Otherwise timing is inaccurate, resulting in devices which depend on it,
like omap-keypad, broken.
Tested on Amstrad Delta.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
[tony@atomide.com: removed comment referencing a development branch]
Use the exact value found in omap1_rate_table, otherwise I have been
experiencing issues with correct timekeeping on my Amstrad Delta.
60MHz
Commit e9b7086b80c4d9e354f4edc9e280ae85a60df408 (ARM: OMAP: Fix
reprogramming of dpll1 rate) fixed a regression for systems that
did not rely on bootloader set rates.
However, it also introduced a new problem where the rates selected
in .config would not take affect as omap1_select_table_rate
currently refuses to reprogram DPLL1 if it's already initialized.
This was not a problem earlier, as the reprogramming was done
earlier with ck_dpll1_p->rate uninitialized.
Fix this by forcing the reprogramming on systems booting at rates
below 60MHz. Note that the long term fix is to make the rates
SoC specific later on.
Thanks for Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> for figuring
this one out.
Reported-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Acked-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Commit a66cb3454f220f49f900646ebdc76cb943319eb7 (ARM: OMAP: Map SRAM
later on with ioremap_exec()) moved the SRAM init to happen later
to remove a dependency to early SoC detection for map_io.
This broke booting on some boards not using Kconfig option for
OMAP_CLOCKS_SET_BY_BOOTLOADER as the dpll1 reprogramming would
cause the following error:
kernel BUG at arch/arm/plat-omap/sram.c:226!
Internal error: Oops - undefined instruction: 0 [#1] PREEMPT
Modules linked in:
CPU: 0 Not tainted (3.2.0-rc1-e3 #9)
PC is at omap_sram_reprogram_clock+0x28/0x30
LR is at omap1_select_table_rate+0x88/0xb4
pc : [<c001b0c4>] lr : [<c0019f54>] psr: 600000d3
sp : c035bf10 ip : c035bf20 fp : c035bf1c
r10: c035bfd4 r9 : 54029252 r8 : c03f8120
r7 : c0362b50 r6 : 00b71b00 r5 : c03873cc r4 : c0362b40
r3 : 00000000 r2 : c0362b40 r1 : 0000010a r0 : 00002cb0
Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
Control: 0000317f Table: 10004000 DAC: 00000017
Process swapper (pid: 0, stack limit = 0xc035a270)
Stack: (0xc035bf10 to 0xc035c000)
bf00: c035bf3c c035bf20 c0019f54 c001b0ac
bf20: 00001000 00002cb3 00000004 c035ed4c c035bf74 c035bf40 c033ea24 c0019edc
bf40: c02f526c 00000002 00000015 bc058c9b 93111a16 c035335c 02000000 c035ed4c
bf60: c035ed4c c03f8120 c035bf84 c035bf78 c00194c4 c033e8ec c035bfc4 c035bf88
bf80: c033bc24 c00194a0 c035bf90 c035bf98 00000000 00000000 00000000 00000000
bfa0: 00000001 00000000 c0354678 c035ece4 10004000 103532f4 c035bff4 c035bfc8
bfc0: c0338574 c033b598 00000000 00000000 00000000 c035467c 0000317d c035c03c
bfe0: c0354678 c035ece4 00000000 c035bff8 10008040 c0338508 00000000 00000000
Backtrace:
[<c001b09c>] (omap_sram_reprogram_clock+0x0/0x30) from [<c0019f54>] (omap1_select_table_rate+0x88/0xb4)
[<c0019ecc>] (omap1_select_table_rate+0x0/0xb4) from [<c033ea24>] (omap1_clk_init+0x148/0x334)
r7:c035ed4c r6:00000004 r5:00002cb3 r4:00001000
[<c033e8dc>] (omap1_clk_init+0x0/0x334) from [<c00194c4>] (omap1_init_early+0x34/0x48)
r8:c03f8120 r7:c035ed4c r6:c035ed4c r5:02000000 r4:c035335c
[<c0019490>] (omap1_init_early+0x0/0x48) from [<c033bc24>] (setup_arch+0x69c/0x79c)
[<c033b588>] (setup_arch+0x0/0x79c) from [<c0338574>] (start_kernel+0x7c/0x2f4)
[<c03384f8>] (start_kernel+0x0/0x2f4) from [<10008040>] (0x10008040)
r7:c035ece4 r6:c0354678 r5:c035c03c r4:0000317d
Code: 0a000002 e1a0e00f e12fff13 e89da800 (e7f001f2)
Fix this by adding omap1_clk_late_init() that only reprograms dpll1
if the bootloader rate is less than 60MHz. This also allows removing
of the OMAP_CLOCKS_SET_BY_BOOTLOADER option.
