After the device names are created using PLATFORM_DEVID_AUTO, the old
device names given in usb_bind_phy are no longer valid causing the musb
controller not to get the phy reference. Updated the usb_bind_phy with
the new device names to get MUSB functional in omap4 panda.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Use usbhs_init_phys() to register the PHY's VCC and RESET
regulators and the NOP PHY device.
Get rid of managing the PHY clock as it will be done by the PHY driver.
For that to work we create a clock alias that links the PHY clock name
to the PHY device name.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Pull ARM SoC-specific updates from Arnd Bergmann:
"This is a larger set of new functionality for the existing SoC
families, including:
- vt8500 gains support for new CPU cores, notably the Cortex-A9 based
wm8850
- prima2 gains support for the "marco" SoC family, its SMP based
cousin
- tegra gains support for the new Tegra4 (Tegra114) family
- socfpga now supports a newer version of the hardware including SMP
- i.mx31 and bcm2835 are now using DT probing for their clocks
- lots of updates for sh-mobile
- OMAP updates for clocks, power management and USB
- i.mx6q and tegra now support cpuidle
- kirkwood now supports PCIe hot plugging
- tegra clock support is updated
- tegra USB PHY probing gets implemented diffently"
* tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits)
ARM: prima2: remove duplicate v7_invalidate_l1
ARM: shmobile: r8a7779: Correct TMU clock support again
ARM: prima2: fix __init section for cpu hotplug
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3)
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3)
arm: socfpga: Add SMP support for actual socfpga harware
arm: Add v7_invalidate_l1 to cache-v7.S
arm: socfpga: Add entries to enable make dtbs socfpga
arm: socfpga: Add new device tree source for actual socfpga HW
ARM: tegra: sort Kconfig selects for Tegra114
ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114
ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC
ARM: tegra: Fix build error for gic update
ARM: tegra: remove empty tegra_smp_init_cpus()
ARM: shmobile: Register ARM architected timer
ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move
ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT
ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles
ARM: mxs: use apbx bus clock to drive the timers on timrotv2
Pull ARM SoC cleanups from Arnd Bergmann:
"A large number of cleanups, all over the platforms. This is dominated
largely by the Samsung platforms (s3c, s5p, exynos) and a few of the
others moving code out of arch/arm into more appropriate subsystems.
The clocksource and irqchip drivers are now abstracted to the point
where platforms that are already cleaned up do not need to even
specify the driver they use, it can all get configured from the device
tree as we do for normal device drivers. The clocksource changes
basically touch every single platform in the process.
We further clean up the use of platform specific header files here,
with the goal of turning more of the platforms over to being
"multiplatform" enabled, which implies that they cannot expose their
headers to architecture independent code any more.
It is expected that no functional changes are part of the cleanup.
The overall reduction in total code lines is mostly the result of
removing broken and obsolete code."
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits)
ARM: mvebu: correct gated clock documentation
ARM: kirkwood: add missing include for nsa310
ARM: exynos: move exynos4210-combiner to drivers/irqchip
mfd: db8500-prcmu: update resource passing
drivers/db8500-cpufreq: delete dangling include
ARM: at91: remove NEOCORE 926 board
sunxi: Cleanup the reset code and add meaningful registers defines
ARM: S3C24XX: header mach/regs-mem.h local
ARM: S3C24XX: header mach/regs-power.h local
ARM: S3C24XX: header mach/regs-s3c2412-mem.h local
ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/
ARM: S3C24XX: transform s3c2443 subirqs into new structure
ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs
ARM: S3C24XX: move s3c2443 irq code to irq.c
ARM: S3C24XX: transform s3c2416 irqs into new structure
ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs
ARM: S3C24XX: move s3c2416 irq init to common irq code
ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property
ARM: S3C24XX: Move irq syscore-ops to irq-pm
clocksource: always define CLOCKSOURCE_OF_DECLARE
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/soc
These changes contain the OMAP USB related platform data changes
that were dropped from linux next because of the merge conflicts
as requested by me and Olof. The reason was that at this point
we really should be able to do the arch/arm related changes
separately from driver changes to avoid dependencies between
branches.
These patches were initially part of the USB related MFD patches.
Based on our comments, Roger Quadros quickly reworked these
patches into a shared branch between ARM SoC tree and the MFD
tree, then separate patches for the OMAP platform data and
MFD driver.
Note that this branch will conflict with c1d1cd597fc7
("ARM: OMAP2+: omap_device: remove obsolete pm_lats and
early_device code"). Please see http://lkml.org/lkml/2013/2/11/16
for the merge resolution.
