path: root/arch/arm/mach-omap2/clock.c
2008-10-14Merge branch 'omap-all' into develRussell King
Conflicts: arch/arm/mach-omap2/gpmc.c arch/arm/mach-omap2/irq.c
2008-10-03Merge unstable branch 'omap-rmk'Russell King
Merge branch 'omap-rmk' into omap-all
2008-09-06[ARM] Convert asm/bitops.h to linux/bitops.hRussell King
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-09-05[ARM] omap: fix lots of 'Using plain integer as NULL pointer'Russell King
2008-08-19ARM: OMAP2: Clockdomain: Integrate OMAP3 clocks with clockdomain codePaul Walmsley
This patch integrates the OMAP3 clock tree with the clockdomain code. This patch: - marks OMAP34xx clocks with their corresponding clockdomain. - adds code to convert the clockdomain name to a clockdomain pointer in the struct clk during clk_register(). - modifies OMAP2 clock usecounting to call into the clockdomain code when clocks are enabled or disabled. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03ARM: OMAP2: Clock: New OMAP2/3 DPLL rate rounding algorithmPaul Walmsley
This patch adds a new rate rounding algorithm for DPLL clocks on the OMAP2/3 architecture. For a desired DPLL target rate, there may be several multiplier/divider (M, N) values which will generate a sufficiently close rate. Lower N values result in greater power economy. However, lower N values can cause the difference between the rounded rate and the target rate ("rate error") to be larger than it would be with a higher N. This can cause downstream devices to run more slowly than they otherwise would. This DPLL rate rounding algorithm: - attempts to find the lowest possible N (DPLL divider) to reach the target_rate (since, according to Richard Woodruff <r-woodruff@ti.com>, lower N values save more power than higher N values). - allows developers to set an upper bound on the error between the rounded rate and the desired target rate ("rate tolerance"), so an appropriate balance between rate fidelity and power savings can be set. This maximum rate error tolerance is set via omap2_set_dpll_rate_tolerance(). - never returns a rounded rate higher than the target rate. The rate rounding algorithm caches the last rounded M, N, and rate computation to avoid rounding the rate twice for each clk_set_rate() call. (This patch does not yet implement set_rate for DPLLs; that follows in a future patch.) The algorithm trades execution speed for rate accuracy. It will find the (M, N) set that results in the least rate error, within a specified rate tolerance. It does this by evaluating each divider setting - on OMAP3, this involves 128 steps. Another approach to DPLL rate rounding would be to bail out as soon as a valid rate is found within the rate tolerance, which would trade rate accuracy for execution speed. Alternate implementations welcome. This code is not yet used by the OMAP24XX DPLL clock, since it is currently defined as a composite clock, fusing the DPLL M,N and the M2 output divider. This patch also renames the existing OMAP24xx DPLL programming functions to highlight that they program both the DPLL and the DPLL's output multiplier. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: SRAM: Split sram24xx.S into sram242x.S and sram243x.STony Lindgren
Split sram24xx.S into sram242x.S and sram243x.S Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-05-09ARM: OMAP: PRCM fixes to ssi clock handlingJouni Högander
ssi_l4_ick should have PARENT_CONTROLS_CLOCK flag. ST_SSI_STDBY bit in idlest register cannot be used in omap2_clk_wait_ready Signed-off-by: Jouni Högander <jouni.hogander@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: New DPLL clock frameworkRoman Tereshonkov
These changes is the result of the discussion with Paul Walmsley. His ideas are included into this patch. Remove DPLL output divider handling from DPLLs and CLKOUTX2 clocks, and place it into specific DPLL output divider clocks (e.g., dpll3_m2_clk). omap2_get_dpll_rate() now returns the correct DPLL rate, as represented by the DPLL's CLKOUT output. Also add MPU and IVA2 subsystem clocks, along with high-frequency bypass support. Add support for DPLLs function in locked and bypass clock modes. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Clean up 24xx clock codeTony Lindgren
Clean up 24xx clock code to sync it with linux-omap tree. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Change 24xx to use shared clock code and new reg accessPaul Walmsley
This patch changes 24xx to use shared clock code and new register access. Note that patch adds some temporary OLD_CK defines to keep patch more readable. These temporary defines will be removed in the next patch. Also not all clocks are changed in this patch to limit the size. Also, the patch fixes few incorrect clock defines in clock24xx.h. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Add common clock framework for 24xx and 34xxPaul Walmsley
This patch adds a common clock framework for 24xx and 34xx. Note that this patch does not add it to Makefile until in next patch. Some functions are modified from earlier 24xx clock framework code. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Move clock.c to clock24xx.cPaul Walmsley