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Commit 7b88e62f5d219a86d81bdf4388012c97dc42e8f8 (ARM: OMAP1: Use generic
map_io, init_early and init_irq) changed omap1 to use generic map_io.
Looks like I missed one board though. Fix this by adding a custom
map_io for Amstrad E3.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
There is no use for omap-alsa.h and board-palmz71.c doesn't need it either.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Fix "Enable 32kHz OS timer in order to allow sleep states in idle"
warning. We are now compiling in bothe MPU timer and 32 KiHz timer,
so this warning is only valid when MPU_TIMER is set and OMAP_DM_TIMER
is not set.
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits)
ARM: OMAP: Warn if omap_ioremap is called before SoC detection
ARM: OMAP: Move set_globals initialization to happen in init_early
ARM: OMAP: Map SRAM later on with ioremap_exec()
ARM: OMAP: Remove calls to SRAM allocations for framebuffer
ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done
ARM: OMAP1: Use generic map_io, init_early and init_irq
arm/dts: OMAP3+: Add mpu, dsp and iva nodes
arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver
ARM: OMAP2+: l3-noc: Add support for device-tree
ARM: OMAP2+: board-generic: Add i2c static init
ARM: OMAP2+: board-generic: Add DT support to generic board
arm/dts: Add support for OMAP3 Beagle board
arm/dts: Add initial device tree support for OMAP3 SoC
arm/dts: Add support for OMAP4 SDP board
arm/dts: Add support for OMAP4 PandaBoard
arm/dts: Add initial device tree support for OMAP4 SoC
ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node
ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration
of: Add helpers to get one string in multiple strings property
ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures
Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
* 'next/timer' of git://git.linaro.org/people/arnd/arm-soc:
clocksource: fixup ux500 build problems
ARM: omap: use __devexit_p in dmtimer driver
ARM: ux500: Reprogram timers upon resume
ARM: plat-nomadik: timer: Export reset functions
ARM: plat-nomadik: timer: Add support for periodic timers
ARM: ux500: Move timer code to separate file
ARM: ux500: add support for clocksource DBX500 PRCMU
clocksource: add DBX500 PRCMU Timer support
ARM: plat-nomadik: MTU sched_clock as an option
ARM: OMAP: dmtimer: add error handling to export APIs
ARM: OMAP: dmtimer: low-power mode support
ARM: OMAP: dmtimer: skip reserved timers
ARM: OMAP: dmtimer: pm_runtime support
ARM: OMAP: dmtimer: switch-over to platform device driver
ARM: OMAP: dmtimer: platform driver
ARM: OMAP2+: dmtimer: convert to platform devices
ARM: OMAP1: dmtimer: conversion to platform devices
ARM: OMAP2+: dmtimer: add device names to flck nodes
ARM: OMAP: Add support for dmtimer v2 ip
* 'next/cleanup' of git://git.linaro.org/people/arnd/arm-soc: (125 commits)
ARM: mach-mxs: fix machines' initializers order
mmc: mxcmmc: explicitly includes mach/hardware.h
arm/imx: explicitly includes mach/hardware.h in pm-imx27.c
arm/imx: remove mx27_setup_weimcs() from mx27.h
arm/imx: explicitly includes mach/hardware.h in mach-kzm_arm11_01.c
arm/imx: remove mx31_setup_weimcs() from mx31.h
ARM: tegra: devices.c should include devices.h
ARM: tegra: cpu-tegra: unexport two functions
ARM: tegra: cpu-tegra: sparse type fix
ARM: tegra: dma: staticify some tables and functions
ARM: tegra: tegra2_clocks: don't export some tables
ARM: tegra: tegra_powergate_is_powered should be static
ARM: tegra: tegra_rtc_read_ms should be static
ARM: tegra: tegra_init_cache should be static
ARM: tegra: pcie: 0 -> NULL changes
ARM: tegra: pcie: include board.h
ARM: tegra: pcie: don't cast __iomem pointers
ARM: tegra: tegra2_clocks: 0 -> NULL changes
ARM: tegra: tegra2_clocks: don't cast __iomem pointers
ARM: tegra: timer: don't cast __iomem pointers
Fix up trivial conflicts in
arch/arm/mach-omap2/Makefile,
arch/arm/mach-u300/{Makefile.boot,core.c}
arch/arm/plat-{mxc,omap}/devices.c
Theis resolves lots of simple conflicts between the omap
cleanup and the mach/memory.h removal series.
