[ Upstream commit 8cbbf1745dcde7ba7e423dc70619d223de90fd43 ]
When exposing data access through debugfs, the correct
debugfs_create_*() functions must be used, depending on data type.
Remove all casts from data pointers passed to debugfs_create_*()
functions, as such casts prevent the compiler from flagging bugs.
Correct all wrong usage:
- clk.rate is unsigned long, not u32,
- clk.flags is u8, not u32, which exposed the successive
clk.rate_offset and clk.src_offset fields.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[ Upstream commit 657279778af54f35e54b07b6687918f254a2992c ]
OMAP1510, OMAP5910 and OMAP310 have only 9 logical channels.
OMAP1610, OMAP5912, OMAP1710, OMAP730, and OMAP850 have 16 logical channels
available.
The wired 17 for the lch_count must have been used to cover the 16 + 1
dedicated LCD channel, in reality we can only use 9 or 16 channels.
The d->chan_count is not used by the omap-dma stack, so we can skip the
setup. chan_count was configured to the number of logical channels and not
the actual number of physical channels anyways.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either
built-in or as a module, use that macro instead of open coding the same.
Using the macro makes the code more readable by helping abstract away some
of the Kconfig built-in and module enable details.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Pull ARM SoC platform updates from Olof Johansson:
"Improved and new platform support for various SoCs:
New SoC support:
- Broadcom BCM23550
- Freescale i.MX7Solo
- Qualcomm MDM9615
- Renesas r8a7792
Improvements:
- convert clps711x to multiplatform
- debug uart improvements for Atmel platforms
- Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram
- OMAP tweaks and improvements to hwmod
- OMAP support for kexec on SMP"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: davinci: fix build break because of undeclared dm365_evm_snd_data
ARM: s3c64xx: smartq: Avoid sparse warnings
ARM: sti: Implement dummy L2 cache's write_sec
ARM: STi: Update machine _namestr to be more generic.
arm: meson: explicitly select clk drivers
ARM: tango: add Suspend-to-RAM support
ARM: hisi: consolidate the hisilicon machine entries
ARM: tango: fix CONFIG_HOTPLUG_CPU=n build
MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry
MAINTAINERS: Update BCM63XX entry
MAINTAINERS: Add NS2 entry
MAINTAINERS: Fix nsp false-positives
MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries
ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs
ARM: clps711x: Switch to MULTIPLATFORM
ARM: clps711x: Remove boards support
ARM: clps711x: Add basic DT support
ARM: clps711x: Reduce static map size
ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu
ARM: oxnas: Change OX810SE default driver config
- dts: rename 'ide-disk' to 'disk-activity'
- platform: rename 'ide-disk' to 'disk-activity'
- defconfig: rename 'LEDS_TRIGGER_IDE_DISK' to 'LEDS_TRIGGER_DISK'
Signed-off-by: Stephan Linz <linz@li-pro.net>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
After OMAP1 IRQ definitions have been changed by commit 685e2d08c54b
("ARM: OMAP1: Change interrupt numbering for sparse IRQ") introduced
in v4.2, ams-delta FIQ handler which depends on them no longer works
as expected. Fix it.
Created and tested on Amstrad Delta against Linux-4.7-rc3
Signed-off-by: Janusz Krzysztofik <jmkrzyszt@gmail.com>
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Pull ARM SoC platform updates from Arnd Bergmann:
"Newly added support for additional SoCs:
- Axis Artpec-6 SoC family
- Allwinner A83T SoC
- Mediatek MT7623
- NXP i.MX6QP SoC
- ST Microelectronics stm32f469 microcontroller
New features:
- SMP support for Mediatek mt2701
- Big-endian support for NXP i.MX
- DaVinci now uses the new DMA engine dma_slave_map
- OMAP now uses the new DMA engine dma_slave_map
- earlyprintk support for palmchip uart on mach-tango
- delay timer support for orion
Other:
- Exynos PMU driver moved out to drivers/soc/
- Various smaller updates for Renesas, Xilinx, PXA, AT91, OMAP,
uniphier"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: uniphier: rework SMP code to support new System Bus binding
ARM: uniphier: add missing of_node_put()
ARM: at91: avoid defining CONFIG_* symbols in source code
ARM: DRA7: hwmod: Add data for eDMA tpcc, tptc0, tptc1
ARM: imx: Make reset_control_ops const
ARM: imx: Do L2 errata only if the L2 cache isn't enabled
ARM: imx: select ARM_CPU_SUSPEND only for imx6
dmaengine: pxa_dma: fix the maximum requestor line
ARM: alpine: select the Alpine MSI controller driver
ARM: pxa: add the number of DMA requestor lines
dmaengine: mmp-pdma: add number of requestors
dma: mmp_pdma: Add the #dma-requests DT property documentation
ARM: OMAP2+: Add rtc hwmod configuration for ti81xx
ARM: s3c24xx: Avoid warning for inb/outb
ARM: zynq: Move early printk virtual address to vmalloc area
ARM: DRA7: hwmod: Add custom reset handler for PCIeSS
ARM: SAMSUNG: Remove unused register offset definition
ARM: EXYNOS: Cleanup header files inclusion
drivers: soc: samsung: Enable COMPILE_TEST
MAINTAINERS: Add maintainers entry for drivers/soc/samsung
OMAP1 can not boot in DT mode and to be able to clean up the driver
regarding to the dmaengine API use (switching to the new API) the
device/slave -> filter mapping needs to be provided to the omap-dma driver.
