path: root/arch/arm/mach-omap1/sleep.S
2011-02-04ARM: 6649/1: omap: use fncpy to copy the PM code functions to SRAMJean Pihet
The new fncpy API is better suited* for copying some code to SRAM at runtime. This patch changes the ad-hoc code to the more generic fncpy API. *: 1. fncpy ensures that the thumb mode bit is propagated, 2. fncpy provides the security of type safety between the original function and the sram function pointer. Tested OK on OMAP3 in low power modes (RET/OFF) using omap2plus_defconfig with !CONFIG_THUMB2_KERNEL. Compile tested on OMAP1/2 using omap1_defconfig. Boot tested on OMAP1 & OMAP2 Tested OK with suspend/resume on OMAP2420/n810 Boots fine on osk5912 and n800 Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Kevin Hilman <khilman@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Dave Martin <dave.martin@linaro.org> Tested-by: Kevin Hilman <khilman@ti.com> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-07OMAP7XX: Rename all the rest of the omap730 references in omap1 coreAlistair Buxton
This patch is part of a series which removes references to omap730 in code which is shared with omap850, replacing them with references to omap7xx. This updates all the remaining omap730 references in miscellaneous local variables, macros and similar. Signed-off-by: Alistair Buxton <a.j.buxton@gmail.com> Reviewed-by: Zebediah C. McClure <zmc@lurian.net>
2009-05-28OMAP1: PM: update and decouple from OMAP2/3 PM coreKevin Hilman
Update OMAP1-specific PM infrastructure. This is a sync of what is in linux-omap for OMAP1. This mostly de-couples OMAP1 PM from OMAP2/3 PM and renames things accordingly, and removes omap2/3 specific code from OMAP1 specific headers. Original OMAP1 decoupling patch for OMAP PM branch by Paul Walmsley. Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-08ARM: OMAP1: Remove omap_sram_idle()Vivek Kutal
This patch removes omap_sram_idle() that is no longer used. The function called in pm_idle is omap_sram_suspend, omap_sram_idle() is not used anywhere in omap1. Signed-off-by: Vivek Kutal <vivek.kutal@celunite.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-04-02[ARM] 3430/1: ARM: OMAP: 5/8 Update PMTony Lindgren
Patch from Tony Lindgren Update OMAP PM code from linux-omap tree: - Move PM code from plat-omap to mach-omap1 and mach-omap2 by Tony Lindgren - Add minimal PM support for omap24xx by Tony Lindgren and Richard Woodruff - Misc updates to omap1 PM code by Tuukka Tikkanen et al - Updates to the SRAM code needed for PM and FB by Imre Deak Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