arch/arm/mach-imx/mach-cpuimx27.c
arch/arm/mach-omap1/board-ams-delta.c
arch/arm/mach-omap1/board-generic.c
arch/arm/mach-omap1/board-h2.c
arch/arm/mach-omap1/board-h3.c
arch/arm/mach-omap1/board-nokia770.c
arch/arm/mach-omap1/board-osk.c
arch/arm/mach-omap1/board-palmte.c
arch/arm/mach-omap1/board-palmtt.c
arch/arm/mach-omap1/board-palmz71.c
arch/arm/mach-omap1/board-sx1.c
arch/arm/mach-omap1/board-voiceblue.c
arch/arm/mach-omap1/io.c
arch/arm/mach-omap2/io.c
arch/arm/plat-omap/io.c
These files will fail to compile if we dont clean them up in advance
and have them include the appropriate headers they need.
These files all make use of one of the EXPORT_SYMBOL variants
or the THIS_MODULE macro. So they will need <linux/export.h>
arch/arm/mach-mxs/include/mach/gpio.h
arch/arm/plat-mxc/include/mach/gpio.h
drivers/video/omap/lcd_apollon.c
drivers/video/omap/lcd_ldp.c
drivers/video/omap/lcd_overo.c
Fix up all conflicts between the memory.h cleanup and bug fixes.
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
* 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits)
ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h>
ARM: 7104/1: plat-pxa: break out GPIO driver specifics
ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem
ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics
ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h>
ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h
ARM: 7083/1: rewrite U300 GPIO to use gpiolib
ARM: 7074/1: gpio: davinci: eliminate unused variable warnings
ARM: 7063/1: Orion: gpio: add missing include of linux/types.h
ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build
ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio
ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq
ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio
ARM: 7057/1: mach-pnx4008: rename GPIO header
ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h>
ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function
ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem
ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics
ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem
ARM: 7043/1: mach-ixp2000: rename GPIO header
Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
* 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits)
PM / Clocks: Remove redundant NULL checks before kfree()
PM / Documentation: Update docs about suspend and CPU hotplug
ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist.
ARM: mach-shmobile: sh7372 A4R support (v4)
ARM: mach-shmobile: sh7372 A3SP support (v4)
PM / Sleep: Mark devices involved in wakeup signaling during suspend
PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image
PM / Hibernate: Do not initialize static and extern variables to 0
PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too
PM / Hibernate: Add resumedelay kernel param in addition to resumewait
MAINTAINERS: Update linux-pm list address
PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs
PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs
PM / Hibernate: Add resumewait param to support MMC-like devices as resume file
PM / Hibernate: Fix typo in a kerneldoc comment
PM / Hibernate: Freeze kernel threads after preallocating memory
PM: Update the policy on default wakeup settings
PM / VT: Cleanup #if defined uglyness and fix compile error
PM / Suspend: Off by one in pm_suspend()
PM / Hibernate: Include storage keys in hibernation image on s390
We don't have cpu_is_omapxxxx SoC detection initialized until
SoC detection is initialized from init_early.
Note that with the common map_io we should no longer need
cpu_is_omapxxxx for ioremap.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
This allows us to remove omap hacks for map_io.
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
This allows removing omap hacks for map_io allowing generic
map_io.
Note that in the future we can't do cpu_is_omapxxxx detection
until in init_early. This means that board-innovator.c now
assumes 15xx only, and board-generic.c assumes 16xx only.
This is best fixed later on by passing the SoC type from
device tree.