[arnd - resolved the merge conflict]
Let's have a single platform data structure for the OMAP's High-Speed
USB host subsystem instead of having 3 separate ones i.e. one for
board data, one for USB Host (UHH) module and one for USB-TLL module.
This makes the code much simpler and avoids creating multiple copies of
platform data.
Reviewed-by: Felipe Balbi <balbi@ti.com>
This is w.r.t the changes in PHY library to support adding and getting
multiple PHYs of the same type. In the new design, the
binding information between the PHY and the USB controller should be
specified in the platform specific initialization code. So it's been
done here for OMAP platforms.
Linux 3.8-rc6
Linux 3.8-rc5
Add the UART2 muxing data to the board file (this used to be,
erroneously, done in the bootloader).
Cc: stable <stable@vger.kernel.org> [3.7]
Signed-off-by: Luciano Coelho <coelho@ti.com>
into next/cleanup
From Rob Herring:
Initial irqchip init infrastructure and GIC and VIC clean-ups
This creates irqchip initialization infrastructure from Thomas
Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips
and adapted to use the new infrastructure. All DT enabled platforms
using GIC and VIC are converted over to use the new irqchip_init.
* tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux:
irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h
ARM: picoxcell: use common irqchip_init function
ARM: spear: use common irqchip_init function
irqchip: Move ARM VIC to drivers/irqchip
ARM: samsung: remove unused tick.h
ARM: remove unneeded vic.h includes
ARM: remove mach .handle_irq for VIC users
ARM: VIC: set handle_arch_irq in VIC initialization
ARM: VIC: shrink down vic.h
irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h
ARM: use common irqchip_init for GIC init
irqchip: Move ARM GIC to drivers/irqchip
ARM: remove mach .handle_irq for GIC users
ARM: GIC: set handle_arch_irq in GIC initialization
ARM: GIC: remove direct use of gic_raise_softirq
ARM: GIC: remove assembly ifdefs from gic.h
ARM: mach-ux500: use SGI0 to wake up the other core
arm: add set_handle_irq() to register the parent IRQ controller handler function
irqchip: add basic infrastructure
irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS
Fixed up massive merge conflicts with the timer cleanup due to adjacent changes:
arch/arm/mach-bcm/board_bcm.c
arch/arm/mach-cns3xxx/cns3420vb.c
arch/arm/mach-ep93xx/adssphere.c
arch/arm/mach-ep93xx/edb93xx.c
arch/arm/mach-ep93xx/gesbc9312.c
arch/arm/mach-ep93xx/micro9.c
arch/arm/mach-ep93xx/simone.c
arch/arm/mach-ep93xx/snappercl15.c
arch/arm/mach-ep93xx/ts72xx.c
arch/arm/mach-ep93xx/vision_ep9307.c
arch/arm/mach-highbank/highbank.c
arch/arm/mach-imx/mach-imx6q.c
arch/arm/mach-msm/board-dt-8960.c
arch/arm/mach-netx/nxdb500.c
arch/arm/mach-netx/nxdkn.c
arch/arm/mach-netx/nxeb500hmi.c
arch/arm/mach-nomadik/board-nhk8815.c
arch/arm/mach-picoxcell/common.c
arch/arm/mach-realview/realview_eb.c
arch/arm/mach-realview/realview_pb1176.c
arch/arm/mach-realview/realview_pb11mp.c
arch/arm/mach-realview/realview_pba8.c
arch/arm/mach-realview/realview_pbx.c
arch/arm/mach-socfpga/socfpga.c
arch/arm/mach-spear13xx/spear1310.c
arch/arm/mach-spear13xx/spear1340.c
arch/arm/mach-spear13xx/spear13xx.c
arch/arm/mach-spear3xx/spear300.c
arch/arm/mach-spear3xx/spear310.c
arch/arm/mach-spear3xx/spear320.c
arch/arm/mach-spear3xx/spear3xx.c
arch/arm/mach-spear6xx/spear6xx.c
arch/arm/mach-tegra/board-dt-tegra20.c
arch/arm/mach-tegra/board-dt-tegra30.c
arch/arm/mach-u300/core.c
arch/arm/mach-ux500/board-mop500.c
arch/arm/mach-ux500/cpu-db8500.c
arch/arm/mach-versatile/versatile_ab.c
arch/arm/mach-versatile/versatile_dt.c
arch/arm/mach-versatile/versatile_pb.c
arch/arm/mach-vexpress/v2m.c
include/asm-generic/vmlinux.lds.h
Now that we have GIC moved to drivers/irqchip and all GIC DT init for
platforms using irqchip_init, move gic.h and update the remaining
includes.