When CONFIG_DEBUG_ICEDCC is set, we don't use the platform
specific putc() function, but use icedcc_putc() instead, so
putc is unused and causes a compile time warning:
In file included from ../arch/arm/boot/compressed/misc.c:28:0:
arch/arm/mach-rpc/include/mach/uncompress.h:79:13: warning: 'putc' defined but not used [-Wunused-function]
arch/arm/mach-w90x900/include/mach/uncompress.h:30:13: warning: 'putc' defined but not used [-Wunused-function]
On most platforms, this does not happen, because putc is defined
as 'static inline' so the compiler will automatically drop it
when it's unused.
This changes the remaining seven platforms to behave the same way.
"Updates for new platform support:
- New platform: Tango4 from Sigma Designs.
- Broadcom BCM2836 (Raspberry Pi 2 SoC)
- Enable cpufreq on Freescale i.MX7D
- Rockchip: SMP support for rk3036, general support for rk3228
- SMP support on Broadcom Kona and NSP
- Cleanups for OMAP removing legacy IOMMU data
+ a bunch of misc fixes and tweaks for various platforms"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (46 commits)
ARM: tango: Fix UP build issues
ARM: tango: pass ARM arch level for smc.S
ARM: bcm2835: Add Kconfig support for bcm2836
ARM: OMAP2+: Add support for dm814x and dra62x usb
ARM: OMAP2+: Add mmc hwmod entries for dm814x
ARM: OMAP2+: Update 81xx clock and power domains for default, active and sgx
ARM: OMAP2+: Fix SoC detection for dra62x j5-eco
ARM: tango4: Initial platform support
ARM: bcm2835: Add a compat string for bcm2836 machine probe
dt-bindings: Add root properties for Raspberry Pi 2
ARM: imx: select SRC for i.MX7
ARM: uniphier: select PINCTRL
ARM: OMAP2+: Remove device creation for omap-pcm-audio
ARM: OMAP1: Remove device creation for omap-pcm-audio
ARM: rockchip: enable support for RK3228 SoCs
ARM: rockchip: use const and __initconst for rk3036 smp_operations
ARM: zynq: Select ARCH_HAS_RESET_CONTROLLER
ARM: BCM: Add SMP support for Broadcom 4708
ARM: BCM: Add SMP support for Broadcom NSP
ARM: BCM: Clean up SMP support for Broadcom Kona
Pull ARM SoC multiplatform code updates from Arnd Bergmann:
"This branch is the culmination of 5 years of effort to bring the ARMv6
and ARMv7 platforms together such that they can all be enabled and
boot the same kernel. It has been a tremendous amount of cleanup and
refactoring by a huge number of people, and creation of several new
(and major) subsystems to better abstract out all the platform details
in an appropriate manner.
The bulk of this branch is a large patchset from Arnd that brings
several of the more minor and older platforms we have closer to
multiplatform support. Among these are MMP, S3C64xx, Orion5x, mv78xx0
and realview Much of this is moving around header files from old mach
directories, but there are also some cleanup patches of debug_ll
(lowlevel debug per-platform options) and other parts.
Linus Walleij also has some patchs to clean up the older ARM Realview
platforms by finally introducing DT support, and Rob Herring has some
for ARM Versatile which is now DT-only. Both of these platforms are
now multiplatform.
Finally, a couple of patches from Russell for Dove PMU, and a fix from
Valentin Rothberg for Exynos ADC, which were rebased on top of the
series to avoid conflicts"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: realview: don't select SMP_ON_UP for UP builds
ARM: s3c: simplify s3c_irqwake_{e,}intallow definition
ARM: s3c64xx: fix pm-debug compilation
iio: exynos-adc: fix irqf_oneshot.cocci warnings
ARM: realview: build realview-dt SMP support only when used
ARM: realview: select apropriate targets
ARM: realview: clean up header files
ARM: realview: make all header files local
ARM: no longer make CPU targets visible separately
ARM: integrator: use explicit core module options
ARM: realview: enable multiplatform
ARM: make default platform work for NOMMU
ARM: debug-ll: move DEBUG_LL_UART_EFM32 to correct Kconfig location
ARM: defconfig: use correct debug_ll settings
ARM: versatile: convert to multi-platform
ARM: versatile: merge mach code into a single file
ARM: versatile: switch to DT only booting and remove legacy code
ARM: versatile: add DT based PCI detection
ARM: pxa: mark ezx structures as __maybe_unused
ARM: pxa: mark raumfeld init functions as __maybe_unused
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"Here is the bulk of GPIO changes for v4.5.
Notably there are big refactorings mostly by myself, aimed at getting
the gpio_chip into a shape that makes me believe I can proceed to
preserve state for a proper userspace ABI (character device) that has
already been proposed once, but resulted in the feedback that I need
to go back and restructure stuff. So I've been restructuring stuff.
