
Linux omap kernel tree
Cc: linux-mtd@lists.infradead.org
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Since omapnand driver never find its way into mainline, switch to gen_nand instead.
Following patch is compile tested only, but it is based on code I wrote for
NetStar board and runtime tested it there.
Use smc91x_platdata to setup smc91x, so we can get rid of OMAP specific stuff
in smc91x driver
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
This patch is part of a series which removes references to omap730 in code
which is shared with omap850, replacing them with references to omap7xx.
Turns INT_730_* to INT_7XX_* for definitions in irqs.h and all users.
Signed-off-by: Alistair Buxton <a.j.buxton@gmail.com>
Reviewed-by: Zebediah C. McClure <zmc@lurian.net>
OMAP tags are deprecrated so drop them.
Drop UART config data which decides which UARTs to enable during boot.
This is no longer necessary since serial core code disables clocks
after inactivity.
Background: with new UART idle code, all on-chip UARTs are idled using
a configurable inactivity timer (default 5 seconds.) After the
inactivity timer, UART clocks are disabled automatically.
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Switch to gpio_request/free calls
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
This patch replaces some legacy OMAP GPIO calls with the "new" (not
really, any more!) calls that work on most platforms.
The calls addressed by this patch are the simple ones to get and set
values ... for code that's in mainline, including the implementations
of those calls.
Except for the declarations and definitions of those calls, all of
these changes were performed by a simple SED script. Plus, a few
"if() set() else set()" branches were merged by hand.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This just leaves include/asm-arm/plat-* to deal with.