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Now that the GIC initialization sets up the handle_arch_irq pointer, we
can remove it for all machines and make it static.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Pull ARM SoC board updates from Olof Johansson:
"This branch contains a set of various board updates for ARM platforms.
A few shmobile platforms that are stale have been removed, some
defconfig updates for various boards selecting new features such as
pinctrl subsystem support, and various updates enabling peripherals,
etc."
Fix up conflicts mostly as per Olof.
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits)
ARM: S3C64XX: Add dummy supplies for Glenfarclas LDOs
ARM: S3C64XX: Add registration of WM2200 Bells device on Cragganmore
ARM: kirkwood: Add Plat'Home OpenBlocks A6 support
ARM: Dove: update defconfig
ARM: Kirkwood: update defconfig for new boards
arm: orion5x: add DT related options in defconfig
arm: orion5x: convert 'LaCie Ethernet Disk mini v2' to Device Tree
arm: orion5x: basic Device Tree support
arm: orion5x: mechanical defconfig update
ARM: kirkwood: Add support for the MPL CEC4
arm: kirkwood: add support for ZyXEL NSA310
ARM: Kirkwood: new board USI Topkick
ARM: kirkwood: use gpio-fan DT binding on lsxl
ARM: Kirkwood: add Netspace boards to defconfig
ARM: kirkwood: DT board setup for Network Space Mini v2
ARM: kirkwood: DT board setup for Network Space Lite v2
ARM: kirkwood: DT board setup for Network Space v2 and parents
leds: leds-ns2: add device tree binding
ARM: Kirkwood: Enable the second I2C bus
ARM: mmp: select pinctrl driver
Modify the board files to use the SoC-specific system restart
functions. At this point it's possible to remove omap_prcm_restart()
from mach-omap2/prcm.c.
While removing the prototypes for the now-unused restart functions, clean
up a few more obsolete prototypes in mach-omap2/clock.h.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
Device tree support for omapdss is still some way in the future. In an
effort to get a minimal DSS support for DT enabled kernel on selected
OMAP4 boards, we'll go for a temporary solution: We will call the same
non-DT omapdss setup code for OMAP4 SDP and Pandaboards from
board-generic.c, thus enabling DSS for those boards.
This patch moves the display setup code from board-omap4panda.c to
dss-common.c. dss-common.c will be called by the board-omap4panda.c when
running on non-DT kernel, and by board-generic.c when running on DT
enabled kernel.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
omap-for-v3.8/cleanup-headers
arch/arm/mach-omap1/clock.c
arch/arm/mach-omap2/board-2430sdp.c
arch/arm/mach-omap2/board-4430sdp.c
arch/arm/mach-omap2/board-cm-t35.c
arch/arm/mach-omap2/board-igep0020.c
arch/arm/mach-omap2/board-ldp.c
arch/arm/mach-omap2/board-omap3beagle.c
arch/arm/mach-omap2/board-omap3logic.c
arch/arm/mach-omap2/board-omap4panda.c
arch/arm/mach-omap2/board-overo.c
arch/arm/mach-omap2/board-rm680.c
arch/arm/mach-omap2/board-rx51.c
arch/arm/mach-omap2/twl-common.c
arch/arm/mach-omap2/usb-host.c
arch/arm/mach-omap2/usb-musb.c
In order to make single zImage work for ARM architecture,
we need to make sure we don't depend on private headers.
Move USB platform_data to <linux/platform_data/omap-usb.h>
and add a minimal drivers/mfd/usb-omap.h.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Partha Basak <parthab@india.ti.com>
Cc: Keshava Munegowda <keshava_mgowda@ti.com>
Cc: linux-usb@vger.kernel.org
Signed-off-by: Felipe Balbi <balbi@ti.com>
[tony@atomide.com: updated for local mfd/usb-omap.h]
Let's move what we can from plat/usb.h to the local usb.h
for ARM common zImage support.
This is needed so we can remove plat/usb.h for ARM common
zImage support.
Acked-by: Felipe Balbi <balbi@ti.com>
We need to remove this from plat for ARM common zImage
support.
Also remove includes not needed by the omap_hsmmc.c driver.