On the way I ran into brokenness (return code from the get_value()
callback) and had to fix it. Also, refactored generic GPIO to be
simpler.
Some of that is still waiting to trickle down from the subsystems all
over the kernel that provide random gpio_chips, I've touched every
single GPIO driver in the kernel now, oh man I didn't know I was
responsible for so much...
Apart from that we're churning along as usual.
I took some effort to test and retest so it should merge nicely and we
shook out a couple of bugs in -next.
Infrastructural changes:
- In struct gpio_chip, rename the .dev node to .parent to better
reflect the fact that this is not the GPIO struct device
abstraction. We will add that soon so this would be totallt
confusing.
- It was noted that the driver .get_value() callbacks was sometimes
reporting negative -ERR values to the gpiolib core, expecting them
to be propagated to consumer gpiod_get_value() and gpio_get_value()
calls. This was not happening, so as there was a mess of drivers
returning negative errors and some returning "anything else than
zero" to indicate that a line was active. As some would have bit
31 set to indicate "line active" it clashed with negative error
codes. This is fixed by the largeish series clamping values in all
drivers with !!value to [0,1] and then augmenting the code to
propagate error codes to consumers. (Includes some ACKed patches
in other subsystems.)
- Add a void *data pointer to struct gpio_chip. The container_of()
design pattern is indeed very nice, but we want to reform the
struct gpio_chip to be a non-volative, stateless business, and keep
states internal to the gpiolib to be able to hold on to the state
when adding a proper userspace ABI (character device) further down
the road. To achieve this, drivers need a handle at the internal
state that is not dependent on their struct gpio_chip() so we add
gpiochip_add_data() and gpiochip_get_data() following the pattern
of many other subsystems. All the "use gpiochip data pointer"
patches transforms drivers to this scheme.
- The Generic GPIO chip header has been merged into the general
<linux/gpio/driver.h> header, and the custom header for that
removed. Instead of having a separate mm_gpio_chip struct for
these generic drivers, merge that into struct gpio_chip,
simplifying the code and removing the need for separate and
confusing includes.
Misc improvements:
- Stabilize the way GPIOs are looked up from the ACPI legacy
specification.
- Incremental driver features for PXA, PCA953X, Lantiq (patches from
the OpenWRT community), RCAR, Zynq, PL061, 104-idi-48
New drivers:
- Add a GPIO chip to the ALSA SoC AC97 driver.
- Add a new Broadcom NSP SoC driver (this lands in the pinctrl dir,
but the branch is merged here too to account for infrastructural
changes).
- The sx150x driver now supports the sx1502"
* tag 'gpio-v4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (220 commits)
gpio: generic: make bgpio_pdata always visible
gpiolib: fix chip order in gpio list
gpio: mpc8xxx: Do not use gpiochip_get_data() in mpc8xxx_gpio_save_regs()
gpio: mm-lantiq: Do not use gpiochip_get_data() in ltq_mm_save_regs()
gpio: brcmstb: Allow building driver for BMIPS_GENERIC
gpio: brcmstb: Set endian flags for big-endian MIPS
gpio: moxart: fix build regression
gpio: xilinx: Do not use gpiochip_get_data() in xgpio_save_regs()
leds: pca9532: use gpiochip data pointer
leds: tca6507: use gpiochip data pointer
hid: cp2112: use gpiochip data pointer
bcma: gpio: use gpiochip data pointer
avr32: gpio: use gpiochip data pointer
video: fbdev: via: use gpiochip data pointer
gpio: pch: Optimize pch_gpio_get()
Revert "pinctrl: lantiq: Implement gpio_chip.to_irq"
pinctrl: nsp-gpio: use gpiochip data pointer
pinctrl: vt8500-wmt: use gpiochip data pointer
pinctrl: exynos5440: use gpiochip data pointer
pinctrl: at91-pio4: use gpiochip data pointer
Pull MTD updates from Brian Norris:
"Generic MTD:
- populate the MTD device 'of_node' field (and get a proper 'of_node'
symlink in sysfs)
This yielded some new helper functions, and changes across a
variety of drivers
- partitioning cleanups, to prepare for better device-tree based
partitioning in the future
Eliminate a lot of boilerplate for drivers that want to use
OF-based partition parsing
The DT bindings for this didn't settle yet, so most non-cleanup
portions are deferred for a future release
NAND:
- embed a struct mtd_info inside struct nand_chip
This is really long overdue; too many drivers have to do the same
silly boilerplate to allocate and link up two "independent"
structs, when in fact, everyone is assuming there is an exact 1:1
relationship between a NAND chips struct and its underlying MTD.
This aids improved helpers and should make certain abstractions
easier in the future.