Boards used to specify zreladdr in their Makefile.boot with
zreladdr-y := x, so conflicting zreladdrs were silently overwritten.
This patch changes this to zreladdr-y += x, so that we end
up with multiple words in zreladdr in such a case. We can
detect this later and complain if necessary.
These address definitions are OMAP1 specific can be in single source file.
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Register access can be made more generic by calculating register address
offsets runtime from common register definitions and by using reg_size and
reg_step variables that are passed via platform data. Common register
definitions are possible since McBSP registers are ordered similarly between
OMAP versions.
Remove also references to OMAP2+ specific config_type variable from generic
McBSP code since other variables and feature flags are better to carry needed
information from platform code.
plat-omap/devices.c
Only OMAP1s are using omap_mcbsp_register_board_cfg after OMAP2+ hwmod
conversion so it can be moved to mach-omap1/mcbsp.c.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
This achieves two goals:
1) Get rid of omap_uart_v2p() and omap_uart_p2v() which were the last users
of PLAT_PHYS_OFFSET.
2) Remove the probing of the M bit in the CP15 control reg and make
the access to the .data variables completely position independent.
Tested-by: Tony Lindgren <tony@atomide.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
This is the first step to remove PLAT_PHYS_OFFSET usage from the debug
UART code.
Some platforms (like OMAP not to name it) are doing rather complicated
hacks just to determine the base UART address to use. Let's give their
addruart macro some slack by providing an extra work register which will
allow for much needed cleanups.
This is basically a no-op as this commit is only adding the extra argument
to the macro but no one is using it yet.
Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org>
Convert OMAP1 dmtimers into a platform devices and then registers with
device model framework so that it can be bound to corresponding driver.
Signed-off-by: Thara Gopinath <thara@ti.com>
Signed-off-by: Tarun Kanti DebBarma <tarun.kanti@ti.com>
Acked-by: Cousson, Benoit <b-cousson@ti.com>
Since the PM clock management code in drivers/base/power/clock_ops.c
is used for both runtime PM and system suspend/hibernation, the
definitions of data structures and headers related to it should not
be located in include/linux/pm_rumtime.h. Move them to a separate
header file.
devel-stable
Signed-off-by: Jon Medhurst <tixy@yxit.co.uk>
CC: Tony Lindgren <tony@atomide.com>
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: Consolidate the clkdev header files
ARM: set vga memory base at run-time
ARM: convert PCI defines to variables
ARM: pci: make pcibios_assign_all_busses use pci_has_flag
ARM: remove unnecessary mach/hardware.h includes
pci: move microblaze and powerpc pci flag functions into asm-generic
powerpc: rename ppc_pci_*_flags to pci_*_flags
Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits)
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx
ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210
ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100
ARM: S3C24XX: Use generic s3c_set_platdata for devices
ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND
ARM: SAMSUNG: Use generic s3c_set_platdata for NAND
ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI
ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON
ARM: SAMSUNG: Use generic s3c_set_platdata for FB
ARM: SAMSUNG: Use generic s3c_set_platdata for TS
ARM: S3C64XX: Add PWM backlight support on SMDK6410
ARM: S5P64X0: Add PWM backlight support on SMDK6450
ARM: S5P64X0: Add PWM backlight support on SMDK6440
ARM: S5PC100: Add PWM backlight support on SMDKC100
ARM: S5PV210: Add PWM backlight support on SMDKV210
ARM: EXYNOS4: Add PWM backlight support on SMDKC210
ARM: EXYNOS4: Add PWM backlight support on SMDKV310
ARM: SAMSUNG: Create a common infrastructure for PWM backlight support
clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0
Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (51 commits)
PM: Improve error code of pm_notifier_call_chain()
PM: Add "RTC" to PM trace time stamps to avoid confusion
PM / Suspend: Export suspend_set_ops, suspend_valid_only_mem
PM / Suspend: Add .suspend_again() callback to suspend_ops
PM / OPP: Introduce function to free cpufreq table
ARM / shmobile: Return -EBUSY from A4LC power off if A3RV is active
PM / Domains: Take .power_off() error code into account