Cc: linux-mmc@vger.kernel.org
Acked-by: Chris Ball <cjb@laptop.org>
Acked-by: Venkatraman S <svenkatr@ti.com>
[tony@atomide.com: fold in removal of unused driver includes]
Pull fbdev updates from Florian Tobias Schandinat:
"This includes:
- large updates for OMAP
- basic OMAP5 DSS support for DPI and DSI outputs
- large cleanups and restructuring
- some update to Exynos and da8xx-fb
- removal of the pnx4008 driver (arch removed)
- various other small patches"
Fix up some trivial conflicts (mostly just include line changes, but
also some due to the renaming of the deferred work functions by Tejun).
* tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6: (193 commits)
gbefb: fix compile error
video: mark nuc900fb_map_video_memory as __devinit
video/mx3fb: set .owner to prevent module unloading while being used
video: exynos_dp: use clk_prepare_enable and clk_disable_unprepare
drivers/video/exynos/exynos_mipi_dsi.c: fix error return code
drivers/video/savage/savagefb_driver.c: fix error return code
video: s3c-fb: use clk_prepare_enable and clk_disable_unprepare
da8xx-fb: save and restore LCDC context across suspend/resume cycle
da8xx-fb: add pm_runtime support
video/udlfb: fix line counting in fb_write
OMAPDSS: add missing include for string.h
OMAPDSS: DISPC: Configure color conversion coefficients for writeback
OMAPDSS: DISPC: Add manager like functions for writeback
OMAPDSS: DISPC: Configure writeback FIFOs
OMAPDSS: DISPC: Configure writeback specific parameters in dispc_wb_setup()
OMAPDSS: DISPC: Configure overlay-like parameters in dispc_wb_setup
OMAPDSS: DISPC: Add function to set channel in for writeback
OMAPDSS: DISPC: Don't set chroma resampling bit for writeback
OMAPDSS: DISPC: Downscale chroma if plane is writeback
OMAPDSS: DISPC: Configure input and output sizes for writeback
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
From Tony Lindgren:
This branch contains regression fixes for omap4/5 ASoC
audio that were caused by the fact that u-boot stopped
muxing non essential pins.
As omap audio and dmaengine development happens on
these platforms, let's make sure they are usable.
Of course this should have been fixed earlier and
not during the -rc cycle.
* tag 'omap-for-v3.7-rc1/fixes-asoc-regression-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM/dts: omap5-evm: pinmux configuration for audio
ARM/dts: Add pinctrl driver entries for omap5
ARM/dts: omap4-panda: pinmux configuration for audio
ARM/dts: omap4-sdp: pinmux configuration for audio
ARM/dts: omap5-evm: Disable unused McBSP3
ARM/dts: omap4-sdp: Disable unused McBSP3
ARM/dts: omap4-panda: Disable unused audio IPs
ARM: OMAP: board-omap4panda: Pin mux configuration for audio needs
ARM: OMAP: board-4430-sdp: Pin mux configuration for audio needs
Use the enum for board_ref_clock from linux/wl12xx.h
Signed-off-by: Vikram Narayanan <vikram186@gmail.com>
Cc: linux-omap@vger.kernel.org
Reviewed-by: Pankaj Jangra<jangra.pankaj9@gmail.com>
u-boot stopped configuring 'non essential' pins recently. These pins are
essential for audio and need to be done to have working audio on the board.
Pin Mux configuration for: twl6040 audpwron gpio, McPDM, and McBSP1.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Pull late ARM soc platform updates from Olof Johansson:
"This branch contains updates to OMAP and Marvell platforms (kirkwood,
dove, mvebu) that came in after we had done the big multiplatform
merges, so they were kept separate from the rest, and not separated
into the traditional topics of cleanup/driver/platform features.
For OMAP, the updates are:
- Runtime PM conversions for the GPMC and RNG IP blocks
- Preparation patches for the OMAP common clock framework conversion
- clkdev alias additions required by other drivers
- Performance Monitoring Unit (PMU) support for OMAP2, 3, and
non-4430 OMAP4
- OMAP hwmod code and data improvements
- Preparation patches for the IOMMU runtime PM conversion
- Preparation patches for OMAP4 full-chip retention support
For Kirkwood/Dove/mvebu:
- New driver for "address decoder controller" for mvebu, which is a
piece of hardware that configures addressable devices and
peripherals. First user is the boot rom aperture on armada XP
since it is needed for SMP support.
- New device tree bindings for peripherals such as gpio-fan, iconnect
nand, mv_cesa and the above address decoder controller.