Also causes a lot of churn, helped along by some automated code
transformations
- add more core support for detecting (and "correcting") bitflips in
erased pages; requires opt-in by drivers, but at least we kill a
few bad implementations and hopefully stave off future ones
- pxa3xx_nand: cleanups, a few fixes, and PM improvements
- new JZ4780 NAND driver
SPI NOR:
- provide default erase function, for controllers that just want to
send the SECTOR_ERASE command directly
- fix some module auto-loading issues with device tree
("jedec,spi-nor")
- error handling fixes
- new Mediatek QSPI flash driver
Other:
- cfi: force valid geometry Kconfig (finally!)
This one used to trip up randconfigs occasionally, since bots
aren't deterred by big scary "advanced configuration" menus
More? Probably. See the commit logs"
* tag 'for-linus-20160112' of git://git.infradead.org/linux-mtd: (168 commits)
mtd: jz4780_nand: replace if/else blocks with switch/case
mtd: nand: jz4780: Update ecc correction error codes
mtd: nandsim: use nand_get_controller_data()
mtd: jz4780_nand: remove useless mtd->priv = chip assignment
staging: mt29f_spinand: make use of nand_set/get_controller_data() helpers
mtd: nand: make use of nand_set/get_controller_data() helpers
ARM: make use of nand_set/get_controller_data() helpers
mtd: nand: add helpers to access ->priv
mtd: nand: jz4780: driver for NAND devices on JZ4780 SoCs
mtd: nand: jz4740: remove custom 'erased check' implementation
mtd: nand: diskonchip: remove custom 'erased check' implementation
mtd: nand: davinci: remove custom 'erased check' implementation
mtd: nand: use nand_check_erased_ecc_chunk in default ECC read functions
mtd: nand: return consistent error codes in ecc.correct() implementations
doc: dt: mtd: new binding for jz4780-{nand,bch}
mtd: cfi_cmdset_0001: fixing memory leak and handling failed kmalloc
mtd: spi-nor: wait until lock/unlock operations are ready
mtd: tests: consolidate kmalloc/memset 0 call to kzalloc
jffs2: use to_delayed_work
mtd: nand: assign reasonable default name for NAND drivers
The separate struct bgpio_chip has been a pain to handle, both
by being confusingly similar in name to struct gpio_chip and
for being contained inside a struct so that struct gpio_chip
is contained in a struct contained in a struct, making several
steps of dereferencing necessary.
Make things simpler: include the fields directly into
<linux/gpio/driver.h>, #ifdef:ed for CONFIG_GENERIC_GPIO, and
get rid of the <linux/basic_mmio_gpio.h> altogether. Prefix
some of the member variables with bgpio_* and add proper
kerneldoc while we're at it.
Modify all users to handle the change and use a struct
gpio_chip directly. And while we're at it: replace all
container_of() dereferencing by gpiochip_get_data() and
registering the gpio_chip with gpiochip_add_data().
Cc: arm@kernel.org
Cc: Alexander Shiyan <shc_work@mail.ru>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Olof Johansson <olof@lixom.net>
Cc: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Cc: Rabin Vincent <rabin@rab.in>
Cc: linux-omap@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Cc: bcm-kernel-feedback-list@broadcom.com
Acked-by: Gregory Fong <gregory.0xf0@gmail.com>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
The omap-pcm in ASoC is no longer a platform device. No need to create this
device anymore.
mtd_to_nand() was recently introduced to avoid direct accesses to the
mtd->priv field. Update all ARM specific implementations to use this
helper.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Some header files are never included outside of a mach-omap1
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Let's not mix platform_data headers with the core headers. Instead, let's
create a subdir at linux/platform_data and move the headers to that
common place, adding it to MAINTAINERS.
The headers were moved with:
mkdir include/linux/platform_data/media/; git mv include/media/gpio-ir-recv.h include/media/ir-rx51.h include/media/mmp-camera.h include/media/omap1_camera.h include/media/omap4iss.h include/media/s5p_hdmi.h include/media/si4713.h include/media/sii9234.h include/media/smiapp.h include/media/soc_camera.h include/media/soc_camera_platform.h include/media/timb_radio.h include/media/timb_video.h include/linux/platform_data/media/
And the references fixed with this script:
MAIN_DIR="linux/platform_data/"
PREV_DIR="media/"
DIRS="media/"
echo "Checking affected files" >&2
for i in $DIRS; do
for j in $(find include/$MAIN_DIR/$i -type f -name '*.h'); do
n=`basename $j`
git grep -l $n
done
done|sort|uniq >files && (
echo "Handling files..." >&2;
echo "for i in \$(cat files|grep -v Documentation); do cat \$i | \\";
cd include/$MAIN_DIR;
for j in $DIRS; do
for i in $(ls $j); do
echo "perl -ne 's,(include [\\\"\\<])$PREV_DIR($i)([\\\"\\>]),\1$MAIN_DIR$j\2\3,; print \$_' |\\";
done;
done;
echo "cat > a && mv a \$i; done";
echo "Handling documentation..." >&2;
echo "for i in MAINTAINERS \$(cat files); do cat \$i | \\";
for j in $DIRS; do
echo " perl -ne 's,include/$PREV_DIR($i)\b,include/$MAIN_DIR$j\1,; print \$_' |\\";
done;
done;
) >script && . ./script
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Remove board support files for 10 years discontinued VoiceBlue board.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Simtec Linux Team <linux@simtec.co.uk>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Migrate omap timer32 driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Migrate omap driver to the new 'set-state' interface provided by
now.