This patch moves clock.h to clock24xx.c to make room for adding common clock code for 24xx and 34xx. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Move clock.h to clock24xx.hPaul Walmsley
This patch moves clock.h to clock24xx.h to make room for adding common clock code for 24xx and 34xx. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-10-31[ARM] Fix assignment instead of condition in arm/mach-omap2/clock.cRoel Kluin
Fix assignment instead of condition Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-08-22ARM: OMAP2: Force APLLs always activeJuha Yrjola
The APLLs are most efficiently idled by hardware. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-07ARM: OMAP: Include missing headerTony Lindgren
Include missing header for do_div() Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP: Sync clocks with linux-omap treeTony Lindgren
Mostly clean up CONFIG_OMAP_RESET_CLOCKS. Also includes a patch from Imre Deak to make McSPI clocks use id. Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP2: Make sure peripherals can be accessed after clk_enableJuha Yrjola
Some peripherals seem to need additional delay until they can actually be accessed after enabling their FCLK and ICLK. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP2: Keep both APLLs active during bootupJuha Yrjola
Enabling and disabling the 54 MHz and 96 MHz APLLs can happen unnecessarily often during bootup. Make sure they're kept enabled during init. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP: Add support for forcing osc_ck onJuha Yrjola
Some boards might use the oscillator clock for powering external peripherals. Add support for making sure osc_ck stays active even when trying to go to sleep. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP: Add write memory barriers to OMAP2 clock codeJuha Yrjola
After adjusting clock parameters, OMAP2 CPUs need a memory barrier to make sure the changes go into effect immediately. Otherwise bad things will happen if we try to access the peripheral whose clock is just being enabled. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP: Fix OMAP2 clock.c typoSamuel Ortiz
A forgotten parenthesis in clock.c caused the PLL stabilization loop to not be executed correctly. Signed-off-by: Samuel Ortiz <samuel.ortiz@solidboot.com> Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP: Avoid sleeping during arch_resetTony Lindgren
If we call clk_get() from arch_reset we get ugly messages before reboot. Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 3541/2: workaround for PXA27x erratum E7 [ARM] nommu: provide a way for correct control register value selection [ARM] 3705/1: add supersection support to ioremap() [ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure [ARM] 3706/2: ep93xx: add cirrus logic edb9315a support [ARM] 3704/1: format IOP Kconfig with tabs, create more consistency [ARM] 3703/1: Add help description for ARCH_EP80219 [ARM] 3678/1: MMC: Make OMAP MMC work [ARM] 3677/1: OMAP: Update H2 defconfig [ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1 [ARM] Add section support to ioremap [ARM] Fix sa11x0 SDRAM selection [ARM] Set bit 4 on section mappings correctly depending on CPU [ARM] 3666/1: TRIZEPS4 [1/5] core ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE ARM: OMAP: Update dmtimers ARM: OMAP: Make clock variables static ARM: OMAP: Fix GPMC compilation when DEBUG is defined ARM: OMAP: Mux updates for external DMA and GPIO ...
2006-06-26ARM: OMAP: Fix 32 kHz timer and modify GP timer to use GPT1Timo Teras
The dmtimer framework update broke 32 kHz timer as udelay() does not work before system timer is started (and GPT1 should not be reset). This also makes the GP timer use GPT1. This requires a fix in clock framework. Signed-off-by: Timo Teras <timo.teras@solidboot.com> Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-06-26ARM: OMAP: Correct two bugs in arch/arm/mach-omap2/clock.cJarkko Nikula
omap2_clk_set_rate: dif_off must use clk->rate_offset, not clk->src_off. omap2_get_src_field: for the case CM_SYSCLKOUT_SEL1, val must be 2 for 96MHz and 3 for 54MHz. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-04-02[ARM] 3426/1: ARM: OMAP: 1/8 Update clock frameworkTony Lindgren
Patch from Tony Lindgren Update OMAP clock framework from linux-omap tree. The highlights of the patch are: - Add support for omap730 clocks by Andrzej Zaborowski - Fix compile warnings by Dirk Behme - Add support for using dev id by Tony Lindgren and Komal Shah - Move memory timings and PRCM into separate files by Tony Lindgren Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-17ARM: OMAP: 3/4 Fix clock framework to use clk_enable/disable for omap2Tony Lindgren
This patch fixes OMAP clock framework to use clk_enable/disable instead of clk_use/unuse as specified in include/linux/clk.h. Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-01-07[ARM] Move asm/hardware/clock.h to linux/clk.hRussell King
This is needs to be visible to other architectures using the AMBA bus and peripherals. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3146/1: OMAP 3b/5: Add omap24xx clock frameworkTony Lindgren
Patch from Tony Lindgren This patch adds omap24xx specific clock code by Richard Woodruff, Nishant Menon, Tony Lindgren et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