- Some defconfig updates, mostly to enable new DT boards and a few
drivers.
- New drivers using the pincontrol subsystem for dove, kirkwood and
mvebu
- New clean gpio driver for mvebu"
* tag 'soc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (98 commits)
ARM: mvebu: fix build breaks from multi-platform conversion
ARM: OMAP4460/4470: PMU: Enable PMU for OMAP4460/70
ARM: OMAP2+: PMU: Add runtime PM support
ARM: OMAP4430: PMU: prepare to create PMU device via HWMOD
ARM: OMAP2+: PMU: Convert OMAP2/3 devices to use HWMOD
ARM: OMAP3: hwmod data: Add debugss HWMOD data
ARM: OMAP2+: clockdomain/hwmod: add workaround for EMU clockdomain idle problems
ARM: OMAP: Add a timer attribute for timers that can interrupt the DSP
hwrng: OMAP: remove SoC restrictions from driver registration
ARM: OMAP: split OMAP1, OMAP2+ RNG device registration
hwrng: OMAP: convert to use runtime PM
hwrng: OMAP: store per-device data in per-device variables, not file statics
ARM: OMAP2xxx: hwmod/CM: add RNG integration data
ARM: OMAP2+: gpmc: minimal driver support
ARM: OMAP2+: gpmc: Adapt to HWMOD
ARM: OMAP2/3: hwmod data: add gpmc
ARM: OMAP4: hwmod data: add mmu hwmod for ipu and dsp
ARM: OMAP3: hwmod data: add mmu data for iva and isp
ARM: OMAP: iommu: fix including iommu.h without IOMMU_API selected
ARM: OMAP4: hwmod data: add missing HWMOD_NO_IDLEST flags to some PRCM IP blocks
Merge in the late Kirkwood branch with the OMAP late branch for upstream
submission.
Final contents described in shared tag.
Fixup remove/change conflicts in arch/arm/mach-omap2/devices.c and
drivers/spi/spi-omap2-mcspi.c.
Pull ARM soc multiplatform enablement from Olof Johansson:
"This is a pretty significant branch. It's the introduction of the
first multiplatform support on ARM, and with this (and the later
branch) merged, it is now possible to build one kernel that contains
support for highbank, vexpress, mvebu, socfpga, and picoxcell. More
platforms will be convered over in the next few releases.
Two critical last things had to be done for this to be practical and
possible:
* Today each platform has its own include directory under
mach-<mach>/include/mach/*, and traditionally that is where a lot
of driver/platform shared definitions have gone, such as platform
data structures. They now need to move out to a common location
instead, and this branch moves a large number of those out to
include/linux/platform_data.
* Each platform used to list the device trees to compile for its
boards in mach-<mach>/Makefile.boot.
Both of the above changes will mean that there are some merge
conflicts to come (and some to resolve here). It's a one-time move
and once it settles in, we should be good for quite a while. Sorry
for the overhead."
Fix conflicts as per Olof.
* tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits)
ARM: add v7 multi-platform defconfig
ARM: msm: Move core.h contents into common.h
ARM: highbank: call highbank_pm_init from .init_machine
ARM: dtb: move all dtb targets to common Makefile
ARM: spear: move platform_data definitions
ARM: samsung: move platform_data definitions
ARM: orion: move platform_data definitions
ARM: vexpress: convert to multi-platform
ARM: initial multiplatform support
ARM: mvebu: move armada-370-xp.h in mach dir
ARM: vexpress: remove dependency on mach/* headers
ARM: picoxcell: remove dependency on mach/* headers
ARM: move all dtb targets out of Makefile.boot
ARM: picoxcell: move debug macros to include/debug
ARM: socfpga: move debug macros to include/debug
ARM: mvebu: move debug macros to include/debug
ARM: vexpress: move debug macros to include/debug
ARM: highbank: move debug macros to include/debug
ARM: move debug macros to common location
ARM: make mach/gpio.h headers optional
On OMAP4 the i2c1 bus is dedicated for the PMIC and audio related devices.
Manufacturers can opt to use different codec than twl6040 and also can add
audio related IC to the bus (external amplifier for example on SDP4430).
Make it possible to add different set of additional devices to i2c1 bus on
OMAP4 boards.
[tony@atomide.com: updated for removal of irqs.h]
As part of Common Clk Framework (CCF) the clk_enable() operation
was split into a clk_prepare() which could sleep, and a clk_enable()
which should never sleep. Similarly the clk_disable() was
split into clk_disable() and clk_unprepare(). This was
needed to handle complex cases where in a clk gate/ungate
would require a slow and a fast part to be implemented.