Pull ARM SoC platform support updates from Kevin Hilman:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. Some highlights from this round:
- sunxi: SMP support for A23 SoC
- socpga: big-endian support
- pxa: conversion to common clock framework
- bcm: SMP support for BCM63138
- imx: support new I.MX7D SoC
- zte: basic support for ZX296702 SoC"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (134 commits)
ARM: zx: Add basic defconfig support for ZX296702
ARM: dts: zx: add an initial zx296702 dts and doc
clk: zx: add clock support to zx296702
dt-bindings: Add #defines for ZTE ZX296702 clocks
ARM: socfpga: fix build error due to secondary_startup
MAINTAINERS: ARM64: EXYNOS: Extend entry for ARM64 DTS
ARM: ep93xx: simone: support for SPI-based MMC/SD cards
MAINTAINERS: update Shawn's email to use kernel.org one
ARM: socfpga: support suspend to ram
ARM: socfpga: add CPU_METHOD_OF_DECLARE for Arria 10
ARM: socfpga: use CPU_METHOD_OF_DECLARE for socfpga_cyclone5
ARM: EXYNOS: register power domain driver from core_initcall
ARM: EXYNOS: use PS_HOLD based poweroff for all supported SoCs
ARM: SAMSUNG: Constify platform_device_id
ARM: EXYNOS: Constify irq_domain_ops
ARM: EXYNOS: add coupled cpuidle support for Exynos3250
ARM: EXYNOS: add exynos_get_boot_addr() helper
ARM: EXYNOS: add exynos_set_boot_addr() helper
ARM: EXYNOS: make exynos_core_restart() less verbose
ARM: EXYNOS: fix exynos_boot_secondary() return value on timeout
Pull clkdev updates from Russell King:
"This series addresses some breakage in clkdev caused by a previous
patch set from the clk tree which introduced per-user clk structures.
This basically renamed the existing 'struct clk' to 'struct clk_hw',
and introduced a new 'struct clk'.
This change will break anyone using clk_add_alias() with the common
clk code enabled. Thankfully, the intersection of users of
clk_add_alias() and those using the common clk code is practically
zero, but this is something which should be fixed to keep the code
sane.
The problem is that clk_add_alias() does this:
r = clk_get(...);
l = clkdev_alloc(r, ...);
clk_put(...);
which causes the alias to store a pointer to 'r', which has been
freed.
The original patch set tried to work around this problem incorrectly -
at clk_get() time, it tried to convert the struct clk to a struct
clk_hw, and then creating a new struct clk from that. Clearly, if the
original struct clk has been freed, then we have a use-after-free bug.
We have other places in the tree which do something similar, so this
series also addresses those locations too.
This series addresses this problem by converting clkdev to store and
use the clk_hw pointer. This allows clk_get() to only have to create
it's per-user struct clk from the clk_hw. We can also get to the
desired clk_hw at clk_add_alias() or clk lookup creation time, when
the struct clk is "alive".
We also perform some cleanups of the code:
- replacing looped calls to clkdev_add() with clkdev_add_table()
- replacing open-coded lookup allocation (which should have been
using clkdev_alloc()) and subsequent clkdev_add() with
clkdev_create()
- replacing open-coded clk_add_alias() with clk_add_alias()"
* 'for-linus-clk' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
clk: s2mps11: use clkdev_create()
ASoC: migor: use clkdev_create()
ARM: omap2: use clkdev_add_alias()
ARM: omap2: use clkdev_create()
ARM: orion: use clkdev_create()
ARM: lpc32xx: convert to use clkdev_add_table()
SH: use clkdev_add_table()
clkdev: add clkdev_create() helper
clkdev: const-ify connection id to clk_add_alias()
clkdev: get rid of redundant clk_add_alias() prototype in linux/clk.h
clkdev: drop __init from clkdev_add_table()
clk: update clk API documentation to clarify clk_round_rate()
clkdev: use clk_hw internally
This is cleary used after init time too for example for
configuring UART wake-up events during runtime. This fixes
section mismatch warnings for randconfig builds that happen
because __init_or_module.
With the omap1 SPARSE_IRQ changes mach/irqs.h is no longer
automatically included. Turns out now we rely on ARCH_OMAP15XX
including hardware.h from memory.h, so without ARCH_OMAP15XX
we get build failures.
As we have legacy drivers still relying on these indirect
includes, let's not add more mach includes to the drivers.
Those have to be removed anyways for multiplatform support.
Let's fix up mach-omap1 to include soc.h where cpu_is_omap
checks are done, and common.h for board-*.c files.
But let's keep the indirect memory.h include for now to avoid
unnecessary churn in the drivers.
Change interrupt numbering for sparse IRQ. We do this using
a fixed offset until we can drop irqs.h once all it's users
have been updated.
Note that this depends on the GPIO fix for the MPUIO IRQs
"gpio: omap: Fix regression for MPUIO interrupts".