ARM / shmobile: Use genpd_queue_power_off_work()
ARM / shmobile: Use pm_genpd_poweroff_unused()
PM / Domains: Introduce function to power off all unused PM domains
OMAP: PM: disable idle on suspend for GPIO and UART
OMAP: PM: omap_device: add API to disable idle on suspend
OMAP: PM: omap_device: add system PM methods for PM domain handling
OMAP: PM: omap_device: conditionally use PM domain runtime helpers
PM / Runtime: Add new helper function: pm_runtime_status_suspended()
PM / Domains: Queue up power off work only if it is not pending
PM / Domains: Improve handling of wakeup devices during system suspend
PM / Domains: Do not restore all devices on power off error
PM / Domains: Allow callbacks to execute all runtime PM helpers
PM / Domains: Do not execute device callbacks under locks
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: (61 commits)
gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renaming
mcp23s08: add i2c support
mcp23s08: isolate spi specific parts
mcp23s08: get rid of setup/teardown callbacks
gpio/tegra: dt: add binding for gpio polarity
mcp23s08: remove unused work queue
gpio/da9052: remove a redundant assignment for gpio->da9052
gpio/mxc: add device tree probe support
ARM: mxc: use ARCH_NR_GPIOS to define gpio number
gpio/mxc: get rid of the uses of cpu_is_mx()
gpio/mxc: add missing initialization of basic_mmio_gpio shadow variables
gpio: Move mpc5200 gpio driver to drivers/gpio
GPIO: DA9052 GPIO module v3
gpio/tegra: Use engineering names in DT compatible property
of/gpio: Add new method for getting gpios under different property names
gpio/dt: Refine GPIO device tree binding
gpio/ml-ioh: fix off-by-one for displaying variable i in dev_err
gpio/pca953x: Deprecate meaningless device-tree bindings
gpio/pca953x: Remove dynamic platform data pointer
gpio/pca953x: Fix IRQ support.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup
Now most of ARM machines has the alsmot same __clk_get/put() macro
So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files
But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config
Now there are only 3 caese.
1) define the clk structure with clkdev macro => Need to move clk structure to proper header file
arch/arm/mach-versatile/include/mach/clkdev.h
arch/arm/mach-realview/include/mach/clkdev.h
arch/arm/mach-vexpress/include/mach/clkdev.h
arch/arm/mach-integrator/include/mach/clkdev.h
2) export the __clk_get/put function at clock.c
arch/arm/mach-shmobile/include/mach/clkdev.h
3) demuxing the clk source
arch/arm/mach-u300/include/mach/clkdev.h
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
* pm-domains: (33 commits)
PM / Domains: Make failing pm_genpd_prepare() clean up properly
PM / Domains: Set device state to "active" during system resume
ARM: mach-shmobile: sh7372 A3RV requires A4LC
PM / Domains: Export pm_genpd_poweron() in header
ARM: mach-shmobile: sh7372 late pm domain off
ARM: mach-shmobile: Runtime PM late init callback
ARM: mach-shmobile: sh7372 D4 support
ARM: mach-shmobile: sh7372 A4MP support
ARM: mach-shmobile: sh7372: make sure that fsi is peripheral of spu2
ARM: mach-shmobile: sh7372 A3SG support
These McBSP port number enums are used only in two places in the McBSP code
so we may remove then and just use numeric values like rest of the code does.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Pointers to statically declared platform device structures which are
registered with platform_device_register() are then used during run time
to access these structure members, for example from platform_uevent()
and much more. Therefore, these structures should never be placed inside
sections which are dropped after boot. Fix platform devices incorrectly
tagged with __initdata which happen to exist inside OMAP sub-trees.
This bug has exhibited itself on my ARM/OMAP1 based Amstrad Delta
videophone after commit 6d3163ce86dd386b4f7bda80241d7fea2bc0bb1d, "mm:
check if any page in a pageblock is reserved before marking it
MIGRATE_RESERVE", resulting in reading from several
/sys/device/platform/*/uevent files always ending up with segmentation
faults.
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Varadarajan, Charulatha <charu@ti.com>
Cc: Jarkko Nikula <jhnikula@gmail.com>
The common PM clock management functions may be used for system
suspend/resume as well as for runtime PM, so rename them
accordingly. Modify kerneldoc comments describing these functions
and kernel messages printed by them, so that they refer to power
management in general rather that to runtime PM.