None of the clocks below seem to be in the 'complex' clocks
category and are just simple clocks which are enabled/disabled
through simple register writes.
Most of the instances also seem to be called in non-atomic
context which means its safe to move all of those from
using a clk_enable() to clk_prepare_enable() and clk_disable() to
clk_disable_unprepare().
For some others, mainly the ones handled through the hwmod framework
there is a possibility that they get called in either an atomic
or a non-atomic context.
The way these get handled below work only as long as clk_prepare
is implemented as a no-op (which is the case today) since this gets
called very early at boot while most subsystems are unavailable.
Hence these are marked with a *HACK* comment, which says we need
to re-visit these once we start doing something meaningful with
clk_prepare/clk_unprepare like doing voltage scaling or something
that involves i2c.
This is in preparation of OMAP moving to CCF.
Based on initial changes from Mike Turquette.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
* multiplatform/smp_ops:
ARM: consolidate pen_release instead of having per platform definitions
ARM: smp: Make SMP operations mandatory
ARM: SoC: convert spear13xx to SMP operations
ARM: SoC: convert imx6q to SMP operations
ARM: SoC: convert highbank to SMP operations
ARM: SoC: convert shmobile SMP to SMP operations
ARM: SoC: convert ux500 to SMP operations
ARM: SoC: convert MSM to SMP operations
ARM: SoC: convert Exynos4 to SMP operations
ARM: SoC: convert Tegra to SMP operations
ARM: SoC: convert OMAP4 to SMP operations
ARM: SoC: convert VExpress/RealView to SMP operations
ARM: SoC: add per-platform SMP operations
Conflicts due to file moves or removals in:
arch/arm/mach-msm/board-msm8960.c
arch/arm/mach-msm/board-msm8x60.c
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-trimslice.c
Conflicts due to board file cleanup:
arch/arm/mach-tegra/board-paz00.c
Conflicts due to cpu hotplug addition:
arch/arm/mach-tegra/hotplug.c
Convert OMAP4 to use struct smp_operations to provide its SMP
and CPU hotplug operations.
Tested on both Panda and IGEPv2 (MULTI_OMAP kernel)
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
As the plat and mach includes need to disappear for single zImage work,
we need to remove plat/hardware.h.
Do this by splitting plat/hardware.h into omap1 and omap2+ specific files.
The old plat/hardware.h already has omap1 only defines, so it gets moved
to mach/hardware.h for omap1. For omap2+, we use the local soc.h
that for now just includes the related SoC headers to keep this patch more
readable.
Note that the local soc.h still includes plat/cpu.h that can be dealt
with in later patches. Let's also include plat/serial.h from common.h for
all the board-*.c files. This allows making the include files local later
on without patching these files again.
Note that only minimal changes are done in this patch for the
drivers/watchdog/omap_wdt.c driver to keep things compiling. Further
patches are needed to eventually remove cpu_is_omap usage in the drivers.
Also only minimal changes are done to sound/soc/omap/* to remove the
unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's
no need to include omap44xx.h.
While at it, also sort some of the includes in the standard way.
Cc: linux-watchdog@vger.kernel.org
Cc: alsa-devel@alsa-project.org
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Liam Girdwood <lrg@ti.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
As the interrupts should only be defined in the platform_data, and
eventually coming from device tree, there's no need to define them
in header files.
Let's remove the hardcoded references to irqs.h and fix up the includes
so we don't rely on headers included in irqs.h. Note that we're
defining OMAP_INTC_START as 0 to the interrupts. This will be needed
when we enable SPARSE_IRQ. For some drivers we need to add
#include <plat/cpu.h> for now until these drivers are fixed to
remove cpu_is_omapxxxx() usage.
While at it, sort som of the includes the standard way, and add
the trailing commas where they are missing in the related data
structures.
Note that for drivers/staging/tidspbridge we just define things
locally.
Cc: Paul Walmsley <paul@pwsan.com>
We can't use hardcoded interrupts for SPARSE_IRQ, and can replace
the hardcoded gpio_base with twl_gpiochip.base after it's been
allocated.
Cc: Grant Likely <grant.likely@secretlab.ca>
plat/board.h file is now empty - remove it.
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: linux-mtd@lists.infradead.org
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
We currently manage HDMI GPIOs in the board files via
platform_enable/disable calls. This won't work with device tree, and in
any case the correct place to manage the GPIOs is in the HDMI driver.