Also note that this patch adds some extra irq alloc warnings
that will go away when we stop calling irq_alloc_descs
in gpio-omap.c with a follow-up patch.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
This allows us to get a bit further with SPARSE_IRQ and
MULTIARCH support.
Note that we now also rename omap_irq_flags to omap_l2_irq
as that's the omap_irq_flags naming is confusing. It just
contains the interrupt number for the l2 irq.
Let's set up things ready for enabling sparse IRQ and remove the
omap_read/write usage.
These have been indirectly included via asm/irqs.h that
has included mach/hardware.h unless SPARSE_IRQ is specified.
Let's move them to where the other OMAP serial defines for
8250 are.
USE_PM_CLK_RUNTIME_OPS is introduced so we don't repeat the same code
to do runtime_suspend and runtime_resume across users of PM clocks.
Use it to remove the boilerplate code.
Signed-off-by: Rajendra Nayak <rnayak@codeaurora.org>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
clk_add_alias() is provided by clkdev, and is not part of the clk API.
Howver, it is prototyped in two locations: linux/clkdev.h and
linux/clk.h. This is a mess. Get rid of the redundant and unnecessary
version in linux/clk.h.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Building an OMAP1510-only Kconfig generates the following warnings:
arch/arm/mach-omap1/pm.c: In function ¡omap1_pm_idle¢:
arch/arm/mach-omap1/pm.c:123:2: warning: #warning Enable 32kHz OS timer in order to allow sleep states in idle [-Wcpp]
arch/arm/mach-omap1/pm.c: At top level:
arch/arm/mach-omap1/pm.c:76:23: warning: ¡enable_dyn_sleep¢ defined but not used [-Wunused-variable]
static unsigned short enable_dyn_sleep = 0;
These are not so easy to fix in an obviously correct fashion, since I
don't have these devices up and running in my testbed. So, use
arch/arm/plat-omap/Kconfig and the existing pm.c source as a guide,
and posit that deep power saving states are only supported on OMAP16xx
chips with kernels built with both CONFIG_OMAP_DM_TIMER=y and
CONFIG_OMAP_32K_TIMER=y.
While here, clean up a few printk()s and unnecessary #ifdefs.
This second version of the patch incorporates several suggestions from
Jon Hunter <jgchunter@gmail.com>.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Jon Hunter <jonathanh@nvidia.com>
Cc: Tuukka Tikkanen <tuukka.tikkanen@linaro.org>
Acked-by: Jon Hunter <jgchunter@gmail.com>
Pull ARM SoC cleanups from Olof Johansson:
"This is a good healthy set of various code removals. Total net delta
is 8100 lines removed.
Among the larger cleanups are:
- Removal of old Samsung S3C DMA infrastructure by Arnd
- Removal of the non-DT version of the 'lager' board by Magnus Damm
- General stale code removal on OMAP and Davinci by Rickard Strandqvist
- Removal of non-DT support on am3517 platforms by Tony Lindgren
... plus several other cleanups of various platforms across the board"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (47 commits)
ARM: sirf: drop redundant function and marco declaration
arm: omap: specify PMUs are for ARMv7 CPUs
arm: shmobile: specify PMUs are for ARMv7 CPUs
arm: iop: specify PMUs are for XScale CPUs
arm: pxa: specify PMUs are for XScale CPUs
arm: realview: specify PMU types
ARM: SAMSUNG: remove unused DMA infrastructure
ARM: OMAP3: Add back Kconfig option MACH_OMAP3517EVM for ASoC
ARM: davinci: Remove CDCE949 driver
ARM: at91: remove useless at91rm9200_set_type()
ARM: at91: remove useless at91rm9200_dt_initialize()
ARM: at91: move debug-macro.S into the common space
ARM: at91: remove useless at91_sysirq_mask_rtx
ARM: at91: remove useless config MACH_AT91SAM9_DT
ARM: at91: remove useless config MACH_AT91RM9200_DT
ARM: at91: remove unused mach/memory.h
ARM: at91: remove useless header file includes
ARM: at91: remove unneeded header file
rtc: at91/Kconfig: remove useless options
ARM: at91/Documentation: add a README for Atmel SoCs
The omap1's debug-macro.S is similar to the generic 8250 code. Compared to
the 8520 code the omap1 macro automatically determines what UART to use
based on breadcrumbs left by the bootloader and automatically copes with
the eccentric register layout on OMAP7XX.
This patch drops both these features and relies instead on the generic
8250 macros:
1. Dropping support for the bootloader breadcrumbs is identical to the
way the migration was handled for OMAP2 (see 808b7e07464d...).
2. Support for OMAP7XX still exists but it must be configured by hand
(DEBUG_OMAP7XXUART1/2/3) rather than handled at runtime.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Remove the function omap_32k_timer_read() that is not used anywhere.
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Remove the function irq_bank_readl() that is not used anywhere.
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks
depending on CONFIG_PM_RUNTIME may now be changed to depend on
CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere in the code under
arch/arm/ (the defconfig files will be modified later).
Acked-by: Nishanth Menon <nm@ti.com>
"This merge window brings a good size of cleanups on various platforms.
