path: root/arch/arm/mach-omap1/board-sx1-mmc.c
2012-10-15ARM: OMAP: Split plat/mmc.h into local headers and platform_dataTony Lindgren
We need to remove this from plat for ARM common zImage support. Also remove includes not needed by the omap_hsmmc.c driver. Cc: linux-mmc@vger.kernel.org Acked-by: Chris Ball <cjb@laptop.org> Acked-by: Venkatraman S <svenkatr@ti.com> [tony@atomide.com: fold in removal of unused driver includes] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-20ARM: OMAP1: Move board-sx1.h from plat to machTony Lindgren
This is only used by omap1. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-08ARM: gpio: convert includes of mach/gpio.h and asm/gpio.h to linux/gpio.hRussell King
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h before we start consolidating the individual platform implementations of the gpio header files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-12omap: Fix spotty MMC voltagesTony Lindgren
As noted by Michał Mirosław <mirqus@gmail.com>, the voltages should cover the supported voltage range, or support only one voltage. As all these boards are using a GPIO to enable the power, chances are that only 3.3V cards are supported on these boards. Reported-by: Michał Mirosław <mirqus@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-03-23ARM: OMAP: No need to include board-palm*.h from hardware.hTony Lindgren
Move the defines to the associated board file and remove the now unnecessary header files. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10omap mmc: Add better MMC low-level initTony Lindgren
This will simplify the MMC low-level init, and make it more flexible to add support for a newer MMC controller in the following patches. The patch rearranges platform data and gets rid of slot vs controller confusion in the old data structures. Also fix device id numbering in the clock code. Some code snippets are based on an earlier patch by Russell King <linux@arm.linux.org.uk>. Cc: Pierre Ossman <drzeus-mmc@drzeus.cx> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-12-10omap mmc: Remove broken MMC init codeTony Lindgren
Most of the omap1 MMC boards got broken by an earlier patch 138ab9f8321f67c71984ca43222efa71b0a0a0a9. If you look closely, the MMC init funtions are pretty much just stubs. Remove broken init code to make room for cleaner MMC init code. Cc: Pierre Ossman <drzeus-mmc@drzeus.cx> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-08ARM: OMAP1: Use MMC multislot structures for Siemens SX1 boardCarlos Eduardo Aguiar
Use MMC multislot structures for Siemens SX1 board Signed-off-by: Carlos Eduardo Aguiar <carlos.aguiar@indt.org.br> Signed-off-by: Tony Lindgren <tony@atomide.com>