This patch moves the handling of the GPIOs to the HDMI driver. The GPIO
handling is moved to the common hdmi.c file, and this probably needs to
be revisited when adding OMAP5 HDMI support to see if the GPIO handling
needs to be moved to IP specific files.
Pull trivial tree from Jiri Kosina:
"Trivial updates all over the place as usual."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits)
Fix typo in include/linux/clk.h .
pci: hotplug: Fix typo in pci
iommu: Fix typo in iommu
video: Fix typo in drivers/video
Documentation: Add newline at end-of-file to files lacking one
arm,unicore32: Remove obsolete "select MISC_DEVICES"
module.c: spelling s/postition/position/g
cpufreq: Fix typo in cpufreq driver
trivial: typo in comment in mksysmap
mach-omap2: Fix typo in debug message and comment
scsi: aha152x: Fix sparse warning and make printing pointer address more portable.
Change email address for Steve Glendinning
Btrfs: fix typo in convert_extent_bit
via: Remove bogus if check
netprio_cgroup.c: fix comment typo
backlight: fix memory leak on obscure error path
Documentation: asus-laptop.txt references an obsolete Kconfig item
Documentation: ManagementStyle: fixed typo
mm/vmscan: cleanup comment error in balance_pgdat
mm: cleanup on the comments of zone_reclaim_stat
Correcting spelling typo in mach-omap2
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
The sys_nirq2 is used for twl6040, make sure the pin is configured
correctly.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Pull sweeping late_initcall cleanup for arm-soc from Olof Johansson:
"This is a patch series from Shawn Guo that moves from individual
late_initcalls() to using a member in the machine structure to invoke
a platform's late initcalls.
This cleanup is a step in the move towards multiplatform kernels since
it would reduce the need to check for compatible platforms in each and
every initcall."
Fix up trivial conflicts in arch/arm/mach-{exynos/mach-universal_c210.c,
imx/mach-cpuimx51.c, omap2/board-generic.c} due to changes nearby (and,
in the case of cpuimx51.c the board support being deleted)
* tag 'cleanup-initcall' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: ux500: use machine specific hook for late init
ARM: tegra: use machine specific hook for late init
ARM: shmobile: use machine specific hook for late init
ARM: sa1100: use machine specific hook for late init
ARM: s3c64xx: use machine specific hook for late init
ARM: prima2: use machine specific hook for late init
ARM: pnx4008: use machine specific hook for late init
ARM: omap2: use machine specific hook for late init
ARM: omap1: use machine specific hook for late init
ARM: msm: use machine specific hook for late init
ARM: imx: use machine specific hook for late init
ARM: exynos: use machine specific hook for late init
ARM: ep93xx: use machine specific hook for late init
ARM: davinci: use machine specific hook for late init
ARM: provide a late_initcall hook for platform initialization
Pull arm-soc board specific changes from Olof Johansson:
"While we generally attempt to get rid of board specific files and
replace them with device tree based descriptions, a lot of platforms
have not come that far:
In shmobile, we add two new board files because their recently started
effort to add DT support has not proceeded enough to use it for all of
the important hardware.
In Kirkwood, we are adding support for new boards with a combination
of DT and board file contents in multiple cases.
pxa/mmp and imx are extending support for existing board files but not
adding new ones."
Fix up trivial conflicts in arch/arm/mach-{mmp/ttc_dkb.c,shmobile/{Kconfig,Makefile}}
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits)
ARM: shmobile: fix smp build
ARM: kirkwood: Add support for RaidSonic IB-NAS6210/6220 using devicetree
kirkwood: Add iconnect support
orion/kirkwood: create a generic function for gpio led blinking
kirkwood/orion: fix orion_gpio_set_blink
ARM: kirkwood: Define DNS-320/DNS-325 NAND in fdt
kirkwood: Allow nand to be configured via. devicetree
mtd: Add orion_nand devicetree bindings
ARM: kirkwood: Basic support for DNS-320 and DNS-325
ARM: mach-shmobile: Use DT_MACHINE for armadillo 800 eva
ARM: mach-shmobile: Use DT_MACHINE for KZM9G
ARM: pxa: hx4700: Add Synaptics NavPoint touchpad
ARM: pxa: Use REGULATOR_SUPPLY macro
ARM: mach-shmobile: kzm9g: enable SMP boot
ARM: mach-shmobile: kzm9g: defconfig update
ARM: mach-shmobile: kzm9g: add PCF8757 gpio-key
ARM: mach-shmobile: kzm9g: add SDHI support
ARM: mach-shmobile: kzm9g: add MMCIF support
ARM: mach-shmobile: kzm9g: correct screen direction
ARM: mach-shmobile: sh73a0.h: add GPIO_NR
Pull non-critical arm-soc bug fixes from Olof Johansson:
"These bug fixes were not important enough to have them included in the
v3.4 release, mostly because they cover harmless warnings or
unrealistic configurations. Instead we queue them up to be picked up
in the next merge window."