Among the bigger ones:
- Removal of Samsung s5pc100 and s5p64xx platforms. Both of these
have lacked active support for quite a while, and after asking
around nobody showed interest in keeping them around. If needed,
they could be resurrected in the future but it's more likely that
we would prefer reintroduction of them as DT and
multiplatform-enabled platforms instead.
- OMAP4 controller code register define diet. They defined a lot of
registers that were never actually used, etc.
- Move of some of the Tegra platform code (PMC, APBIO, fuse,
powergate) to drivers/soc so it can be shared with 64-bit code.
This also converts them over to traditional driver models where
possible.
- Removal of legacy gpio-samsung driver, since the last users have
been removed (moved to pinctrl)
Plus a bunch of smaller changes for various platforms that sort of
dissapear in the diffstat for the above. clps711x cleanups, shmobile
header file refactoring/moves for multiplatform friendliness, some
misc cleanups, etc"
* tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits)
drivers: CCI: Correct use of ! and &
video: clcd-versatile: Depend on ARM
video: fix up versatile CLCD helper move
MAINTAINERS: Add sdhci-st file to ARCH/STI architecture
ARM: EXYNOS: Fix build breakge with PM_SLEEP=n
MAINTAINERS: Remove Kirkwood
ARM: tegra: Convert PMC to a driver
soc/tegra: fuse: Set up in early initcall
ARM: tegra: Always lock the CPU reset vector
ARM: tegra: Setup CPU hotplug in a pure initcall
soc/tegra: Implement runtime check for Tegra SoCs
soc/tegra: fuse: fix dummy functions
soc/tegra: fuse: move APB DMA into Tegra20 fuse driver
soc/tegra: Add efuse and apbmisc bindings
soc/tegra: Add efuse driver for Tegra
ARM: tegra: move fuse exports to soc/tegra/fuse.h
ARM: tegra: export apb dma readl/writel
ARM: tegra: Use a function to get the chip ID
ARM: tegra: Sort includes alphabetically
ARM: tegra: Move includes to include/soc/tegra
<mach/memory.h>
The platforms selecting NEED_MACH_MEMORY_H defined the start address of
their physical memory in the respective <mach/memory.h>. With
ARM_PATCH_PHYS_VIRT=y (which is quite common today) this is useless
though because the definition isn't used but determined dynamically.
So remove the definitions from all <mach/memory.h> and provide the
Kconfig symbol PHYS_OFFSET with the respective defaults in case
ARM_PATCH_PHYS_VIRT isn't enabled.
This allows to drop the dependency of PHYS_OFFSET on !NEED_MACH_MEMORY_H
which prevents compiling an integrator nommu-kernel.
(CONFIG_PAGE_OFFSET which has "default PHYS_OFFSET if !MMU" expanded to
"0x" because CONFIG_PHYS_OFFSET doesn't exist as INTEGRATOR selects
NEED_MACH_MEMORY_H.)
This removes the FIXME message above ocpi_enable being declared
for proper locking in this function. As of the current kernel
verisons there is no need for locking as only one driver uses
this function currently and therefore there is no need for real
locking requirements.
Signed-off-by: Nicholas Krause <xerofoify@gmail.com>
Commit 193ab2a60700 ("usb: gadget: allow multiple gadgets to be built")
apparently required that checks for CONFIG_USB_GADGET_OMAP would be
replaced with checks for CONFIG_USB_OMAP. Do so now for the remaining
checks for CONFIG_USB_GADGET_OMAP, even though these checks have
basically been broken since v3.1.
And, since we're touching this code, use the IS_ENABLED() macro, so
things will now (hopefully) also work if USB_OMAP is modular.
Fixes: 193ab2a60700 ("usb: gadget: allow multiple gadgets to be built")
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
A check for CONFIG_SX1_OLD_FLASH was added in v2.6.24. But the related
Kconfig symbol was never part of the tree. So we can remove some dead
code.
A check for CONFIG_CBUS_TAHVO_USB was added in v2.6.17. The related
Kconfig symbol has never been part of the tree. Remove that check.
Replace the while (...) loop with a simple if (...) statement, while
we're at it.
Pull ARM SoC cleanups from Arnd Bergmann:
"These cleanup patches are mainly move stuff around and should all be
harmless. They are mainly split out so that other branches can be
based on top to avoid conflicts.
