path: root/arch/arm/mach-omap1/devices.c
2007-05-08ARM: OMAP: Sync core code with linux-omapTony Lindgren
This patch syncs omap specific core code with linux-omap. Most of the changes are needed to fix bitrot caused by driver updates in linux-omap tree. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[PATCH] add rtc-omap driverDavid Brownell
This creates a new RTC-framework driver for the RTC/calendar module found in various OMAP1 chips. (OMAP2 and OMAP3 use external RTCs, like those in TI's multifunction PM companion chips.) It's been in the Linux-OMAP tree for several months now, and other trees before that, so it's quite stable. The most notable issue is that the OMAP IRQ code doesn't yet support the RTC IRQ as a wakeup event. Once that's fixed, a patch will be needed. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-09[ARM] 3460/1: ARM: OMAP: Remove unnecessary nop_release()Tony Lindgren
Patch from Tony Lindgren Remove unnecessary omap_nop_release() as noted by RMK. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3433/1: ARM: OMAP: 8/8 Update board filesTony Lindgren
Patch from Tony Lindgren This patch syncs OMAP board support with linux-omap tree. The highlights of the patch are: - Add support for Nokia 770 by Juha Yrjola - Add support for Samsung Apollon by Kyungmin Park - Add support for Amstrad E3 videophone by Jonathan McDowell - Remove board-netstar.c board support as requested by Ladislav Michl - Do platform_device registration in board files by Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3141/1: OMAP 1/5: Update omap1 specific filesTony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Omap1 serial pport and framebuffer init updates by Imre Deak - Add support for omap310 processor and Palm Tungsten E PDA by Laurent Gonzales, Romain Goyet, et al. Omap310 and omap1510 processors are now handled as omap15xx. - Omap1 specific changes to shared omap clock framework by Tony Lindgren - Omap1 specific changes to shared omap pin mux framework by Tony Lindgren - Other misc fixes, such as update memory timings for smc91x, omap1 specific device initialization etc. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[ARM] 2890/1: OMAP 1/4: Update omap1 specific files, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Convert more drivers to register resources in board-*.c to take advantage of the driver model by David Brownell and Ladislav Michl - Use set_irq_type() for GPIO interrupts instead of omap_set_gpio_edge_ctrl() by David Brownell - Add minimal support for handling optional add-on boards, such as OSK Mistral board with LCD and keypad, by David Brownell - Minimal support for loading functions to SRAM by Tony Lindgren - Wake up from serial port by muxing RX lines temporarily into GPIO interrupts by Tony Lindgren - 32KHz sched_clock by Tony Lindgren and Juha Yrjola Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