Fixed up trivial conflict in arch/arm/mach-omap2/board-omap4panda.c
* tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: spear6xx: remove board selection options
ARM: OMAP: igep0020: Specify the VPLL2 regulator unconditionally
ARM: OMAP2+: INTC: fix Kconfig option for TI81XX
ARM: OMAP2+: remove incorrect irq_chip ack field
ARM: OMAP4: Adding ID for OMAP4460 ES1.1
ARM: OMAP4: panda: add statics to remove warnings
ARM: OMAP2+: Incorrect Register Offsets in OMAP Mailbox
ARM: OMAP: fix trivial warnings for dspbridge
arm: davinci: use for_each_set_bit_from
ARM: OMAP4: hsmmc: check for null pointer
ARM: OMAP1: fix compilation issue in board-sx1.c
ARM: disable SUSPEND/ARCH_SUSPEND_POSSIBLE for ARCH_TEGRA
ARM: davinci: da850-evm: fix section mismatch
ARM: tegra: add pll_x freq table entry for 750MHz
ARM: davinci: mark spi_board_info arguments as const
ARM: davinci: fix incorrect pdctl next bit position
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
Clean up for omap DSS board init in preparation for adding DT support.
By Tomi Valkeinen
via Tomi Valkeinen (1) and Tony Lindgren (1)
* tag 'omap-cleanup-dss-for-v3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
OMAPDSS: DSI: implement generic DSI pin config
OMAPDSS: Taal: move reset gpio handling to taal driver
OMAPDSS: TFP410: rename dvi files to tfp410
OMAPDSS: TFP410: rename dvi -> tfp410
OMAP: board-files: remove custom PD GPIO handling for DVI output
OMAPDSS: panel-dvi: add PD gpio handling
Resolved context conflicts in arch/arm/mach-omap2/board-omap4panda.c.
These supplies going to be needed for the twl6040 driver.
Add platform device registratation for HDMI audio codec. This is to
be able to transmit audio through the HDMI output featured in Pandaboard
and PandaboardES boards.
Signed-off-by: Ricardo Neri <ricardo.neri@ti.com>
The "uim" deamon requires sysfs entries that are filled in using
this platform data.
Signed-off-by: Mircea Gherzan <mgherzan@gmail.com>
Add statics to board-omap4-panda.c's internal functions and data
structures to remove sparse warnings:
arch/arm/mach-omap2/board-omap4panda.c:234:29: warning: symbol
'omap_panda_wlan_data' was not declared. Should it be static?
arch/arm/mach-omap2/board-omap4panda.c:441:24: warning: symbol
'omap4_panda_dvi_device' was not declared. Should it be static?
arch/arm/mach-omap2/board-omap4panda.c:451:12: warning: symbol
'omap4_panda_dvi_init' was not declared. Should it be static?
arch/arm/mach-omap2/board-omap4panda.c:512:13: warning: symbol
'omap4_panda_display_init' was not declared. Should it be static?
Sparse and cppcheck warning fixes
By Paul Walmsley
via Paul Walmsley (1) and Tony Lindgren (1)
* tag 'omap-cleanup-sparse-for-v3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: clean up some cppcheck warnings
ARM: OMAP1: board files: deduplicate and clean some NAND-related code
ARM: OMAP: USB: remove unnecessary sideways include
ARM: OMAP: DMA: use constant array maximum, drop some LCD DMA code
ARM: OMAP: OCM RAM: use memset_io() when clearing SRAM
ARM: OMAP: fix 'using plain integer as NULL pointer' sparse warnings
ARM: OMAP2+: GPMC: resolve type-conversion warning from sparse
ARM: OMAP1: OHCI: use platform_data fn ptr to enable OCPI bus
ARM: OMAP1: OCPI: move to mach-omap1/
ARM: OMAP: add includes for missing prototypes
ARM: OMAP2+: declare file-local functions as static
Now that the tfp410 driver has been renamed in the code, this patch
finishes the renaming by renaming the files.