Notable changes are:
- We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no
longer used (Uwe Kleine-König)
- The Qualcomm MSM platform is split out into legacy mach-msm and
new-style mach-qcom, to allow easier maintainance of the new
hardware support without regressions (Kumar Gala)
- A rework of some of the Kconfig logic to simplify multiplatform
support (Rob Herring)
- Samsung Exynos gets closer to supporting multiplatform (Sachin
Kamat and others)
- mach-bcm3528 gets merged into mach-bcm (Stephen Warren)
- at91 gains some common clock framework support (Alexandre Belloni,
Jean-Jacques Hiblot and other French people)"
* tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits)
ARM: hisi: select HAVE_ARM_SCU only for SMP
ARM: efm32: allow uncompress debug output
ARM: prima2: build reset code standalone
ARM: at91: add PWM clock
ARM: at91: move sam9261 SoC to common clk
ARM: at91: prepare common clk transition for sam9261 SoC
ARM: at91: updated the at91_dt_defconfig with support for the ADS7846
ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek
ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs
ARM: at91: dt: Add at91sam9261 dt SoC support
ARM: at91: switch sam9rl to common clock framework
ARM: at91/dt: define main clk frequency of at91sam9rlek
ARM: at91/dt: define at91sam9rl clocks
ARM: at91: prepare common clk transition for sam9rl SoCs
ARM: at91: prepare sam9 dt boards transition to common clk
ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek
ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs
ARM: at91: Add at91sam9rl DT SoC support
ARM: at91: prepare at91sam9rl DT transition
ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig
Pull ARM SoC non-critical bug fixes from Arnd Bergmann:
"Lots of isolated bug fixes that were not found to be important enough
to be submitted before the merge window or backported into stable
kernels.
The vast majority of these came out of Arnd's randconfig testing and
just prevents running into build-time bugs in configurations that we
do not care about in practice"
* tag 'fixes-non-critical-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: at91: fix a typo
ARM: moxart: fix CPU selection
ARM: tegra: fix board DT pinmux setup
ARM: nspire: Fix compiler warning
IXP4xx: Fix DMA masks.
Revert "ARM: ixp4xx: Make dma_set_coherent_mask common, correct implementation"
IXP4xx: Fix Goramo Multilink GPIO conversion.
Revert "ARM: ixp4xx: fix gpio rework"
ARM: tegra: make debug_ll code build for ARMv6
ARM: sunxi: fix build for THUMB2_KERNEL
ARM: exynos: add missing include of linux/module.h
ARM: exynos: fix l2x0 saved regs handling
ARM: samsung: select CRC32 for SAMSUNG_PM_CHECK
ARM: samsung: select ATAGS where necessary
ARM: samsung: fix SAMSUNG_PM_DEBUG Kconfig logic
ARM: samsung: allow serial driver to be disabled
ARM: s5pv210: enable IDE support in MACH_TORBRECK
ARM: s5p64x0: fix building with only one soc type
ARM: s3c64xx: select power domains only when used
ARM: s3c64xx: MACH_SMDK6400 needs HSMMC1
Pull ARM changes from Russell King:
- Perf updates from Will Deacon:
- Support for Qualcomm Krait processors (run perf on your phone!)
- Support for Cortex-A12 (run perf stat on your FPGA!)
- Support for perf_sample_event_took, allowing us to automatically decrease
the sample rate if we can't handle the PMU interrupts quickly enough
(run perf record on your FPGA!).
- Basic uprobes support from David Long:
This patch series adds basic uprobes support to ARM. It is based on
patches developed earlier by Rabin Vincent. That approach of adding
hooks into the kprobes instruction parsing code was not well received.
This approach separates the ARM instruction parsing code in kprobes out
into a separate set of functions which can be used by both kprobes and
uprobes. Both kprobes and uprobes then provide their own semantic action
tables to process the results of the parsing.
- ARMv7M (microcontroller) updates from Uwe Kleine-König
- OMAP DMA updates (recently added Vinod's Ack even though they've been
sitting in linux-next for a few months) to reduce the reliance of
omap-dma on the code in arch/arm.
- SA11x0 changes from Dmitry Eremin-Solenikov and Alexander Shiyan
- Support for Cortex-A12 CPU
- Align support for ARMv6 with ARMv7 so they can cooperate better in a
single zImage.
- Addition of first AT_HWCAP2 feature bits for ARMv8 crypto support.
- Removal of IRQ_DISABLED from various ARM files
- Improved efficiency of virt_to_page() for single zImage
- Patch from Ulf Hansson to permit runtime PM callbacks to be available for
AMBA devices for suspend/resume as well.
- Finally kill asm/system.h on ARM.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (89 commits)
dmaengine: omap-dma: more consolidation of CCR register setup
dmaengine: omap-dma: move IRQ handling to omap-dma
dmaengine: omap-dma: move register read/writes into omap-dma.c
ARM: omap: dma: get rid of 'p' allocation and clean up
ARM: omap: move dma channel allocation into plat-omap code
ARM: omap: dma: get rid of errata global
ARM: omap: clean up DMA register accesses
ARM: omap: remove almost-const variables
ARM: omap: remove references to disable_irq_lch
dmaengine: omap-dma: cleanup errata 3.3 handling
dmaengine: omap-dma: provide register read/write functions
dmaengine: omap-dma: use cached CCR value when enabling DMA
dmaengine: omap-dma: move barrier to omap_dma_start_desc()
dmaengine: omap-dma: move clnk_ctrl setting to preparation functions
dmaengine: omap-dma: improve efficiency loading C.SA/C.EI/C.FI registers
dmaengine: omap-dma: consolidate clearing channel status register
dmaengine: omap-dma: move CCR buffering disable errata out of the fast path
dmaengine: omap-dma: provide register definitions
dmaengine: omap-dma: consolidate setup of CCR
dmaengine: omap-dma: consolidate setup of CSDP
